74VHC08BQ,115
74VHC08BQ,115
    NEXPERIA(安世)
    DHVQFN-14-EP(2.5x3)
    电压电平转换器 5V 75mA DHVQFN14_3X2.5MM-EP
74VHC08BQ,115 数据手册
74VHC08; 74VHCT08 Quad 2-input AND gate Rev. 01 — 30 June 2009 Product data sheet 1. General description The 74VHC08; 74VHCT08 are high-speed Si-gate CMOS devices and are pin compatible with Low-power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard JESD7-A. The 74VHC08; 74VHCT08 provide the quad 2-input AND function. 2. Features n n n n Balanced propagation delays All inputs have a Schmitt-trigger action Inputs accepts voltages higher than VCC Input levels: u The 74VHC08 operates with CMOS logic levels u The 74VHCT08 operates with TTL logic levels n ESD protection: u HBM JESD22-A114E exceeds 2000 V u MM JESD22-A115-A exceeds 200 V u CDM JESD22-C101C exceeds 1000 V n Multiple package options n Specified from −40 °C to +85 °C and from −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number 74VHC08D Package Temperature range Name Description Version −40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 −40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 −40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm 74VHCT08D 74VHC08PW 74VHCT08PW 74VHC08BQ 74VHCT08BQ SOT762-1 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate 4. Functional diagram 1 & 3 & 6 2 1 1A 2 1B 4 2A 5 2B 9 3A 10 3B 12 4A 13 4B 1Y 3 4 2Y 6 5 3Y 8 9 A Y & 8 B 10 4Y mna221 11 12 mna222 & 11 13 mna223 Fig 1. Logic symbol Fig 2. IEC logic symbol Fig 3. Logic diagram (one gate) 5. Pinning information 5.1 Pinning 1A terminal 1 index area 14 VCC 74VHC08 74VHCT08 74VHC08 74VHCT08 1 14 VCC 1B 2 13 4B 1B 2 13 4B 1Y 3 12 4A 2A 4 2B 5 2Y 6 1 1A 4 11 4Y 10 3B 2B 5 2Y 6 9 3A GND 7 8 3Y 11 4Y GND(1) 10 3B 9 8 2A 3Y 12 4A 7 3 GND 1Y 3A 001aak041 Transparent top view 001aak040 (1) The die substrate is attached to this pad using conductive die attach material. It can not be used as a supply pin or input. Fig 4. Pin configuration SO14 and TSSOP14 Fig 5. Pin configuration DHVQFN14 © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 2 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A 1 data input 1B 2 data input 1Y 3 data output 2A 4 data input 2B 5 data input 2Y 6 data output GND 7 ground (0 V) 3Y 8 data output 3A 9 data input 3B 10 data input 4Y 11 data output 4A 12 data input 4B 13 data input VCC 14 supply voltage 6. Functional description Table 3. Function selection[1] Input Output nA nB nY L X L X L L H H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage Conditions Min Max Unit −0.5 +7.0 V −0.5 +7.0 V −20 - mA - ±20 mA - ±25 mA input clamping current VI < −0.5 V [1] IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] IO output current VO = −0.5 V to (VCC + 0.5 V) ICC supply current - 75 mA IGND ground current −75 - mA Tstg storage temperature −65 +150 °C IIK © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 3 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate Table 4. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Ptot total power dissipation Tamb = −40 °C to +125 °C [1] Min Max Unit SO14 package [2] - 500 mW TSSOP14 package [3] - 500 mW DHVQFN14 package [4] - 500 mW The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 °C. [3] Ptot derates linearly with 5.5 mW/K above 60 °C. [4] Ptot derates linearly with 4.5 mW/K above 60 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74VHC08 74VHCT08 Unit Min Typ Max Min Typ Max VCC supply voltage 2.0 5.0 5.5 4.5 5.0 5.5 V VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature −40 +25 +125 −40 +25 +125 °C ∆t/∆V input transition rise and fall rate VCC = 3.3 V ± 0.3 V - - 100 - - - ns/V VCC = 5.0 V ± 0.5 V - - 20 - - 20 ns/V 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max 1.5 - - 1.5 - 1.5 - VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V For type 74VHC08 VIH VIL VOH HIGH-level input voltage LOW-level input voltage VCC = 2.0 V V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = −50 µA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = −50 µA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = −50 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = −4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.4 - V IO = −8.0 mA; VCC = 4.5 V 3.94 - - 3.8 - 3.7 - V © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 4 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter VOL 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max LOW-level VI = VIH or VIL output voltage IO = 50 µA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 µA II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 µA CI input capacitance - 3.0 10 - 10 - 10 pF For type 74VHCT08 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = −50 µA 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 µA IO = −8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 µA IO = 8.0 mA II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 µA ∆ICC additional per input pin; supply current VI = VCC − 2.1 V; IO = 0 A; other pins at VCC or GND; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3.0 10 - 10 - 10 pF © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 5 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 7. Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 4.0 8.8 1.0 10.5 1.0 11.0 ns CL = 50 pF - 5.6 12.3 1.0 14 1.0 15.5 ns - 3.0 5.9 1.0 7.0 1.0 7.5 ns 4.2 7.9 1.0 9.0 1.0 10.0 ns - 10.0 - - - - - pF - 3.2 6.9 1.0 8.0 1.0 9.0 ns - 4.2 7.9 1.0 9.0 1.0 10.0 ns - 12.0 - - - - - pF For type 74VHC08 tpd propagation delay nA, nB to nY; see Figure 6 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF CPD power CL = 50 pF; fi = 1 MHz; dissipation VI = GND to VCC capacitance [3] For type 74VHCT08 tpd propagation delay nA, nB to nY; see Figure 6 [2] VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF CPD power CL = 50 pF; fi = 1 MHz; dissipation VI = GND to VCC capacitance [3] [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching Σ(CL × VCC2 × fo) = sum of the outputs. © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 6 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate 11. Waveforms VI VM nA, nB input GND t PHL t PLH VOH VM nY output VOL mna224 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. The input (nA, nB) to output (nY) propagation delays Table 8. Measurement points Type Input Output VM VM 74VHC08 0.5VCC 0.5VCC 74VHCT08 1.5 V 0.5VCC © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 7 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 7. Load circuit for switching times Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74VHC08 VCC ≤ 3.0 ns 15 pF, 50 pF 1 kΩ open GND VCC 74VHCT08 3.0 V ≤ 3.0 ns 15 pF, 50 pF 1 kΩ open GND VCC © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 8 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 9 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 Fig 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Package outline SOT402-1 (TSSOP14) © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 10 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT762-1 14 terminals; body 2.5 x 3 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 6 y y1 C v M C A B w M C b L 1 7 Eh e 14 8 13 9 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b 1 0.05 0.00 0.30 0.18 mm c D (1) Dh E (1) Eh 0.2 3.1 2.9 1.65 1.35 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT762-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 10. Package outline SOT762-1 (DHVQFN14) © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 11 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor LSTTL Low-power Schottky Transistor-Transistor Logic ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model CDM Charged Device Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74VHC_VHCT08_1 20090630 Product data sheet - - © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 12 of 14 74VHC08; 74VHCT08 Nexperia Quad 2-input AND gate 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 15.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © 74VHC_VHCT08_1 Product data sheet Rev. 01 — 30 June 2009 Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia 74VHC08; 74VHCT08 Quad 2-input AND gate 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 June 2009 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74VHC08BQ,115 74VHC08D,118 74VHC08PW,118 74VHCT08BQ,115 74VHCT08D,118 74VHCT08PW,118
74VHC08BQ,115 价格&库存
很抱歉,暂时无法提供与“74VHC08BQ,115”相匹配的价格&库存,您可以联系我们找货
74VHC08BQ,115
  • 3000+1.378243000+0.17850
  • 6000+1.338976000+0.17341
  • 9000+1.319309000+0.17087
  • 15000+1.2975215000+0.16805
  • 21000+1.2847821000+0.16640
  • 30000+1.2725430000+0.16481
库存:2398
74VHC08BQ,115
  • 1+3.269061+0.42338
  • 10+2.2530910+0.29180
  • 25+2.0071625+0.25995
  • 100+1.73335100+0.22449
  • 250+1.60222250+0.20751
  • 500+1.52342500+0.19730
  • 1000+1.458481000+0.18889
库存:2398
