74LVC3G14
Triple inverting Schmitt trigger with 5 V tolerant input
Rev. 16 — 31 July 2019
Product data sheet
1. General description
The 74LVC3G14 provides three inverting buffers with Schmitt trigger input. It is capable of
transforming slowly changing input signals into sharply defined, jitter-free output signals.
The inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device
in a mixed 3.3 V and 5 V environment. Schmitt trigger action at the inputs makes the circuit tolerant
of slower input rise and fall time. This device is fully specified for partial power-down applications
using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current
through the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
±24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Unlimited rise and fall times
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C.
3. Applications
Wave and pulse shaper for highly noisy environment
Astable multivibrator
Monostable multivibrator.
74LVC3G14
Nexperia
4. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVC3G14DP
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads;
body width 3 mm; lead length 0.5 mm
SOT505-2
74LVC3G14DC
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package; 8 leads;
body width 2.3 mm
SOT765-1
74LVC3G14GT
-40 °C to +125 °C
XSON8
plastic extremely thin small outline package; no leads;
8 terminals; body 1 × 1.95 × 0.5 mm
SOT833-1
74LVC3G14GF
-40 °C to +125 °C
XSON8
8 terminals; body 1.35 × 1 × 0.5 mm
SOT1089
74LVC3G14GN
-40 °C to +125 °C
XSON8
8 terminals; body 1.2 × 1.0 × 0.35 mm
SOT1116
74LVC3G14GS
-40 °C to +125 °C
XSON8
8 terminals; body 1.35 × 1.0 × 0.35 mm
SOT1203
5. Marking
Table 2. Marking codes
Type number
Marking code [1]
74LVC3G14DP
V14
74LVC3G14DC
V14
74LVC3G14GT
V14
74LVC3G14GF
VK
74LVC3G14GN
VK
74LVC3G14GS
VK
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
6. Functional diagram
1A
1Y
3Y
3A
2A
2Y
A
Y
mna025
001aah729
001aah728
Fig. 1.
Logic symbol
74LVC3G14
Product data sheet
Fig. 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig. 3.
Logic diagram
(one Schmitt trigger)
Nexperia B.V. 2019. All rights reserved
2 / 18
74LVC3G14
Nexperia
7. Pinning information
7.1. Pinning
74LVC3G14
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
74LVC3G14
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
001aab834
Transparent top view
001aag081
Fig. 4.
Pin configuration SOT505-2 (TSSOP8) and
SOT765-1 (VSSOP8)
Fig. 5.
Pin configuration SOT833-1, SOT1089, SOT1116
and SOT1203 (XSON8)
7.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1A, 2A, 3A
1, 3, 6
data input
1Y, 2Y, 3Y
7, 5, 2
data output
GND
4
ground (0 V)
VCC
8
supply voltage
8. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level
Input nA
Output nY
L
H
H
L
74LVC3G14
Product data sheet
3 / 18
74LVC3G14
Nexperia
9. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+6.5
V
-50
-0.5
+6.5
V
±50
mA
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO > VCC or VO < 0 V
VO
output voltage
Active mode
[1]
-0.5
VCC + 0.5
V
Power-down mode; VCC = 0 V
[1]
-0.5
+6.5
V
±50
mA
VI < 0 V
[1]
IO
output current
ICC
supply current
100
mA
IGND
ground current
-100
mA
Ptot
total power dissipation
250
mW
Tstg
storage temperature
-65
+150
°C
[1]
[2]
VO = 0 V to VCC
mA
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT505-2 (TSSOP8) packages: Ptot derates linearly with 4.6 mW/K above 96 °C.
For SOT765-1 (VSSOP8) packages: Ptot derates linearly with 4.9 mW/K above 99 °C.
For SOT833-1 (XSON8) packages: Ptot derates linearly with 3.1 mW/K above 68 °C.
For SOT1089 (XSON8) packages: Ptot derates linearly with 4.0 mW/K above 88 °C.
For SOT1116 (XSON8) packages: Ptot derates linearly with 4.2 mW/K above 90 °C.
For SOT1203 (XSON8) packages: Ptot derates linearly with 3.6 mW/K above 81 °C.
10. Recommended operating conditions
Table 6. Operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Conditions
Active mode
74LVC3G14
Product data sheet
Min
Max
Unit
1.65
5.5
V
V
VCC
V
V
-40
+125
°C
4 / 18
74LVC3G14
Nexperia
11. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VOH
VOL
Conditions
HIGH-level output
voltage
LOW-level output
voltage
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
VCC - 0.1
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
0.95
V
IO = -8 mA; VCC = 2.3 V
1.9
1.7
V
IO = -12 mA; VCC = 2.7 V
2.2
1.9
V
IO = -24 mA; VCC = 3.0 V
2.3
2.0
V
IO = -32 mA; VCC = 4.5 V
3.8
3.4
V
IO = 100 μA;
VCC = 1.65 V to 5.5 V
0.1
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
0.7
V
IO = 8 mA; VCC = 2.3 V
0.3
0.45
V
IO = 12 mA; VCC = 2.7 V
0.4
0.6
V
IO = 24 mA; VCC = 3.0 V
0.55
0.8
V
IO = 32 mA; VCC = 4.5 V
VI = VT+ or VTIO = -100 μA;
VI = VT+ or VT-
0.55
0.8
V
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
±0.1
±1
±1
μA
IOFF
power-off leakage
current
VI or VO = 5.5 V; VCC = 0 V
±0.1
±2
±2
μA
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
μA
ΔICC
additional supply
current
VI = VCC - 0.6 V; IO = 0 A;
VCC = 2.3 V to 5.5 V
5
500
500
μA
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
3.5
pF
[1]
All typical values are measured at maximum VCC and Tamb = 25 °C.
11.1. Transfer characteristics
Table 8. Transfer characteristics
Voltages are referenced to GND (ground = 0 V; for test circuit see Fig. 10.
Symbol Parameter
VT+
positive-going
threshold voltage
74LVC3G14
Product data sheet
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
VCC = 1.8 V
0.70
1.10
1.50
0.70
1.70
V
VCC = 2.3 V
1.00
1.40
1.80
1.00
2.00
V
VCC = 3.0 V
1.30
1.76
2.20
1.30
2.40
V
VCC = 4.5 V
1.90
2.47
3.10
1.90
3.30
V
VCC = 5.5 V
2.20
2.91
3.60
2.20
3.80
V
see Fig. 6 and Fig. 7
5 / 18
74LVC3G14
Nexperia
Symbol Parameter
VT-
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
VCC = 1.8 V
0.25
0.61
0.90
0.25
1.10
V
VCC = 2.3 V
0.40
0.80
1.15
0.40
1.35
V
VCC = 3.0 V
0.60
1.04
1.50
0.60
1.70
V
VCC = 4.5 V
1.00
1.55
2.00
1.00
2.20
V
VCC = 5.5 V
1.20
1.86
2.30
1.20
2.50
V
VCC = 1.8 V
0.15
0.49
1.00
0.15
1.20
V
VCC = 2.3 V
0.25
0.60
1.10
0.25
1.30
V
VCC = 3.0 V
0.40
0.73
1.20
0.40
1.40
V
VCC = 4.5 V
0.60
0.92
1.50
0.60
1.70
V
VCC = 5.5 V
0.70
1.02
1.70
0.70
1.90
V
negative-going
threshold voltage
VH
[1]
Conditions
(VT+ - VT-); see Fig. 6, Fig. 7
and Fig. 8
hysteresis voltage
All typical values are measured at Tamb = 25 °C
11.2. Waveforms transfer characteristics
VO
VT-
VT+
mna208
VT+ and VT- limits at 70 % and 20 %.
mna207
Fig. 7.
ICC
(mA)
VH
VT-
VO
VI
VH
Fig. 6.
VT+
VI
Definition of VT+, VT- and VH
mdb627
14
12
10
8
6
4
2
1
1.5
VI (V)
2
VCC = 3.0 V
Fig. 8.
Typical transfer characteristics
74LVC3G14
Product data sheet
6 / 18
74LVC3G14
Nexperia
12. Dynamic characteristics
Table 9. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 10.
Symbol Parameter
tpd
propagation delay
CPD
[1]
[2]
[3]
Conditions
power dissipation
capacitance
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
VCC = 1.65 V to 1.95 V
1.0
4.2
11.0
1.0
12.0
ns
VCC = 2.3 V to 2.7 V
0.5
3.0
6.5
0.5
7.2
ns
VCC = 2.7 V
0.5
3.8
7.0
0.5
7.7
ns
VCC = 3.0 V to 3.6 V
0.5
3.2
6.0
0.5
6.7
ns
VCC = 4.5 V to 5.5 V
0.5
2.4
4.3
0.5
4.7
ns
18.1
pF
nA to nY; see Fig. 9
[2]
VI = GND to VCC; VCC = 3.3 V [3]
Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL × VCC × fo) = sum of outputs.
12.1. Waveforms and test circuit
VI
VM
nA input
VM
GND
t PHL
t PLH
VOH
VM
nY output
VOL
VM
mna344
Measurement points are given in Table 10.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 9.
The data input (nA) to output (nY) propagation delays
Table 10. Measurement points
VCC
Input VM
Output VM
1.65 V to 1.95 V
0.5 × VCC
0.5 × VCC
2.3 V to 2.7 V
0.5 × VCC
0.5 × VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5 × VCC
0.5 × VCC
74LVC3G14
Product data sheet
7 / 18
74LVC3G14
Nexperia
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
mna616
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 10. Test circuit for measuring switching times
Table 11. Test data
Supply voltage
Input
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
VEXT
Load
13. Application information
The slow input rise and fall times cause additional power dissipation, this can be calculated using
the following formula:
Padd = fi × (tr × ΔICC(AV) + tf × ΔICC(AV)) × VCC where:
Padd = additional power dissipation (μW);
fi = input frequency (MHz);
tr = input rise time (ns); 10 % to 90 %;
tf = input fall time (ns); 90 % to 10 %;
ΔICC(AV) = average additional supply current (μA).
ΔICC(AV) differs with positive or negative input transitions, as shown in Fig. 11.
An example of a relaxation circuit using the 74LVC3G14 is shown in Fig. 12.
74LVC3G14
Product data sheet
8 / 18
74LVC3G14
Nexperia
mnb086
50
ΔICC(AV)
(mA)
(1)
40
30
10
3
4
5
VCC (V)
6
Linear change of VI between 0.8 V to 2.0 V. All values given are typical unless otherwise specified.
(1) Positive-going edge.
(2) Negative-going edge.
Fig. 11. ΔICC(AV) as a function of VCC
R
C
mna035
For K-factor, see Fig. 13
Fig. 12. Relaxation oscillator
aaa-022057
1.2
K-factor
1
0.8
0.6
0.4
0.2
2
3
4
5
VCC (V)
6
Fig. 13. Typical K-factor for relaxation oscillator
74LVC3G14
Product data sheet
9 / 18
74LVC3G14
Nexperia
14. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Fig. 14. Package outline SOT505-2 (TSSOP8)
74LVC3G14
Product data sheet
10 / 18
74LVC3G14
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Fig. 15. Package outline SOT765-1 (VSSOP8)
74LVC3G14
Product data sheet
11 / 18
74LVC3G14
Nexperia
XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
1
2
SOT833-1
b
4
3
4×
(2)
L
L1
e
8
7
6
e1
5
e1
e1
8×
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A(1)
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.25
0.17
2.0
1.9
1.05
0.95
0.6
0.5
0.35
0.27
0.40
0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT833-1
MO-252
EUROPEAN
PROJECTION
ISSUE DATE
07-11-14
07-12-07
Fig. 16. Package outline SOT833-1 (XSON8)
74LVC3G14
Product data sheet
12 / 18
74LVC3G14
Nexperia
XSON8: extremely thin small outline package; no leads;
8 terminals; body 1.35 x 1 x 0.5 mm
SOT1089
E
terminal 1
index area
D
A
A1
detail X
(4×)(2)
e
L
(8×)(2)
b 4
5
e1
1
terminal 1
index area
8
L1
X
scale
Dimensions
Unit
mm
max
nom
min
1 mm
A(1)
0.5
A1
b
D
E
e
e1
L
L1
0.04 0.20 1.40 1.05
0.35 0.40
0.15 1.35 1.00 0.55 0.35 0.30 0.35
0.12 1.30 0.95
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
SOT1089
sot1089_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-09
10-04-12
MO-252
Fig. 17. Package outline SOT1089 (XSON8)
74LVC3G14
Product data sheet
13 / 18
74LVC3G14
Nexperia
8 terminals; body 1.2 x 1.0 x 0.35 mm
1
2
SOT1116
b
4
3
(4×)(2)
L
L1
e
8
7
e1
6
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
max 0.35 0.04 0.20 1.25 1.05
nom
0.15 1.20 1.00 0.55
min
0.12 1.15 0.95
e1
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
Outline
version
sot1116_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1116
Fig. 18. Package outline SOT1116 (XSON8)
74LVC3G14
Product data sheet
14 / 18
74LVC3G14
Nexperia
8 terminals; body 1.35 x 1.0 x 0.35 mm
SOT1203
b
1
2
3
(4×)(2)
4
L
L1
e
8
7
6
e1
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.40 1.05
0.35 0.40
nom
min
0.12 1.30 0.95
0.27 0.32
Note
Outline
version
sot1203_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1203
Fig. 19. Package outline SOT1203 (XSON8)
74LVC3G14
Product data sheet
15 / 18
74LVC3G14
Nexperia
15. Abbreviations
Table 12. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
16. Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVC3G14 v.16
20190731
Product data sheet
Modifications:
74LVC3G14 v.15
20190103
Modifications:
74LVC3G14 v.15
Type number 74LVC3G14GM (SOT902-2/XQFN8) removed.
Table 5: Derating values for Ptot total power dissipation updated.
Product data sheet
74LVC3G14 v.14
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74LVC3G14GD (SOT996-2) removed.
74LVC3G14 v.14
20161215
Modifications:
74LVC3G14 v.13
20160315
Modifications:
74LVC3G14 v.12
20130409
Modifications:
74LVC3G14 v.11
20120706
Modifications:
74LVC3G14 v.10
20111123
Modifications:
74LVC3G14 v.9
20110922
74LVC3G14 v.8
20100819
74LVC3G14 v.7
Product data sheet
74LVC3G14 v.13
Table 7: The maximum limits for leakage current and supply current have changed.
Product data sheet
74LVC3G14 v.12
Fig. 13 added (typical K-factor for relaxation oscillator).
Product data sheet
74LVC3G14 v.11
For type number 74LVC3G14GD XSON8U has changed to XSON8.
Product data sheet
74LVC3G14 v.10
For type number 74LVC3G14GM the SOT code has changed to SOT902-2.
74LVC3G14 v.9
Product data sheet
74LVC3G14 v.8
Product data sheet
74LVC3G14 v.7
20080612
Product data sheet
74LVC3G14 v.6
74LVC3G14 v.6
20080207
Product data sheet
74LVC3G14 v.5
74LVC3G14 v.5
20071005
Product data sheet
74LVC3G14 v.4
74LVC3G14 v.4
20070314
Product data sheet
74LVC3G14 v.3
74LVC3G14 v.3
20050131
Product data sheet
74LVC3G14 v.2
74LVC3G14 v.2
20041027
Product data sheet
74LVC3G14 v.1
74LVC3G14 v.1
20040510
Product data sheet
74LVC3G14
Product data sheet
Product data sheet
Legal pages updated.
16 / 18
74LVC3G14
Nexperia
17. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LVC3G14
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
17 / 18
74LVC3G14
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Marking.......................................................................... 2
6. Functional diagram.......................................................2
7. Pinning information......................................................3
7.1. Pinning.........................................................................3
7.2. Pin description............................................................. 3
8. Functional description................................................. 3
9. Limiting values............................................................. 4
10. Recommended operating conditions........................4
11. Static characteristics..................................................5
11.1. Transfer characteristics..............................................5
11.2. Waveforms transfer characteristics............................ 6
12. Dynamic characteristics............................................ 7
12.1. Waveforms and test circuit........................................ 7
13. Application information............................................. 8
14. Package outline........................................................ 10
15. Abbreviations............................................................ 16
16. Revision history........................................................16
17. Legal information......................................................17
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 31 July 2019
74LVC3G14
Product data sheet
18 / 18
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC3G14GD,125 74LVC3G14GN,115 74LVC3G14GS,115 74LVC3G14DC,125 74LVC3G14DP,125
74LVC3G14GM,125 74LVC3G14GT,115 74LVC3G14GF,115
