74LVC1G97GF,132
74LVC1G97GF,132
    NEXPERIA(安世)
    XSON6_1X1MM
    可配置多功能门 6XSON
74LVC1G97GF,132 数据手册
74LVC1G97 Low-power configurable multiple function gate Rev. 6 — 8 August 2018 Product data sheet 1. General description The 74LVC1G97 is a configurable multiple function gate with Schmitt-trigger inputs. The device can be configured as any of the following logic functions MUX, AND, OR, NAND, NOR, inverter and buffer; using the 3-bit input. All inputs can be connected to VCC or GND. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V environments. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • • • Wide supply voltage range from 1.65 V to 5.5 V 5 V tolerant input/output for interfacing with 5 V logic High noise immunity Complies with JEDEC standard: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8B/JESD36 (2.7 V to 3.6 V). ±24 mA output drive (VCC = 3.0 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101E exceeds 1000 V CMOS low power consumption Latch-up performance exceeds 250 mA Direct interface with TTL levels Inputs accept voltages up to 5 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C. 74LVC1G97 Nexperia Low-power configurable multiple function gate 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G97GW -40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74LVC1G97GV -40 °C to +125 °C SC-74 plastic surface mounted package; 6 leads SOT457 74LVC1G97GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1.45 × 0.5 mm SOT886 74LVC1G97GF -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1 × 0.5 mm SOT891 74LVC1G97GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 × 1.0 × 0.35 mm SOT1115 74LVC1G97GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 × 1.0 × 0.35 mm SOT1202 74LVC1G97GX -40 °C to +125 °C X2SON6 plastic thermal enhanced extremely thin small outline package; no leads; 6 terminals; body 1.0 × 0.8 × 0.35 mm SOT1255 4. Marking Table 2. Marking Type number Marking code [1] 74LVC1G97GW YV 74LVC1G97GV Y97 74LVC1G97GM YV 74LVC1G97GF YV 74LVC1G97GN YV 74LVC1G97GS YV 74LVC1G97GX YV [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram A 3 4 B C Fig. 1. 1 Y 6 001aad998 Logic symbol 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 2 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate 6. Pinning information 6.1. Pinning 74LVC1G97 74LVC1G97 B 1 6 C GND 2 5 VCC A 3 4 Y B 1 6 C GND 2 5 VCC A 3 4 Y 001aan191 001aan190 Fig. 2. Transparent top view Pin configuration SOT363 (SC-88) and SOT457 (SC-74) Fig. 3. Pin configuration SOT886 (XSON6) 74LVC1G97 74LVC1G97 B 1 B 1 6 C GND 2 5 VCC A 3 4 Y 2 GND 5 3 A 001aan192 VCC 4 Y Transparent top view Transparent top view Fig. 4. C 6 aaa-025870 Pin configuration SOT891, SOT1115, and SOT1202 (XSON6) Fig. 5. Pin configuration SOT1255 (X2SON6) 6.2. Pin description Table 3. Pin description Symbol Pin Description B 1 data input GND 2 ground (0 V) A 3 data input Y 4 data output VCC 5 supply voltage C 6 data input 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 3 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Output Input C B A Y L L L L L L H L L H L H L H H H H L L L H L H H H H L L H H H H 7.1. Logic configurations Table 5. Function selection table Logic function Figure 2-input MUX see Fig. 6 2-input AND see Fig. 7 2-input OR with one input inverted see Fig. 8 2-input NAND with one input inverted see Fig. 8 2-input AND with one input inverted see Fig. 9 2-input NOR with one input inverted see Fig. 9 2-input OR see Fig. 10 Inverter see Fig. 11 Buffer see Fig. 12 VCC B B Y A A C Fig. 6. 1 6 2 5 3 4 VCC C A C Y A Y 1 6 2 5 3 4 Y 001aae003 001aae002 2-input MUX C Fig. 7. 2-input AND gate VCC A C A C Y Y A 1 6 2 5 3 4 VCC C B C Y B C Y Y B 1 6 2 5 3 4 001aae004 Fig. 8. Product data sheet Y 001aae005 2-input NAND gate with input A inverted or 2-input OR gate with input C inverted 74LVC1G97 C Fig. 9. 2-input NOR gate with input B inverted or 2-input AND gate with input C inverted All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 4 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate VCC VCC B B C Y 1 6 2 5 3 4 C C Y Y 1 6 2 5 3 4 C Y 001aae007 001aae006 Fig. 10. 2-input OR gate Fig. 11. Inverter VCC B B Y 1 6 2 5 3 4 Y 001aae008 Fig. 12. Buffer 8. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +6.5 V -50 - [1] -0.5 +6.5 V VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V - ±50 mA VO output voltage Active mode [1][2] -0.5 +6.5 V Power-down mode [1][2] -0.5 +6.5 V - ±50 mA +100 mA VI < 0 V IO output current ICC supply current - IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] [3] VO = 0 V to VCC mA Tamb = -40 °C to +125 °C [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. For SC-88 and SC-74 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON6 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 7. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage 1.65 - 5.5 V VI input voltage 0 - 5.5 V VO output voltage Active mode 0 - VCC V VCC = 0 V; Power-down mode 0 - 5.5 V -40 - +125 °C Tamb ambient temperature 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 5 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate 10. Static characteristics Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VOL LOW-level output voltage VOH HIGH-level output voltage Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.1 - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.7 V IO = 8 mA; VCC = 2.3 V - - 0.3 - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V IO = 32 mA; VCC = 4.5 V - - 0.55 - 0.8 V VCC - 0.1 - - VCC - 0.1 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 0.95 - V IO = -8 mA; VCC = 2.3 V 1.9 - - 1.7 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 1.9 - V IO = -24 mA; VCC = 3.0 V 2.3 - - 2.0 - V IO = -32 mA; VCC = 4.5 V VI = VCC or GND VI = VCC or GND IO = -100 μA; VCC = 1.65 V to 5.5 V 3.8 - - 3.4 - V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - ±0.1 ±1 - ±1 μA IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - ±0.1 ±2 - ±2 μA ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - 0.1 4 - 4 μA ΔICC additional supply current VI = VCC - 0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V - 5 500 - 500 μA CI input capacitance - 2.5 - - - pF [1] Typical values are measured at maximum VCC and Tamb = 25 °C. 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 6 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate 11. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 14. Symbol Parameter tpd propagation delay CPD [1] [2] [3] Conditions power dissipation capacitance -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max VCC = 1.65 V to 1.95 V 1.0 6.0 14.4 1.0 18.0 ns VCC = 2.3 V to 2.7 V 0.5 3.5 8.3 0.5 10.4 ns VCC = 2.7 V 0.5 4.2 8.5 0.5 10.6 ns VCC = 3.0 V to 3.6 V 0.5 3.8 6.3 0.5 7.9 ns VCC = 4.5 V to 5.5 V 0.5 3.0 5.1 0.5 6.4 ns - 22 - - - pF A, B, C to Y; see Fig. 13 [2] VCC = 3.3 V; VI = GND to VCC [3] Typical values are measured at nominal VCC and at Tamb = 25 °C. tpd is the same as tPLH and tPHL CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of outputs. 11.1. Waveforms and test circuit VI A, B, C input VM VM GND t PHL t PLH VOH VM Y output VM VOL t PLH t PHL VOH Y output VM VOL VM 001aab593 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 13. Input A, B and C to output Y propagation delay times 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 7 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate Table 10. Measurement points Supply voltage Input Output VCC VM VI VM 1.65 V to 1.95 V 0.5VCC VCC 0.5VCC 2.3 V to 2.7 V 0.5VCC VCC 0.5VCC 2.7 V 1.5 V 2.7 V 1.5 V 3.0 V to 3.6 V 1.5 V 2.7 V 1.5 V 4.5 V to 5.5 V 0.5VCC VCC 0.5VCC VEXT VCC G VI RL VO DUT RT CL RL mna616 Measurement points are given in Table 11. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 14. Test circuit for measuring switching times Table 11. Measurement points Supply voltage Input VEXT Load VCC VI tr = tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 8 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate 12. Transfer characteristics Table 12. Transfer characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VT+ positive-going threshold voltage VT- negative-going threshold voltage -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max VCC = 1.8 V 0.70 1.02 1.20 0.67 1.20 V VCC = 2.3 V 1.11 1.42 1.60 1.08 1.60 V VCC = 3.0 V, see Fig. 19 1.50 1.79 2.00 1.47 2.00 V VCC = 4.5 V 2.16 2.52 2.74 2.13 2.74 V VCC = 5.5 V 2.61 2.99 3.33 2.58 3.33 V VCC = 1.8 V 0.30 0.53 0.72 0.30 0.75 V VCC = 2.3 V 0.58 0.77 1.00 0.58 1.03 V VCC = 3.0 V, see Fig. 19 0.80 1.04 1.30 0.80 1.33 V VCC = 4.5 V 1.21 1.55 1.90 1.21 1.93 V VCC = 5.5 V 1.45 1.86 2.29 1.45 2.32 V VCC = 1.8 V 0.30 0.48 0.62 0.23 0.62 V VCC = 2.3 V 0.40 0.64 0.80 0.34 0.80 V VCC = 3.0 V, see Fig. 19 0.50 0.75 1.00 0.44 1.00 V VCC = 4.5 V 0.71 0.97 1.20 0.65 1.20 V VCC = 5.5 V 0.71 1.13 1.40 0.65 1.40 V See Fig. 15, Fig. 16, Fig. 17 and Fig. 18 See Fig. 15, Fig. 16, Fig. 17 and Fig. 18 hysteresis voltage (VT+ - VT-). See Fig. 15, Fig. 16, Fig. 17 and Fig. 18 VH [1] Conditions Typical values are measured at Tamb = 25 °C. 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 9 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate 12.1. Waveforms transfer characteristics VO VT+ VI VT- VO VI VH VT+ VH VT- mna208 VT+ and VT- limits are at 70 % and 20 %. mna207 Fig. 15. Transfer characteristic Fig. 16. Definition of VT+, VT- and VH VO VT+ VI VH VT- VO VI VH VT- VT+ mnb155 VT+ and VT- limits are at 70 % and 20 %. mnb154 Fig. 17. Transfer characteristic Fig. 18. Definition of VT+, VT- and VH 001aab594 16 I CC (mA) 12 8 4 0 0 1 2 VI (V) 3 Fig. 19. Typical 74LVC1G97 transfer characteristic; VCC = 3.0 V 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 10 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate 13. Package outline Plastic surface-mounted package; 6 leads SOT363 D B E y A X HE 6 5 v M A 4 Q pin 1 index A 1 2 e1 A1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig. 20. Package outline SOT363 (SC-88) 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 11 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate Plastic surface-mounted package (TSOP6); 6 leads D SOT457 B E y A X HE 6 5 v M A 4 Q pin 1 index A A1 1 2 c 3 Lp e bp w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT457 JEITA EUROPEAN PROJECTION ISSUE DATE 05-11-07 06-03-16 SC-74 Fig. 21. Package outline SOT457 (SC-74) 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 12 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig. 22. Package outline SOT886 (XSON6) 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 13 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 e1 4 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Fig. 23. Package outline SOT891 (XSON6) 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 14 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 e1 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig. 24. Package outline SOT1115 (XSON6) 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 15 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig. 25. Package outline SOT1202 (XSON6) 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 16 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate X2SON6: plastic thermal enhanced extremely thin small outline package; no leads; 6 terminals; body 1.0 x 0.8 x 0.35 mm SOT1255 X A D B A pin 1 ID area E A1 detail X C e1 b (4x) 4 3 y1 C A B v y L (4x) 2 5 Dh (2x) 1 6 e2 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 D Dh E e1 e2 b L v y y1 max 0.35 0.04 1.05 0.30 0.85 0.30 0.25 nom 0.32 0.02 1.00 0.25 0.80 0.60 0.40 0.25 0.20 0.10 0.05 0.05 0.22 0.17 min 0.30 0.00 0.95 0.22 0.75 sot1255_po Outline version References IEC JEDEC JEITA European projection Issue date 15-07-20 15-07-22 SOT1255 Fig. 26. Package outline SOT1255 (X2SON6) 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 17 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate 14. Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G97 v.6 20180808 Product data sheet - 74LVC1G97 v.5 Modifications: • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74LVC1G97 v.5 20161212 Modifications: • • 74LVC1G97 v.4 20140910 Modifications: • 74LVC1G97 v.3 20111207 Product data sheet - 74LVC1G97 v.2 74LVC1G97 v.2 20110309 Product data sheet - 74LVC1G97 v.1 74LVC1G97 v.1 20101221 Product data sheet - - 74LVC1G97 Product data sheet Product data sheet - 74LVC1G97 v.4 Table 8: The maximum limits for leakage current and supply current have changed. •Type number 74LVC1G97GX (X2SON6/SOT1255) added. Product data sheet - 74LVC1G97 v.3 Package outline drawing of SOT886 (Fig. 22) modified. All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 18 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC1G97 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 19 / 20 74LVC1G97 Nexperia Low-power configurable multiple function gate Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 7.1. Logic configurations.....................................................4 8. Limiting values............................................................. 5 9. Recommended operating conditions..........................5 10. Static characteristics..................................................6 11. Dynamic characteristics.............................................7 11.1. Waveforms and test circuit........................................ 7 12. Transfer characteristics............................................. 9 12.1. Waveforms transfer characteristics..........................10 13. Package outline........................................................ 11 14. Abbreviations............................................................ 18 15. Revision history........................................................18 16. Legal information......................................................19 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 8 August 2018 74LVC1G97 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 8 August 2018 © Nexperia B.V. 2018. All rights reserved 20 / 20 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC1G97GF,132 74LVC1G97GM,132 74LVC1G97GN,132 74LVC1G97GS,132 74LVC1G97GV,125 74LVC1G97GW,125 74LVC1G97GXZ
74LVC1G97GF,132 价格&库存
很抱歉,暂时无法提供与“74LVC1G97GF,132”相匹配的价格&库存,您可以联系我们找货
