HEF40106BTT,118
HEF40106BTT,118
    NEXPERIA(安世)
    TSSOP14_5X4.4MM
    IC INVERTER 6CH 6-INP 14TSSOP
HEF40106BTT,118 数据手册
HEF40106B Hex inverting Schmitt trigger Rev. 8 — 10 December 2015 Product data sheet 1. General description The HEF40106B provides six inverting buffers. Each input has a Schmitt trigger circuit. The inverting buffer switches at different points for positive-going and negative-going signals. The difference between the positive voltage (VT+) and the negative voltage (VT) is defined as hysteresis voltage (VH). The HEF40106B may be used for enhanced noise immunity or to “square up” slowly changing waveforms. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits       Schmitt trigger input discrimination Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +125 C Complies with JEDEC standard JESD 13-B 3. Applications  Wave and pulse shapers  Astable multivibrators  Monostable multivibrators 4. Ordering information Table 1. Ordering information All types operate from 40 C to +125 C Type number Package Name Description Version HEF40106BT SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 HEF40106BTT TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 HEF40106B Nexperia Hex inverting Schmitt trigger 5. Functional diagram       $ < $ < $ < $ < $ < $ <       $ < PQD PQD Fig 1. Functional diagram Fig 2. Logic diagram (one inverting buffer) 6. Pinning information 6.1 Pinning +()% $   9'' <   $ $   < <   $ $   < <   $ 966   < DDO Fig 3. Pin configuration HEF40106B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 2 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger 6.2 Pin description Table 2. Pin description Symbol Pin Description 1A to 6A 1, 3, 5, 9, 11, 13 input 1Y to 6Y 2, 4, 6, 8, 10, 12 output VDD 14 supply voltage VSS 7 ground (0 V) 7. Functional description Table 3. Function table[1] Input Output nA nY L H H L [1] H = HIGH voltage level; L = LOW voltage level. 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O Conditions VI < 0.5 V or VI > VDD + 0.5 V Min Max 0.5 +18 V - 10 mA 0.5 VDD + 0.5 V - 10 mA input/output current - 10 mA IDD supply current - 50 mA Tstg storage temperature 65 +150 C Tamb ambient temperature 40 +125 C Ptot total power dissipation P power dissipation VO < 0.5 V or VO > VDD + 0.5 V Unit Tamb = 40 C to +125 C SO14 [1] - 500 mW TSSOP14 [2] - 500 mW - 100 mW per output [1] For SO14 packages: above Tamb = 70 C, Ptot derates linearly with 8 mW/K. [2] For TSSOP14 packages: above Tamb = 60 C, Ptot derates linearly with 5.5 mW/K. HEF40106B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 3 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VDD Conditions Min Max supply voltage 3 15 V VI input voltage 0 VDD V Tamb ambient temperature 40 +125 C in free air Unit 10. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD; unless otherwise specified. Symbol Parameter VOH VOL IOH IOL HIGH-level output voltage IO < 1 A VDD Tamb = 40 C Tamb = +25 C Tamb = +85 C Tamb = +125 C Unit Min Max Min Max Min Max Min Max 4.95 - 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 - 0.05 V 5V LOW-level output voltage IO < 1 A 15 V - 0.05 - 0.05 - 0.05 - 0.05 V HIGH-level output current VO = 2.5 V 5V - 1.7 - 1.4 - 1.1 - 1.1 mA VO = 4.6 V 5V - 0.64 - 0.5 - 0.36 - 0.36 mA VO = 9.5 V 10 V - 1.6 - 1.3 - 0.9 - 0.9 mA LOW-level output current II input leakage current IDD supply current CI Conditions input capacitance HEF40106B Product data sheet VO = 13.5 V 15 V - 4.2 - 3.4 - 2.4 - 2.4 mA VO = 0.4 V 5V 0.64 - 0.5 - 0.36 - 0.36 - mA VO = 0.5 V 10 V 1.6 - 1.3 - 0.9 - 0.9 - mA VO = 1.5 V 15 V 4.2 - 3.4 - 2.4 - 2.4 - mA 15 V - 0.1 - 0.1 - 1.0 - 1.0 A all valid input 5 V combinations; 10 V IO = 0 A 15 V - 0.25 - 0.25 - 7.5 - 7.5 A - 0.5 - 0.5 - 15.0 - 15.0 A - 1.0 - 1.0 - 30.0 - 30.0 A - - - 7.5 - - - - pF All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 4 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger 11. Dynamic characteristics Table 7. Dynamic characteristics Tamb = 25 C; CL = 50 pF; tr = tf  20 ns; wave forms see Figure 4; test circuit see Figure 5; unless otherwise specified. Symbol Parameter HIGH to LOW propagation delay tPHL tPLH tTHL [1] VDD Typ Max Unit 63 ns + (0.55 ns/pF)CL - 90 180 ns 10 V 29 ns + (0.23 ns/pF)CL - 35 70 ns 15 V 22 ns + (0.16 ns/pF)CL - 30 60 ns 58 ns + (0.55 ns/pF)CL - 75 150 ns 10 V 29 ns + (0.23 ns/pF)CL - 35 70 ns 15 V 22 ns + (0.16 ns/pF)CL - 30 60 ns 5V 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns nA or nB to nY 5 V nA or nB to nY 5 V HIGH to LOW output transition time nY to LOW nA or nB to HIGH Extrapolation formula[1] Min LOW to HIGH propagation delay LOW to HIGH output transition time tTLH Conditions 5V 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns Typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF). Table 8. Dynamic power dissipation VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol Parameter PD dynamic power dissipation VDD Typical formula where: 5V PD = 2300  fi + (fo  CL)  VDD (W) fi = input frequency in MHz; 10 V PD = 9000  fi + (fo  CL)  VDD2 (W) fo = output frequency in MHz; 15 V PD = 20000  fi + (fo  CL)  VDD2 (W) 2 CL = output load capacitance in pF; (fo  CL) = sum of the outputs; VDD = supply voltage in V. HEF40106B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 5 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger 12. Waveforms WU 9, WI  LQSXW 90 9  W3+/ 92+ W3/+  90 RXWSXW  92/ W7+/ W7/+ DDJ Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. tr, tf = input rise and fall times. Fig 4. Propagation delay and output transition time Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD 9'' * 9, 92 '87 &/ 57 DDJ Test data given in Table 10. Definitions for test circuit: DUT = Device Under Test. CL = load capacitance including jig and probe capacitance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig 5. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD  20 ns 50 pF HEF40106B Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 6 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger 13. Transfer characteristics Table 11. Transfer characteristics VSS = 0 V; see Figure 6 and Figure 7. Symbol Parameter Conditions VDD Tamb = 40 C to +85 C Min positive-going threshold voltage VT+ negative-going threshold voltage VT hysteresis voltage VH [1] Typ[1] Tamb = 40 C to +125 C Unit Max Min Max 5V 2.0 3.0 3.5 2.0 3.5 V 10 V 3.7 5.8 7.0 3.7 7.0 V 15 V 4.9 8.3 11.0 4.9 11.0 V 5V 1.5 2.2 3.0 1.5 3.0 V 10 V 3.0 4.5 6.3 3.0 6.3 V 15 V 4.0 6.5 10.1 4.0 10.1 V 5V 0.5 0.8 - 0.5 - V 10 V 0.7 1.3 - 0.7 - V 15 V 0.9 1.8 - 0.9 - V All typical values are at Tamb = 25 C. 92 9, 97 9+ 97 9, 9+ 97 Fig 6. 97 Transfer characteristic HEF40106B Product data sheet 92 DDJ DDJ Fig 7. Waveforms showing definition of VT+ and VT (between limits at 30 % and 70 %) and VH All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 7 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger DDO  DDO  ,' —$ ,' —$                      9, 9  9, 9 a. VDD = 5 V; Tamb = 25 C b. VDD = 10 V; Tamb = 25 C DDO  ,' —$            9, 9 c. Fig 8. VDD = 15 V; Tamb = 25 C Typical drain current as a function of input HEF40106B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 8 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger DDO  9, 9  93  91        9'' 9 Tamb = 25 C. Fig 9. Typical switching levels as a function of supply voltage 14. Application information Some examples of applications for the HEF40106B are: • Wave and pulse shapers • Astable multivibrators • Monostable multivibrators 5 &3 5 & & PQD  DDO Fig 10. Astable multivibrator Fig 11. Schmitt trigger driven via a high-impedance input If a Schmitt trigger is driven via a high-impedance (R > 1 k), then it is necessary to V DD – V SS C > ------------------------ ; otherwise oscillation can occur incorporate a capacitor C with a value of -----CP VH on the edges of a pulse. Cp is the external parasitic capacitance between inputs and output; the value depends on the circuit board layout. HEF40106B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 9 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger 15. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV        ș R R  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 12. Package outline SOT108-1 (SO14) HEF40106B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 10 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 13. Package outline SOT402-1 (TSSOP14) HEF40106B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 11 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger 16. Abbreviations Table 12. Abbreviations Acronym Description DUT Device Under Test 17. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF40106B v.8 20151210 Product data sheet - HEF40106B v.7 Modifications: HEF40106B v.7 Modifications: • Type number HEF40106BP (SOT27-1) removed. 20111121 • • Product data sheet - HEF40106B v.6 Legal pages updated. Changes in “General description” and “Features and benefits”. HEF40106B v.6 20110823 Product data sheet - HEF40106B v.5 HEF40106B v.5 20110511 Product data sheet - HEF40106B v.4 HEF40106B v.4 20101115 Product data sheet - HEF40106B_CNV v.3 HEF40106B_CNV v.3 19950101 Product specification - HEF40106B_CNV v.2 HEF40106B_CNV v.2 19950101 Product specification - - HEF40106B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 12 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger 18. Legal information 18.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 18.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 18.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. HEF40106B Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 13 of 15 HEF40106B Nexperia Hex inverting Schmitt trigger Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 18.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 19. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com HEF40106B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2015 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia HEF40106B Hex inverting Schmitt trigger 20. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 17 18 18.1 18.2 18.3 18.4 19 20 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Transfer characteristics . . . . . . . . . . . . . . . . . . 7 Application information. . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 December 2015 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: HEF40106BT,652 HEF40106BT,653 HEF40106BTT,112 HEF40106BTT,118
HEF40106BTT,118 价格&库存
很抱歉,暂时无法提供与“HEF40106BTT,118”相匹配的价格&库存,您可以联系我们找货
HEF40106BTT,118
  • 1+3.01800
  • 100+2.81680
  • 300+2.61560
  • 500+2.41440
  • 2000+2.31380
  • 5000+2.25344
HEF40106BTT,118
  • 1+4.123211+0.49720
  • 3+3.626553+0.43731
  • 10+3.2985710+0.39776
  • 25+2.9237325+0.35256
  • 100+2.53016100+0.30510
  • 500+1.93979500+0.23391
  • 2500+1.311932500+0.15820
库存:1942
HEF40106BTT,118
    • 5+1.74820
    • 50+1.38910
    • 150+1.23520
    • 500+1.04318
    • 2500+0.95764
    • 5000+0.90634
    库存:2826
