74HC123BQ,115
74HC123BQ,115
    NEXPERIA(安世)
    DHVQFN-16-EP(2.5x3.5)
    带复位的双可触发单稳多谐振荡器
74HC123BQ,115 数据手册
74HC123; 74HCT123 Dual retriggerable monostable multivibrator with reset Rev. 10 — 3 December 2015 Product data sheet 1. General description The 74HC123; 74HCT123 are high-speed Si-gate CMOS devices and are pin compatible with Low-power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard no. 7A. The 74HC123; 74HCT123 are dual retriggerable monostable multivibrators with output pulse width control by three methods: 1. The basic pulse is programmed by selection of an external resistor (REXT) and capacitor (CEXT). 2. Once triggered, the basic output pulse width may be extended by retriggering the gated active LOW-going edge input (nA) or the active HIGH-going edge input (nB). By repeating this process, the output pulse period (nQ = HIGH, nQ = LOW) can be made as long as desired. Alternatively an output delay can be terminated at any time by a LOW-going edge on input nRD, which also inhibits the triggering. 3. An internal connection from nRD to the input gates makes it possible to trigger the circuit by a HIGH-going signal at input nRD as shown in Table 3. Schmitt-trigger action in the nA and nB inputs, makes the circuit highly tolerant to slower input rise and fall times. The 74HC123; 74HCT123 are identical to the 74HC423; 74HCT423 but can be triggered via the reset input. 2. Features and benefits      DC triggered from active HIGH or active LOW inputs Retriggerable for very long pulses up to 100 % duty factor Direct reset terminates output pulse Schmitt-trigger action on all inputs except for the reset input ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Specified from 40 C to +85 C and from 40 C to +125 C 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 3. Ordering information Table 1. Ordering information Type number 74HC123D Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm SOT763-1 74HCT123D 74HC123DB 74HCT123DB 74HC123PW 74HCT123PW 74HC123BQ 4. Functional diagram   6 $ % 5' 4   4  5' 4  4 5'   6 % 5(;7&(;7 7  $ &(;7 4   &(;7 5(;7&(;7 4 7 4   4 5'  DDD Fig 1. Functional diagram 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 2 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset   &;    5(;7&(;7  5(;7&(;7 4  $ 4  4   4  4  %  % 5'   PQD 5  5' Fig 2.  4    5' &; 5&;  7  $ 5   6  &(;7  &(;7  5&;  PQD Logic symbol Fig 3. IEC logic symbol Q5(;7&(;7 9&& Q4 Q5' 5 &/ 9&& Q4 5 &/ 9&& 5 &/ &/ Q$ Q% Fig 4. &/ 5 PQD Logic diagram 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 3 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 5. Pinning information 5.1 Pinning  $ WHUPLQDO LQGH[DUHD +& +&7  9&& +& %   5(;7&(;7 $   9&& 5'   &(;7 %   5(;7&(;7 4   4 5'   &(;7 4   4 4   4 &(;7  4   4 5(;7&(;7  &(;7   5' 5(;7&(;7   % *1'    5'   $  % *1' $ 9&&  DDI 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to VCC. Fig 5. Pin configuration for SO16, SSOP16 and TSSOP16 Fig 6. Pin configuration for DHVQFN16 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A 1 negative-edge triggered input 1 1B 2 positive-edge triggered input 1 1RD 3 direct reset LOW and positive-edge triggered input 1 1Q 4 active LOW output 1 2Q 5 active HIGH output 2 2CEXT 6 external capacitor connection 2 2REXT/CEXT 7 external resistor and capacitor connection 2 GND 8 ground (0 V) 2A 9 negative-edge triggered input 2 2B 10 positive-edge triggered input 2 2RD 11 direct reset LOW and positive-edge triggered input 2 2Q 12 active LOW output 2 1Q 13 active HIGH output 1 1CEXT 14 external capacitor connection 1 1REXT/CEXT 15 external resistor and capacitor connection 1 VCC 16 supply voltage 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 4 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 6. Functional description Table 3. Function table[1] Input Output nRD nA nB nQ nQ L X X L H H[2] H[2] X H X L[2] X X L L[2] H L  H  H  L H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care;  = LOW-to-HIGH transition;  = HIGH-to-LOW transition; = one HIGH level output pulse; [2] = one LOW level output pulse. If the monostable was triggered before this condition was established, the pulse will continue as programmed. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions VI < 0.5 V or VI > VCC + 0.5 V Min Max Unit 0.5 +7 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current except for pins nREXT/CEXT; VO = 0.5 V to (VCC + 0.5 V) - 25 mA ICC supply current - 50 mA IGND ground current Tstg storage temperature Ptot total power dissipation [1] - 50 mA 65 +150 C SO16 package [1] - 500 mW SSOP16 package [2] - 500 mW TSSOP16 package [2] - 500 mW DHVQFN16 package [3] - 500 mW For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. [2] For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. [3] For DHVQFN16 package: Ptot derates linearly with 4.5 mW/K above 60 C. 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 5 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions 74HC123 74HCT123 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 40 +25 +125 40 +25 +125 Tamb nRD input ambient temperature C 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V 74HC123 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage IO = 4 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V LOW-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A - - 8.0 - 80 - 160 A II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 6 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter CI 25 C Conditions input capacitance 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 3.5 - - - - - pF 74HCT123 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V - - 0.1 - 1.0 - 1.0 A - - 8.0 - 80 - 160 A pins nA, nB - 35 125 - 160 - 170 A pin nRD - 50 180 - 225 - 245 A - 3.5 - - - - - pF IO = 4 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A IO = 4.0 mA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V ICC additional per input pin; IO = 0 A; supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V CI input capacitance 74HC_HCT123 Product data sheet VI = VCC or GND; VCC = 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 7 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 12. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 83 255 - 320 - 385 ns VCC = 4.5 V - 30 51 - 64 - 77 ns VCC = 5 V; CL = 15 pF - 26 - - - - - ns VCC = 6.0 V - 24 43 - 54 - 65 ns VCC = 2.0 V - 66 215 - 270 - 325 ns VCC = 4.5 V - 24 43 - 54 - 65 ns VCC = 5 V; CL = 15 pF - 20 - - - - - ns - 19 37 - 46 - 55 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 100 8 - 125 - 150 - ns VCC = 4.5 V 20 3 - 25 - 30 - ns VCC = 6.0 V 17 2 - 21 - 26 - ns VCC = 2.0 V 100 17 - 125 - 150 - ns VCC = 4.5 V 20 6 - 25 - 30 - ns VCC = 6.0 V 17 5 - 21 - 26 - ns VCC = 2.0 V 100 14 - 125 - 150 - ns VCC = 4.5 V 20 5 - 25 - 30 - ns 17 4 - 21 - 26 - ns CEXT = 100 nF; REXT = 10 k - 450 - - - - - s CEXT = 0 pF; REXT = 5 k - 75 - - - - - ns 74HC123 tpd propagation delay nRD, nA, nB to nQ or nQ; CEXT = 0 pF; REXT = 5 k; see Figure 9 [1] nRD (reset) to nQ or nQ; CEXT = 0 pF; REXT = 5 k; see Figure 9 VCC = 6.0 V tt tW [1] transition time see Figure 9 pulse width nA LOW; see Figure 10 nB HIGH; see Figure 10 nRD LOW; see Figure 11 VCC = 6.0 V nQ HIGH and nQ LOW; VCC = 5.0 V; see Figure 10 and 11 74HC_HCT123 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 8 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 12. Symbol Parameter 25 C Conditions trtrig retrigger time nA, nB; CEXT = 0 pF; REXT = 5 k; VCC = 5.0 V; see Figure 10 REXT external timing see Figure 7 resistor VCC = 2.0 V [3][4] VCC = 5.0 V 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 110 - - - - - ns 10 - 1000 - - - - k 2 - 1000 - - - - k CEXT external timing VCC = 5.0 V; see Figure 7 capacitor [4] - - - - - - - pF CPD power dissipation capacitance [5] - 54 - - - - - pF VCC = 4.5 V - 30 51 - 64 - 77 ns VCC = 5 V; CL = 15 pF - 26 - - - - - ns VCC = 4.5 V - 27 46 - 58 - 69 ns VCC = 5 V; CL = 15 pF - 23 - - - - - ns VCC = 4.5 V - 28 51 - 64 - 77 ns VCC = 5 V; CL = 15 pF - 26 - - - - - ns - 23 46 - 58 - 69 ns - 23 - - - - - ns - 7 15 - 19 - 22 ns per monostable; VI = GND to VCC 74HCT123 tPHL HIGH to LOW propagation delay nRD, nA, nB to nQ or nQ; CEXT = 0 pF; REXT = 5 k; see Figure 9 nRD (reset) to nQ or nQ; CEXT = 0 pF; REXT = 5 k; see Figure 9 tPLH LOW to HIGH propagation delay nRD, nA, nB to nQ or nQ; CEXT = 0 pF; REXT = 5 k; see Figure 9 nRD (reset) to nQ or nQ; CEXT = 0 pF; REXT = 5 k; see Figure 9 VCC = 4.5 V VCC = 5 V; CL = 15 pF tt transition time VCC = 4.5 V; see Figure 9 74HC_HCT123 Product data sheet [1] All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 9 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 12. Symbol Parameter tW pulse width 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max nA LOW; see Figure 10 20 3 - 25 - 30 - ns nB HIGH; see Figure 10 20 5 - 25 - 30 - ns 20 7 - 25 - 30 - ns CEXT = 100 nF; REXT = 10 k - 450 - - - - - s CEXT = 0 pF; REXT = 5 k - 75 - - - - - ns - 110 - - - - - ns 2 - 1000 - - - - k VCC = 4.5 V nRD LOW; see Figure 11 [2] nQ HIGH and nQ LOW; VCC = 5.0 V; see Figure 10 and 11 nA, nB; CEXT = 0 pF; REXT = 5 k; VCC = 5.0 V; see Figure 10 [3][4] trtrig retrigger time REXT external timing VCC = 5.0 V; see Figure 7 resistor CEXT external timing VCC = 5.0 V; see Figure 7 capacitor [4] - - - - - - - pF CPD power dissipation capacitance [5] - 56 - - - - - pF per monostable; VI = GND to VCC  1.5 V [1] tpd is the same as tPHL and tPLH; tt is the same as tTHL and tTLH [2] For other REXT and CEXT combinations see Figure 7. If CEXT > 10 nF, the next formula is valid. tW = K  REXT  CEXT, where: tW = typical output pulse width in ns; REXT = external resistor in k; CEXT = external capacitor in pF; K = constant = 0.45 for VCC = 5.0 V and 0.55 for VCC = 2.0 V. The inherent test jig and pin capacitance at pins 15 and 7 (nREXT/CEXT) is approximately 7 pF. [3] The time to retrigger the monostable multivibrator depends on the values of REXT and CEXT. The output pulse width will only be extended when the time between the active-going edges of the trigger input pulses meets the minimum retrigger time. If CEXT >10 pF, the next formula (at VCC = 5.0 V) for the setup time of a retrigger pulse is valid: trtrig = 30 + 0.19  REXT  CEXT0.9 + 13  REXT1.05, where: trtrig = retrigger time in ns; CEXT = external capacitor in pF; REXT = external resistor in k. The inherent test jig and pin capacitance at pins 15 and 7 (nREXT/CEXT) is 7 pF. [4] [5] When the device is powered-up, initiate the device via a reset pulse, when CEXT < 50 pF. CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi + (CL  VCC2  fo) + 0.75  CEXT  VCC2  fo + D  16  VCC where: fi = input frequency in MHz; fo = output frequency in MHz; D = duty factor in %; CL = output load capacitance in pF; VCC = supply voltage in V; CEXT = timing capacitance in pF; (CL  VCC2  fo) sum of outputs. 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 10 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset DDD  W:  QV DDD  . IDFWRU                   &(;7 S)      9&& 9 VCC = 5.0 V; Tamb = 25 C. CEXT = 10 nF; REXT = 10 k to 100 k. Tamb = 25 C. (1) REXT = 100 k (2) REXT = 50 k (3) REXT = 10 k (4) REXT = 2 k Fig 7. Typical output pulse width as a function of the external capacitor value 74HC_HCT123 Product data sheet Fig 8. 74HC123 typical ‘K’ factor as function of VCC All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 11 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 11. Waveforms 9, 90 Q%LQSXW *1' W: 9, 90 Q$LQSXW *1' W: 9, 90 Q5'LQSXW *1' W3/+ W3/+ W: 92+ Q4RXWSXW 9< 90 9; 92/ W7+/ W: 92/ W3/+ W: 92+ Q4RXWSXW W3+/ UHVHW 9< 90 9; W3+/ W3+/ W7/+ W3/+ UHVHW W3+/ DDD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 9. Propagation delays from inputs (nA, nB, nRD) to outputs (nQ, nQ) and output transition times 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 12 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset Q%LQSXW W: Q$LQSXW WUWULJ W: Q4RXWSXW W: W: W: PQD nRD = HIGH Fig 10. Output pulse control using retrigger pulse Q%LQSXW Q5'LQSXW W: Q4RXWSXW W: W: PQD nA = LOW Fig 11. Output pulse control using reset input nRD 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 13 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 8. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 12. Test circuit for measuring switching times Table 8. Test data Type Input VI tr, tf CL RL tPHL, tPLH 74HC123 VCC 6 ns 15 pF, 50 pF 1 k open 74HCT123 3V 6 ns 15 pF, 50 pF 1 k open 74HC_HCT123 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 S1 position © Nexperia B.V. 2017. All rights reserved 14 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 12. Application information 12.1 Timing component connections The basic output pulse width is essentially determined by the values of the external timing components REXT and CEXT. &(;7  5(;7 *1' Q&(;7 Q5(;7&(;7         Q$ Q% 9&& Q4       Q4   Q5' DDD (1) For minimum noise generation it is recommended to ground pins 6 (2CEXT) and 14 (1CEXT) externally to pin 8 (GND). Fig 13. Timing component connections 12.2 Power-up considerations When the monostable is powered-up it may produce an output pulse, with a pulse width defined by the values of REXT and CEXT. This output pulse can be eliminated using the circuit shown in Figure 14. &(;7 5(;7 *1' Q&(;7 Q5(;7&(;7       Q$ Q% 9&&   Q4       Q4   Q5' 5(6(7 9&& DDD Fig 14. Power-up output pulse elimination circuit 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 15 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 12.3 Power-down considerations A large capacitor CEXT may cause problems when powering-down the monostable due to the energy stored in this capacitor. When a system containing this device is powered-down or a rapid decrease of VCC to zero occurs, the monostable may sustain damage, due to the capacitor discharging through the input protection diodes. To avoid this possibility, use a damping diode (DEXT) preferably a germanium or Schottky type diode able to withstand large current surges and connect as shown in Figure 15. '(;7 &(;7 5(;7 *1' Q&(;7 Q5(;7&(;7         Q$ Q% 9&& Q4       Q4   Q5' DDD Fig 15. Power-down protection circuit 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 16 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 13. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 16. Package outline SOT109-1 (SO16) 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 17 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   GHWDLO; Z 0 ES H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 17. Package outline SOT338-1 (SSOP16) 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 18 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 18. Package outline SOT403-1 (TSSOP16) 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 19 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset '+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV 627 WHUPLQDOVERG\[[PP % ' $ $ $ ( F GHWDLO; WHUPLQDO LQGH[DUHD WHUPLQDO LQGH[DUHD & H H E   \ \ & Y 0 & $ % Z 0 & /   (K H     'K ;   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 PP $   PD[ $ E      F '   'K (   (K          H / Y Z \ \        H  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& -(,7$ 627  02  (8523($1 352-(&7,21 ,668('$7(    Fig 19. Package outline SOT763-1 (DHVQFN16) 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 20 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 14. Abbreviations Table 9. Abbreviations Acronym Abbreviation CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MM Machine Model 15. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT123 v.10 20151203 Product data sheet - 74HC_HCT123 v.9 Modifications: 74HC_HCT123 v.9 Modifications: 74HC_HCT123 v.8 Modifications: • Type numbers 74HC123N and 74HCT123N (SOT38-4) removed. 20150119 • - 74HC_HCT123 v.8 Table 7: Power dissipation capacitance condition for 74HCT123 is corrected. 20111216 • Product data sheet Product data sheet - 74HC_HCT123 v.7 Legal pages updated. 74HC_HCT123 v.7 20110825 Product data sheet - 74HC_HCT123 v.6 74HC_HCT123 v.6 20110314 Product data sheet - 74HC_HCT123 v.5 74HC_HCT123 v.5 20090713 Product data sheet - 74HC_HCT123 v.4 74HC_HCT123 v.4 20060616 Product data sheet - 74HC_HCT123 v.3 74HC_HCT123 v.3 20040511 Product specification - 74HC_HCT123_CNV v.2 74HC_HCT123_CNV v.2 19980708 Product specification - - 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 21 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT123 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 22 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 23 of 24 74HC123; 74HCT123 Nexperia Dual retriggerable monostable multivibrator with reset 18. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 12.1 12.2 12.3 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Application information. . . . . . . . . . . . . . . . . . 15 Timing component connections . . . . . . . . . . . 15 Power-up considerations . . . . . . . . . . . . . . . . 15 Power-down considerations . . . . . . . . . . . . . . 16 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 17 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 21 Legal information. . . . . . . . . . . . . . . . . . . . . . . 22 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 22 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Contact information. . . . . . . . . . . . . . . . . . . . . 23 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 03 December 2015 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC123DB 74HCT123D 74HCT123DB 74HC123BQ,115 74HC123D,652 74HC123DB,112 74HC123DB,118 74HC123D,653 74HC123N,652 74HC123PW,112 74HC123PW,118 74HCT123D,652 74HCT123DB,112 74HCT123DB,118 74HCT123D,653 74HCT123N,652 74HCT123PW,112 74HCT123PW,118 74HCT123D/AUJ 74HC123D/AUJ
74HC123BQ,115 价格&库存
很抱歉,暂时无法提供与“74HC123BQ,115”相匹配的价格&库存,您可以联系我们找货
74HC123BQ,115
  • 3000+1.355413000+0.17614
  • 6000+1.316716000+0.17111
  • 9000+1.297339000+0.16859
  • 15000+1.2758515000+0.16580
  • 21000+1.2632921000+0.16417
  • 30000+1.2512130000+0.16260
库存:2970
74HC123BQ,115
  • 1+3.176731+0.41283
  • 10+2.2215810+0.28870
  • 25+1.9746925+0.25662
  • 100+1.70489100+0.22156
  • 250+1.57622250+0.20484
  • 500+1.49863500+0.19475
  • 1000+1.434541000+0.18643
库存:2970
74HC123BQ,115
