74LVC1G14
Single Schmitt-trigger inverter
Rev. 15 — 8 June 2018
1
Product data sheet
General description
The 74LVC1G14 provides the inverting buffer function with Schmitt-trigger input. It is
capable of transforming slowly changing input signals into sharply defined, jitter-free
output signals.
The input can be driven from either 3.3 V or 5 V devices. This feature allows the use
of this device in a mixed 3.3 V and 5 V environment. Schmitt-trigger action at the input
makes the circuit tolerant for slower input rise and fall time.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the
device when it is powered down.
2
Features and benefits
• Wide supply voltage range from 1.65 V to 5.5 V
• High noise immunity
• Complies with JEDEC standard:
– JESD8-7 (1.65 V to 1.95 V)
– JESD8-5 (2.3 V to 2.7 V)
– JESD8-B/JESD36 (2.7 V to 3.6 V).
• ±24 mA output drive (VCC = 3.0 V)
• CMOS low power consumption
• Latch-up performance exceeds 250 mA
• Direct interface with TTL levels
• Unlimited rise and fall times
• Input accepts voltages up to 5 V
• Multiple package options
• ESD protection:
– HBM: ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2000 V
– MM: JESD22-A115-A exceeds 200 V.
• Specified from -40 °C to +85 °C and -40 °C to +125 °C.
3
Applications
• Wave and pulse shaper
• Astable multivibrator
• Monostable multivibrator
74LVC1G14
Nexperia
4
Ordering information
Table 1. Ordering information
Type number
Package
Temperature
range
Name
Description
Version
74LVC1G14GW
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74LVC1G14GV
-40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74LVC1G14GM
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads;
6 terminals; body 1 x 1.45 x 0.5 mm
SOT886
74LVC1G14GF
-40 °C to +125 °C
XSON6
6 terminals; body 1 x 1 x 0.5 mm
SOT891
74LVC1G14GN
-40 °C to +125 °C
XSON6
6 terminals; body 0.9 x 1.0 x 0.35 mm
SOT1115
74LVC1G14GS
-40 °C to +125 °C
XSON6
6 terminals; body 1.0 x 1.0 x 0.35 mm
SOT1202
74LVC1G14GX
-40 °C to +125 °C
X2SON5
plastic thermal enhanced extremely thin
small outline package; no leads; 5 terminals;
body 0.8 x 0.8 x 0.35 mm
SOT1226
74LVC1G14GX4 -40 °C to +125 °C
X2SON4
small outline package; no leads; 4 terminals;
body 0.6 x 0.6 x 0.32 mm
SOT1269-2
5
Marking
Table 2. Marking
Type number
Marking code
74LVC1G14GW
VF
74LVC1G14GV
V14
74LVC1G14GM
VF
74LVC1G14GF
VF
74LVC1G14GN
VF
74LVC1G14GS
VF
74LVC1G14GX
VF
74LVC1G14GX4
VF
[1]
[1] The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74LVC1G14
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
2 / 22
74LVC1G14
Nexperia
6
Functional diagram
A
Y
A
mna023
mna025
mna024
Figure 1. Logic symbol
7
Y
Figure 2. IEC logic symbol
Figure 3. Logic diagram
Pinning information
7.1 Pinning
74LVC1G14
74LVC1G14
n.c.
1
A
2
GND
5
3
n.c.
1
6
VCC
A
2
5
n.c.
GND
3
4
Y
VCC
4
001aae976
Y
Transparent top view
001aab655
Figure 5. Pin configuration SOT886, SOT891, SOT1115
and SOT1202
Figure 4. Pin configuration SOT353-1 and SOT753
74LVC1G14
74LVC1G14
n.c.
1
5
VCC
4
Y
A
1
4
VCC
GND
2
3
Y
3
GND
A
2
aaa-003024
aaa-028401
Figure 6. Pin configuration SOT1226 (X2SON5)
Figure 7. Pin configuration SOT1269-2 (X2SON4)
7.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
TSSOP5, SC-74A and X2SON5
XSON6
X2SON4
n.c.
1
1, 5
not connected
A
2
2
1
data input
GND
3
3
2
ground (0 V)
Y
4
4
3
data output
VCC
5
6
4
supply voltage
74LVC1G14
Product data sheet
3 / 22
74LVC1G14
Nexperia
8
Functional description
Table 4. Function table
[1]
Input
Output
A
Y
L
H
H
L
[1] H = HIGH voltage level; L = LOW voltage level
9
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
VO
Conditions
Min
Max
Unit
-0.5
+6.5
V
input voltage
[1]
-0.5
+6.5
V
output voltage
Active mode
[1]
-0.5
VCC + 0.5
V
Power-down mode; VCC = 0 V
[1]
-0.5
+6.5
V
-50
mA
IIK
input clamping current
VI < 0 V
IOK
output clamping current
VO > VCC or VO < 0 V
±50
mA
IO
output current
VO = 0 V to VCC
±50
mA
ICC
supply current
+100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
Tamb = -40 °C to +125 °C
TSSOP5, SC-74A, XSON6
and X2SON5 package
[2]
250
mW
X2SON4 package
[3]
150
mW
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2] For TSSOP5 and SC-74A packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 package: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
[3] For X2SON4 packages: above 57 °C the value of Ptot derates linearly with 1.7 mW/K.
74LVC1G14
Product data sheet
4 / 22
74LVC1G14
Nexperia
10 Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
Conditions
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
V
-40
+125
°C
ambient temperature
11 Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
VOH
HIGH-level
output voltage
VOL
IOFF
[1]
Max
Min
Max
Unit
VI = VT+ or VTVCC - 0.1
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
1.54
0.95
V
IO = -8 mA; VCC = 2.3 V
1.9
2.15
1.7
V
IO = -12 mA; VCC = 2.7 V
2.2
2.50
1.9
V
IO = -24 mA; VCC = 3.0 V
2.3
2.62
2.0
V
IO = -32 mA; VCC = 4.5 V
3.8
4.11
3.4
V
IO = 100 μA;
VCC = 1.65 V to 5.5 V
0.10
0.10
V
IO = 4 mA; VCC = 1.65 V
0.07
0.45
0.70
V
IO = 8 mA; VCC = 2.3 V
0.12
0.30
0.45
V
IO = 12 mA; VCC = 2.7 V
0.17
0.40
0.60
V
IO = 24 mA; VCC = 3.0 V
0.33
0.55
0.80
V
IO = 32 mA; VCC = 4.5 V
0.39
0.55
0.80
V
±0.1
±1
±1
μA
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
power-off
VI or VO = 5.5 V; VCC = 0 V
±0.1
±2
±2
μA
0.1
4
4
μA
LOW-level
output voltage
II
Typ
-40 °C to +125 °C
input leakage
IO = -100 μA;
VI = VT+ or VT-
leakage
current
ICC
supply current VI = 5.5 V or GND; IO = 0 A;
74LVC1G14
Product data sheet
5 / 22
74LVC1G14
Nexperia
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
Typ
[1]
-40 °C to +125 °C
Max
Min
Max
Unit
ΔICC
additional
VI = VCC - 0.6 V; IO = 0 A;
supply current VCC = 2.3 V to 5.5 V
5
500
500
μA
CI
input
5.0
pF
VCC = 3.3 V; VI = GND to VCC
capacitance
[1] All typical values are measured at maximum VCC and Tamb = 25 °C.
Table 8. Transfer characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9.
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
VT+
VT-
VH
positive-going
threshold voltage
negative-going
threshold voltage
[1]
Typ
-40 °C to +125 °C
Max
Min
Max
Unit
see Figure 10 and Figure 11
VCC = 1.8 V
0.82
1.0
1.14
0.79
1.14
V
VCC = 2.3 V
1.03
1.2
1.40
1.00
1.40
V
VCC = 3.0 V
1.29
1.5
1.71
1.26
1.71
V
VCC = 4.5 V
1.84
2.1
2.36
1.81
2.36
V
VCC = 5.5 V
2.19
2.5
2.79
2.16
2.79
V
VCC = 1.8 V
0.46
0.6
0.75
0.46
0.78
V
VCC = 2.3 V
0.65
0.8
0.96
0.65
0.99
V
VCC = 3.0 V
0.88
1.0
1.24
0.88
1.27
V
VCC = 4.5 V
1.32
1.5
1.84
1.32
1.87
V
VCC = 5.5 V
1.58
1.8
2.24
1.58
2.27
V
VCC = 1.8 V
0.26
0.4
0.51
0.19
0.51
V
VCC = 2.3 V
0.28
0.4
0.57
0.22
0.57
V
VCC = 3.0 V
0.31
0.5
0.64
0.25
0.64
V
VCC = 4.5 V
0.40
0.6
0.77
0.34
0.77
V
VCC = 5.5 V
0.47
0.6
0.88
0.41
0.88
V
hysteresis voltage (VT+ - VT-); see Figure 10,
Figure 11 and Figure 12
[1] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
74LVC1G14
Product data sheet
6 / 22
74LVC1G14
Nexperia
12 Dynamic characteristics
Table 9. Dynamic characteristics
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
tpd
propagation delay
power dissipation
-40 °C to +125 °C
Max
Min
Max
Unit
[2]
A to Y; see Figure 8
VCC = 1.65 V to 1.95 V
1.0
4.1
11.0
1.0
14.0
ns
VCC = 2.3 V to 2.7 V
0.7
2.8
6.5
0.7
8.5
ns
VCC = 2.7 V
0.7
3.2
6.5
0.7
8.5
ns
VCC = 3.0 V to 3.6 V
0.7
3.0
5.5
0.7
7.0
ns
0.7
2.2
5.0
0.7
6.5
ns
15.4
pF
VCC = 4.5 V to 5.5 V
CPD
Typ
[1]
[3]
capacitance
[2] tpd is the same as tPLH and tPHL.
[3] CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi + (CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V.
12.1 Waveform and test circuit
VI
VM
A input
GND
t PHL
t PLH
VOH
VM
Y output
VOL
mna640
Measurement points are given in Table 10.
VOL and VOH are typical output voltage levels that occur with the output load.
Figure 8. The data input (A) to output (Y) propagation delays
74LVC1G14
Product data sheet
7 / 22
74LVC1G14
Nexperia
Table 10. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5 x VCC
0.5 x VCC
2.3 V to 2.7 V
0.5 x VCC
0.5 x VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5 x VCC
0.5 x VCC
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
mna616
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 9. Test circuit for measuring switching times
Table 11. Test data
Supply voltage
Input
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
74LVC1G14
Product data sheet
VEXT
Load
8 / 22
74LVC1G14
Nexperia
12.2 Waveforms transfer characteristics
VO
VT+
VI
VH
VT-
VO
VI
VH
VT-
VT+
mna208
VT+ and VT- limits at 70 % and 20 %.
mna207
Figure 10. Transfer characteristic
Figure 11. Definition of VT+, VT- and VH
mna641
10
ICC
(mA)
8
6
4
2
2
VI (V)
3
VCC = 3.0 V.
Figure 12. Typical transfer characteristics
13 Application information
The slow input rise and fall times cause additional power dissipation, this can be
calculated using the following formula:
Padd = fi x (tr x ΔICC(AV) + tf x ΔICC(AV)) x VCC where:
Padd = additional power dissipation (μW);
fi = input frequency (MHz);
tr = input rise time (ns); 10 % to 90 %;
tf = input fall time (ns); 90 % to 10 %;
ΔICC(AV) = average additional supply current (μA).
Average ΔICC(AV) differs with positive or negative input transitions, as shown in Figure 13.
An example of a relaxation circuit using the 74LVC1G14 is shown in Figure 14.
74LVC1G14
Product data sheet
9 / 22
74LVC1G14
Nexperia
mna642
12
average
I CC
10
(mA)
positive-going
edge
8
6
4
negative-going
edge
2
4
VCC (V)
6
Linear change of VI between 0.8 V to 2.0 V.
All values given are typical unless otherwise specified.
Figure 13. Average additional supply current as a function of supply voltage
R
C
mna035
For K-factor, see Figure 15
Figure 14. Relaxation oscillator
K
aaa-021985
1.2
1
0.8
0.6
0.4
0.2
2
3
4
5
VCC (V)
6
Figure 15. Typical K-factor for relaxation oscillator
74LVC1G14
Product data sheet
10 / 22
74LVC1G14
Nexperia
14 Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Figure 16. Package outline SOT353-1 (TSSOP5)
74LVC1G14
Product data sheet
11 / 22
74LVC1G14
Nexperia
Plastic surface-mounted package; 5 leads
SOT753
D
B
E
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
JEITA
SC-74A
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
Figure 17. Package outline SOT753 (SC-74A)
74LVC1G14
Product data sheet
12 / 22
74LVC1G14
Nexperia
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Figure 18. Package outline SOT886 (XSON6)
74LVC1G14
Product data sheet
13 / 22
74LVC1G14
Nexperia
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
e1
4
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Figure 19. Package outline SOT891 (XSON6)
74LVC1G14
Product data sheet
14 / 22
74LVC1G14
Nexperia
XSON6: extremely thin small outline package; no leads;
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Figure 20. Package outline SOT1115 (XSON6)
74LVC1G14
Product data sheet
15 / 22
74LVC1G14
Nexperia
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Figure 21. Package outline SOT1202 (XSON6)
74LVC1G14
Product data sheet
16 / 22
74LVC1G14
Nexperia
X2SON5: plastic thermal enhanced extremely thin small outline package; no leads;
5 terminals; body 0.8 x 0.8 x 0.35 mm
D
A
B
SOT1226
X
A
E
A1
A3
detail X
terminal 1
index area
e
v
w
b
1
2
terminal 1
index area
C
C A B
C
y1 C
y
k
D
h
3
L
5
4
1 mm
scale
Dimensions
Unit
mm
A(1)
A1
A3
D
Dh
E
b
e
k
L
max 0.35 0.04 0.128 0.85 0.30 0.85 0.27
0.27
nom
0.80 0.25 0.80 0.22 0.48
0.22
min
0.040 0.75 0.20 0.75 0.17
0.20 0.17
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Dimension A is including plating thickness.
2. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
References
IEC
JEDEC
EIAJ
sot1226_po
European
projection
Issue date
12-04-10
12-04-25
SOT1226
Figure 22. Package outline SOT1226 (X2SON5)
74LVC1G14
Product data sheet
17 / 22
74LVC1G14
Nexperia
X2SON4: plastic thermal enhanced extremely thin small outline package; no leads;
4 terminals; body 0.6 x 0.6 x 0.32 mm
SOT1269-2
X
A
D
B
pin 1
ID area
A
E
detail X
A1
C
e
y1 C
2
y
3
L
(4x)
e
1
4
v
w
b
(4x)
C A B
C
1 mm
scale
Unit
mm
A
A1
D
E
b
e
L
max 0.35 0.04 0.65 0.65 0.20
nom 0.32 0.02 0.60 0.60 0.15 0.40
min 0.30 0.00 0.55 0.55 0.10
v
w
y
y1
0.23
0.18 0.10 0.05 0.05 0.05
0.13
sot1269-2_po
Outline
version
SOT1269-2
References
IEC
JEDEC
JEITA
European
projection
Issue date
17-04-07
17-06-30
Figure 23. Package outline SOT1269-2 (X2SON4)
74LVC1G14
Product data sheet
18 / 22
74LVC1G14
Nexperia
15 Abbreviations
Table 12. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
TTL
Transistor-Transistor Logic
HBM
Human Body Model
ESD
ElectroStatic Discharge
MM
Machine Model
DUT
Device Under Test
16 Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC1G14 v.15
20180608
Product data sheet
74LVC1G14 v.15
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
• Added type number 74LVC1G14GX4 (SOT1269-2)
74LVC1G14 v.14
20161202
Modifications:
• Table 7: The maximum limits for leakage current and supply current have changed.
74LVC1G14 v.13
20160315
Modifications:
• Figure 15 added (typical K-factor for relaxation oscillator).
74LVC1G14 v.12
20120806
Modifications:
• Package outline drawing of SOT1226 (Figure 22) modified.
74LVC1G14 v.11
20120412
Modifications:
• Added type number 74LVC1G14GX (SOT1226)
• Package outline drawing of SOT886 (Figure 18) modified.
74LVC1G14 v.10
20111206
Modifications:
• Legal pages updated.
74LVC1G14 v.9
20110922
74LVC1G14 v.8
Product data sheet
Product data sheet
Product data sheet
Product data sheet
74LVC1G14 v.13
74LVC1G14 v.12
74LVC1G14 v.11
74LVC1G14 v.10
74LVC1G14 v.9
Product data sheet
74LVC1G14 v.8
20101110
Product data sheet
74LVC1G14 v.7
74LVC1G14 v.7
20070718
Product data sheet
74LVC1G14 v.6
74LVC1G14 v.6
20060615
Product data sheet
74LVC1G14 v.5
74LVC1G14 v.5
20040910
Product specification
74LVC1G14 v.4
74LVC1G14 v.4
20021119
74LVC1G14 v.3
74LVC1G14 v.3
20020521
74LVC1G14 v.2
74LVC1G14 v.2
20010406
74LVC1G14 v.1
74LVC1G14 v.1
20001212
74LVC1G14
Product data sheet
Product data sheet
19 / 22
74LVC1G14
Nexperia
17 Legal information
17.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
17.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
17.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74LVC1G14
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
20 / 22
74LVC1G14
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74LVC1G14
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
17.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
21 / 22
74LVC1G14
Nexperia
Contents
1
2
3
4
5
6
7
7.1
7.2
8
9
10
11
12
12.1
12.2
13
14
15
16
17
General description ............................................ 1
Features and benefits .........................................1
Applications .........................................................1
Ordering information .......................................... 2
Marking .................................................................2
Functional diagram ............................................. 3
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 3
Functional description ........................................4
Limiting values .................................................... 4
Recommended operating conditions ................ 5
Static characteristics .......................................... 5
Dynamic characteristics .....................................7
Waveform and test circuit .................................. 7
Waveforms transfer characteristics ....................9
Application information ......................................9
Package outline .................................................11
Abbreviations .................................................... 19
Revision history ................................................ 19
Legal information .............................................. 20
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 8 June 2018
Document identifier: 74LVC1G14
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC1G14GS,132 74LVC1G14GN,132 74LVC1G14GF,132 74LVC1G14GM,115 74LVC1G14GM,132
74LVC1G14GV,125 74LVC1G14GW,125 74LVC1G14GX,125 74LVC1G14GX4Z
