74LVC1G58-Q100
Low-power configurable multiple function gate
Rev. 2 — 9 December 2016
Product data sheet
1. General description
The 74LVC1G58-Q100 provides configurable multiple functions. The output state is
determined by eight patterns of 3-bit input. The user can choose the logic functions AND,
OR, NAND, NOR, XOR, inverter and buffer. All inputs can be connected to VCC or GND.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this
device in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
All inputs (A, B and C) are Schmitt trigger inputs. They are capable of transforming slowly
changing input signals into sharply defined, jitter-free output signals.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V).
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
74LVC1G58-Q100
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
74LVC1G58GW-Q100 40 C to +125 C
74LVC1G58GV-Q100
40 C to +125 C
Description
Version
SC-88
plastic surface-mounted package; 6 leads
SOT363
TSOP6
plastic surface-mounted package (TSOP6); 6 leads SOT457
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G58GW-Q100
YK
74LVC1G58GV-Q100
V58
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Fig 1.
DDE
Logic symbol
6. Pinning information
6.1 Pinning
/9&*4
*1'
9&&
DDD
Fig 2.
Pin configuration SOT363 and SOT457
74LVC1G58_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 17
74LVC1G58-Q100
Nexperia
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
B
1
data input
GND
2
ground (0 V)
A
3
data input
Y
4
data output
VCC
5
supply voltage
C
6
data input
7. Functional description
Table 4.
Function table[1]
Inputs
Output
C
B
A
Y
L
L
L
L
L
L
H
H
L
H
L
L
L
H
H
H
H
L
L
H
H
L
H
H
H
H
L
L
H
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level
7.1 Logic configurations
Table 5.
Function selection table
Logic function
Figure
2-input NAND
see Figure 3
2-input NAND with both inputs inverted
see Figure 6
2-input AND with inverted input
see Figure 4 and 5
2-input NOR with inverted input
see Figure 4 and 5
2-input OR
see Figure 6
2-input OR with both inputs inverted
see Figure 3
2-input XOR
see Figure 7
Buffer
see Figure 8
Inverter
see Figure 9
74LVC1G58_Q100
Product data sheet
3 of 17
74LVC1G58-Q100
Nexperia
9&&
9&&
DDE
DDE
Fig 3.
2-input NAND gate or 2-input OR with both
inputs inverted
Fig 4.
2-input AND gate with inverted B input or
2-input NOR gate with inverted C input
9&&
9&&
DDE
DDE
Fig 5.
2-input AND gate with inverted C input or
2-input NOR gate with inverted A input
Fig 6.
2-input OR gate or 2-input NAND gate with
9&&
9&&
DDE
Fig 7.
DDE
2-input XOR gate
Fig 8.
Buffer
9&&
DDE
Fig 9.
Inverter
74LVC1G58_Q100
Product data sheet
4 of 17
74LVC1G58-Q100
Nexperia
8. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
mA
50
mA
Active mode
[1][2]
0.5
+6.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
VO > VCC or VO < 0 V
IO
output current
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
[1]
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
9. Recommended operating conditions
Table 7.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
Conditions
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
C
ambient temperature
74LVC1G58_Q100
Product data sheet
5 of 17
74LVC1G58-Q100
Nexperia
10. Static characteristics
Table 8.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Typ[1]
Max
Unit
IO = 100 A; VCC = 1.65 V to 5.5 V
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
V
IO = 8 mA; VCC = 2.3 V
0.3
V
Conditions
Tamb = 40 C to +85 C
VOL
VOH
LOW-level output voltage
VI = VT+ or VT
IO = 12 mA; VCC = 2.7 V
0.4
V
IO = 24 mA; VCC = 3.0 V
0.55
V
IO = 32 mA; VCC = 4.5 V
0.55
V
HIGH-level output voltage VI = VT+ or VT
VCC 0.1
V
1.2
V
1.9
V
2.2
V
2.3
V
3.8
V
0.1
1
A
II
input leakage current
VI = 5.5 V or GND; VCC = 0 V to 5.5 V
IOFF
power-off leakage current VI or VO = 5.5 V; VCC = 0 V
0.1
2
A
ICC
supply current
VI = 5.5 V or GND;
VCC = 1.65 V to 5.5 V; IO = 0 A
0.1
4
A
ICC
additional supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 2.3 V to 5.5 V
5
500
A
CI
input capacitance
2.5
pF
0.1
V
0.7
V
0.45
V
0.6
V
0.8
V
0.8
V
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
VOL
VOH
VI = VT+ or VT
74LVC1G58_Q100
Product data sheet
6 of 17
74LVC1G58-Q100
Nexperia
Table 8.
Static characteristics …continued
Min
Typ[1]
Max
1
A
2
A
ICC
supply current
VI = 5.5 V or GND;
4
A
ICC
500
A
Symbol
Parameter
Conditions
II
IOFF
[1]
Unit
Typical values are measured at maximum VCC and Tamb = 25 C.
11. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 11.
Symbol Parameter
tpd
propagation delay
40 C to +85 C
Conditions
A, B, C to Y; see Figure 10
[1]
Max
Min
Max
1.0
6.0
14.4
1.0
18.0
ns
VCC = 2.3 V to 2.7 V
0.5
3.5
8.3
0.5
10.4
ns
VCC = 2.7 V
0.5
4.2
8.5
0.5
10.6
ns
VCC = 3.0 V to 3.6 V
0.5
3.8
6.3
0.5
7.9
ns
0.5
3.0
5.1
0.5
6.4
ns
pF
VCC = 4.5 V to 5.5 V
power dissipation
capacitance
Typ[1]
[2]
VCC = 1.65 V to 1.95 V
CPD
40 C to +125 C Unit
Min
VCC = 3.3 V; VI = GND to VCC
[3]
Typical values are measured at nominal VCC and at Tamb = 25 C.
[2]
tpd is the same as tPLH and tPHL
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74LVC1G58_Q100
Product data sheet
7 of 17
74LVC1G58-Q100
Nexperia
12. Waveforms
9,
$%&LQSXW
90
90
*1'
W 3+/
W 3/+
92+
90
很抱歉,暂时无法提供与“74LVC1G58GW-Q100H”相匹配的价格&库存,您可以联系我们找货
