74LVC1G38GW-Q100H
74LVC1G38GW-Q100H
    NEXPERIA(安世)
    TSSOP5_2X1.25MM
    2-input与非门;漏极开路
74LVC1G38GW-Q100H 数据手册
74LVC1G38-Q100 2-input NAND gate; open drain Rev. 2 — 9 December 2016 Product data sheet 1. General description The 74LVC1G38-Q100 provides a 2-input NAND function. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device as translator in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 1.65 V to 5.5 V  5 V tolerant outputs for interfacing with 5 V logic  High noise immunity  Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V).  24 mA output drive (VCC = 3.0 V)  CMOS low power consumption  Open drain outputs  Latch-up performance exceeds 250 mA  Direct interface with TTL levels  Inputs accept voltages up to 5 V  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 74LVC1G38-Q100 Nexperia 2-input NAND gate; open drain 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G38GW-Q100 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G38GV-Q100 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G38GW-Q100 YB 74LVC1G38GV-Q100 YB [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram <  $  <   %   Logic symbol % *1' DDE DDE Fig 1. $ Fig 2. DDE IEC logic symbol Fig 3. Logic diagram 6. Pinning information 6.1 Pinning /9&*4 $  %  *1'   9&&  < DDD Fig 4. Pin configuration for SOT353-1 and SOT753 74LVC1G38_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 13 74LVC1G38-Q100 Nexperia 2-input NAND gate; open drain 6.2 Pin description Table 3. Pin description Symbol Pin Description A 1 data input B 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage 7. Functional description Table 4. Function table[1] Input Output A B L L Z L H Z H L Z H H L [1] Y H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF state. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions Min Max Unit 0.5 +6.5 V 50 - [1] 0.5 +6.5 VI < 0 V mA VI input voltage IOK output clamping current VO > VCC or VO < 0 V - 50 mA VO output voltage Active mode [1][2] 0.5 +6.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA IO output current ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 300 mW total power dissipation Ptot VO = 0 V to VCC V Tamb = 40 C to +125 C [3] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 74LVC1G38_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 13 74LVC1G38-Q100 Nexperia 2-input NAND gate; open drain 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - 5.5 V Disable mode; VCC = 1.65 V to 5.5 V 0 - 5.5 V Power-down mode; VCC = 0 V 0 - 5.5 V 40 - +125 C - - 20 ns/V - - 10 ns/V Min Typ Tamb ambient temperature t/V input transition rise and VCC = 1.65 V to 2.7 V fall rate VCC = 2.7 V to 5.5 V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 VIH VIL VOL Conditions Max Unit C[1] HIGH-level input voltage LOW-level input voltage LOW-level output voltage VCC = 1.65 V to 1.95 V 0.65VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7VCC - - V VCC = 1.65 V to 1.95 V - - 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC V VI = VIH or VIL - - - IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0.1 1 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - 0.1 2 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - 0.1 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - 0.1 4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V; per pin - 5 500 A CI input capacitance - 2.5 - pF 74LVC1G38_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 13 74LVC1G38-Q100 Nexperia 2-input NAND gate; open drain Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit 0.65VCC - - V Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL LOW-level output voltage VOL VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7VCC - - V VCC = 1.65 V to 1.95 V - - 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC V VI = VIH or VIL - - - IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 1 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - 2 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - - 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - - 4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V; per pin - - 500 A [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 C. 74LVC1G38_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 13 74LVC1G38-Q100 Nexperia 2-input NAND gate; open drain 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter propagation delay tpd power dissipation capacitance CPD 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max VCC = 1.65 V to 1.95 V 1.0 3.0 10.0 1.0 12.5 ns VCC = 2.3 V to 2.7 V 0.5 1.8 6.0 0.5 7.5 ns VCC = 2.7 V 0.5 2.5 5.0 0.5 6.5 ns VCC = 3.0 V to 3.6 V 0.5 2.3 4.5 0.5 5.7 ns VCC = 4.5 V to 5.5 V 0.5 1.5 3.9 0.5 4.9 ns - 6 - - - pF A, B to Y; see Figure 5 [2] [3] VCC = 3.3 V; VI = GND to VCC [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPZL and tPLZ. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 12. Waveform and test circuit 9, $%LQSXW 90 *1' W 3/= W 3=/ 9&&
74LVC1G38GW-Q100H 价格&库存
很抱歉,暂时无法提供与“74LVC1G38GW-Q100H”相匹配的价格&库存,您可以联系我们找货
74LVC1G38GW-Q100H
  • 3000+0.570333000+0.07387
  • 6000+0.551416000+0.07142
  • 9000+0.541949000+0.07019
  • 15000+0.5314415000+0.06883
  • 21000+0.5253121000+0.06804
  • 30000+0.5194030000+0.06727
74LVC1G38GW-Q100H
    • 5+0.98216
    • 50+0.96012
    • 150+0.94544
    库存:92
    74LVC1G38GW-Q100H
    • 1+1.506331+0.19509
    • 10+0.9892710+0.12812
    • 25+0.8730325+0.11307
    • 100+0.74120100+0.09600
    • 250+0.67813250+0.08783
    • 500+0.64033500+0.08293
    • 1000+0.608971000+0.07887
