HEF4070B
Quad 2-input EXCLUSIVE-OR gate
Rev. 5 — 16 December 2015
Product data sheet
1. General description
The HEF4070B is a quad 2-input EXCLUSIVE-OR gate. The outputs are fully buffered for
the highest noise immunity and pattern insensitivity to output impedance.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS
(usually ground). Unused inputs must be connected to VDD, VSS, or another input.
2. Features and benefits
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Specified from 40 C to +85 C
Complies with JEDEC standard JESD 13-B
3. Applications
Logical comparators
Parity checkers and generators
4. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
HEF4070BT
40 C to +85 C
SO14
plastic small outline package; 14 leads; body width 3.9 mm SOT108-1
Version
HEF4070B
Nexperia
5. Functional diagram
DDD
Fig 1.
Functional diagram
Fig 2.
PQD
Logic diagram (one gate)
6. Pinning information
6.1 Pinning
9''
966
DDD
Fig 3.
Pin configuration
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A, 2A, 3A, 4A
1, 5, 8, 12
data input
1B, 2B, 3B, 4B
2, 6, 9, 13
data input
1Y, 2Y, 3Y, 4Y
3, 4, 10, 11
data output
VSS
7
ground (0 V)
VDD
14
supply voltage
HEF4070B
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 11
HEF4070B
Nexperia
7. Functional description
Table 3.
Functional table[1]
Input
Output
nA
nB
nY
L
L
L
L
H
H
H
L
H
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0.5 V or VI > VDD + 0.5 V
Min
Max
0.5
+18
V
10
mA
0.5
VO < 0.5 V or VO > VDD + 0.5 V
Unit
VDD + 0.5 V
10
mA
II/O
input/output current
10
mA
IDD
supply current
50
mA
Tstg
storage temperature
65
+150
C
Tamb
ambient temperature
40
+85
C
Ptot
total power dissipation
500
mW
100
mW
Tamb = 40 C to +85 C
SO14
P
[1]
power dissipation
per output
[1]
For SO14 packages: above Tamb = 70 C, Ptot derates linearly with 8 mW/K.
9. Recommended operating conditions
Table 5.
Symbol
Parameter
VDD
supply voltage
Conditions
Min
Max
3
15
Unit
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
40
+85
C
t/V
input transition rise and fall rate
VDD = 5 V
3.75
s/V
VDD = 10 V
0.5
s/V
VDD = 15 V
0.08
s/V
HEF4070B
Product data sheet
3 of 11
HEF4070B
Nexperia
10. Static characteristics
Table 6.
VSS = 0 V; VI = VSS or VDD; unless otherwise specified
Symbol Parameter
Conditions
VDD
Tamb = 40 C Tamb = +25 C Tamb = +85 C Unit
Min
VIH
VIL
VOH
VOL
IOH
IOL
HIGH-level
input voltage
LOW-level
input voltage
IO < 1 A
HIGH-level
output voltage
IO < 1 A
LOW-level
output voltage
IO < 1 A
HIGH-level
output current
LOW-level
output current
II
input leakage
current
IDD
supply current
CI
IO < 1 A
input
capacitance
HEF4070B
Product data sheet
Max
Min
Max
Min
Max
5V
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
V
15 V
0.05
0.05
0.05
V
mA
VO = 2.5 V
5V
1.7
1.4
1.1
VO = 4.6 V
5V
0.52
0.44
0.36 mA
VO = 9.5 V
10 V
1.3
1.1
0.9
mA
VO = 13.5 V
15 V
3.6
3.0
2.4
mA
VO = 0.4 V
5V
0.52
0.44
0.36
mA
VO = 0.5 V
10 V
1.3
1.1
0.9
mA
VO = 1.5 V
15 V
3.6
3.0
2.4
mA
15 V
0.3
0.3
1.0
A
5V
1.0
1.0
7.5
A
10 V
2.0
2.0
15.0
A
15 V
4.0
4.0
30.0
A
7.5
pF
all valid input combinations;
IO = 0 A
4 of 11
HEF4070B
Nexperia
11. Dynamic characteristics
Table 7.
Tamb = 25 C; waveforms see Figure 4; test circuit see Figure 5; unless otherwise specified.[1]
Symbol Parameter
HIGH to LOW
propagation delay
tPHL
LOW to HIGH
propagation delay
tPLH
Conditions
VDD
Extrapolation formula
Min
Typ
Max
Unit
nA or nB to nY 5 V
58 ns + (0.55 ns/pF)CL
85
175
ns
10 V
24 ns + (0.23 ns/pF)CL
35
75
ns
15 V
21 ns + (0.16 ns/pF)CL
30
55
ns
43 ns + (0.55 ns/pF)CL
75
150
ns
19 ns + (0.23 ns/pF)CL
30
65
ns
nA or nB to nY 5 V
10 V
17 ns + (0.16 ns/pF)CL
25
50
ns
10 ns + (1.00 ns/pF)CL
60
120
ns
10 V
9 ns + (0.42 ns/pF)CL
30
60
ns
15 V
6 ns + (0.28 ns/pF)CL
ns
15 V
transition time
tt
5V
[2]
[1]
The typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF).
[2]
tt is the same as tTHL and tTLH.
Table 8.
Dynamic power dissipation
VSS = 0 V; tr = tf 20 ns; Tamb = 25 C.
Symbol Parameter
PD
dynamic power dissipation
VDD
Typical formula
where:
5V
PD = 1100 fi + (fo CL) VDD (W)
2
fi = input frequency in MHz;
10 V PD = 4900 fi + (fo CL) VDD (W) fo = output frequency in MHz;
15 V PD = 14400 fi + (fo CL) VDD2 (W) CL = output load capacitance in pF;
2
(fo CL) = sum of the outputs;
VDD = supply voltage in V.
HEF4070B
Product data sheet
5 of 11
HEF4070B
Nexperia
12. Waveforms
WU
9,
WI
90
Q$Q%LQSXW
9
W3+/
92+
W3/+
90
Q
很抱歉,暂时无法提供与“HEF4070BT-Q100J”相匹配的价格&库存,您可以联系我们找货
