74LVC1G38GW,125
74LVC1G38GW,125
    NEXPERIA(安世)
    TSSOP5_2.25X1.35MM
    电压电平转换器 1.65~5.5V 100mA TSSOP5_2.25X1.35MM
74LVC1G38GW,125 数据手册
74LVC1G38 2-input NAND gate; open drain Rev. 8 — 7 December 2016 Product data sheet 1. General description The 74LVC1G38 provides a 2-input NAND function. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device as translator in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits              Wide supply voltage range from 1.65 V to 5.5 V 5 V tolerant outputs for interfacing with 5 V logic High noise immunity Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V). ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V 24 mA output drive (VCC = 3.0 V) CMOS low power consumption Open drain outputs Latch-up performance exceeds 250 mA Direct interface with TTL levels Inputs accept voltages up to 5 V Multiple package options Specified from 40 C to +125 C. 74LVC1G38 Nexperia 2-input NAND gate; open drain 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G38GW 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G38GV 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1G38GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74LVC1G38GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 74LVC1G38GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74LVC1G38GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74LVC1G38GX 40 C to +125 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm SOT1226 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G38GW YB 74LVC1G38GV YB 74LVC1G38GM YB 74LVC1G38GF YB 74LVC1G38GN YB 74LVC1G38GS YB 74LVC1G38GX YB [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram <  $  <   % Logic symbol 74LVC1G38 Product data sheet   % *1' DDE DDE Fig 1. $ Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 DDE Fig 3. Logic diagram © Nexperia B.V. 2017. All rights reserved 2 of 19 74LVC1G38 Nexperia 2-input NAND gate; open drain 6. Pinning information 6.1 Pinning /9&* /9&* $  %  *1'    $   9&& %   QF *1'   < 9&& < DDE 7UDQVSDUHQWWRSYLHZ DDE Fig 4. Pin configuration SOT353-1 and SOT753 Fig 5. Pin configuration SOT886 /9&* /9&* $ $   9&& %   QF *1'   <  9&&  <  *1' % DDI  DDD 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ Fig 6.  Pin configuration SOT891, SOT1115 and SOT1202 Fig 7. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description TSSOP5 and X2SON5 XSON6 A 1 1 data input B 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 74LVC1G38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 19 74LVC1G38 Nexperia 2-input NAND gate; open drain 7. Functional description Table 4. Function table[1] Input Output A B Y L L Z L H Z H L Z H H L [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current output voltage VO Conditions Min VI < 0 V [1] Max Unit 0.5 +6.5 50 - 0.5 +6.5 V V mA - 50 mA Active mode [1][2] 0.5 +6.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA 100 mA VO > VCC or VO < 0 V IO output current ICC supply current - IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 300 mW total power dissipation Ptot VO = 0 V to VCC Tamb = 40 C to +125 C [3] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON 5packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 74LVC1G38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 19 74LVC1G38 Nexperia 2-input NAND gate; open drain 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - 5.5 V Disable mode; VCC = 1.65 V to 5.5 V 0 - 5.5 V Power-down mode; VCC = 0 V 0 - 5.5 V 40 - +125 C - - 20 ns/V - - 10 ns/V Min Typ Tamb ambient temperature t/V input transition rise and VCC = 1.65 V to 2.7 V fall rate VCC = 2.7 V to 5.5 V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 VIH VIL VOL Conditions Max Unit C[1] HIGH-level input voltage LOW-level input voltage LOW-level output voltage 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - VI = VIH or VIL VCC = 1.65 V to 1.95 V 0.35  VCC V 0.3  VCC V - - - IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0.1 1 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - 0.1 2 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - 0.1 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - 0.1 4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V; per pin - 5 500 A CI input capacitance - 2.5 - pF 74LVC1G38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 19 74LVC1G38 Nexperia 2-input NAND gate; open drain Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit 0.65  VCC - - V Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL LOW-level output voltage VOL VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - VI = VIH or VIL - - 0.3  VCC V - IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 1 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - 2 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - - 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - - 4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V; per pin - - 500 A [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 C. 74LVC1G38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 6 of 19 74LVC1G38 Nexperia 2-input NAND gate; open drain 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 9. Symbol Parameter propagation delay tpd power dissipation capacitance CPD 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max VCC = 1.65 V to 1.95 V 1.0 3.0 10.0 1.0 12.5 ns VCC = 2.3 V to 2.7 V 0.5 1.8 6.0 0.5 7.5 ns VCC = 2.7 V 0.5 2.5 5.0 0.5 6.5 ns VCC = 3.0 V to 3.6 V 0.5 2.3 4.5 0.5 5.7 ns VCC = 4.5 V to 5.5 V 0.5 1.5 3.9 0.5 4.9 ns - 6 - - - pF A, B to Y; see Figure 8 [2] [3] VCC = 3.3 V; VI = GND to VCC [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPZL and tPLZ. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 12. AC waveforms 9, $%LQSXW 90 *1' W 3/= W 3=/ 9&&
74LVC1G38GW,125 价格&库存
很抱歉,暂时无法提供与“74LVC1G38GW,125”相匹配的价格&库存,您可以联系我们找货
74LVC1G38GW,125
  • 1+1.28165
  • 3+1.17384
  • 10+1.07083
  • 25+0.95297
  • 100+0.82025
  • 215+0.49289
  • 590+0.46606
  • 3000+0.44822
库存:2133
74LVC1G38GW,125
    • 3000+0.342443000+0.04096
    • 9000+0.334089000+0.03996
    • 12000+0.3313012000+0.03963
    • 30000+0.3248030000+0.03885
    • 45000+0.3173845000+0.03797
    库存:3000
    74LVC1G38GW,125
    • 1+1.186591+0.14193
    • 10+0.7962710+0.09525
    • 25+0.6982225+0.08352
    • 100+0.59059100+0.07065
    • 250+0.53888250+0.06446
    • 500+0.50803500+0.06077
    • 1000+0.482431000+0.05771
    库存:5536
    74LVC1G38GW,125
    • 3000+0.450853000+0.05393
    • 6000+0.435406000+0.05208
    • 9000+0.427649000+0.05115
    • 15000+0.4190815000+0.05013
    • 21000+0.4140621000+0.04953
    • 30000+0.4092430000+0.04895
    • 75000+0.3988575000+0.04771
    • 150000+0.39260150000+0.04696
    库存:5536
    74LVC1G38GW,125
    • 1+1.322611+0.15820
    • 3+1.259313+0.15063
    • 10+1.1620110+0.13899
    • 25+1.0278625+0.12295
    • 100+0.88426100+0.10577
    • 500+0.68020500+0.08136
    • 3000+0.482763000+0.05775
    库存:2133
    74LVC1G38GW,125
    • 1+1.177801+0.15000
    • 10+0.6974010+0.08880
    • 100+0.50380100+0.06420
    • 1000+0.478101000+0.06090
    • 3000+0.428003000+0.05450
    • 9000+0.403509000+0.05140
    • 45000+0.3942045000+0.05020
    • 99000+0.3860099000+0.04920
    库存:7027
