74AHCT123ABQ-Q100X
74AHCT123ABQ-Q100X
    NEXPERIA(安世)
    DHVQFN16_2.5X3.5MM_EP
    带复位的双可触发单稳多谐振荡器
74AHCT123ABQ-Q100X 数据手册
74AHC123A-Q100; 74AHCT123A-Q100 Dual retriggerable monostable multivibrator with reset Rev. 1 — 23 May 2013 Product data sheet 1. General description The 74AHC123A-Q100; 74AHCT123A-Q100 are high-speed Si-gate CMOS devices and are pin compatible with Low-power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard no. 7A. The 74AHC123A-Q100; 74AHCT123A-Q100 are dual retriggerable monostable multivibrators with output pulse width control by three methods. The selection of an external resistor (Rext) and capacitor (Cext) program the basic pulse time. The external resistor and capacitor are normally connected as shown in Figure 11. Once triggered, the basic output pulse width may be extended by retriggering the gated active LOW-going edge input (nA) or the active HIGH-going edge input (nB). By repeating this process, the output pulse period (nQ = HIGH, nQ = LOW) can be made as long as desired. Alternatively an output delay can be terminated at any time by a LOW-going edge on input nRD, which also inhibits the triggering. An internal connection from nRD to the input gate makes it possible to trigger the circuit by a positive-going signal at input nRD as shown in Table 3. Figure 8 and Figure 9 illustrate pulse control by retriggering and early reset. The values of the external timing components Rext and Cext, determine the basic output pulse width. When Cext  10 nF, the typical output pulse width is defined as: tW = Rext  Cext where tW = pulse width in ns; Rext = external resistor in k; Cext = external capacitor in pF. Schmitt-trigger action at all inputs makes the circuit highly tolerant to slower input rise and fall times. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  All inputs have a Schmitt-trigger action  Inputs accept voltages higher than VCC  DC triggered from active HIGH or active LOW inputs  Retriggerable for very long pulses up to 100 % duty factor  Direct reset terminates output pulse  For 74AHC123A-Q100 only: operates with CMOS input levels  For 74AHCT123A-Q100 only: operates with TTL input levels  ESD protection: 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Ordering information Table 1. Ordering information Type number 74AHC123AD-Q100 Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal SOT763-1 enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm 74AHCT123AD-Q100 74AHC123APW-Q100 74AHCT123APW-Q100 74AHC123ABQ-Q100 74AHCT123ABQ-Q100 4. Functional diagram 14 15 1 14 1CEXT 6 2CEXT CX RCX 13 & 2 15 1REXT/CEXT 7 2REXT/CEXT 4 3 R S Q 1A 1 2A 9 1B 2 2B 10 13 1Q 5 2Q 6 T 7 Q 4 1Q 9 12 2Q CX RCX 5 & 10 RD 1RD 3 12 2RD 11 11 R 001aae521 Fig 1. Logic symbol 74AHC_AHCT123A_Q100 Product data sheet 001aae522 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 2 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset 14 15 S 1A 1B 1RD 13 Q 1 4 Q 2 2RD 1Q 1Q RD 3 6 S 2B 1REXT/CEXT T 7 2A 1CEXT 5 Q 9 2CEXT 2REXT/CEXT 2Q T 12 Q 10 2Q RD 11 aaa-000650 Fig 3. Functional diagram 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 3 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset nREXT/CEXT VCC Q RD R Q R CL VCC CL VCC R CL A B CL CL 001aae524 R For minimum noise generation, ground pins 6 (2CEXT) and 14 (1CEXT) externally to pin 8 (GND). Fig 4. Functional diagram 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 4 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset 5. Pinning information 5.1 Pinning  $ WHUPLQDO LQGH[DUHD $+&$4 $+&7$4  5(;7&(;7   &(;7  4   5(;7&(;7 4    &(;7 4  4   4 &(;7  4   4    5' 5(;7&(;7 &(;7 5(;7&(;7   % *1'   $  4 *1'   5'  %  % 5'   9&&  $  % 5' *1' $  9&& $+&$4 $+&7$4 DDD 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 5. Pin configuration SO16, TSSOP16 Fig 6. Pin configuration DHVQFN16 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A 1 negative-edge triggered input 1 1B 2 positive-edge triggered input 1 1RD 3 direct reset LOW and positive-edge triggered input 1 1Q 4 active LOW output 1 2Q 5 active HIGH output 2 2CEXT 6 external capacitor connection 2 2REXT/CEXT 7 external resistor and capacitor connection 2 GND 8 ground (0 V) 2A 9 negative-edge triggered input 2 2B 10 positive-edge triggered input 2 2RD 11 direct reset LOW and positive-edge triggered input 2 2Q 12 active LOW output 2 1Q 13 active HIGH output 1 1CEXT 14 external capacitor connection 1 1REXT/CEXT 15 external resistor and capacitor connection 1 VCC 16 supply voltage 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 5 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset 6. Functional description Table 3. Function table[1] Input Output nRD nA nB nQ nQ L X X L H H[2] H[2] X H X L[2] X X L L[2] H L  H  H  L H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care;  = LOW-to-HIGH transition;  = HIGH-to-LOW transition; = one HIGH level output pulse; = one LOW level output pulse. [2] If the monostable multivibrator was triggered before this condition was established, the pulse continues as programmed. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage Conditions Min Max Unit 0.5 +7.0 V 0.5 +7.0 V IIK input clamping current VI < 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] 20 - mA - 20 mA IO output current VO = 0.5 V to (VCC + 0.5 V) - 25 mA ICC supply current - 75 mA IGND ground current 75 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation Tamb = 40 C to +125 C SO16 package [2] - 500 mW TSSOP16 package [3] - 500 mW DHVQFN16 package [4] - 500 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 C. [3] Ptot derates linearly with 5.5 mW/K above 60 C. [4] Ptot derates linearly with 4.5 mW/K above 60 C. 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 6 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74AHC123A-Q100 74AHCT123A-Q100 Min Min Typ Max Typ Unit Max VCC supply voltage 2.0 5.0 5.5 4.5 5.0 5.5 V VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 3.3 V  0.3 V - - 100 - - - ns/V VCC = 5.0 V  0.5 V - - 20 - - 20 ns/V 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V IO = 50 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 50 A; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = 8.0 mA; VCC = 4.5 V 3.94 - - 3.8 - 3.70 - V IO = 50 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.25 - 2.5 - 10.0 A - - 0.1 - 1.0 - 2.0 A 74AHC123A-Q100 VIH VIL VOH VOL II HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL input leakage VI = 5.5 V or GND; current VCC = 0 V to 5.5 V [1] nREXT/CEXT pins nA, nB, nRD 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 7 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter ICC supply current 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - - 4.0 - 40 - 80 A VCC = 3.0 V - 160 250 - 280 - 280 A VCC = 4.5 V - 380 500 - 650 - 650 A VCC = 5.5 V - 560 750 - 975 - 975 A VI = VCC or GND; IO = 0 A; VCC = 5.5 V [1] active state (per circuit); VI = VCC or GND CI input capacitance - 5.0 10 - 10 - 10 pF CO output capacitance - 4.0 - - - - - pF 74AHCT123A-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 50 A 4.4 4.5 - 4.4 - 4.4 - V IO = 8.0 mA 3.94 - - 3.8 - 3.70 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V VOL II ICC IO = 50 A IO = 8.0 mA - - 0.36 - 0.44 - 0.55 V - - 0.25 - 2.5 - 10.0 A pins nA, nB, nRD; VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 2.0 A VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A VCC = 4.5 V - 380 500 - 650 - 650 A VCC = 5.5 V [1] input leakage nREXT/CEXT; current VI = 5.5 V or GND; VCC = 0 V to 5.5 V supply current active state (per circuit); VI = VCC or GND [1] - 560 750 - 975 - 975 A CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4.0 - - - - - pF [1] Voltage on nREXT/CEXT = 0.5 VCC and pin nREXT/CEXT in OFF-state during test. 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 8 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 12. Symbol Parameter 25 C Conditions Min 40 C to +85 C 40 C to +125 C Unit Typ[1] Max Min Max Min Max 74AHC123A-Q100 tpd propagation delay nA and nB to nQ and nQ; see Figure 7 [2] VCC = 3.0 V to 3.6 V CL = 15 pF - 7.4 20.6 1.0 24.0 1.0 26.0 ns CL = 50 pF - 10.5 24.1 1.0 27.5 1.0 30.0 ns - 5.1 12.0 1.0 14.0 1.0 15.5 ns - 7.3 14.0 1.0 16.0 1.0 17.5 ns VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF nRD to nQ and nQ; see Figure 7 [2] VCC = 3.0 V to 3.6 V CL = 15 pF - 8.2 22.4 1.0 26.0 1.0 28.0 ns CL = 50 pF - 11.7 25.9 1.0 29.5 1.0 32.0 ns - 5.6 12.9 1.0 15.0 1.0 16.5 ns - 8.1 14.9 1.0 17.0 1.0 19.0 ns CL = 15 pF - 6.4 15.8 1.0 18.5 1.0 20.0 ns CL = 50 pF - 9.2 19.3 1.0 22.0 1.0 24.5 ns CL = 15 pF - 4.4 9.4 1.0 11.0 1.0 12.0 ns CL = 50 pF - 6.3 11.4 1.0 13.0 1.0 14.5 ns VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF nRD to nQ and nQ (reset); see Figure 7 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 9 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset Table 7. Dynamic characteristics …continued GND = 0 V; For test circuit see Figure 12. Symbol Parameter tW pulse width 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max VCC = 3.0 V to 3.6 V 5.0 - - 5.0 - 5.0 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.0 - ns VCC = 3.0 V to 3.6 V 5.0 - - 5.0 - 5.0 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.0 - ns 5.0 - - 5.0 - 5.0 - ns 5.0 - - 5.0 - 5.0 - ns inputs; nA = LOW; see Figure 7 inputs; nB = HIGH; see Figure 7 inputs; nRD = LOW; see Figure 7 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V outputs; nQ = LOW and nQ = HIGH; CL = 50 pF; see Figure 7, Figure 8, Figure 9 and Figure 10 [3] Cext = 28 pF; Rext = 2 k VCC = 3.0 V to 3.6 V - 115 240 - 300 - 300 ns VCC = 4.5 V to 5.5 V - 100 200 - 240 - 240 ns VCC = 3.0 V to 3.6 V 90 100 110 90 110 85 115 s VCC = 4.5 V to 5.5 V 90 100 110 90 110 85 115 s VCC = 3.0 V to 3.6 V 0.9 1 1.1 0.9 1.1 0.85 1.15 ms VCC = 4.5 V to 5.5 V 0.9 1 1.1 0.9 1.1 0.85 1.15 ms VCC = 3.0 V to 3.6 V - 60 - - - - - ns VCC = 4.5 V to 5.5 V - 39 - - - - - ns - 1.5 - - - - - s - 1.2 - - - - - s - 57 - - - - - pF Cext = 0.01 F; Rext = 10 k Cext = 0.1 F; Rext = 10 k; trtrig retrigger time nA to nB; Cext = 100 pF; Rext = 1 k; CL = 50 pF; see Figure 8 and Figure 10 nA to nB; Cext = 0.01 F; Rext = 1 k; CL = 50 pF; see Figure 8 and Figure 10 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CPD power CL = 50 pF; fi = 1 MHz; dissipation VI = GND to VCC capacitance 74AHC_AHCT123A_Q100 Product data sheet [4] All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 10 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset Table 7. Dynamic characteristics …continued GND = 0 V; For test circuit see Figure 12. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max - 5.0 12.0 1.0 14.0 1.0 15.5 ns - 7.1 14.0 1.0 16.0 1.0 17.5 ns CL = 15 pF - 5.2 12.9 1.0 15.0 1.0 16.5 ns CL = 50 pF - 7.5 14.9 1.0 17.0 1.0 18.5 ns CL = 15 pF - 4.7 9.4 1.0 11.0 1.0 12.0 ns CL = 50 pF - 6.7 11.4 1.0 13.0 1.0 14.5 ns 5.0 - - 5.0 - 5.0 - ns 5.0 - - 5.0 - 5.0 - ns 5.0 - - 5.0 - 5.0 - ns - 100 200 - 240 - 240 ns 90 100 110 90 110 85 115 s 0.9 1 1.1 0.9 1.1 0.85 1.15 ms 74AHCT123A-Q100 tpd propagation delay nA and nB to nQ and nQ; see Figure 7 [2] VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF nRD to nQ and nQ; see Figure 7 [2] VCC = 4.5 V to 5.5 V nRD to nQ and nQ (reset); see Figure 7 [2] VCC = 4.5 V to 5.5 V tW pulse width inputs; nA = LOW; CL = 50 pF; see Figure 7 VCC = 4.5 V to 5.5 V inputs; nB = HIGH; CL = 50 pF; see Figure 7 VCC = 4.5 V to 5.5 V inputs; nRD = LOW; CL = 50 pF; see Figure 7 VCC = 4.5 V to 5.5 V outputs; nQ = LOW and nQ = HIGH; CL = 50 pF; Cext = 28 pF; Rext = 2 k; see Figure 7, Figure 8, Figure 9 and Figure 10 VCC = 4.5 V to 5.5 V [3] Cext = 0.01 F; Rext = 10 k VCC = 4.5 V to 5.5 V Cext = 0.1 F; Rext = 10 k VCC = 4.5 V to 5.5 V 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 11 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset Table 7. Dynamic characteristics …continued GND = 0 V; For test circuit see Figure 12. Symbol Parameter trtrig retrigger time 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max - 60 - - - - - ns - 1.5 - - - - - s - 58 - - - - - pF 5 - - - - - - k nA to nB; Cext = 100 pF; Rext = 1 k; CL = 50 pF; see Figure 8 and Figure 10 VCC = 4.5 V to 5.5 V nA to nB; Cext = 0.01 F; Rext = 1 k; CL = 50 pF; see Figure 8 and Figure 10 VCC = 4.5 V to 5.5 V CPD power CL = 50 pF; fi = 1 MHz; dissipation VI = GND to VCC capacitance [4] External components Rext external resistance Cext external VCC = 2.0 V capacitance V > 3.0 V CC VCC = 2.0 V VCC > 3.0 V 1 - - - - - - k [5] - - - - - - - pF [5] - - - - - - - pF [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL; Cext = 0 pF; Rext = 5 k. [3] For Cext  10 nF, the typical value of the pulse width tW (s) = Cext (nF)  Rext (k). [4] CPD is used to determine the dynamic power dissipation PD (W). PD = CPD  VCC2  fi + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V. [5] Cext has no limits. 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 12 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset 11. Waveforms nB input (nA LOW) VM tW VM nA input (nB HIGH) tW RESET VM nRD input tPLH nQ output tPLH tW VM tPHL tW nQ output tPLH tW VM tPHL tPHL tPLH tPHL 001aae528 Measurement points are given in Table 8. Fig 7. Table 8. Propagation delay input (nA, nB, nRD) to output (nQ, nQ) Measurement points Type Input Output VM VM 74AHC123A-Q100 0.5VCC 0.5VCC 74AHCT123A-Q100 1.5 V 0.5VCC nB input tW nA input trtrig tW nQ output tW tW 001aae526 nRD = HIGH Fig 8. Output pulse control using retrigger pulse 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 13 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset nB input nRD input nQ output tW tW 001aae527 nA = LOW Fig 9. Output pulse control using reset input nRD trt nA input nB input nRD input nREXT/CEXT nQ output nQ output tW tW tW + trt 001aah086 Fig 10. Input and output timing 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 14 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset VCC REXT CEXT to nCEXT (pin 14 or 6) to nREXT/CEXT (pin 15 or 7) mna519 Fig 11. Timing component connections VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistor S1 = Test selection switch Fig 12. Load circuitry for switching times Table 9. Test data Type 74AHC123A-Q100 Input Product data sheet S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ VCC 3.0 ns 15 pF, 50 pF 1 k open GND VCC 3.0 ns 15 pF, 50 pF 1 k open GND VCC 74AHCT123A-Q100 3.0 V 74AHC_AHCT123A_Q100 Load All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 15 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 13. Package outline SOT109-1 (SO16) 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 16 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 14. Package outline SOT403-1 (TSSOP16) 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 17 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 7 y y1 C v M C A B w M C b L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 15. Package outline SOT763-1 (DHVQFN16) 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 18 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charge Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MIL Military MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT123A_Q100 v.1 20130523 Product data sheet - - 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 19 of 22 74AHC123A-Q100; 74AHCT123A-Q100 Nexperia Dual retriggerable monostable multivibrator with reset 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AHC_AHCT123A_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 20 of 22 Nexperia 74AHC123A-Q100; 74AHCT123A-Q100 Dual retriggerable monostable multivibrator with reset No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AHC_AHCT123A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 May 2013 © Nexperia B.V. 2017. All rights reserved 21 of 22 Nexperia 74AHC123A-Q100; 74AHCT123A-Q100 Dual retriggerable monostable multivibrator with reset 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 5 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 6 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 7 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 16 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 19 Legal information. . . . . . . . . . . . . . . . . . . . . . . 20 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 20 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Contact information. . . . . . . . . . . . . . . . . . . . . 21 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 May 2013 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AHCT123ABQ-Q100X 74AHCT123APW-Q100J 74AHC123APW-Q100J 74AHCT123AD-Q100J 74AHC123ADQ100J 74AHC123ABQ-Q100X
74AHCT123ABQ-Q100X 价格&库存
很抱歉,暂时无法提供与“74AHCT123ABQ-Q100X”相匹配的价格&库存,您可以联系我们找货
74AHCT123ABQ-Q100X
  • 1000+3.07136
  • 10000+2.73932
  • 100000+2.32428
库存:51000
