74LVT02D,112
74LVT02D,112
    NEXPERIA(安世)
    SO-14_8.65X3.9MM
    电压电平转换器 2.7~3.6V 64mA SOIC14_8.75X4MM
74LVT02D,112 数据手册
74LVT02 3.3 V Quad 2-input NOR gate Rev. 3 — 7 April 2017 1 Product data sheet General description The 74LVT02 is a high-performance BiCMOS product designed for VCC operation at 3.3 V. The 74LVT02 is a quad 2-input NOR gate. 2 Features and benefits • • • • Wide supply voltage range from 2.7 V to 3.6 V Output capability: +64 mA and -32 mA TTL input and output switching levels Latch-up protection – JESD78 Class II exceeds 500 mA • Complies with JEDEC standards: – JESD8C (2.7 V to 3.6 V) • ESD protection: – HBM JESD22-A114E exceeds 2000 V – MM JESD22-A115-A exceeds 200 V • Specified from -40 °C to 85 °C 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVT02D -40 °C to +85 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LVT02DB -40 °C to +85 °C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74LVT02PW -40 °C to +85 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate 4 Functional diagram 2 1A 3 1B 5 2A 6 2B 8 3A 9 3B 11 4A 12 4B 2 1Y 1 2Y 4 3Y 10 3 5 6 8 9 11 13 4Y 12 1 ≥1 4 ≥1 10 ≥1 13 A Y B 001aah084 mna216 Figure 1. Logic symbol 5 ≥1 Figure 2. IEC logic symbol mna215 Figure 3. Logic diagram (one gate) Pinning information 5.1 Pinning 74LVT02 1Y 1 14 VCC 1A 2 13 4Y 1B 3 12 4B 2Y 4 11 4A 2A 5 10 3Y 2B 6 9 3B GND 7 8 3A 74LVT02 1Y 1 14 VCC 1A 2 13 4Y 1B 3 12 4B 2Y 4 11 4A 2A 5 10 3Y 2B 6 9 3B GND 7 8 3A aaa-026558 aaa-026557 Figure 4. Pin configuration for SOT108-1 (SO14) Figure 5. Pin configuration for SOT337-1 and SOT402-1 (SSOP14 and TSSOP14) 5.2 Pin description Table 2. Pin description Symbol Pin Description 1Y to 4Y 1, 4, 10, 13 data output 1A to 4A 2, 5, 8, 11 data input 1B to 4B 3, 6, 9,12 data input GND 7 ground (0 V) VCC 14 supply voltage 74LVT02 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate 6 Functional description Table 3. Function table [1] Output Input nA nB nY L L H L H L H L L H H L [1] H = HIGH voltage level; L = LOW voltage level 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions supply voltage Min Max Unit -0.5 +4.6 V input voltage [1] -0.5 +7.0 V VO output voltage output in OFF-state or HIGH-state [1] -0.5 +7.0 V IIK input clamping current VI < 0 V -50 - mA IOK output clamping current VO < 0 V -50 - mA IO output current output in LOW-state - 64 mA output in HIGH-state -32 - mA VI Tstg storage temperature Tj Ptot [1] [2] [3] -65 +150 °C junction temperature [2] - 150 °C total power dissipation [3] - 500 mW Tamb = -40 to +85 °C The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. For SO14 packages: above 70 °C derate linearly with 8 mW/K. For SSOP14 and TSSOP14 packages: above 60 °C derate linearly with 5.5 mW/K. 8 Recommended operating conditions Table 5. Operating conditions Symbol Parameter Conditions Min Typ Max Unit 2.7 - 3.6 V 0 - 5.5 V VCC supply voltage VI input voltage IOH HIGH-level output current -20 - - mA IOL LOW-level output current - - 32 mA Tamb ambient temperature in free-air -40 - +85 °C Δt/ΔV input transition rise and fall rate outputs enabled - - 10 ns/V 74LVT02 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 2.7 V; IIK = -18 mA -1.2 [1] Typ Max Unit Tamb = -40 °C to +85 °C VIK input clamping voltage VIH HIGH-level input voltage 2.0 VIL LOW-level input voltage - VOH HIGH-level output voltage VOL II VCC = 2.7 V to 3.6 V; IOH = -100 μA V - - V - 0.8 V - V VCC - 0.2 VCC = 2.7 V; IOH = -6 mA 2.4 - - V VCC = 3.0 V; IOH = -20 mA 2.0 - - V LOW-level output voltage VCC = 2.7 V; IOL = 100 μA - 0.2 V VCC = 2.7 V; IOL = 24 mA - 0.5 V VCC = 3.0 V; IOL = 32 mA - 0.5 V VCC = 0 V or 3.6 V; VI = 5.5 V - - 10 μA - ±1 μA ±100 μA input leakage current VCC = 3.6 V; VI = VCC or GND IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V ICC supply current VCC = 3.6 V; VI = GND or VCC; IO = 0 A output HIGH output LOW ΔICC additional supply current per input pin; VCC = 3.0 V to 3.6 V; one input at VCC - 0.6 V and other inputs at VCC or GND CI input capacitance VI = 0 V or 3.0 V [1] [2] - [2] - - 0.02 mA - 1 2 mA 0.2 μA - pF - - 3 Typical values are measured at Tamb = 25 °C and VCC = 3.3 V. This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 74LVT02 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7. Symbol Parameter Conditions Min [1] Typ Max Unit Tamb = -40 °C to +85 °C tPLH LOW to HIGH propagation delay tPHL HIGH to LOW propagation delay [1] nA or nB to nY; see Figure 6 VCC = 2.7 V - - 5.2 ns VCC = 3.0 V to 3.6 V 1 2.8 4.4 ns VCC = 2.7 V - - 3.4 ns VCC = 3.0 V to 3.6 V 1 2.6 3.6 ns nA or nB to nY; see Figure 6 Typical values are measured at Tamb = 25 °C and VCC = 3.3 V. 10.1 Waveforms and test circuit VI VM A, B input GND t PHL t PLH VOH VM Y output mna612 VOL Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. Input to output propagation delays Table 8. Measurement points Output Input VM VI VM 1.5 V 2.7 V 1.5 V 74LVT02 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VCC PULSE GENERATOR VI VO DUT RT CL RL 001aaf615 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. RL = load resistance. Figure 7. Test circuit for measuring switching times Table 9. Test data Input Load Test VI fi tW tr, tf CL RL 2.7 V ≤ 10 MHz 500 ns ≤ 2.5 ns 50 pF 500 Ω 74LVT02 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 tPLH, tPHL © Nexperia B.V. 2017. All rights reserved. 6 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate 11 Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 8. Package outline SOT108-1 (SO14) 74LVT02 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm D SOT337-1 E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp L 7 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.4 0.9 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT337-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 9. Package outline SOT337-1 (SSOP14) 74LVT02 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 10. Package outline SOT402-1 (TSSOP14) 74LVT02 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate 12 Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVT02 v.3 20170324 Product data sheet - 74LVT02 v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74LVT02 v.2 19960815 74LVT02 Product data sheet Product specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 74LVT02 v.1 © Nexperia B.V. 2017. All rights reserved. 10 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVT02 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVT02 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 April 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 13 74LVT02 Nexperia 3.3 V Quad 2-input NOR gate Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 2 Pinning ............................................................... 2 Pin description ................................................... 2 Functional description ........................................3 Limiting values .................................................... 3 Recommended operating conditions ................ 3 Static characteristics .......................................... 4 Dynamic characteristics .....................................5 Waveforms and test circuit ................................ 5 Package outline ...................................................7 Abbreviations .................................................... 10 Revision history ................................................ 10 Legal information .............................................. 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 7 April 2017 Document identifier: 74LVT02 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVT02D,112 74LVT02DB,112 74LVT02DB,118 74LVT02D,118 74LVT02PW,112 74LVT02PW,118
74LVT02D,112 价格&库存
很抱歉,暂时无法提供与“74LVT02D,112”相匹配的价格&库存,您可以联系我们找货
