74VHC14; 74VHCT14
Hex inverting Schmitt trigger
Rev. 01 — 17 August 2009
Product data sheet
1. General description
The 74VHC14; 74VHCT14 are a high-speed Si-gate CMOS devices and are pin
compatible with Low-power Schottky TTL (LSTTL). They are specified in compliance with
JEDEC standard No. 7A.
The 74VHC14; 74VHCT14 provide six inverting buffers with Schmitt-trigger action. They
are capable of transforming slowly changing input signals into sharply defined, jitter-free
output signals.
2. Features
n
n
n
n
Balanced propagation delays
All inputs have Schmitt-trigger action
Inputs accept voltages higher than VCC
Input levels:
u The 74VHC14 operates with CMOS input level
u The 74VHCT14 operates with TTL input level
n ESD protection:
u HBM EIA/JESD22-A114E exceeds 2000 V
u MM EIA/JESD22-A115-A exceeds 200 V
u CDM EIA/JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
74VHC14; 74VHCT14
Nexperia
3. Ordering information
Table 1.
Type number
Package
74VHC14D
Temperature range Name
Description
Version
−40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
−40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
−40 °C to +125 °C
DHVQFN14
plastic dual in-line compatible thermal enhanced very SOT762-1
thin quad flat package; no leads; 14 terminals; body
2.5 × 3 × 0.85 mm
74VHCT14D
74VHC14PW
74VHCT14PW
74VHC14BQ
74VHCT14BQ
4. Functional diagram
1
3
5
9
11
13
1A
1Y
2A
2Y
3A
3Y
4A
4Y
5A
5Y
6A
6Y
Logic symbol
2
3
4
5
6
9
8
11
10
13
12
2
4
6
8
10
12
Fig 2.
IEC logic symbol
Y
mna025
Fig 3.
Logic diagram
(one Schmitt-trigger)
74VHC_VHCT14_1
Product data sheet
A
001aac497
mna204
Fig 1.
1
Nexperia B.V. 2017. All rights reserved
2 of 16
74VHC14; 74VHCT14
Nexperia
5. Pinning information
5.1 Pinning
1
1A
terminal 1
index area
74VHC14
74VHCT14
14 VCC
74VHC14
74VHCT14
1Y
2
13 6A
1A
1
14 VCC
2A
3
12 6Y
1Y
2
13 6A
2Y
4
11 5A
2A
3
12 6Y
3A
5
2Y
4
11 5A
3Y
6
6
9
4A
7
8
4Y
8
3Y
GND
10 5Y
9
4Y
10 5Y
7
5
GND
3A
GND(1)
4A
001aak043
Transparent top view
001aak042
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as a
supply pin or input.
Fig 4.
Pin configuration SO14 and TSSOP14
Fig 5.
Pin configuration DHVQFN14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A
1
data input 1
1Y
2
data output 1
2A
3
data input 2
2Y
4
data output 2
3A
5
data input 3
3Y
6
data output 3
GND
7
ground (0 V)
4Y
8
data output 4
4A
9
data input 4
5Y
10
data output 5
5A
11
data input 5
6Y
12
data output 6
6A
13
data input 6
VCC
14
supply voltage
74VHC_VHCT14_1
Product data sheet
3 of 16
74VHC14; 74VHCT14
Nexperia
6. Functional description
Table 3.
Function table[1]
Input
Output
nA
nY
L
H
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
Min
Max
Unit
−0.5
+7.0
V
−0.5
+7.0
V
−20
mA
−20
+20
mA
−25
+25
mA
IIK
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
ICC
supply current
+75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
500
mW
total power dissipation
Ptot
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For TSSOP14 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
For DHVQFN14 packages: above 60 °C the value of Ptot derates linearly at 4.5 mW/K.
8. Recommended operating conditions
Table 5.
Symbol
Operating conditions
Parameter
Conditions
Min
Typ
Max
Unit
74VHC14
VCC
supply voltage
2.0
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
74VHCT14
74VHC_VHCT14_1
Product data sheet
4 of 16
74VHC14; 74VHCT14
Nexperia
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
74VHC14
VOH
VOL
HIGH-level
output voltage
LOW-level
output voltage
VI = VT+ or VT−
VI = VT+ or VT−
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
µA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2.0
µA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
4.4
4.5
4.4
4.4
V
3.94
3.80
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
74VHCT14
VOH
VOL
HIGH-level
output voltage
VI = VT+ or VT−
LOW-level
output voltage
VI = VT+ or VT−
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
µA
ICC
supply current
VCC = 5.5 V
2.0
µA
∆ICC
additional
supply current
per input pin;
VI = VCC − 2.1 V; other pins
at VCC or GND; IO = 0 A;
VCC = 4.5 V to 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
74VHC_VHCT14_1
Product data sheet
5 of 16
74VHC14; 74VHCT14
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
4.3
12.8
1.0
15.0
1.0
16.0
ns
CL = 50 pF
5.8
16.3
1.0
18.0
1.0
20.5
ns
3.2
8.6
1.0
10.0
1.0
11.0
ns
4.2
10.6
1.0
12.0
1.0
13.5
ns
10
pF
4.0
7.0
1.0
8.0
1.0
9.0
ns
5.4
8.0
1.0
9.0
1.0
10.0
ns
12
pF
74VHC14
tpd
[2]
propagation nA to nY; see Figure 6
delay
VCC = 3.0 V to 3.6 V
CL = 15 pF
CL = 50 pF
CPD
power
fi = 1 MHz; VI = GND to VCC
dissipation
capacitance
[3]
74VHCT14
tpd
[2]
delay
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
[3]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
74VHC_VHCT14_1
Product data sheet
6 of 16
74VHC14; 74VHCT14
Nexperia
11. Waveforms
VI
VM
nA input
VM
GND
t PHL
t PLH
VOH
VM
nY output
VM
VOL
mna344
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6.
Input to output propagation delays
Table 8.
Measurement points
Type
Input
Output
VM
VM
74VHC14
0.5VCC
0.5VCC
74VHCT14
1.5 V
0.5VCC
VI
negative
pulse
tW
90 %
VM
VM
10 %
GND
tr
tf
tr
VI
positive
pulse
GND
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VO
DUT
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
Fig 7.
Load circuitry for measuring switching times
74VHC_VHCT14_1
Product data sheet
7 of 16
74VHC14; 74VHCT14
Nexperia
Table 9.
Test data
Type
Input
Load
Test
VI
tr, tf
CL
74VHC14
VCC
≤ 3.0 ns
50 pF, 15 pF
tPLH, tPHL
74VHCT14
3.0 V
≤ 3.0 ns
50 pF, 15 pF
tPLH, tPHL
12. Transfer characteristics
Table 10. Transfer characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); see Figure 8 and Figure 9.
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
VCC = 3.0 V
2.2
2.2
2.2
V
VCC = 4.5 V
3.15
3.15
3.15
V
VCC = 5.5 V
3.85
3.85
3.85
V
74VHC14
VT+
VT−
VH
positive-going
threshold
voltage
negative-going VCC = 3.0 V
threshold
VCC = 4.5 V
voltage
VCC = 5.5 V
0.9
0.9
0.9
V
1.35
1.35
1.35
V
1.65
1.65
1.65
V
VCC = 3.0 V
0.3
1.2
0.3
1.2
0.25
1.2
V
VCC = 4.5 V
0.4
1.4
0.4
1.4
0.35
1.4
V
VCC = 5.5 V
0.5
1.6
0.5
1.6
0.45
1.6
V
VCC = 4.5 V
1.9
1.9
1.9
V
VCC = 5.5 V
2.1
2.1
2.1
V
negative-going VCC = 4.5 V
threshold
VCC = 5.5 V
voltage
0.5
0.5
0.5
V
0.6
0.6
0.6
V
hysteresis
voltage
VCC = 4.5 V
0.4
1.4
0.4
1.4
0.35
1.4
V
VCC = 5.5 V
0.4
1.5
0.4
1.5
0.35
1.5
V
hysteresis
voltage
74VHCT14
VT+
VT−
VH
positive-going
threshold
voltage
13. Transfer characteristics waveforms
VO
VT+
VI
VH
VT−
VI
VH
VT−
Fig 8.
VT+
VO
mna207
mna208
Fig 9.
Transfer characteristics definitions
74VHC_VHCT14_1
Product data sheet
8 of 16
74VHC14; 74VHCT14
Nexperia
mna411
1.5
mna412
5
I CC
I CC
(mA)
(mA)
4
1
3
2
0.5
1
2
VI (V)
1
a. VCC = 3.0 V
2
3
4 V (V) 5
I
b. VCC = 4.5 V
mna413
6
I CC
(mA)
4
2
4
VI (V)
6
c. VCC = 5.5 V
Fig 10. Typical 74VHC transfer characteristics
74VHC_VHCT14_1
Product data sheet
9 of 16
74VHC14; 74VHCT14
Nexperia
mna414
6
mna415
8
I CC
I CC
(mA)
(mA)
6
4
4
2
2
2
3
4 V (V) 5
I
a. VCC = 4.5 V
2
4
VI (V)
6
b. VCC = 5.5 V
Fig 11. Typical 74VHCT transfer characteristics
14. Application information
R
C
mna035
1
T
1
0.55 × RC
For 74VHC14: f = --- ≈ -------------------------
1
T
1
0.60 × RC
For 74VHCT14: f = --- ≈ -------------------------
Fig 12. Relaxation oscillator
74VHC_VHCT14_1
Product data sheet
10 of 16
74VHC14; 74VHCT14
Nexperia
15. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.028
0.024
0.01
0.01
0.004
0.028
0.012
inches 0.069
0.244
0.039
0.041
0.228
0.016
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 13. Package outline SOT108-1 (SO14)
74VHC_VHCT14_1
Product data sheet
11 of 16
74VHC14; 74VHCT14
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 14. Package outline SOT402-1 (TSSOP14)
74VHC_VHCT14_1
Product data sheet
12 of 16
74VHC14; 74VHCT14
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
0.5
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 15. Package outline SOT762-1 (DHVQFN14)
74VHC_VHCT14_1
Product data sheet
13 of 16
74VHC14; 74VHCT14
Nexperia
16. Abbreviations
Table 11.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
17. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74VHC_VHCT14_1
20090817
Product data sheet
74VHC_VHCT14_1
Product data sheet
14 of 16
74VHC14; 74VHCT14
Nexperia
18. Legal information
18.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
18.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
18.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
18.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
19. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74VHC_VHCT14_1
Product data sheet
15 of 16
Nexperia
74VHC14; 74VHCT14
20. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
16
17
18
18.1
18.2
18.3
18.4
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Transfer characteristics. . . . . . . . . . . . . . . . . . . 8
Transfer characteristics waveforms. . . . . . . . . 8
Application information. . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 17 August 2009
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74VHC14BQ,115 74VHC14D,118 74VHC14PW,118 74VHCT14BQ,115 74VHCT14D,118 74VHCT14PW,118
很抱歉,暂时无法提供与“74VHC14BQ,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+1.375723000+0.17850
- 6000+1.336536000+0.17341
- 9000+1.316899000+0.17086
- 15000+1.2951415000+0.16804
- 21000+1.2824321000+0.16639
- 30000+1.2702130000+0.16481
- 国内价格 香港价格
- 1+3.262991+0.42336
- 10+2.2489010+0.29179
- 25+2.0034325+0.25994
- 100+1.73013100+0.22448
- 250+1.59929250+0.20750
- 500+1.52064500+0.19730
- 1000+1.455821000+0.18889
