HEF4073B
Triple 3-input AND gate
Rev. 4 — 6 October 2017
1
Product data sheet
General description
The HEF4073B is a triple 3-input AND gate. The outputs are fully buffered for highest
noise immunity and pattern insensitivity to output impedance variations.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to
VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input.
2
Features and benefits
3
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Inputs and outputs are protected against electrostatic effects
Specified from -40 °C to +85 °C
Complies with JEDEC standard JESD 13-B
Ordering information
Table 1. Ordering information
Type number
Package
HEF4073BT
4
Temperature range Name
Description
Version
-40 °C to +85 °C
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
SO14
Functional diagram
1A
1B
1C
2A
2B
2C
3A
3B
3C
3
4
6
5
1Y
1
2
9
8
2Y
11
12
13
10
3Y
aaa-027562
Figure 1. Functional diagram
nA
nB
nC
nY
aaa-027563
Figure 2. Logic diagram (one gate)
HEF4073B
Nexperia
5
Pinning information
5.1 Pinning
HEF4073B
2A
1
14 VDD
2B
2
13 3C
1A
3
12 3B
1B
4
11 3A
1C
5
10 3Y
1Y
6
9
2Y
VSS
7
8
2C
aaa-027564
Figure 3. Pin configuration SO14
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
1A, 2A, 3A
3, 1, 11
data input
1B, 2B, 3B
4, 2, 12
data input
1C, 2C, 3C
5, 8, 13
data input
1Y, 2Y, 3Y
6, 9, 10
data output
VSS
7
ground (0 V)
VDD
14
supply voltage
6
Functional description
Table 3. Function selection
[1]
Input
Output
nA
nB
nC
nY
L
X
X
L
X
L
X
L
X
X
L
L
H
H
H
H
[1] H = HIGH voltage level;
L = LOW voltage level;
X = don’t care
HEF4073B
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 11
HEF4073B
Nexperia
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
II/O
Conditions
Min
Max
Unit
-0.5
+18
V
±10
mA
-0.5
VDD + 0.5
±10
mA
input/output current
±10
mA
IDD
supply current
50
mA
Tstg
storage temperature
-65
+150
°C
Tamb
ambient temperature
-40
+85
°C
500
mW
100
mW
Min
Max
Unit
VI < -0.5 V or VI > VDD + 0.5 V
VO < -0.5 V or VO > VDD + 0.5 V
Ptot
total power dissipation
Tamb = -40 °C to + 85 °C
P
power dissipation
per output
[1]
V
[1] For SO14 packages: above Tamb = 70 °C, Ptot derates linearly with 8 mW/K.
8
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
VDD
supply voltage
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
-40
+85
°C
Δt/ΔV
input transition rise and fall rate
VDD = 5 V
3.75
ns/V
VDD = 10 V
0.5
ns/V
VDD = 15 V
0.08
ns/V
HEF4073B
Product data sheet
Conditions
3 / 11
HEF4073B
Nexperia
9
Static characteristics
Table 6. Static characteristics
VSS = 0 V; VI = VSS or VDD; unless otherwise specified.
Symbol
VIH
VIL
VOH
VOL
IOH
IOL
Parameter
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
HIGH-level output
current
LOW-level output
current
II
input leakage
current
IDD
supply current
CI
input capacitance
HEF4073B
Product data sheet
Conditions
Tamb = -40 °C
Tamb = +25 °C
Tamb = +85 °C
Min
Max
Min
Max
Min
Max
5V
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
V
15 V
0.05
0.05
0.05
V
VO = 2.5 V
5V
-1.7
-1.4
-1.1
mA
VO = 4.6 V
5V
-0.52
-0.44
-0.36
mA
VO = 9.5 V
10 V
-1.3
-1.1
-0.9
mA
VO = 13.5 V
15 V
-3.6
-3.0
-2.4
mA
VO = 0.4 V
5V
0.52
0.44
0.36
mA
VO = 0.5 V
10 V
1.3
1.1
0.9
mA
VO = 1.5 V
15 V
3.6
3.0
2.4
mA
15 V
±0.3
±0.3
±1.0
μA
5V
1.0
1.0
7.5
μA
10 V
2.0
2.0
15.0
μA
15 V
4.0
4.0
30.0
μA
7.5
pF
|IO| < 1 μA
|IO| < 1 μA
|IO| < 1 μA
|IO| < 1 μA
all valid input
combinations;
IO = 0 A
VDD
Unit
4 / 11
HEF4073B
Nexperia
10 Dynamic characteristics
Table 7. Dynamic characteristics
VSS = 0 V; Tamb = 25 °C; for test circuit see Figure 5.
Symbol
Parameter
Conditions
tPHL
HIGH to LOW
propagation delay
nA, nB, nC to nY; see Figure 4
tPLH
LOW to HIGH
propagation delay
Extrapolation
[1]
formula
Min
Typ
Max
Unit
VDD = 5 V
23 + 0.55 × CL
55
110
ns
VDD = 10 V
14 + 0.23 × CL
25
50
ns
VDD = 15V
12 + 0.16 × CL
ns
VDD = 5 V
13 + 0.55 × CL
45
90
ns
VDD = 10 V
9 + 0.23 × CL
ns
7 + 0.16 × CL
15
30
ns
10 + 1.0 × CL
60
120
ns
9 + 0.42 × CL
30
60
ns
6 + 0.28 × CL
ns
VDD = 15V
tt
output transition time
nY; see Figure 4
[2]
[1] The typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF).
[2] tt is the same as tTHL and tTLH.
Table 8. Dynamic power dissipation
VSS = 0 V; Tamb = 25 °C.
Symbol
PD
Parameter
dynamic power dissipation
VDD
5V
Typical formula
PD = 600 × fi + Σ(fo × CL) ×
where:
2
VDD
10 V PD = 2700 × fi + Σ(fo × CL) ×
15 V PD = 8400 × fi + Σ(fo × CL) ×
HEF4073B
Product data sheet
fi = input frequency in MHz;
(μW) fo = output frequency in MHz;
CL = output load capacitance in pF;
(μW)
Σ(fo × CL) = sum of the outputs;
VDD = supply voltage in V.
(μW)
2
VDD
2
VDD
5 / 11
HEF4073B
Nexperia
10.1 Waveforms and test circuit
tr
VI
tf
90 %
VM
nA, nB, nC input
10 %
0V
tPLH
VOH
tPHL
90 %
VM
nY output
10 %
VOL
tTLH
tTHL
aaa-027565
Measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output load.
Figure 4. Input to output propagation delay and output transition times
Table 9. Measurement points
Supply voltage
Input
Output
VDD
VM
VM
5 V to 15 V
0.5VDD
0.5VDD
VDD
G
VI
VO
DUT
CL
RT
001aag182
Test data is given in Table 10.
Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
Figure 5. Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VDD
VI
tr, tf
CL
5 V to 15 V
VSS or VDD
≤ 20 ns
50 pF
HEF4073B
Product data sheet
Load
6 / 11
HEF4073B
Nexperia
11 Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
A2
Q
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Figure 6. Package outline SOT108-1 (SO14)
HEF4073B
Product data sheet
7 / 11
HEF4073B
Nexperia
12 Abbreviations
Table 11. Abbreviations
Acronym
Description
DUT
Device Under Test
13 Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
HEF4073B v.4
20171006
Product data sheet
HEF4073B_CNV v.3
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
• Type numbers HEF4073BP and HEF4073BD removed.
HEF4073B_CNV v.3
19950101
HEF4073B
Product data sheet
Product specification
8 / 11
HEF4073B
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
HEF4073B
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
9 / 11
HEF4073B
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
HEF4073B
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
10 / 11
HEF4073B
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Functional diagram ............................................. 1
Pinning information ............................................ 2
Pinning ............................................................... 2
Pin description ................................................... 2
Functional description ........................................2
Limiting values .................................................... 3
Recommended operating conditions ................ 3
Static characteristics .......................................... 4
Dynamic characteristics .....................................5
Waveforms and test circuit ................................ 6
Package outline ...................................................7
Abbreviations ...................................................... 8
Revision history .................................................. 8
Legal information ................................................ 9
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 6 October 2017
Document identifier: HEF4073B
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
HEF4073BP,652 HEF4073BT,652 HEF4073BT,653
