74LVC1G11GN,132
74LVC1G11GN,132
    NEXPERIA(安世)
    XSON6_0.9X1MM
    电压电平转换器 1.65~5.5V 100mA XSON6_0.9X1MM
74LVC1G11GN,132 数据手册
74LVC1G11 Single 3-input AND gate Rev. 10 — 19 July 2017 1 Product data sheet General description The 74LVC1G11 provides a single 3-input AND gate. The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. Schmitt-trigger action at all inputs makes the circuit highly tolerant to slower input rise and fall time. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2 Features and benefits • • • • • • • • • • • 3 Wide supply voltage range from 1.65 V to 5.5 V 5 V tolerant inputs for interfacing with 5 V logic High noise immunity Complies with JEDEC standard: – JESD8-7 (1.65 V to 1.95 V) – JESD8-5 (2.3 V to 2.7 V) – JESD8-B/JESD36 (2.7 V to 3.6 V) ±24 mA output drive (VCC = 3.0 V) ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V CMOS low power consumption Latch-up performance exceeds 250 mA Direct interface with TTL levels Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G11GW -40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74LVC1G11GV -40 °C to +125 °C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74LVC1G11 Nexperia Single 3-input AND gate Type number 74LVC1G11GM Package Temperature range Name Description Version -40 °C to +125 °C XSON6 plastic extremely thin small outline package; SOT886 no leads; 6 terminals; body 1 x 1.45 x 0.5 mm 74LVC1G11GF -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1 x 1 x 0.5 mm 74LVC1G11GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; SOT1115 6 terminals; body 0.9 x 1.0 x 0.35 mm 74LVC1G11GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; SOT1202 6 terminals; body 1.0 x 1.0 x 0.35 mm 74LVC1G11GX 4 -40 °C to +125 °C X2SON6 plastic thermal extremely thin small outline package; no leads; 6 terminals; body 1 x 0.8 x 0.35 mm Marking Table 2. Marking Type number Marking code 74LVC1G11GW VU 74LVC1G11GV V11 74LVC1G11GM VU 74LVC1G11GF VU 74LVC1G11GN VU 74LVC1G11GS VU 74LVC1G11GX VU [1] 5 SOT1255 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. Functional diagram A 1 3 6 1 A B Y C 001aac033 Figure 1.  Logic symbol 74LVC1G11 Product data sheet 4 & 3 4 B Y 6 001aac029 Figure 2.  IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 C 001aac030 Figure 3.  Logic diagram © Nexperia B.V. 2017. All rights reserved. 2 / 19 74LVC1G11 Nexperia Single 3-input AND gate 6 Pinning information 6.1 Pinning 74LVC1G11 74LVC1G11 A 1 6 C GND 2 5 VCC B 3 4 A 1 6 C GND 2 5 VCC B 3 4 Y Y 001aac849 Transparent top view 001aac032 Figure 4.  Pin configuration SOT363 and SOT457 Figure 5.  Pin configuration SOT886 74LVC1G11 74LVC1G11 A 1 A 1 6 C GND 2 5 VCC B 3 4 Y GND C 6 2 3 B 001aaf200 Transparent top view Figure 6.  Pin configuration SOT891, SOT1115 and SOT1202 VCC 5 4 Y aaa-019825 Transparent top view Figure 7.  Pin configuration SOT1255 (X2SON6) 6.2 Pin description Table 3. Pin description Symbol Pin Description A 1 data input GND 2 ground (0 V) B 3 data input Y 4 data output VCC 5 supply voltage C 6 data input 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 19 74LVC1G11 Nexperia Single 3-input AND gate 7 Functional description Table 4. Function table [1] Output Input A B C Y H H H H L X X L X L X L X X L L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V - ±50 mA VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage Active mode [1] [2] -0.5 VCC + 0.5 V Power-down mode [1] [2] -0.5 +6.5 V - ±50 mA - 100 mA -100 - mA - 250 mW -65 +150 °C IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature [1] [2] [3] VI < 0 V [1] VO = 0 V to VCC Tamb = -40 °C to +125 °C [3] mA The input and output voltage ratings may be exceeded if the input and output current ratings are observed. When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. For SC-88 and SC-74 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. For X2SON6 and XSON6 package: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 19 74LVC1G11 Nexperia Single 3-input AND gate 9 Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature Δt/ΔV input transition rise and fall rate Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC V Power-down mode; VCC = 0 V 0 - 5.5 V -40 - +125 °C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V 10 Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C Min VIH VIL VOH HIGH-level VCC = 1.65 V to 1.95 V input voltage Typ [1] -40 °C to +125 °C Max Min Max Unit 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V LOW-level VCC = 1.65 V to 1.95 V - - 0.35VCC - 0.35VCC V input voltage VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - 0.3VCC V VCC - 0.1 - - VCC - 0.1 - V IO = -4 mA; VCC = 1.65 V 1.2 1.54 - 0.95 - V IO = -8 mA; VCC = 2.3 V 1.9 2.15 - 1.7 - V IO = -12 mA; VCC = 2.7 V 2.2 2.50 - 1.9 - V IO = -24 mA; VCC = 3.0 V 2.3 2.62 - 2.0 - V IO = -32 mA; VCC = 4.5 V 3.8 4.11 - 3.4 - V HIGH-level output voltage VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 19 74LVC1G11 Nexperia Single 3-input AND gate Symbol Parameter Conditions -40 °C to +85 °C Min VOL LOW-level output voltage II IOFF Typ [1] -40 °C to +125 °C Max Min Max Unit VI = VIH or VIL IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.10 - 0.10 V IO = 4 mA; VCC = 1.65 V - 0.07 0.45 - 0.70 V IO = 8 mA; VCC = 2.3 V - 0.12 0.30 - 0.45 V IO = 12 mA; VCC = 2.7 V - 0.17 0.40 - 0.60 V IO = 24 mA; VCC = 3.0 V - 0.33 0.55 - 0.80 V IO = 32 mA; VCC = 4.5 V - 0.39 0.55 - 0.80 V - ±0.1 ±1 - ±1 μA - ±0.1 ±2 - ±2 μA - 0.1 4 - 4 μA - 5 500 - 5 00 μA - 4 - - - pF input leakage VI = 5.5 V or GND; current VCC = 0 V to 5.5 V power-off VI or VO = 5.5 V; VCC = 0 V leakage current ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V ΔICC additional VI = VCC - 0.6 V; IO = 0 A; supply current VCC = 2.3 V to 5.5 V; per pin CI input VCC = 3.3 V; VI = GND to VCC capacitance [1] All typical values are measured at Tamb = 25 °C. 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 19 74LVC1G11 Nexperia Single 3-input AND gate 11 Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter Conditions -40 °C to +85 °C Min propagation delay A, B and C to Y; see Figure 8 tpd [1] [2] [3] power dissipation capacitance [1] Max Min Max [2] VCC = 1.65 V to 1.95 V 1.5 4.7 17.2 1.5 21.5 ns VCC = 2.3 V to 2.7 V 1.0 3.0 6.2 1.0 7.8 ns VCC = 2.7 V 1.0 3.0 6.0 1.0 7.5 ns VCC = 3.0 V to 3.6 V 1.0 2.6 4.9 1.0 6.2 ns 1.0 1.9 3.5 1.0 4.4 ns - 13 - - - pF VCC = 4.5 V to 5.5 V CPD Typ -40 °C to +125 °C Unit VI = GND to VCC; VCC = 3.3 V [3] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. tpd is the same as tPLH and tPHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of the outputs. 11.1 Waveform and test circuit VI A, B, C input VM GND VOH tPHL tPLH VM Y output VOL 001aac031 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Figure 8.  The input (A, B, C) to output (Y) propagation delays 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 19 74LVC1G11 Nexperia Single 3-input AND gate Table 9. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5VCC 0.5VCC 2.3 V to 2.7 V 0.5VCC 0.5VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5VCC 0.5VCC VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 9.  Test circuit for measuring switching times Table 10. Test data Supply voltage Input VCC VI tr = tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 74LVC1G11 Product data sheet VEXT Load All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 19 74LVC1G11 Nexperia Single 3-input AND gate 12 Package outline Plastic surface-mounted package; 6 leads SOT363 D B E y A X HE 6 5 v M A 4 Q pin 1 index A 1 2 e1 A1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA SC-88 EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 Figure 10.  Package outline SOT363 (SC-88) 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 19 74LVC1G11 Nexperia Single 3-input AND gate Plastic surface-mounted package (TSOP6); 6 leads D SOT457 B E y A HE 6 5 X v M A 4 Q pin 1 index A A1 1 2 c 3 Lp e bp w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT457 JEITA SC-74 EUROPEAN PROJECTION ISSUE DATE 05-11-07 06-03-16 Figure 11.  Package outline SOT457 (SC-74) 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 19 74LVC1G11 Nexperia Single 3-input AND gate SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Figure 12.  Package outline SOT886 (XSON6) 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 19 74LVC1G11 Nexperia Single 3-input AND gate XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 e1 4 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Figure 13.  Package outline SOT891 (XSON6) 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 19 74LVC1G11 Nexperia Single 3-input AND gate XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Figure 14.  Package outline SOT1115 (XSON6) 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 19 74LVC1G11 Nexperia Single 3-input AND gate XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Figure 15.  Package outline SOT1202 (XSON6) 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 19 74LVC1G11 Nexperia Single 3-input AND gate X2SON6: plastic thermal enhanced extremely thin small outline package; no leads; 6 terminals; body 1.0 x 0.8 x 0.35 mm SOT1255 X A D B A pin 1 ID area E A1 detail X C e1 b (4x) 4 3 y1 C A B v y L (4x) 2 5 Dh (2x) 1 6 e2 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 D Dh E e1 e2 b L v y y1 max 0.35 0.04 1.05 0.30 0.85 0.30 0.25 nom 0.32 0.02 1.00 0.25 0.80 0.60 0.40 0.25 0.20 0.10 0.05 0.05 0.22 0.17 min 0.30 0.00 0.95 0.22 0.75 sot1255_po Outline version References IEC JEDEC JEITA European projection Issue date 15-07-20 15-07-22 SOT1255 Figure 16.  Package outline SOT1255 (X2SON6) 74LVC1G11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 19 74LVC1G11 Nexperia Single 3-input AND gate 13 Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G11 v.10 20170719 Product data sheet - 74LVC1G11 v.9 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74LVC1G11 v.9 20161128 Modifications: • Table 7: The maximum limits for leakage current and supply current have changed. 74LVC1G11 v.8 20150917 Modifications: • Added type number 74LVC1G11GX (SOT1255/X2SON6). 74LVC1G11 v.7 20120704 Modifications: • Package outline drawing of SOT886 (Figure 12) modified. 74LVC1G11 v.6 20111209 Modifications: • Legal pages updated. 74LVC1G11 v.5 20100730 74LVC1G11 v.4 Product data sheet Product data sheet Product data sheet - 74LVC1G11 v.8 74LVC1G11 v.7 74LVC1G11 v.6 - 74LVC1G11 v.5 Product data sheet - 74LVC1G11 v.4 20070801 Product data sheet - 74LVC1G11 v.3 74LVC1G11 v.3 20060906 Product data sheet - 74LVC1G11 v.2 74LVC1G11 v.2 20050503 Product data sheet - 74LVC1G11 v.1 74LVC1G11 v.1 20041130 Product data sheet - - 74LVC1G11 Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 19 74LVC1G11 Nexperia Single 3-input AND gate 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVC1G11 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 17 / 19 74LVC1G11 Nexperia Single 3-input AND gate Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVC1G11 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 10 — 19 July 2017 © Nexperia B.V. 2017. All rights reserved. 18 / 19 74LVC1G11 Nexperia Single 3-input AND gate Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Dynamic characteristics .....................................7 Waveform and test circuit ..................................7 Package outline ...................................................9 Abbreviations .................................................... 16 Revision history ................................................ 16 Legal information .............................................. 17 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 July 2017 Document identifier: 74LVC1G11 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC1G11GN,132 74LVC1G11GS,132 74LVC1G11GF,132 74LVC1G11GM,115 74LVC1G11GM,132 74LVC1G11GV,125 74LVC1G11GW,125 74LVC1G11GXZ
74LVC1G11GN,132 价格&库存
很抱歉,暂时无法提供与“74LVC1G11GN,132”相匹配的价格&库存,您可以联系我们找货
