74LVC1G14GN,132
74LVC1G14GN,132
    NEXPERIA(安世)
    XSON6_0.9X1MM
    电压电平转换器 1.65~5.5V 100mA XSON6_0.9X1MM
74LVC1G14GN,132 数据手册
74LVC1G14 Single Schmitt-trigger inverter Rev. 15 — 8 June 2018 1 Product data sheet General description The 74LVC1G14 provides the inverting buffer function with Schmitt-trigger input. It is capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. Schmitt-trigger action at the input makes the circuit tolerant for slower input rise and fall time. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2 Features and benefits • Wide supply voltage range from 1.65 V to 5.5 V • High noise immunity • Complies with JEDEC standard: – JESD8-7 (1.65 V to 1.95 V) – JESD8-5 (2.3 V to 2.7 V) – JESD8-B/JESD36 (2.7 V to 3.6 V). • ±24 mA output drive (VCC = 3.0 V) • CMOS low power consumption • Latch-up performance exceeds 250 mA • Direct interface with TTL levels • Unlimited rise and fall times • Input accepts voltages up to 5 V • Multiple package options • ESD protection: – HBM: ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2000 V – MM: JESD22-A115-A exceeds 200 V. • Specified from -40 °C to +85 °C and -40 °C to +125 °C. 3 Applications • Wave and pulse shaper • Astable multivibrator • Monostable multivibrator 74LVC1G14 Nexperia Single Schmitt-trigger inverter 4 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G14GW -40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G14GV -40 °C to +125 °C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1G14GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm SOT886 74LVC1G14GF -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm SOT891 74LVC1G14GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm SOT1115 74LVC1G14GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm SOT1202 74LVC1G14GX -40 °C to +125 °C X2SON5 plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm SOT1226 74LVC1G14GX4 -40 °C to +125 °C X2SON4 plastic thermal enhanced extremely thin small outline package; no leads; 4 terminals; body 0.6 x 0.6 x 0.32 mm SOT1269-2 5 Marking Table 2. Marking Type number Marking code 74LVC1G14GW VF 74LVC1G14GV V14 74LVC1G14GM VF 74LVC1G14GF VF 74LVC1G14GN VF 74LVC1G14GS VF 74LVC1G14GX VF 74LVC1G14GX4 VF [1] [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter 6 Functional diagram A Y A mna023 mna025 mna024 Figure 1.  Logic symbol 7 Y Figure 2.  IEC logic symbol Figure 3.  Logic diagram Pinning information 7.1 Pinning 74LVC1G14 74LVC1G14 n.c. 1 A 2 GND 5 3 n.c. 1 6 VCC A 2 5 n.c. GND 3 4 Y VCC 4 001aae976 Y Transparent top view 001aab655 Figure 5.  Pin configuration SOT886, SOT891, SOT1115 and SOT1202 Figure 4.  Pin configuration SOT353-1 and SOT753 74LVC1G14 74LVC1G14 n.c. 1 5 VCC 4 Y A 1 4 VCC GND 2 3 Y 3 GND A 2 aaa-003024 aaa-028401 Transparent top view Transparent top view Figure 6.  Pin configuration SOT1226 (X2SON5) Figure 7.  Pin configuration SOT1269-2 (X2SON4) 7.2 Pin description Table 3. Pin description Symbol Pin Description TSSOP5, SC-74A and X2SON5 XSON6 X2SON4 n.c. 1 1, 5 - not connected A 2 2 1 data input GND 3 3 2 ground (0 V) Y 4 4 3 data output VCC 5 6 4 supply voltage 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter 8 Functional description Table 4. Function table [1] Input Output A Y L H H L [1] H = HIGH voltage level; L = LOW voltage level 9 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI VO Conditions Min Max Unit -0.5 +6.5 V input voltage [1] -0.5 +6.5 V output voltage Active mode [1] -0.5 VCC + 0.5 V Power-down mode; VCC = 0 V [1] -0.5 +6.5 V -50 - mA IIK input clamping current VI < 0 V IOK output clamping current VO > VCC or VO < 0 V - ±50 mA IO output current VO = 0 V to VCC - ±50 mA ICC supply current - +100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation Tamb = -40 °C to +125 °C TSSOP5, SC-74A, XSON6 and X2SON5 package [2] - 250 mW X2SON4 package [3] - 150 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For TSSOP5 and SC-74A packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON5 package: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. [3] For X2SON4 packages: above 57 °C the value of Ptot derates linearly with 1.7 mW/K. 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter 10 Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb Conditions Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC V Power-down mode; VCC = 0 V 0 - 5.5 V -40 - +125 °C ambient temperature 11 Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C Min VOH HIGH-level output voltage VOL IOFF [1] Max Min Max Unit VI = VT+ or VTVCC - 0.1 - - VCC - 0.1 - V IO = -4 mA; VCC = 1.65 V 1.2 1.54 - 0.95 - V IO = -8 mA; VCC = 2.3 V 1.9 2.15 - 1.7 - V IO = -12 mA; VCC = 2.7 V 2.2 2.50 - 1.9 - V IO = -24 mA; VCC = 3.0 V 2.3 2.62 - 2.0 - V IO = -32 mA; VCC = 4.5 V 3.8 4.11 - 3.4 - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.10 - 0.10 V IO = 4 mA; VCC = 1.65 V - 0.07 0.45 - 0.70 V IO = 8 mA; VCC = 2.3 V - 0.12 0.30 - 0.45 V IO = 12 mA; VCC = 2.7 V - 0.17 0.40 - 0.60 V IO = 24 mA; VCC = 3.0 V - 0.33 0.55 - 0.80 V IO = 32 mA; VCC = 4.5 V - 0.39 0.55 - 0.80 V - ±0.1 ±1 - ±1 μA current VI = 5.5 V or GND; VCC = 0 V to 5.5 V power-off VI or VO = 5.5 V; VCC = 0 V - ±0.1 ±2 - ±2 μA - 0.1 4 - 4 μA LOW-level output voltage II Typ -40 °C to +125 °C input leakage IO = -100 μA; VCC = 1.65 V to 5.5 V VI = VT+ or VT- leakage current ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter Symbol Parameter Conditions -40 °C to +85 °C Min Typ [1] -40 °C to +125 °C Max Min Max Unit ΔICC additional VI = VCC - 0.6 V; IO = 0 A; supply current VCC = 2.3 V to 5.5 V - 5 500 - 500 μA CI input - 5.0 - - - pF VCC = 3.3 V; VI = GND to VCC capacitance [1] All typical values are measured at maximum VCC and Tamb = 25 °C. Table 8. Transfer characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter Conditions -40 °C to +85 °C Min VT+ VT- VH positive-going threshold voltage negative-going threshold voltage [1] Typ -40 °C to +125 °C Max Min Max Unit see Figure 10 and Figure 11 VCC = 1.8 V 0.82 1.0 1.14 0.79 1.14 V VCC = 2.3 V 1.03 1.2 1.40 1.00 1.40 V VCC = 3.0 V 1.29 1.5 1.71 1.26 1.71 V VCC = 4.5 V 1.84 2.1 2.36 1.81 2.36 V VCC = 5.5 V 2.19 2.5 2.79 2.16 2.79 V VCC = 1.8 V 0.46 0.6 0.75 0.46 0.78 V VCC = 2.3 V 0.65 0.8 0.96 0.65 0.99 V VCC = 3.0 V 0.88 1.0 1.24 0.88 1.27 V VCC = 4.5 V 1.32 1.5 1.84 1.32 1.87 V VCC = 5.5 V 1.58 1.8 2.24 1.58 2.27 V VCC = 1.8 V 0.26 0.4 0.51 0.19 0.51 V VCC = 2.3 V 0.28 0.4 0.57 0.22 0.57 V VCC = 3.0 V 0.31 0.5 0.64 0.25 0.64 V VCC = 4.5 V 0.40 0.6 0.77 0.34 0.77 V VCC = 5.5 V 0.47 0.6 0.88 0.41 0.88 V see Figure 10 and Figure 11 hysteresis voltage (VT+ - VT-); see Figure 10, Figure 11 and Figure 12 [1] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter 12 Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter Conditions -40 °C to +85 °C Min tpd propagation delay power dissipation -40 °C to +125 °C Max Min Max Unit [2] A to Y; see Figure 8 VCC = 1.65 V to 1.95 V 1.0 4.1 11.0 1.0 14.0 ns VCC = 2.3 V to 2.7 V 0.7 2.8 6.5 0.7 8.5 ns VCC = 2.7 V 0.7 3.2 6.5 0.7 8.5 ns VCC = 3.0 V to 3.6 V 0.7 3.0 5.5 0.7 7.0 ns 0.7 2.2 5.0 0.7 6.5 ns - 15.4 - - - pF VCC = 4.5 V to 5.5 V CPD Typ [1] VCC = 3.3 V; VI = GND to VCC [3] capacitance [1] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi + (CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V. 12.1 Waveform and test circuit VI VM A input GND t PHL t PLH VOH VM Y output VOL mna640 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Figure 8.  The data input (A) to output (Y) propagation delays 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter Table 10. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5 x VCC 0.5 x VCC 2.3 V to 2.7 V 0.5 x VCC 0.5 x VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5 x VCC 0.5 x VCC VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 11. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 9.  Test circuit for measuring switching times Table 11. Test data Supply voltage Input VCC VI tr = tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 74LVC1G14 Product data sheet VEXT Load All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter 12.2 Waveforms transfer characteristics VO VT+ VI VH VT- VO VI VH VT- VT+ mna208 VT+ and VT- limits at 70 % and 20 %. mna207 Figure 10.  Transfer characteristic Figure 11.  Definition of VT+, VT- and VH mna641 10 ICC (mA) 8 6 4 2 0 0 1 2 VI (V) 3 VCC = 3.0 V. Figure 12.  Typical transfer characteristics 13 Application information The slow input rise and fall times cause additional power dissipation, this can be calculated using the following formula: Padd = fi x (tr x ΔICC(AV) + tf x ΔICC(AV)) x VCC where: • • • • • Padd = additional power dissipation (μW); fi = input frequency (MHz); tr = input rise time (ns); 10 % to 90 %; tf = input fall time (ns); 90 % to 10 %; ΔICC(AV) = average additional supply current (μA). Average ΔICC(AV) differs with positive or negative input transitions, as shown in Figure 13. An example of a relaxation circuit using the 74LVC1G14 is shown in Figure 14. 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter mna642 12 average I CC 10 (mA) positive-going edge 8 6 4 negative-going edge 2 0 0 2 4 VCC (V) 6 Linear change of VI between 0.8 V to 2.0 V. All values given are typical unless otherwise specified. Figure 13.  Average additional supply current as a function of supply voltage R C mna035 For K-factor, see Figure 15 Figure 14.  Relaxation oscillator K aaa-021985 1.2 1 0.8 0.6 0.4 0.2 0 1 2 3 4 5 VCC (V) 6 Figure 15.  Typical K-factor for relaxation oscillator 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter 14 Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm D E SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 e e1 L w M bp detail X 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Figure 16.  Package outline SOT353-1 (TSSOP5) 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter Plastic surface-mounted package; 5 leads SOT753 D B E y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT753 JEITA SC-74A EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 Figure 17.  Package outline SOT753 (SC-74A) 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Figure 18.  Package outline SOT886 (XSON6) 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 e1 4 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Figure 19.  Package outline SOT891 (XSON6) 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Figure 20.  Package outline SOT1115 (XSON6) 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Figure 21.  Package outline SOT1202 (XSON6) 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 16 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm D A B SOT1226 X A E A1 A3 detail X terminal 1 index area e v w b 1 2 terminal 1 index area C C A B C y1 C y k D h 3 L 5 4 0 1 mm scale Dimensions Unit mm A(1) A1 A3 D Dh E b e k L max 0.35 0.04 0.128 0.85 0.30 0.85 0.27 0.27 nom 0.80 0.25 0.80 0.22 0.48 0.22 min 0.040 0.75 0.20 0.75 0.17 0.20 0.17 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Dimension A is including plating thickness. 2. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version References IEC JEDEC EIAJ sot1226_po European projection Issue date 12-04-10 12-04-25 SOT1226 Figure 22.  Package outline SOT1226 (X2SON5) 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 17 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter X2SON4: plastic thermal enhanced extremely thin small outline package; no leads; 4 terminals; body 0.6 x 0.6 x 0.32 mm SOT1269-2 X A D B pin 1 ID area A E detail X A1 C e y1 C 2 y 3 L (4x) e 1 4 v w b (4x) C A B C 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 D E b e L max 0.35 0.04 0.65 0.65 0.20 nom 0.32 0.02 0.60 0.60 0.15 0.40 min 0.30 0.00 0.55 0.55 0.10 v w y y1 0.23 0.18 0.10 0.05 0.05 0.05 0.13 sot1269-2_po Outline version SOT1269-2 References IEC JEDEC JEITA European projection Issue date 17-04-07 17-06-30 --- Figure 23. Package outline SOT1269-2 (X2SON4) 74LVC1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 18 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter 15 Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor TTL Transistor-Transistor Logic HBM Human Body Model ESD ElectroStatic Discharge MM Machine Model DUT Device Under Test 16 Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G14 v.15 20180608 Product data sheet - 74LVC1G14 v.15 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Added type number 74LVC1G14GX4 (SOT1269-2) 74LVC1G14 v.14 20161202 Modifications: • Table 7: The maximum limits for leakage current and supply current have changed. 74LVC1G14 v.13 20160315 Modifications: • Figure 15 added (typical K-factor for relaxation oscillator). 74LVC1G14 v.12 20120806 Modifications: • Package outline drawing of SOT1226 (Figure 22) modified. 74LVC1G14 v.11 20120412 Modifications: • Added type number 74LVC1G14GX (SOT1226) • Package outline drawing of SOT886 (Figure 18) modified. 74LVC1G14 v.10 20111206 Modifications: • Legal pages updated. 74LVC1G14 v.9 20110922 74LVC1G14 v.8 Product data sheet Product data sheet Product data sheet Product data sheet - 74LVC1G14 v.13 74LVC1G14 v.12 74LVC1G14 v.11 74LVC1G14 v.10 - 74LVC1G14 v.9 Product data sheet - 74LVC1G14 v.8 20101110 Product data sheet - 74LVC1G14 v.7 74LVC1G14 v.7 20070718 Product data sheet - 74LVC1G14 v.6 74LVC1G14 v.6 20060615 Product data sheet - 74LVC1G14 v.5 74LVC1G14 v.5 20040910 Product specification - 74LVC1G14 v.4 74LVC1G14 v.4 20021119 Product specification - 74LVC1G14 v.3 74LVC1G14 v.3 20020521 Product specification - 74LVC1G14 v.2 74LVC1G14 v.2 20010406 Product specification - 74LVC1G14 v.1 74LVC1G14 v.1 20001212 Product specification - - 74LVC1G14 Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 19 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter 17 Legal information 17.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 17.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 17.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVC1G14 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 20 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVC1G14 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 17.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 15 — 8 June 2018 © Nexperia B.V. 2018. All rights reserved. 21 / 22 74LVC1G14 Nexperia Single Schmitt-trigger inverter Contents 1 2 3 4 5 6 7 7.1 7.2 8 9 10 11 12 12.1 12.2 13 14 15 16 17 General description ............................................ 1 Features and benefits .........................................1 Applications .........................................................1 Ordering information .......................................... 2 Marking .................................................................2 Functional diagram ............................................. 3 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Dynamic characteristics .....................................7 Waveform and test circuit .................................. 7 Waveforms transfer characteristics ....................9 Application information ......................................9 Package outline .................................................11 Abbreviations .................................................... 19 Revision history ................................................ 19 Legal information .............................................. 20 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 8 June 2018 Document identifier: 74LVC1G14 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC1G14GS,132 74LVC1G14GN,132 74LVC1G14GF,132 74LVC1G14GM,115 74LVC1G14GM,132 74LVC1G14GV,125 74LVC1G14GW,125 74LVC1G14GX,125 74LVC1G14GX4Z
74LVC1G14GN,132 价格&库存
很抱歉,暂时无法提供与“74LVC1G14GN,132”相匹配的价格&库存,您可以联系我们找货
