74LVT04-Q100
3.3 V Hex inverter
Rev. 1 — 26 May 2014
Product data sheet
1. General description
The 74LVT04-Q100 is a high-performance product designed for VCC operation at 3.3 V.
The 74LVT04-Q100 provides six inverting buffers.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 3) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 3)
Specified from 40 C to +85 C
TTL input and output switching levels
Latch-up protection
JESD78 class II exceeds 500 mA
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74LVT04D-Q100
40 C to +85 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
74LVT04DB-Q100
40 C to +85 C
SSOP14
plastic shrink small outline package; 14 leads; body SOT337-1
width 5.3 mm
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
74LVT04PW-Q100 40 C to +85 C
SOT402-1
74LVT04-Q100
Nexperia
3.3 V Hex inverter
4. Functional diagram
PQD
Logic symbol
Fig 1.
Y
A
PQD
Fig 2.
mna341
IEC logic symbol
Fig 3.
Logic diagram for one gate
5. Pinning information
5.1 Pinning
/974
9&&
*1'
DDD
Fig 4.
Pin configuration SOT108-1 (SO14), SOT337-1 (SSOP14) and SOT402-1 (TSSOP14)
74LVT04_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
74LVT04-Q100
Nexperia
3.3 V Hex inverter
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
nA
1, 3, 5, 9, 11, 13
data input
nY
2, 4, 6, 8, 10, 12
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Output
nA
nY
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+4.6
V
0.5
+7.0
V
input voltage
[1]
VO
output voltage
output in OFF-state or HIGH-state
[1]
0.5
+7.0
V
IIK
input clamping current
VI < 0 V
50
mA
IOK
output clamping current
VO < 0 V
50
mA
IO
output current
output in LOW-state
64
mA
output in HIGH-state
32
mA
Tstg
storage temperature
65
+150
C
Tj
junction temperature
[2]
150
C
[3]
500
mW
VI
total power dissipation
Ptot
Tamb = 40 °C to +85 °C
[1]
The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
[2]
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
[3]
For SO14 packages: above 70 C derate linearly with 8 mW/K.
For SSOP14 and TSSOP14 packages: above 60 C derate linearly with 5.5 mW/K.
74LVT04_Q100
Product data sheet
3 of 13
74LVT04-Q100
Nexperia
3.3 V Hex inverter
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
2.7
3.6
V
VI
input voltage
V
VIH
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
IOH
HIGH-level output current
mA
IOL
LOW-level output current
32
mA
Tamb
ambient temperature
in free air
40
+85
C
t/V
input transition rise and fall rate
outputs enabled
10
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
40 C to +85 C
Conditions
Min
VCC = 2.7 V; IIK = 18 mA
Max
1.2
V
VCC 0.2
V
VCC = 2.7 V; IOH = 6 mA
2.4
V
VCC = 3.0 V; IOH = 20 mA
2.0
V
VCC = 2.7 V; IOL = 100 A
0.2
V
VCC = 2.7 V; IOL = 24 mA
0.5
V
VCC = 3.0 V; IOL = 32 mA
0.5
V
VCC = 0 V or 3.6 V; VI = 5.5 V
10
A
input clamping voltage
VOH
HIGH-level output voltage VCC = 2.7 V to 3.6 V; IOH = 100 A
LOW-level output voltage
Unit
VIK
VOL
Typ[1]
II
input leakage current
±1
A
IOFF
power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V
±100
A
ICCH
HIGH-level supply current VCC = 3.6 V; outputs HIGH;
VI = GND or VCC, IO = 0 V
0.02
mA
ICCL
LOW-level supply current
VCC = 3.6 V; outputs LOW;
VI = GND or VCC; IO = 0 V
1.5
3
mA
ICC
additional supply current
per input pin
VCC = 3 V to 3.6 V;
one input at VCC 0.6 V;
other inputs at VCC or GND
0.2
A
CI
input capacitance
VI = 3 V or 0 V
3
pF
VCC = 3.6 V; VI = VCC or GND
[2]
[1]
All typical values are at VCC = 3.3 V and Tamb = 25C.
[2]
This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
74LVT04_Q100
Product data sheet
4 of 13
74LVT04-Q100
Nexperia
3.3 V Hex inverter
10. Dynamic characteristics
Table 7.
GND = 0 V; for test circuit, see Figure 6.
Symbol Parameter
40 C to +85 C
Conditions
LOW to HIGH propagation nA to nY; see Figure 5
delay
VCC = 2.7 V
tPLH
VCC = 3.3 V 0.3 V
HIGH to LOW propagation nA to nY; see Figure 5
delay
VCC = 2.7 V
tPHL
VCC = 3.3 V 0.3 V
[1]
Unit
Min
Typ[1]
Max
4.7
ns
1.0
2.6
3.9
ns
3.2
ns
1.0
2.5
3.5
ns
11. Waveforms
9,
90
Q$LQSXW
90
*1'
W 3+/
W 3/+
92+
90
Q
很抱歉,暂时无法提供与“74LVT04DB-Q100J”相匹配的价格&库存,您可以联系我们找货
