74LVC14ADB,118
74LVC14ADB,118
    NEXPERIA(安世)
    SSOP-14_6.2X5.3MM
    电压电平转换器 1.65~3.6V 100mA SSOP14_6.4X5.4MM
74LVC14ADB,118 数据手册
74LVC14A Hex inverting Schmitt trigger with 5 V tolerant input Rev. 6 — 10 June 2016 Product data sheet 1. General description The 74LVC14A provides six inverting buffers with Schmitt trigger input. It is capable of transforming slowly-changing input signals into sharply defined, jitter-free output signals. The inputs switch at different points for positive and negative-going signals. The difference between the positive voltage VT+ and the negative voltage VT is defined as the input hysteresis voltage VH. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device as a translator in mixed 3.3 V and 5 V applications. 2. Features and benefits         Wide supply voltage range from 1.2 V to 3.6 V 5 V tolerant input for interfacing with 5 V logic CMOS low-power consumption Direct interface with TTL levels Unlimited input rise and fall times Inputs accept voltages up to 5.5 V Complies with JEDEC standard JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-B exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Applications  Wave and pulse shapers for highly noisy environments  Astable multivibrators  Monostable multivibrators 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC14AD 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LVC14ADB 40 C to +125 C SSOP14 plastic thin shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LVC14APW 40 C to +125 C 74LVC14ABQ 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin SOT762-1 quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 5. Functional diagram 1 3 5 9 11 13 1A 1Y 2A 2Y 3A 3Y 4A 4Y 5A 5Y 6A 6Y 2 1 2 3 4 5 6 9 8 11 10 13 12 4 6 8 10 12 mna204 001aac497 Fig 1. Logic symbol Fig 2. IEC logic symbol A Y mna025 Fig 3. Logic diagram for one Schmitt trigger 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 2 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 6. Pinning information 1 1A terminal 1 index area 1Y 2 13 6A 2A 3 12 6Y 1A 1 14 VCC 2Y 4 14A 11 5A 1Y 2 13 6A 3A 5 GND(1) 10 5Y 2A 3 12 6Y 3Y 6 2Y 4 3A 3Y GND 7 8 5 10 5Y 4Y 9 11 5A 6 9 4A GND 14A 7 8 4Y 4A 001aac519 Transparent top view 001aac518 Fig 4. 14 VCC 6.1 Pinning (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Pin configuration SO14, SSOP14 and TSSOP14 Fig 5. Pin configuration DHVQFN14 6.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A, 5A, 6A 1, 3, 5, 9, 11, 13 data input 1Y, 2Y, 3Y, 4Y, 5Y, 6Y 2, 4, 6, 8, 10, 12 data output GND 7 ground (0 V) VCC 14 supply voltage 7. Functional description Table 3. Function table[1] Input nA Output nY L H H L [1] H = HIGH voltage level; L = LOW voltage level 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 3 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +6.5 V 0.5 +6.5 V 0.5 VCC + 0.5 V VI input voltage [1] VO output voltage [2] IIK input clamping current VI < 0 V 50 - mA IOK output clamping current VO > VCC or VO < 0 V - 50 mA IO output current VO = 0 V to VCC - 50 mA ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot Tamb = 40 C to +125 C [3] [1] The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] The output voltage ratings may be exceeded if the output current ratings are observed. [3] For SO14 packages: Ptot derates linearly with 8 mW/K above 70 C. For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions functional Min Typ Max Unit 1.65 - 3.6 V 1.2 - - V 0 - 5.5 V VI input voltage VO output voltage 0 - VCC V Tamb ambient temperature 40 - +125 C 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 4 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 10. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions Min VOH HIGH-level output voltage LOW-level voltage output VOL Typ[1] 40 C to +125 C Unit Max Min Max VI = VT+ or VT IO = 100 A; VCC = 1.65 V to 3.6 V VCC  0.2 - - VCC  0.3 - V IO = 4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = 8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = 12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = 18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = 24 mA; VCC = 3.0 V 2.2 - - 2.0 - V IO = 100 A; VCC = 1.65 V to 3.6 V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V VI = VT+ or VT II input leakage current VCC = 3.6 V; VI = 5.5 V or GND - 0.1 5 - 20 A ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 10 - 40 A ICC additional supply current per input pin; VCC = 2.7 V to 3.6 V; VI = VCC  0.6 V; IO = 0 A - 5 500 - 5000 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 4.0 - - - pF [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C. 11. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 7. Symbol Parameter tpd propagation delay 40 C to +85 C Conditions Min Max Min Max - 16 - - - ns VCC = 1.65 V to 1.95 V 1.0 6.1 12.7 1.0 14.7 ns VCC = 2.3 V to 2.7 V 1.5 3.5 7.8 1.5 10.0 ns VCC = 2.7 V 1.5 3.6 7.5 1.5 9.5 ns VCC = 3.0 V to 3.6 V 1.0 3.2 6.4 1.0 8.0 ns - - 1.0 - 1.5 ns nA to nY; see Figure 6 [2] VCC = 1.2 V tsk(o) output skew time 74LVC14A Product data sheet 40 C to +125 C Unit Typ[1] VCC = 3.0 V to 3.6 V [3] All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 5 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 7. Symbol Parameter 40 C to +85 C Conditions Min CPD [1] power dissipation capacitance 40 C to +125 C Unit Typ[1] Max Min Max [4] per buffer; VI = GND to VCC VCC = 1.65 V to 1.95 V - 9.0 - - - pF VCC = 2.3 V to 2.7 V - 12.5 - - - pF VCC = 3.0 V to 3.6 V - 15.6 - - - pF Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively. [2] tpd is the same as tPLH and tPHL. [3] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 12. Waveforms VI VM nA input VM GND t PHL t PLH VOH VM nY output VOL VM mna344 VM = 1.5 V at VCC  2.7 V VM = 0.5  VCC at VCC < 2.7 V. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Propagation delay input (nA) to output (nY) 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 6 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VI PULSE GENERATOR VO DUT RT CL RL 001aaf615 Test data is given in Table 8. Definitions for test circuit: RL = Load resistance CL = Load capacitance including jig and probe capacitance RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 7. Table 8. Load circuitry for measuring switching times Test data Supply voltage Input Load VI tr, tf CL RL 1.2 V VCC  2 ns 30 pF 1 k 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k 2.3 V to 2.7 V VCC  2 ns 30 pF 500  2.7 V 2.7 V  2.5 ns 50 pF 500  3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 7 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 13. Transfer characteristics Table 9. Transfer characteristics Voltages are referenced to GND (ground = 0 V); see Figure 8. Symbol Parameter Tamb = 40 C to +85 C Conditions Min positive-going threshold voltage VT+ negative-going threshold voltage VT hysteresis voltage (VT+  VT) VH Min Max VCC = 1.2 V 0.2 1.0 0.2 1.0 V VCC = 1.65 V 0.4 1.3 0.4 1.3 V VCC = 1.95 V 0.6 1.5 0.6 1.5 V VCC = 2.3 V 0.8 1.7 0.8 1.7 V VCC = 2.5 V 0.9 1.7 0.9 1.7 V VCC = 2.7 V 1.1 2 1.1 2 V VCC = 3 V 1.2 2 1.2 2 V VCC = 3.6 V 1.2 2 1.2 2 V VCC = 1.2 V 0.12 0.75 0.12 0.75 V VCC = 1.65 V 0.15 0.85 0.15 0.85 V VCC = 1.95 V 0.25 0.95 0.25 0.95 V VCC = 2.3 V 0.4 1.1 0.4 1.1 V VCC = 2.5 V 0.4 1.2 0.4 1.2 V VCC = 2.7 V 0.8 1.4 0.8 1.4 V VCC = 3 V 0.8 1.5 0.8 1.5 V VCC = 3.6 V 0.8 1.5 0.8 1.5 V VCC = 1.2 V 0.1 1.0 0.1 1.0 V VCC = 1.65 V 0.2 1.15 0.2 1.15 V VCC = 1.95 V 0.2 1.25 0.2 1.25 V VCC = 2.3 V 0.3 1.3 0.3 1.3 V VCC = 2.5 V 0.3 1.3 0.3 1.3 V VCC = 2.7 V 0.3 1.1 0.3 1.1 V 0.3 1.2 0.3 1.2 V 0.3 1.2 0.3 1.2 V VCC = 3 V VCC = 3.6 V [1] Max Tamb = 40 C to +125 C Unit [1] Typical transfer characteristic is displayed in Figure 9. 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 8 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 14. Waveforms transfer characteristics VT+ VO VI VH VT− VO VI VH VT− Fig 8. VT+ mna208 mna207 VT at 20 % and VT+ at 70 % Definition of VT+, VT and VH mna582 5 I CC (mA) 4 3 2 1 0 0 0.6 1.2 1.8 2.4 3 VI (V) VCC = 3.3 V. Fig 9. Typical transfer characteristic 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 9 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 15. Application information mna581 2.5 I CC (mA) 2.0 (1) 1.5 (2) 1.0 0.5 2.1 2.4 2.7 3.0 3.3 3.6 VCC (V) 3.9 (1) Positive-going edge. (2) Negative going-edge. Linear change of VI between 0.8 V to 2.0 V. All values given are typical unless otherwise specified. Fig 10. Average supply current as a function of supply voltage R C mna035 1 1 f = ---  --------------------- at VCC = 3.0 V T 0.8  RC Fig 11. Relaxation oscillator 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 10 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 16. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 12. Package outline SOT108-1 (SO14) 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 11 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm D SOT337-1 E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp L 7 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.4 0.9 8o o 0 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT337-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig 13. Package outline SOT337-1 (SSOP14) 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 12 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 14. Package outline SOT402-1 (TSSOP14) 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 13 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input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ig 15. Package outline SOT762-1 (DHVQFN14) 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 14 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 17. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 18. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC14A v.6 20160610 Product data sheet - 74LVC14A v.5 - 74LVC14A v.4 Modifications: 74LVC14A v.5 Modifications: • Table 4: table note removed (errata). 20111223 Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Table 4, Table 5, Table 6, Table 7 and Table 8: values added for lower voltage ranges. 74LVC14A v.4 20050215 Product data sheet - 74LVC14A v.3 74LVC14A v.3 20030228 Product specification - 74LVC14A v.2 74LVC14A v.2 20020315 Product specification - 74LVC14A v.1 74LVC14A v.1 19980428 Product specification 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 - © Nexperia B.V. 2017. All rights reserved 15 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input 19. Legal information 19.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 19.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 19.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LVC14A Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 16 of 18 74LVC14A Nexperia Hex inverting Schmitt trigger with 5 V tolerant input Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 19.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 20. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LVC14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 10 June 2016 © Nexperia B.V. 2017. All rights reserved 17 of 18 Nexperia 74LVC14A Hex inverting Schmitt trigger with 5 V tolerant input 21. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 17 18 19 19.1 19.2 19.3 19.4 20 21 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Transfer characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms transfer characteristics. . . . . . . . . 9 Application information. . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 June 2016 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC14ABQ,115 74LVC14AD,112 74LVC14ADB,112 74LVC14ADB,118 74LVC14AD,118 74LVC14APW,112 74LVC14APW,118 74LVC14APW/AUJ
74LVC14ADB,118 价格&库存
很抱歉,暂时无法提供与“74LVC14ADB,118”相匹配的价格&库存,您可以联系我们找货
