74LVC2G32
Dual 2-input OR gate
Rev. 13 — 3 July 2017
1
Product data sheet
General description
The 74LVC2G32 provides a 2-input OR gate function.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of
these devices as translators in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing a damaging backflow current through the device
when it is powered down.
2
Features and benefits
3
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant outputs in the Power-down mode
High noise immunity
±24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Complies with JEDEC standard:
– JESD8-7 (1.65 V to 1.95 V)
– JESD8-5 (2.3 V to 2.7 V)
– JESD8-B/JESD36 (2.7 V to 3.6 V)
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
ESD protection:
– HBM JESD22-A114F exceeds 2000 V
– MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C
Ordering information
Table 1. Ordering information
Type number
Package
Temperature
range
Name
Description
Version
74LVC2G32DP
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads;
body width 3 mm; lead length 0.5 mm
SOT505-2
74LVC2G32DC
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package; 8 leads; SOT765-1
body width 2.3 mm
74LVC2G32
Nexperia
Type number
Package
Temperature
range
Name
Description
Version
74LVC2G32GT
-40 °C to +125 °C
XSON8
plastic extremely thin small outline package; no leads; SOT833-1
8 terminals; body 1 x 1.95 x 0.5 mm
74LVC2G32GF
-40 °C to +125 °C
XSON8
8 terminals; body 1.35 x 1 x 0.5 mm
SOT1089
74LVC2G32GM
-40 °C to +125 °C
XQFN8
plastic, extremely thin quad flat package; no leads;
8 terminals; body 1.6 x 1.6 x 0.5 mm
SOT902-2
74LVC2G32GN
-40 °C to +125 °C
XSON8
8 terminals; body 1.2 x 1.0 x 0.35 mm
SOT1116
74LVC2G32GS
-40 °C to +125 °C
XSON8
8 terminals; body 1.35 x 1.0 x 0.35 mm
SOT1203
74LVC2G32GX
-40 °C to +125 °C
X2SON8
plastic thermal enhanced extremely thin small outline
package; no leads; 8 terminals;
SOT1233
body 1.35 x 0.8 x 0.35 mm
4
Marking
Table 2. Marking codes
Type number
Marking code
74LVC2G32DP
V32
74LVC2G32DC
V32
74LVC2G32GT
V32
74LVC2G32GF
VG
74LVC2G32GM
V32
74LVC2G32GN
VG
74LVC2G32GS
VG
74LVC2G32GX
VG
[1]
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74LVC2G32
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 21
74LVC2G32
Nexperia
5
Functional diagram
≥1
1A
1B
2A
2B
1Y
≥1
2Y
001aah791
001aah792
Figure 1. Logic symbol
Figure 2. IEC logic symbol
B
Y
A
mna166
Figure 3. Logic diagram (one gate)
6
Pinning information
6.1 Pinning
74LVC2G32
1A
1
8
VCC
1B
2
7
1Y
2Y
3
6
2B
GND
4
5
2A
74LVC2G32
1A
1
8
VCC
1B
2
7
1Y
2Y
3
6
2B
GND
4
5
2A
001aab743
Transparent top view
001aab742
Figure 4. Pin configuration SOT505-2 and SOT765-1
74LVC2G32
Product data sheet
Figure 5. Pin configuration SOT833-1, SOT1089,
SOT1116 and SOT1203
3 / 21
74LVC2G32
Nexperia
74LVC2G32
74LVC2G32
8
1Y
VCC
terminal 1
index area
1
7
1A
1A 1
2B
2
6
1B
2A
3
5
2Y
4
1Y
6
2B
5
2A
VCC
1B
2
4
GND
2Y
GND
7
8
3
001aae994
aaa-027038
Figure 6. Pin configuration SOT902-2
Figure 7. Pin configuration SOT1233
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
SOT505-2, SOT765-1, SOT833-1, SOT1089, SOT1116,
SOT1203 and SOT1233
SOT902-2
1A, 2A
1, 5
7, 3
data input
1B, 2B
2, 6
6, 2
data input
GND
4
4
ground (0 V)
1Y, 2Y
7, 3
1, 5
data output
VCC
8
8
supply voltage
7
Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Output
Input
nA
nB
nY
L
L
L
L
H
H
H
L
H
H
H
H
74LVC2G32
Product data sheet
4 / 21
74LVC2G32
Nexperia
8
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
output voltage
VO
Conditions
Min
Max
Unit
-0.5
+6.5
V
[1]
-0.5
+6.5
V
Active mode
[1]
-0.5
VCC + 0.5
V
Power-down mode
[2]
-0.5
+6.5
V
-50
mA
IIK
input clamping current
VI < 0 V
IOK
output clamping current
VO < 0 V or VO > VCC
±50
mA
IO
output current
VO = 0 V to VCC
±50
mA
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
300
mW
Ptot
[1]
[2]
[3]
total power dissipation
Tamb = -40 °C to +125 °C
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal condition.
For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K.
For XSON8 and XQFN8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
For X2SON8 package: above 118 °C the value of Ptot derates linearly with 7.7 mW/K.
9
Recommended operating conditions
Table 6. Operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74LVC2G32
Product data sheet
Min
Max
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode
V
-40
+125
°C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
Unit
5 / 21
74LVC2G32
Nexperia
10 Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
[1]
Typ
Max
Unit
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
VCC = 1.65 V to 1.95 V
0.65 x VCC
V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 x VCC
V
0.35 x VCC
V
0.7
V
0.8
V
0.3 x VCC
V
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
1.53
V
IO = -8 mA; VCC = 2.3 V
1.9
2.13
V
IO = -12 mA; VCC = 2.7 V
2.2
2.50
V
IO = -24 mA; VCC = 3.0 V
2.3
2.60
V
IO = -32 mA; VCC = 4.5 V
3.8
4.10
V
IO = 100 μA; VCC = 1.65 V to 5.5 V
0.1
V
IO = 4 mA; VCC = 1.65 V
0.08
0.45
V
IO = 8 mA; VCC = 2.3 V
0.14
0.3
V
IO = 12 mA; VCC = 2.7 V
0.19
0.4
V
IO = 24 mA; VCC = 3.0 V
0.37
0.55
V
IO = 32 mA; VCC = 4.5 V
0.43
0.55
V
VI = VIH or VIL
IO = -100 μA; VCC = 1.65 V to 5.5 V
VOL
LOW-level output voltage
VI = VIH or VIL
II
input leakage current
VI = 5.5 V or GND; VCC = 0 V to 5.5 V
±0.1
±1
μA
IOFF
power-off leakage current
VI or VO = 5.5 V; VCC = 0 V
±0.1
±2
μA
ICC
supply current
VI = 5.5 V or GND;
0.1
4
μA
5
500
μA
2.5
pF
VCC = 1.65 V to 5.5 V; IO = 0 A
ΔICC
additional supply current
per pin; VI = VCC - 0.6 V;
VCC = 2.3 V to 5.5 V; IO = 0 A
Ci
input capacitance
74LVC2G32
Product data sheet
6 / 21
74LVC2G32
Nexperia
Symbol Parameter
Conditions
Min
[1]
Typ
Max
Unit
VIH
VIL
VOH
0.65 x VCC
V
1.7
V
2.0
V
0.7 x VCC
V
0.35 x VCC
V
0.7
V
0.8
V
0.3 x VCC
V
VCC - 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
0.1
V
0.70
V
0.45
V
0.60
V
0.80
V
0.80
V
VI = VIH or VIL
VOL
VI = VIH or VIL
II
±1
μA
IOFF
±2
μA
ICC
supply current
VI = 5.5 V or GND;
4
μA
500
μA
ΔICC
[1]
All typical values are measured at Tamb = 25 °C.
74LVC2G32
Product data sheet
7 / 21
74LVC2G32
Nexperia
11 Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground 0 V); for test circuit see Figure 9.
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
Typ
1.3
Max
Min
Max
3.9
8.8
1.3
11
ns
0.8
2.4
4.7
0.8
5.9
ns
VCC = 2.7 V
0.8
2.7
4.8
0.8
6.0
ns
VCC = 3.0 V to 3.6 V
0.9
2.2
4.2
0.9
5.3
ns
0.7
1.7
3.2
0.7
4.0
ns
14
pF
CPD
[1]
[2]
[3]
power dissipation
capacitance
Unit
[2]
propagation delay nA, nB to nY; see Figure 8
tpd
[1]
-40 °C to +125 °C
[3]
per gate; VI = GND to VCC
Typical values are measured at nominal VCC and at Tamb = 25 °C.
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL x VCC x fo) = sum of outputs.
11.1 Waveforms and test circuit
VI
VM
nA, nB input
GND
t PHL
t PLH
VOH
nY output
VM
VOL
mna224
Measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output load.
Figure 8. Input (nA, nB) to output (nY) propagation delays
74LVC2G32
Product data sheet
8 / 21
74LVC2G32
Nexperia
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5VCC
0.5VCC
2.3 V to 2.7 V
0.5VCC
0.5VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5VCC
0.5VCC
VI
negative
pulse
tW
90 %
VM
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
PULSE
GENERATOR
VI
RL
VO
DUT
RT
CL
RL
001aae235
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance
CL = Load capacitance including jig and probe capacitance
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
VEXT = Test voltage for switching times
Figure 9. Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
74LVC2G32
Product data sheet
VEXT
Load
9 / 21
74LVC2G32
Nexperia
12 Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Figure 10. Package outline SOT505-2 (TSSOP8)
74LVC2G32
Product data sheet
10 / 21
74LVC2G32
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
0.2
w
0.08
y
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Figure 11. Package outline SOT765-1 (VSSOP8)
74LVC2G32
Product data sheet
11 / 21
74LVC2G32
Nexperia
XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
1
2
SOT833-1
b
4
3
4×
(2)
L
L1
e
8
7
6
e1
5
e1
e1
8×
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A(1)
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.25
0.17
2.0
1.9
1.05
0.95
0.6
0.5
0.35
0.27
0.40
0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT833-1
MO-252
EUROPEAN
PROJECTION
ISSUE DATE
07-11-14
07-12-07
Figure 12. Package outline SOT833-1 (XSON8)
74LVC2G32
Product data sheet
12 / 21
74LVC2G32
Nexperia
XSON8: extremely thin small outline package; no leads;
SOT1089
E
terminal 1
index area
D
A
A1
detail X
(4×)(2)
e
L
(8×)(2)
b 4
5
e1
1
terminal 1
index area
8
L1
X
scale
Dimensions
Unit
mm
max
nom
min
1 mm
A(1)
0.5
A1
b
D
E
e
e1
L
L1
0.04 0.20 1.40 1.05
0.35 0.40
0.15 1.35 1.00 0.55 0.35 0.30 0.35
0.12 1.30 0.95
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
SOT1089
sot1089_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-09
10-04-12
MO-252
Figure 13. Package outline SOT1089 (XSON8)
74LVC2G32
Product data sheet
13 / 21
74LVC2G32
Nexperia
XQFN8: plastic, extremely thin quad flat package; no leads;
SOT902-2
X
D
B
A
terminal 1
index area
E
A
A1
detail X
e
v
w
b
4
3
C
C A B
C
y1 C
y
5
e1
terminal 1
index area
2
6
L 1
7
k
8
L2
L
k
metal area
not for soldering
L3
L1
Dimensions
Unit(1)
mm
max
nom
min
2 mm
scale
A
0.5
A1
b
D
E
e
e1
0.05 0.25 1.65 1.65
0.20 1.60 1.60 0.55
0.00 0.15 1.55 1.55
0.5
k
0.2
L
L1
L2
L3
0.35 0.15 0.25 0.35
0.30 0.10 0.20 0.30
0.25 0.05 0.15 0.25
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT902-2
MO-255
sot902-2_po
European
projection
Issue date
16-07-14
16-11-08
Figure 14. Package outline SOT902-2 (XQFN8)
74LVC2G32
Product data sheet
14 / 21
74LVC2G32
Nexperia
1
2
SOT1116
b
4
3
(4×)(2)
L
L1
e
8
7
e1
6
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 1.25 1.05
nom
0.15 1.20 1.00 0.55
min
0.12 1.15 0.95
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
Outline
version
sot1116_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1116
Figure 15. Package outline SOT1116 (XSON8)
74LVC2G32
Product data sheet
15 / 21
74LVC2G32
Nexperia
SOT1203
b
1
2
3
(4×)(2)
4
L
L1
e
8
7
6
e1
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.40 1.05
0.35 0.40
nom
min
0.12 1.30 0.95
0.27 0.32
Note
Outline
version
sot1203_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1203
Figure 16. Package outline SOT1203 (XSON8)
74LVC2G32
Product data sheet
16 / 21
74LVC2G32
Nexperia
X2SON8: plastic thermal enhanced extremely thin small outline package; no leads;
8 terminals; body 1.35 x 0.8 x 0.35 mm
SOT1233
X
A
B
D
A
E
A1
detail X
pin 1
index area
e
e
1
2
pin 1
index area
C
b
(6x)
8
v
w
3
C A B
C
y
4
Dh
L
(6x)
7
6
b1
(2x)
5
y1 C
e1
1 mm
scale
Unit
mm
A
A1
max 0.35 0.04
nom 0.32
min 0.30 0.00
b
0.25
0.20
0.15
b1
D
Dh
E
1.40 0.27 0.85
0.15 1.35 0.22 0.80
(ref) 1.30 0.17 0.75
e
0.5
e1
L
0.27
0.54 0.22
0.17
v
0.1
w
y
y1
0.05 0.05 0.05
sot1233_po
Outline
version
SOT1233
References
IEC
JEDEC
JEITA
European
projection
Issue date
16-04-21
17-01-05
Figure 17. Package outline SOT1233 (X2SON8)
74LVC2G32
Product data sheet
17 / 21
74LVC2G32
Nexperia
13 Abbreviations
Table 11. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14 Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC2G32v.13
20170703
Product data sheet
74LVC2G32v.12
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
• Type number 74LVC2G32GX (SOT1233 / X2SON8) added.
• Type number 74LVC2G32GD removed.
74LVC2G32v.12
20161215
Modifications:
• Table 7: The maximum limits for leakage current and supply current have changed.
74LVC2G32v.11
20130408
Modifications:
• For type number 74LVC2G32GD XSON8U has changed to XSON8.
74LVC2G32 v.10
20120622
Modifications:
• For type number 74LVC2G32GM the SOT code has changed to SOT902-2.
74LVC2G32 v.9
20111128
Modifications:
• Legal pages updated.
74LVC2G32 v.8
20101110
74LVC2G32 v.7
Product data sheet
Product data sheet
Product data sheet
74LVC2G32v.11
74LVC2G32 v.10
74LVC2G32 v.9
74LVC2G32 v.8
Product data sheet
74LVC2G32 v.7
20080606
Product data sheet
74LVC2G32 v.6
74LVC2G32 v.6
20080227
Product data sheet
74LVC2G32 v.5
74LVC2G32 v.5
20070904
Product data sheet
74LVC2G32 v.4
74LVC2G32 v.4
20060515
Product data sheet
74LVC2G32 v.3
74LVC2G32 v.3
20050201
Product specification
74LVC2G32 v.2
74LVC2G32 v.2
20040922
74LVC2G32 v.1
74LVC2G32 v.1
20031027
74LVC2G32
Product data sheet
Product data sheet
18 / 21
74LVC2G32
Nexperia
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74LVC2G32
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
19 / 21
74LVC2G32
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74LVC2G32
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
20 / 21
74LVC2G32
Nexperia
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
12
13
14
15
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Marking .................................................................2
Functional diagram ............................................. 3
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 4
Functional description ........................................4
Limiting values .................................................... 5
Recommended operating conditions ................ 5
Static characteristics .......................................... 6
Dynamic characteristics .....................................8
Waveforms and test circuit ................................ 8
Package outline .................................................10
Abbreviations .................................................... 18
Revision history ................................................ 18
Legal information .............................................. 19
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 3 July 2017
Document identifier: 74LVC2G32
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC2G32GD,125 74LVC2G32GN,115 74LVC2G32GS,115 74LVC2G32DC,125 74LVC2G32DP,125
74LVC2G32GM,125 74LVC2G32GT,115 74LVC2G32GF,115 74LVC2G32GXX
