74LVC1G57
Low-power configurable multiple function gate
Rev. 8 — 7 December 2016
Product data sheet
1. General description
The 74LVC1G57 provides configurable multiple functions. The output state is determined
by eight patterns of 3-bit input. The user can choose the logic functions AND, OR, NAND,
NOR, XNOR, inverter and buffer. All inputs can be connected to VCC or GND.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this
device in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
All inputs (A, B and C) are Schmitt trigger inputs. They are capable of transforming slowly
changing input signals into sharply defined, jitter-free output signals.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V).
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C.
74LVC1G57
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1G57GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC1G57GV
40 C to +125 C
SC-74
SOT457
74LVC1G57GM
40 C to +125 C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 1.45 0.5 mm
SOT886
74LVC1G57GF
40 C to +125 C
XSON6
no leads; 6 terminals; body 1 1 0.5 mm
SOT891
74LVC1G57GN
40 C to +125 C
XSON6
extremely thin small outline package; no leads;
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74LVC1G57GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G57GW
YC
74LVC1G57GV
V57
74LVC1G57GM
YC
74LVC1G57GF
YC
74LVC1G57GN
YC
74LVC1G57GS
YC
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Fig 1.
DDE
Logic symbol
74LVC1G57
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 20
74LVC1G57
Nexperia
6. Pinning information
6.1 Pinning
/9&*
/9&*
*1'
9&&
*1'
9&&
*1'
9&&
DDI
DDI
7UDQVSDUHQWWRSYLHZ
DDI
Fig 2.
/9&*
Pin configuration SOT363
and SOT457
Fig 3.
Pin configuration SOT886
7UDQVSDUHQWWRSYLHZ
Fig 4.
Pin configuration SOT891,
SOT1115 and SOT1202
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
B
1
data input
GND
2
ground (0 V)
A
3
data input
Y
4
data output
VCC
5
supply voltage
C
6
data input
7. Functional description
Table 4.
Function table[1]
Input
Output
C
B
A
Y
L
L
L
H
L
L
H
L
L
H
L
H
L
H
H
L
H
L
L
L
H
L
H
L
H
H
L
H
H
H
H
H
[1]
H = HIGH voltage level; L = LOW voltage level.
74LVC1G57
Product data sheet
3 of 20
74LVC1G57
Nexperia
7.1 Logic configurations
Table 5.
Function selection table
Logic function
Figure
2-input AND
see Figure 5
2-input AND with both inputs inverted
see Figure 8
2-input NAND with inverted input
see Figure 6 and Figure 7
2-input OR with inverted input
2-input NOR
see Figure 8
2-input NOR with both inputs inverted
see Figure 5
2-input XNOR
see Figure 9
Inverter
see Figure 10
Buffer
see Figure 11
9&&
9&&
DDE
Fig 5.
2-input AND gate or 2-input NOR gate with
DDE
Fig 6.
2-input NAND gate with input B inverted or
2-input OR gate with inverted C input
9&&
9&&
DDE
Fig 7.
2-input NAND gate with input C inverted or
2-input OR gate with inverted A input
DDE
Fig 8.
2-input NOR gate or 2-input AND gate with
9&&
9&&
DDE
DDE
Fig 9.
2-input XNOR gate
74LVC1G57
Product data sheet
Fig 10. Inverter
4 of 20
74LVC1G57
Nexperia
9&&
DDE
Fig 11. Buffer
8. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
Conditions
Min
Max
Unit
0.5
+6.5
V
50
[1]
0.5
+6.5
VI < 0 V
mA
VI
input voltage
IOK
output clamping current
VO > VCC or VO < 0 V
50
mA
VO
output voltage
Active mode
[1][2]
0.5
+6.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
IO
output current
ICC
supply current
+100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
[1]
VO = 0 V to VCC
V
Tamb = 40 C to +125 C
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 7.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
Conditions
Product data sheet
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
VCC = 0 V; Power-down mode
V
40
+125
C
ambient temperature
74LVC1G57
Min
5 of 20
74LVC1G57
Nexperia
10. Static characteristics
Table 8.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
LOW-level
output voltage
VOL
VOH
HIGH-level
output voltage
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
IO = 100 A;
VCC = 1.65 V to 5.5 V
0.1
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
0.7
V
IO = 8 mA; VCC = 2.3 V
0.3
0.45
V
IO = 12 mA; VCC = 2.7 V
0.4
0.6
V
IO = 24 mA; VCC = 3.0 V
0.55
0.8
V
IO = 32 mA; VCC = 4.5 V
0.55
0.8
V
VCC 0.1
VCC 0.1
V
1.2
0.95
V
1.9
1.7
V
2.2
1.9
V
2.3
2.0
V
3.8
3.4
V
VI = VT+ or VT
VI = VT+ or VT
IO = 100 A;
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1
1
A
IOFF
power-off
leakage
current
VI or VO = 5.5 V; VCC = 0 V
0.1
2
2
A
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
A
ICC
additional
supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 2.3 V to 5.5 V
5
500
500
A
CI
input
capacitance
2.5
pF
[1]
Typical values are measured at maximum VCC and Tamb = 25 C.
74LVC1G57
Product data sheet
6 of 20
74LVC1G57
Nexperia
11. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 13.
Symbol Parameter
40 C to +85 C
Conditions
Min
Max
Min
Max
VCC = 1.65 V to 1.95 V
1.0
6.0
14.4
1.0
18
ns
VCC = 2.3 V to 2.7 V
0.5
3.5
8.3
0.5
10.4
ns
VCC = 2.7 V
0.5
4.2
8.5
0.5
10.6
ns
VCC = 3.0 V to 3.6 V
0.5
3.8
6.3
0.5
7.9
ns
VCC = 4.5 V to 5.5 V
0.5
3.0
5.1
0.5
6.4
ns
22
pF
[2]
propagation delay A, B, C to Y; see Figure 12
tpd
power dissipation
capacitance
CPD
[3]
VCC = 3.3 V; VI = GND to VCC
[1]
Typical values are measured at nominal VCC and at Tamb = 25 C.
[2]
tpd is the same as tPLH and tPHL
[3]
40 C to +125 C Unit
Typ[1]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. Waveforms
9,
$%&LQSXW
90
90
*1'
W 3+/
W 3/+
92+
90
很抱歉,暂时无法提供与“74LVC1G57GS,132”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+0.641805000+0.07972
- 10000+0.6232410000+0.07741
- 15000+0.6139415000+0.07626
- 25000+0.6036425000+0.07498
- 35000+0.5976235000+0.07423
- 50000+0.5918250000+0.07351
- 125000+0.57937125000+0.07197
- 国内价格 香港价格
- 1+2.647211+0.32881
- 10+1.7986110+0.22340
- 25+1.5925925+0.19782
- 100+1.36886100+0.17003
- 250+1.26161250+0.15670
- 500+1.19697500+0.14868
- 1000+1.143631000+0.14205
- 2500+1.123282500+0.13952
