74LVC1G04-Q100
Single inverter
Rev. 2 — 7 December 2016
Product data sheet
1. General description
The 74LVC1G04-Q100 provides one inverting buffer.
Input can be driven from either 3.3 V or 5 V devices. These features allow the use of
these devices in a mixed 3.3 V and 5 V environment.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall
time.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant inputs for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V)
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
74LVC1G04-Q100
Nexperia
Single inverter
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74LVC1G04GW-Q100
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74LVC1G04GV-Q100
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G04GW-Q100
VC
74LVC1G04GV-Q100
V04
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
PQD
Fig 1.
Logic symbol
PQD
PQD
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram
6. Pinning information
6.1 Pinning
/9&*4
QF
*1'
9&&
DDD
Fig 4.
Pin configuration SOT353-1 and SOT753
74LVC1G04_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
74LVC1G04-Q100
Nexperia
Single inverter
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
n.c.
1
not connected
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
7. Functional description
Table 4.
Function table[1]
Input
Output
A
Y
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
mA
50
Active mode
[1][2]
0.5
VCC + 0.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
100
mA
100
mA
250
mW
65
+150
C
VO > VCC or VO < 0 V
VO = 0 to VCC
Tamb = 40 C to +125 C
[3]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
74LVC1G04_Q100
Product data sheet
mA
3 of 13
74LVC1G04-Q100
Nexperia
Single inverter
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
VO
VCC = 0 V; Power-down mode
VO
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
Min
Typ[1]
Max
0.65 VCC
V
10. Static characteristics
Table 7.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
VCC = 1.65 V to 1.95 V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC
V
0.7
V
0.8
V
0.3 VCC
V
VI = VIH or VIL
IO = 100 A; VCC = 1.65 V to 5.5 V
VOL
LOW-level output voltage
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
V
IO = 8 mA; VCC = 2.3 V
1.9
V
IO = 12 mA; VCC = 2.7 V
2.2
V
IO = 24 mA; VCC = 3.0 V
2.3
V
IO = 32 mA; VCC = 4.5 V
3.8
V
0.1
V
VI = VIH or VIL
74LVC1G04_Q100
Product data sheet
0.35 VCC V
0.45
V
0.3
V
0.4
V
0.55
V
0.55
V
4 of 13
74LVC1G04-Q100
Nexperia
Single inverter
Table 7.
Static characteristics …continued
Min
Typ[1]
Max
VCC = 0 V to 5.5 V; VI = 5.5 V or GND
0.1
1
A
power-off leakage current
VCC = 0 V; VI or VO = 5.5 V
0.1
2
A
ICC
supply current
VI = 5.5 V or GND;
VCC = 1.65 V to 5.5 V; IO = 0 A
0.1
4
A
ICC
additional supply current
per pin; VCC = 2.3 V to 5.5 V;
VI = VCC 0.6 V; IO = 0 A
5
500
A
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
5
pF
0.65 VCC
V
1.7
V
Symbol Parameter
Conditions
II
input leakage current
IOFF
Unit
VIH
VIL
VOH
2.0
V
0.7 VCC
V
0.8
V
0.3 VCC
V
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
0.1
V
0.70
V
0.45
V
0.60
V
0.80
V
0.80
V
0.7
V
VI = VIH or VIL
VOL
0.35 VCC V
VI = VIH or VIL
II
1
A
IOFF
2
A
ICC
supply current
VI = 5.5 V or GND;
4
A
ICC
500
A
[1]
All typical values are measured at VCC = 3.3 V and Tamb = 25 C.
74LVC1G04_Q100
Product data sheet
5 of 13
74LVC1G04-Q100
Nexperia
Single inverter
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 6.
Symbol Parameter
40 C to +85 C
Conditions
power dissipation
capacitance
CPD
Unit
Min
Max
Min
Max
1.0
3.0
7.5
1.0
9.5
ns
0.5
2.0
5.0
0.5
6.5
ns
VCC = 2.7 V
0.5
2.3
5.2
0.5
7.0
ns
VCC = 3.0 V to 3.6 V
0.5
2.0
4.2
0.5
5.5
ns
0.5
1.6
3.7
0.5
5.0
ns
14
pF
[2]
propagation delay A to Y; see Figure 5
tpd
40 C to +125 C
Typ[1]
[3]
VI = GND to VCC; VCC = 3.3 V
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. AC waveforms
9,
90
$LQSXW
*1'
W 3+/
W 3/+
92+
90
很抱歉,暂时无法提供与“74LVC1G04GV-Q100H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.413753000+0.05309
- 6000+0.399276000+0.05123
- 9000+0.392009000+0.05030
- 15000+0.3839715000+0.04927
- 21000+0.3792621000+0.04867
- 30000+0.3747430000+0.04809
- 国内价格 香港价格
- 1+1.324401+0.16994
- 10+0.8651310+0.11101
- 25+0.7630325+0.09791
- 100+0.64479100+0.08274
- 250+0.58932250+0.07562
- 500+0.55557500+0.07129
- 1000+0.527741000+0.06772
