74HC123; 74HCT123
Dual retriggerable monostable multivibrator with reset
Rev. 10 — 3 December 2015
Product data sheet
1. General description
The 74HC123; 74HCT123 are high-speed Si-gate CMOS devices and are pin compatible
with Low-power Schottky TTL (LSTTL). They are specified in compliance with JEDEC
standard no. 7A.
The 74HC123; 74HCT123 are dual retriggerable monostable multivibrators with output
pulse width control by three methods:
1. The basic pulse is programmed by selection of an external resistor (REXT) and
capacitor (CEXT).
2. Once triggered, the basic output pulse width may be extended by retriggering the
gated active LOW-going edge input (nA) or the active HIGH-going edge input (nB). By
repeating this process, the output pulse period (nQ = HIGH, nQ = LOW) can be made
as long as desired. Alternatively an output delay can be terminated at any time by a
LOW-going edge on input nRD, which also inhibits the triggering.
3. An internal connection from nRD to the input gates makes it possible to trigger the
circuit by a HIGH-going signal at input nRD as shown in Table 3.
Schmitt-trigger action in the nA and nB inputs, makes the circuit highly tolerant to slower
input rise and fall times.
The 74HC123; 74HCT123 are identical to the 74HC423; 74HCT423 but can be triggered
via the reset input.
2. Features and benefits
DC triggered from active HIGH or active LOW inputs
Retriggerable for very long pulses up to 100 % duty factor
Direct reset terminates output pulse
Schmitt-trigger action on all inputs except for the reset input
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Specified from 40 C to +85 C and from 40 C to +125 C
74HC123; 74HCT123
Nexperia
3. Ordering information
Table 1.
Type number
74HC123D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
40 C to +125 C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
40 C to +125 C
DHVQFN16
plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 16 terminals;
body 2.5 3.5 0.85 mm
SOT763-1
74HCT123D
74HC123DB
74HCT123DB
74HC123PW
74HCT123PW
74HC123BQ
4. Functional diagram
6
5'
4
4
5'
4
4
5'
6
5(;7&(;7
7
&(;7
4
&(;7
5(;7&(;7
4
7
4
4
5'
DDD
Fig 1.
Functional diagram
74HC_HCT123
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 24
74HC123; 74HCT123
Nexperia
5(;7&(;7
5(;7&(;7
4
4
4
4
4
5'
PQD
5
5'
Fig 2.
4
5'
5&;
7
5
6
&(;7
&(;7
5&;
PQD
Logic symbol
Fig 3.
IEC logic symbol
Q5(;7&(;7
9&&
Q4
Q5'
5
9&&
Q4
5
9&&
5
Q$
Q%
Fig 4.
5
PQD
Logic diagram
74HC_HCT123
Product data sheet
3 of 24
74HC123; 74HCT123
Nexperia
5. Pinning information
5.1 Pinning
WHUPLQDO
LQGH[DUHD
+&7
9&&
5(;7&(;7
9&&
5'
&(;7
5(;7&(;7
4
4
5'
&(;7
4
4
4
4
&(;7
4
4
5(;7&(;7
&(;7
5'
5(;7&(;7
*1'
5'
*1'
9&&
DDI
7UDQVSDUHQWWRSYLHZ
DDD
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to VCC.
Fig 5.
Pin configuration for SO16, SSOP16 and
TSSOP16
Fig 6.
Pin configuration for DHVQFN16
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A
1
negative-edge triggered input 1
1B
2
positive-edge triggered input 1
1RD
3
direct reset LOW and positive-edge triggered input 1
1Q
4
active LOW output 1
2Q
5
active HIGH output 2
2CEXT
6
external capacitor connection 2
2REXT/CEXT
7
external resistor and capacitor connection 2
GND
8
ground (0 V)
2A
9
negative-edge triggered input 2
2B
10
positive-edge triggered input 2
2RD
11
direct reset LOW and positive-edge triggered input 2
2Q
12
active LOW output 2
1Q
13
active HIGH output 1
1CEXT
14
external capacitor connection 1
1REXT/CEXT
15
external resistor and capacitor connection 1
VCC
16
supply voltage
74HC_HCT123
Product data sheet
4 of 24
74HC123; 74HCT123
Nexperia
6. Functional description
Table 3.
Function table[1]
Input
Output
nRD
nA
nB
nQ
nQ
L
X
X
L
H
H[2]
H[2]
X
H
X
L[2]
X
X
L
L[2]
H
L
H
H
L
H
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; = LOW-to-HIGH transition; = HIGH-to-LOW transition;
= one HIGH level output pulse;
[2]
= one LOW level output pulse.
If the monostable was triggered before this condition was established, the pulse will continue as programmed.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
Conditions
VI < 0.5 V or VI > VCC + 0.5 V
Min
Max
Unit
0.5
+7
V
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
mA
IO
output current
except for pins nREXT/CEXT;
VO = 0.5 V to (VCC + 0.5 V)
25
mA
ICC
supply current
50
mA
IGND
ground current
Tstg
storage temperature
Ptot
total power dissipation
[1]
50
mA
65
+150
C
SO16 package
[1]
500
mW
SSOP16 package
[2]
500
mW
TSSOP16 package
[2]
500
mW
DHVQFN16 package
[3]
500
mW
For SO16 package: Ptot derates linearly with 8 mW/K above 70 C.
[2]
For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
[3]
For DHVQFN16 package: Ptot derates linearly with 4.5 mW/K above 60 C.
74HC_HCT123
Product data sheet
5 of 24
74HC123; 74HCT123
Nexperia
8. Recommended operating conditions
Table 5.
Symbol Parameter
VCC
supply voltage
Conditions
74HC123
74HCT123
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
t/V
input transition rise and
fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
40
+25
+125
40
+25
+125
Tamb
nRD input
ambient temperature
C
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
HIGH-level
VI = VIH or VIL
output voltage
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
74HC123
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
IO = 4 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
LOW-level
VI = VIH or VIL
output voltage
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
VI = VCC or GND; VCC = 6.0 V
0.1
1.0
1.0
A
8.0
80
160
A
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
74HC_HCT123
Product data sheet
6 of 24
74HC123; 74HCT123
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
CI
25 C
Conditions
input
capacitance
Min
Typ
Max
Min
Max
Min
Max
3.5
pF
74HCT123
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = 20 A
4.4
4.5
4.4
4.4
V
3.98
4.32
3.84
3.7
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.1
1.0
1.0
A
8.0
80
160
A
pins nA, nB
35
125
160
170
A
pin nRD
50
180
225
245
A
3.5
pF
IO = 4 mA
VOL
LOW-level
output voltage
IO = 20 A
IO = 4.0 mA
II
input leakage
current
ICC
VCC = 5.5 V
ICC
additional
per input pin; IO = 0 A;
supply current VI = VCC 2.1 V;
other inputs at VCC or GND;
CI
input
capacitance
74HC_HCT123
Product data sheet
VI = VCC or GND; VCC = 5.5 V
7 of 24
74HC123; 74HCT123
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 12.
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
83
255
320
385
ns
VCC = 4.5 V
30
51
64
77
ns
VCC = 5 V; CL = 15 pF
26
ns
VCC = 6.0 V
24
43
54
65
ns
VCC = 2.0 V
66
215
270
325
ns
VCC = 4.5 V
24
43
54
65
ns
ns
19
37
46
55
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
VCC = 2.0 V
100
8
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
2
21
26
ns
VCC = 2.0 V
100
17
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
5
21
26
ns
VCC = 2.0 V
100
14
125
150
ns
VCC = 4.5 V
25
30
ns
17
4
21
26
ns
CEXT = 100 nF;
REXT = 10 k
450
s
CEXT = 0 pF;
REXT = 5 k
75
ns
74HC123
tpd
propagation
delay
nRD, nA, nB to nQ or nQ;
CEXT = 0 pF;
REXT = 5 k;
see Figure 9
[1]
nRD (reset) to nQ or nQ;
CEXT = 0 pF;
REXT = 5 k;
see Figure 9
VCC = 6.0 V
tt
tW
[1]
transition time see Figure 9
pulse width
nA LOW; see Figure 10
nB HIGH; see Figure 10
nRD LOW; see Figure 11
VCC = 6.0 V
nQ HIGH and nQ LOW;
VCC = 5.0 V;
see Figure 10 and 11
74HC_HCT123
Product data sheet
[2]
8 of 24
74HC123; 74HCT123
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 C
Conditions
trtrig
retrigger time
nA, nB; CEXT = 0 pF;
REXT = 5 k; VCC = 5.0 V;
see Figure 10
REXT
external timing see Figure 7
resistor
VCC = 2.0 V
[3][4]
VCC = 5.0 V
Min
Typ
Max
Min
Max
Min
Max
110
ns
10
1000
k
2
1000
k
CEXT
external timing VCC = 5.0 V; see Figure 7
capacitor
[4]
pF
CPD
power
dissipation
capacitance
[5]
54
pF
VCC = 4.5 V
30
51
64
77
ns
26
ns
VCC = 4.5 V
27
46
58
69
ns
23
ns
VCC = 4.5 V
28
51
64
77
ns
26
ns
23
46
58
69
ns
23
ns
7
15
19
22
ns
per monostable;
VI = GND to VCC
74HCT123
tPHL
HIGH to LOW
propagation
delay
CEXT = 0 pF; REXT =
5 k; see Figure 9
CEXT = 0 pF;
REXT = 5 k;
see Figure 9
tPLH
LOW to HIGH
propagation
delay
CEXT = 0 pF;
REXT = 5 k;
see Figure 9
CEXT = 0 pF; REXT =
5 k; see Figure 9
VCC = 4.5 V
tt
transition time VCC = 4.5 V; see Figure 9
74HC_HCT123
Product data sheet
[1]
9 of 24
74HC123; 74HCT123
Nexperia
Table 7.
Symbol Parameter
tW
pulse width
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
25
30
ns
25
30
ns
25
30
ns
CEXT = 100 nF;
REXT = 10 k
450
s
CEXT = 0 pF;
REXT = 5 k
75
ns
110
ns
2
1000
k
VCC = 4.5 V
[2]
nQ HIGH and nQ LOW;
VCC = 5.0 V;
see Figure 10
[3][4]
trtrig
retrigger time
REXT
resistor
CEXT
capacitor
[4]
pF
CPD
power
dissipation
capacitance
[5]
56
pF
per monostable;
VI = GND to VCC 1.5 V
[1]
tpd is the same as tPHL and tPLH; tt is the same as tTHL and tTLH
[2]
For other REXT and CEXT combinations see Figure 7. If CEXT > 10 nF, the next formula is valid.
tW = K REXT CEXT, where:
tW = typical output pulse width in ns;
REXT = external resistor in k;
CEXT = external capacitor in pF;
K = constant = 0.45 for VCC = 5.0 V and 0.55 for VCC = 2.0 V.
The inherent test jig and pin capacitance at pins 15 and 7 (nREXT/CEXT) is approximately 7 pF.
[3]
The time to retrigger the monostable multivibrator depends on the values of REXT and CEXT. The output pulse width will only be
extended when the time between the active-going edges of the trigger input pulses meets the minimum retrigger time. If CEXT >10 pF,
the next formula (at VCC = 5.0 V) for the setup time of a retrigger pulse is valid:
trtrig = 30 + 0.19 REXT CEXT0.9 + 13 REXT1.05, where:
trtrig = retrigger time in ns;
CEXT = external capacitor in pF; REXT = external resistor in k.
The inherent test jig and pin capacitance at pins 15 and 7 (nREXT/CEXT) is 7 pF.
[4]
[5]
When the device is powered-up, initiate the device via a reset pulse, when CEXT < 50 pF.
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi + (CL VCC2 fo) + 0.75 CEXT VCC2 fo + D 16 VCC where:
fi = input frequency in MHz;
fo = output frequency in MHz;
D = duty factor in %;
CL = output load capacitance in pF;
VCC = supply voltage in V;
CEXT = timing capacitance in pF;
(CL VCC2 fo) sum of outputs.
74HC_HCT123
Product data sheet
10 of 24
74HC123; 74HCT123
Nexperia
DDD
W:
QV
DDD
IDFWRU
&(;7S)
9&&9
VCC = 5.0 V; Tamb = 25 C.
CEXT = 10 nF; REXT = 10 k to 100 k.
Tamb = 25 C.
(1) REXT = 100 k
(2) REXT = 50 k
(3) REXT = 10 k
(4) REXT = 2 k
Fig 7.
Typical output pulse width as a function of the
external capacitor value
74HC_HCT123
Product data sheet
Fig 8.
74HC123 typical ‘K’ factor as function of VCC
11 of 24
74HC123; 74HCT123
Nexperia
11. Waveforms
9,
90
Q%LQSXW
*1'
W:
9,
90
Q$LQSXW
*1'
W:
9,
90
Q5'LQSXW
*1'
W3/+
W3/+
W:
92+
Q4RXWSXW
9<
90
9;
92/
W7+/
W:
92/
W3/+
W:
92+
Q4RXWSXW
W3+/
UHVHW
9<
90
9;
W3+/
W3+/
W7/+
W3/+
UHVHW
W3+/
DDD
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 9.
Propagation delays from inputs (nA, nB, nRD) to outputs (nQ, nQ) and output transition times
74HC_HCT123
Product data sheet
12 of 24
74HC123; 74HCT123
Nexperia
Q%LQSXW
W:
Q$LQSXW
WUWULJ
W:
Q4RXWSXW
W:
W:
W:
PQD
nRD = HIGH
Fig 10. Output pulse control using retrigger pulse
Q%LQSXW
Q5'LQSXW
W:
Q4RXWSXW
W:
W:
PQD
nA = LOW
Fig 11. Output pulse control using reset input nRD
74HC_HCT123
Product data sheet
13 of 24
74HC123; 74HCT123
Nexperia
9,
W:
QHJDWLYH
SXOVH
90
9
WI
WU
WU
WI
9,
SRVLWLYH
SXOVH
9
90
90
90
W:
9&&
9&&
9,
92
5/
6
RSHQ
'87
57
DDG
Test data is given in Table 8.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig 12. Test circuit for measuring switching times
Table 8.
Test data
Type
Input
VI
tr, tf
CL
RL
tPHL, tPLH
74HC123
VCC
6 ns
15 pF, 50 pF
1 k
open
74HCT123
3V
6 ns
15 pF, 50 pF
1 k
open
74HC_HCT123
Product data sheet
Load
S1 position
14 of 24
74HC123; 74HCT123
Nexperia
12. Application information
12.1 Timing component connections
The basic output pulse width is essentially determined by the values of the external timing
components REXT and CEXT.
&(;7
5(;7
*1'
Q&(;7
Q5(;7&(;7
Q$
Q%
9&&
Q4
Q4
Q5'
DDD
(1) For minimum noise generation it is recommended to ground pins 6 (2CEXT) and 14 (1CEXT)
externally to pin 8 (GND).
Fig 13. Timing component connections
12.2 Power-up considerations
When the monostable is powered-up it may produce an output pulse, with a pulse width
defined by the values of REXT and CEXT. This output pulse can be eliminated using the
circuit shown in Figure 14.
&(;7
5(;7
*1'
Q&(;7
Q5(;7&(;7
Q$
Q%
9&&
Q4
Q4
Q5'
5(6(7
9&&
DDD
Fig 14. Power-up output pulse elimination circuit
74HC_HCT123
Product data sheet
15 of 24
74HC123; 74HCT123
Nexperia
12.3 Power-down considerations
A large capacitor CEXT may cause problems when powering-down the monostable due to
the energy stored in this capacitor. When a system containing this device is
powered-down or a rapid decrease of VCC to zero occurs, the monostable may sustain
damage, due to the capacitor discharging through the input protection diodes. To avoid
this possibility, use a damping diode (DEXT) preferably a germanium or Schottky type
diode able to withstand large current surges and connect as shown in Figure 15.
'(;7
&(;7
5(;7
*1'
Q&(;7
Q5(;7&(;7
Q$
Q%
9&&
Q4
Q4
Q5'
DDD
Fig 15. Power-down protection circuit
74HC_HCT123
Product data sheet
16 of 24
74HC123; 74HCT123
Nexperia
13. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
Z 0
ES
GHWDLO;
PP
VFDOH
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
PP
LQFKHV
ș
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
5()(5(1&(6
287/,1(
9(56,21
627
06
-(,7$
(8523($1
352-(&7,21
,668('$7(
Fig 16. Package outline SOT109-1 (SO16)
74HC_HCT123
Product data sheet
17 of 24
74HC123; 74HCT123
Nexperia
6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
GHWDLO;
Z 0
ES
H
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 17. Package outline SOT338-1 (SSOP16)
74HC_HCT123
Product data sheet
18 of 24
74HC123; 74HCT123
Nexperia
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 18. Package outline SOT403-1 (TSSOP16)
74HC_HCT123
Product data sheet
19 of 24
74HC123; 74HCT123
Nexperia
'+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV
627
WHUPLQDOVERG\[[PP
F
GHWDLO;
WHUPLQDO
LQGH[DUHD
WHUPLQDO
LQGH[DUHD
H
H
E
Y 0 & $ %
Z 0 &
(K
H
'K
PP
VFDOH
81,7
PP
PD[
E
F
'K
(K
H
Y
Z
H
1RWH
5()(5(1&(6
287/,1(
9(56,21
-(,7$
627
02
(8523($1
352-(&7,21
,668('$7(
Fig 19. Package outline SOT763-1 (DHVQFN16)
74HC_HCT123
Product data sheet
20 of 24
74HC123; 74HCT123
Nexperia
14. Abbreviations
Table 9.
Abbreviations
Acronym
Abbreviation
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
15. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT123 v.10
20151203
Product data sheet
74HC_HCT123 v.9
Modifications:
74HC_HCT123 v.9
Modifications:
74HC_HCT123 v.8
Modifications:
Type numbers 74HC123N and 74HCT123N (SOT38-4) removed.
20150119
74HC_HCT123 v.8
Table 7: Power dissipation capacitance condition for 74HCT123 is corrected.
20111216
Product data sheet
Product data sheet
74HC_HCT123 v.7
Legal pages updated.
74HC_HCT123 v.7
20110825
Product data sheet
74HC_HCT123 v.6
74HC_HCT123 v.6
20110314
Product data sheet
74HC_HCT123 v.5
74HC_HCT123 v.5
20090713
Product data sheet
74HC_HCT123 v.4
74HC_HCT123 v.4
20060616
Product data sheet
74HC_HCT123 v.3
74HC_HCT123 v.3
20040511
Product specification
74HC_HCT123_CNV v.2
74HC_HCT123_CNV v.2
19980708
74HC_HCT123
Product data sheet
21 of 24
74HC123; 74HCT123
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC_HCT123
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
22 of 24
74HC123; 74HCT123
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC_HCT123
Product data sheet
23 of 24
74HC123; 74HCT123
Nexperia
18. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
12.1
12.2
12.3
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Application information. . . . . . . . . . . . . . . . . . 15
Timing component connections . . . . . . . . . . . 15
Power-up considerations . . . . . . . . . . . . . . . . 15
Power-down considerations . . . . . . . . . . . . . . 16
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 17
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 21
Legal information. . . . . . . . . . . . . . . . . . . . . . . 22
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 22
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 23
Contact information. . . . . . . . . . . . . . . . . . . . . 23
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24
Date of release: 03 December 2015
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC123DB 74HCT123D 74HCT123DB 74HC123BQ,115 74HC123D,652 74HC123DB,112 74HC123DB,118
74HC123D,653 74HC123N,652 74HC123PW,112 74HC123PW,118 74HCT123D,652 74HCT123DB,112
74HCT123DB,118 74HCT123D,653 74HCT123N,652 74HCT123PW,112 74HCT123PW,118 74HCT123D/AUJ
74HC123D/AUJ
