74LVC1G11GW-Q100H
74LVC1G11GW-Q100H
    NEXPERIA(安世)
    SOT363-6
    电压电平转换器 1.65~5.5V 100mA SOT363-6
74LVC1G11GW-Q100H 数据手册
74LVC1G11-Q100 Single 3-input AND gate Rev. 2 — 7 December 2016 Product data sheet 1. General description The 74LVC1G11-Q100 provides a single 3-input AND gate. The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. Schmitt trigger action at all inputs makes the circuit highly tolerant to slower input rise and fall time. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 1.65 V to 5.5 V  5 V tolerant inputs for interfacing with 5 V logic  High noise immunity  Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V)  24 mA output drive (VCC = 3.0 V)  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  CMOS low power consumption  Latch-up performance exceeds 250 mA  Direct interface with TTL levels  Multiple package options 74LVC1G11-Q100 Nexperia Single 3-input AND gate 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G11GW-Q100 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 40 C to +125 C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74LVC1G11GV-Q100 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G11GW-Q100 VU 74LVC1G11GV-Q100 V11 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram $     $ % <   & Logic symbol 74LVC1G11_Q100 Product data sheet  % <  & DDF Fig 1. DDF DDF Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 2 — 7 December 2016 Fig 3. Logic diagram © Nexperia B.V. 2017. All rights reserved 2 of 13 74LVC1G11-Q100 Nexperia Single 3-input AND gate 6. Pinning information 6.1 Pinning /9&*4 $   & *1'   9&& %   < DDD Fig 4. Pin configuration SOT363 and SOT457 6.2 Pin description Table 3. Pin description Symbol Pin Description A 1 data input GND 2 ground (0 V) B 3 data input Y 4 data output VCC 5 supply voltage C 6 data input 7. Functional description Table 4. Function table[1] Input Output A B C Y H H H H L X X L X L X L X X L L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 74LVC1G11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 13 74LVC1G11-Q100 Nexperia Single 3-input AND gate 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VI < 0 V [1] IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Min Max Unit 0.5 +6.5 V 50 - 0.5 +6.5 V mA mA - 50 Active mode [1][2] 0.5 VCC + 0.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA - 100 mA 100 - mA - 250 mW 65 +150 C VO > VCC or VO < 0 V output voltage VO [1] Conditions VO = 0 V to VCC Tamb = 40 C to +125 C [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate 74LVC1G11_Q100 Product data sheet Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC V Power-down mode; VCC = 0 V 0 - 5.5 V 40 - +125 C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 2 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 13 74LVC1G11-Q100 Nexperia Single 3-input AND gate 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter HIGH-level input voltage VIH LOW-level input voltage VIL VOH 40 C to +85 C Conditions VCC = 1.65 V to 1.95 V Min Max Min Max Unit 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.65 V to 1.95 V - - 0.35VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - 0.3VCC V VCC  0.1 - - VCC  0.1 - V 1.2 1.54 - 0.95 - V HIGH-level VI = VIH or VIL output voltage IO = 100 A; VCC = 1.65 V to 5.5 V IO = 4 mA; VCC = 1.65 V 0.35VCC V IO = 8 mA; VCC = 2.3 V 1.9 2.15 - 1.7 - V IO = 12 mA; VCC = 2.7 V 2.2 2.50 - 1.9 - V IO = 24 mA; VCC = 3.0 V 2.3 2.62 - 2.0 - V IO = 32 mA; VCC = 4.5 V 3.8 4.11 - 3.4 - V - - 0.10 - 0.10 V - 0.07 0.45 - 0.70 V LOW-level VI = VIH or VIL output voltage IO = 100 A; VCC = 1.65 V to 5.5 V VOL 40 C to +125 C Typ[1] IO = 4 mA; VCC = 1.65 V IO = 8 mA; VCC = 2.3 V - 0.12 0.30 - 0.45 V IO = 12 mA; VCC = 2.7 V - 0.17 0.40 - 0.60 V IO = 24 mA; VCC = 3.0 V - 0.33 0.55 - 0.80 V IO = 32 mA; VCC = 4.5 V - 0.39 0.55 - 0.80 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0.1 1 - 1 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - 0.1 2 - 2 A ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - 0.1 4 - 4 A ICC additional VI = VCC  0.6 V; IO = 0 A; supply current VCC = 2.3 V to 5.5 V; per pin - 5 500 - 500 A CI input capacitance - 4 - - - pF [1] VCC = 3.3 V; VI = GND to VCC All typical values are measured at Tamb = 25 C. 74LVC1G11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 13 74LVC1G11-Q100 Nexperia Single 3-input AND gate 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 40 C to +85 C Conditions Min Max Min Max VCC = 1.65 V to 1.95 V 1.5 4.7 17.2 1.5 21.5 ns VCC = 2.3 V to 2.7 V 1.0 3.0 6.2 1.0 7.8 ns VCC = 2.7 V 1.0 3.0 6.0 1.0 7.5 ns VCC = 3.0 V to 3.6 V 1.0 2.6 4.9 1.0 6.2 ns VCC = 4.5 V to 5.5 V 1.0 1.9 3.5 1.0 4.4 ns - 13 - - - pF propagation delay A, B and C to Y; see Figure 5 tpd power dissipation capacitance CPD 40 C to +125 C Unit Typ[1] VI = GND to VCC; VCC = 3.3 V [2] [3] [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 12. Waveforms 9, $%& LQSXW 90 *1' W3+/ W3/+ 92+ 90
74LVC1G11GW-Q100H 价格&库存
很抱歉,暂时无法提供与“74LVC1G11GW-Q100H”相匹配的价格&库存,您可以联系我们找货
74LVC1G11GW-Q100H
    74LVC1G11GW-Q100H
    • 5+0.98205
    • 50+0.77858
    • 150+0.67673
    • 500+0.60048
    • 3000+0.53936
    • 6000+0.50890
    库存:3898
