74LVC1G57GV,125
74LVC1G57GV,125
    NEXPERIA(安世)
    TSOP-6_2.9X1.5MM
    低功耗可配置多功能门
74LVC1G57GV,125 数据手册
74LVC1G57 Low-power configurable multiple function gate Rev. 8 — 7 December 2016 Product data sheet 1. General description The 74LVC1G57 provides configurable multiple functions. The output state is determined by eight patterns of 3-bit input. The user can choose the logic functions AND, OR, NAND, NOR, XNOR, inverter and buffer. All inputs can be connected to VCC or GND. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. All inputs (A, B and C) are Schmitt trigger inputs. They are capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. 2. Features and benefits             Wide supply voltage range from 1.65 V to 5.5 V 5 V tolerant input/output for interfacing with 5 V logic High noise immunity Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8B/JESD36 (2.7 V to 3.6 V). ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V 24 mA output drive (VCC = 3.0 V) CMOS low power consumption Latch-up performance exceeds 250 mA Direct interface with TTL levels Inputs accept voltages up to 5 V Multiple package options Specified from 40 C to +85 C and 40 C to +125 C. 74LVC1G57 Nexperia Low-power configurable multiple function gate 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G57GW 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74LVC1G57GV 40 C to +125 C SC-74 plastic surface-mounted package; 6 leads SOT457 74LVC1G57GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1.45  0.5 mm SOT886 74LVC1G57GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1  0.5 mm SOT891 74LVC1G57GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74LVC1G57GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G57GW YC 74LVC1G57GV V57 74LVC1G57GM YC 74LVC1G57GF YC 74LVC1G57GN YC 74LVC1G57GS YC [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram $   % & Fig 1.  <  DDE Logic symbol 74LVC1G57 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 20 74LVC1G57 Nexperia Low-power configurable multiple function gate 6. Pinning information 6.1 Pinning /9&* /9&* %   *1'   9&& $   < & %   & *1'   9&& $  %   & *1'   9&& $   < < DDI DDI 7UDQVSDUHQWWRSYLHZ DDI Fig 2.  /9&* Pin configuration SOT363 and SOT457 Fig 3. Pin configuration SOT886 7UDQVSDUHQWWRSYLHZ Fig 4. Pin configuration SOT891, SOT1115 and SOT1202 6.2 Pin description Table 3. Pin description Symbol Pin Description B 1 data input GND 2 ground (0 V) A 3 data input Y 4 data output VCC 5 supply voltage C 6 data input 7. Functional description Table 4. Function table[1] Input Output C B A Y L L L H L L H L L H L H L H H L H L L L H L H L H H L H H H H H [1] H = HIGH voltage level; L = LOW voltage level. 74LVC1G57 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 20 74LVC1G57 Nexperia Low-power configurable multiple function gate 7.1 Logic configurations Table 5. Function selection table Logic function Figure 2-input AND see Figure 5 2-input AND with both inputs inverted see Figure 8 2-input NAND with inverted input see Figure 6 and Figure 7 2-input OR with inverted input see Figure 6 and Figure 7 2-input NOR see Figure 8 2-input NOR with both inputs inverted see Figure 5 2-input XNOR see Figure 9 Inverter see Figure 10 Buffer see Figure 11 9&& % & % & < % <       9&& % & & < % & < % <       DDE Fig 5. 2-input AND gate or 2-input NOR gate with both inputs inverted & < DDE Fig 6. 2-input NAND gate with input B inverted or 2-input OR gate with inverted C input 9&& 9&& $ & $ & < $ <       $ & & < $ & < < $       DDE Fig 7. 2-input NAND gate with input C inverted or 2-input OR gate with inverted A input & < DDE Fig 8. 2-input NOR gate or 2-input AND gate with both inputs inverted 9&& 9&& % % & <       & $ < $ <       DDE DDE Fig 9. 2-input XNOR gate 74LVC1G57 Product data sheet < Fig 10. Inverter All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 20 74LVC1G57 Nexperia Low-power configurable multiple function gate 9&& % % <       < DDE Fig 11. Buffer 8. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions Min Max Unit 0.5 +6.5 V 50 - [1] 0.5 +6.5 VI < 0 V mA VI input voltage IOK output clamping current VO > VCC or VO < 0 V - 50 mA VO output voltage Active mode [1][2] 0.5 +6.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA IO output current ICC supply current - +100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot [1] VO = 0 V to VCC V Tamb = 40 C to +125 C [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 7. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb Conditions Product data sheet Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC V VCC = 0 V; Power-down mode 0 - 5.5 V 40 - +125 C ambient temperature 74LVC1G57 Min All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 20 74LVC1G57 Nexperia Low-power configurable multiple function gate 10. Static characteristics Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter LOW-level output voltage VOL VOH HIGH-level output voltage 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.7 V IO = 8 mA; VCC = 2.3 V - - 0.3 - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V IO = 32 mA; VCC = 4.5 V - - 0.55 - 0.8 V VCC  0.1 - - VCC  0.1 - V IO = 4 mA; VCC = 1.65 V 1.2 - - 0.95 - V IO = 8 mA; VCC = 2.3 V 1.9 - - 1.7 - V IO = 12 mA; VCC = 2.7 V 2.2 - - 1.9 - V IO = 24 mA; VCC = 3.0 V 2.3 - - 2.0 - V IO = 32 mA; VCC = 4.5 V 3.8 - - 3.4 - V VI = VT+ or VT VI = VT+ or VT IO = 100 A; VCC = 1.65 V to 5.5 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0.1 1 - 1 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - 0.1 2 - 2 A ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - 0.1 4 - 4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V - 5 500 - 500 A CI input capacitance - 2.5 - - - pF [1] Typical values are measured at maximum VCC and Tamb = 25 C. 74LVC1G57 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 6 of 20 74LVC1G57 Nexperia Low-power configurable multiple function gate 11. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 13. Symbol Parameter 40 C to +85 C Conditions Min Max Min Max VCC = 1.65 V to 1.95 V 1.0 6.0 14.4 1.0 18 ns VCC = 2.3 V to 2.7 V 0.5 3.5 8.3 0.5 10.4 ns VCC = 2.7 V 0.5 4.2 8.5 0.5 10.6 ns VCC = 3.0 V to 3.6 V 0.5 3.8 6.3 0.5 7.9 ns VCC = 4.5 V to 5.5 V 0.5 3.0 5.1 0.5 6.4 ns - 22 - - - pF [2] propagation delay A, B, C to Y; see Figure 12 tpd power dissipation capacitance CPD [3] VCC = 3.3 V; VI = GND to VCC [1] Typical values are measured at nominal VCC and at Tamb = 25 C. [2] tpd is the same as tPLH and tPHL [3] 40 C to +125 C Unit Typ[1] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 12. Waveforms 9, $%&LQSXW 90 90 *1' W 3+/ W 3/+ 92+ 90
74LVC1G57GV,125 价格&库存
很抱歉,暂时无法提供与“74LVC1G57GV,125”相匹配的价格&库存,您可以联系我们找货
74LVC1G57GV,125
  • 3000+0.477663000+0.06200
  • 6000+0.461336000+0.05988
  • 9000+0.453169000+0.05882
  • 15000+0.4441115000+0.05764
  • 21000+0.4388121000+0.05695
  • 30000+0.4337230000+0.05629
74LVC1G57GV,125
  • 1+1.237901+0.16066
  • 10+0.8387910+0.10886
  • 25+0.7376225+0.09573
  • 100+0.62482100+0.08109
  • 250+0.57080250+0.07408
  • 500+0.53796500+0.06982
  • 1000+0.511051000+0.06633
74LVC1G57GV,125
