74HCT221D,118
74HCT221D,118
    NEXPERIA(安世)
    SOIC-16
    带复位的双不可重触发单稳多谐振荡器
74HCT221D,118 数据手册
74HCT221 Dual non-retriggerable monostable multivibrator with reset Rev. 3 — 26 October 2016 Product data sheet 1. General description The 74HCT221 is a dual non-retriggerable monostable multivibrator. Each multivibrator features edge-triggered inputs (nA and nB), either of which can be used as an enable input. Pulse triggering occurs at a particular voltage level and is not directly related to the transition time of the input pulse. Schmitt-trigger input circuitry for the nB inputs allow jitter-free triggering from inputs with slow transition rates, providing the circuit with excellent noise immunity. Once triggered, the outputs (nQ, nQ) are independent of further transitions of nA and nB inputs. The output pulse width is defined by the following relationship: tW = 0.7  CEXT  REXT The output pulses can be terminated by the active LOW reset inputs (nRD). Pulse width stability is achieved through internal compensation and is virtually independent of VCC and temperature. In most applications pulse stability will only be limited by the accuracy of the external timing components. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Input levels:  For 74HCT221: TTL level  Pulse width variance is typically less than 5%  Direct reset terminates output pulse  Schmitt-trigger action on nB inputs  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package 74HCT221D Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 4. Functional diagram   6 4  $  &(;7 5(;7&(;7 4 7  4  % 4 5'  5'   6 $  4  &(;7 5(;7&(;7 4 7 4  %  4 5'  5' DDD Fig 1. Functional diagram   &;    5(;7&(;7  5(;7&(;7 4  $  $  %  % 4  4   7 Fig 2. Logic symbol 74HCT221 Product data sheet &; 4 5'   5&;  4   4    5'  5' 5   6  &(;7  &(;7  5&;  5 DDD DDD Fig 3. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 2 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset Q$ Q% Q5' 9&& SRZHURQ UHVHW 5 4 Q5(;7&(;7 ' 9&& )) & & 9&& SXOOGRZQ LSRS 9&& 4 ' )) & Q4 Q&(;7 Q4 4 & *1' 5 DDD Fig 4. Logic diagram 9&& 5(;7 &(;7 *1' Q&(;7 Q5(;7&(;7 DDD It is recommended to connect pins nCEXT externally to the GND pin. Fig 5. Timing component connections 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 3 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 5. Pinning information 5.1 Pinning +&7 $   9&& %   5(;7&(;7 5'   &(;7 4   4 4   4 &(;7   5' 5(;7&(;7   % *1'   $ DDD Fig 6. Pin configuration for SO16 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A 1 negative-edge triggered input 1 1B 2 positive-edge triggered input 1 1RD 3 direct reset LOW and positive-edge triggered input 1 1Q 4 active LOW output 1 2Q 5 active HIGH output 2 2CEXT 6 external capacitor connection 2 2REXT/CEXT 7 external resistor and capacitor connection 2 GND 8 ground (0 V) 2A 9 negative-edge triggered input 2 2B 10 positive-edge triggered input 2 2RD 11 direct reset LOW and positive-edge triggered input 2 2Q 12 active LOW output 2 1Q 13 active HIGH output 1 1CEXT 14 external capacitor connection 1 1REXT/CEXT 15 external resistor and capacitor connection 1 VCC 16 supply voltage 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 4 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 6. Functional description Table 3. Function table[1] Input Output nRD nA nB nQ nQ L X X L H H[2] H[2] X H X L[2] X X L L[2] H L  H  H  L H [1] [3] [3] H = HIGH voltage level; L = LOW voltage level; X = don’t care;  = LOW-to-HIGH transition;  = HIGH-to-LOW transition; = one HIGH level output pulse; = one LOW level output pulse. [2] If the monostable was triggered before this condition was established, the pulse will continue as programmed. [3] For this combination the reset input must be LOW and the following sequence must be used: pin nA must be set HIGH or pin nB set LOW; then pin nA must be LOW and pin nB set HIGH. Now the reset input goes from LOW-to-HIGH and the device will be triggered. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions VI < 0.5 V or VI > VCC + 0.5 V Min Max Unit 0.5 +7 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current except for pins nREXT/CEXT; VO = 0.5 V to (VCC + 0.5 V) - 25 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] SO16 package [1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 5 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage Conditions VO output voltage t/V input transition rise and fall rate Min Typ Max Unit 4.5 5.0 5.5 V 0 - VCC V 0 - VCC V - 1.67 139 ns/V 40 +25 +125 C nA, nRD input VCC = 4.5 V Tamb ambient temperature 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V - - 0.1 - 1.0 - 1.0 A - - 8.0 - 80 - 160 A pin nB - 30 108 - 135 - 147 A pins nA, nRD - 50 180 - 225 - 245 A - 3.5 - - - - - pF IO = 4 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A IO = 4.0 mA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V ICC additional per input pin; IO = 0 A; supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V CI input capacitance 74HCT221 Product data sheet VI = VCC or GND; VCC = 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 6 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 15. Symbol Parameter tPLH 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 4.5 V - 30 50 - 63 - 75 ns VCC = 5 V; CL = 15 pF - 36 - - - - - ns VCC = 4.5 V - 24 42 - 53 - 63 ns VCC = 5 V; CL = 15 pF - 36 - - - - - ns VCC = 4.5 V - 31 51 - 64 - 77 ns VCC = 5 V; CL = 15 pF - 36 - - - - - ns VCC = 4.5 V - 26 44 - 55 - 75 ns VCC = 5 V; CL = 15 pF - 32 - - - - - ns VCC = 4.5 V - 21 35 - 44 - 53 ns VCC = 5 V; CL = 15 pF - 32 - - - - - ns VCC = 4.5 V - 26 43 - 54 - 65 ns VCC = 5 V; CL = 15 pF - 32 - - - - - ns - 26 43 - 54 - 65 ns - 32 - - - - - ns - 7 15 - 19 - 22 ns LOW to HIGH CEXT = 0 pF; REXT = 5 k; propagation see Figure 7 and Figure 8 delay nA, nRD to nQ (trigger) nB to nQ (trigger) nRD to nQ (reset) tPHL HIGH to LOW CEXT = 0 pF; REXT = 5 k; propagation see Figure 7 and Figure 8 delay nA to nQ (trigger) nB to nQ (trigger) nRD to nQ (trigger) nRD to nQ (reset) VCC = 4.5 V VCC = 5 V; CL = 15 pF tt transition time VCC = 4.5 V; see Figure 7 74HCT221 Product data sheet [1] All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 7 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 15. Symbol Parameter tW pulse width 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max 20 13 - 25 - 30 - ns 22 13 - 28 - 33 - ns 630 700 770 602 798 595 805 s VCC = 4.5 V; CEXT = 28 pF; REXT = 2 k - 140 - - - - - ns VCC = 4.5 V; CEXT = 1 nF; REXT = 2 k - 1.5 - - - - - s VCC = 4.5 V; CEXT = 1 nF; REXT = 10 k - 7 - - - - - s 20 12 - 25 - 30 - ns 2 - 1000 - - - - k nA LOW; nB HIGH; (trigger); see Figure 7 VCC = 4.5 V nRD LOW; see Figure 10 VCC = 4.5 V nQ HIGH and nQ LOW; see Figure 8 VCC = 5 V; CEXT = 100 nF; REXT = 10 k nQ or nQ (trigger); see Figure 8 trec recovery time REXT external VCC = 5.0 V; see Figure 13 timing resistor CEXT external timing capacitor 74HCT221 Product data sheet nRD to nA, nB; see Figure 11 VCC = 5.0 V; see Figure 13 All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 no limits pF © Nexperia B.V. 2017. All rights reserved 8 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 15. Symbol Parameter CPD [1] [2] power dissipation capacitance 25 C Conditions per monostable; VI = GND to VCC  1.5 V 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 96 - - - - - [2] pF tt is the same as tTHL and tTLH CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi + (CL  VCC2  fo) + 0.33  CEXT  VCC2  fo + D  28  VCC where: fi = input frequency in MHz; fo = output frequency in MHz; D = duty factor in %; CL = output load capacitance in pF; VCC = supply voltage in V; CEXT = timing capacitance in pF; (CL  VCC2  fo) sum of outputs. 11. Waveforms and graphs W: 9, Q$LQSXW 90 *1' W: 9, Q%LQSXW 90 *1' 92+ Q4RXWSXW W3/+ 9< 90 9; 92/ W7+/ W: 92+ Q4RXWSXW 92/ 9< 90 9; W3+/ W7/+ DDD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Propagation delay from input (nA, nB) to output (nQ, nQ), nA, nB pulse widths and output transition times 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 9 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset Table 8. Measurement points Input Output VM VM VX VY 1.3 V 1.3 V 0.1VCC 0.9VCC 9, 90 Q5'LQSXW *1' W3+/ 92+ Q4RXWSXW 90 92/ W3/+ 92+ Q4RXWSXW 90 92/ DDD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. Propagation delay from reset input (nRD) to outputs (nQ, nQ) Q%LQSXW W: Q$LQSXW W: Q4RXWSXW W: W: DDD nRD = HIGH Fig 9. Output pulse control 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 10 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset Q%LQSXW Q5'LQSXW Q4RXWSXW W: W: DDD nA = LOW Fig 10. Output pulse control using reset input nRD W: 9, 90 Q5'LQSXW *1' WUHF 9, Q%LQSXW 90 *1' WUHF 9, Q$LQSXW 90 *1' DDD Measurement points are given in Table 8. Fig 11. Reset input (nRD) to inputs nA or nB recovery times 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 11 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset DDD  W: QV                    &(;7 S) VCC = 4.5 V; Tamb = 25 C. (1) REXT = 100 k (2) REXT = 50 k (3) REXT = 10 k (4) REXT = 2 k Fig 12. Typical output pulse width as a function of the external capacitor DDD  DDD C. IDFWRU W: —V                 7DPE ƒ& CEXT = 0.1 F; REXT = 10 k.; VCC = 5.0 V    9&& 9 REXT = 10 k; Tamb = 25 C. (1) CEXT = 0.001 F (2) CEXT = 0.01 F (3) CEXT = 0.1 F (4) CEXT = 1 F Fig 13. Typical output pulse width as a function of the ambient temperature 74HCT221 Product data sheet Fig 14. “K” factor as function of the supply voltage All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 12 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 9, W:  QHJDWLYH SXOVH 90 9 9, WI WU WU WI  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 57 6 RSHQ '87 &/ DDG Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 15. Test circuit for measuring switching times Table 9. Test data Input Load S1 position VI tr, tf CL RL tPHL, tPLH 3V 6 ns 15 pF, 50 pF 1 k open 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 13 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 12. Application information 12.1 Power-down considerations A large capacitor CEXT may cause problems when powering-down the monostable due to the energy stored in this capacitor. When a system containing this device is powered-down or a rapid decrease of VCC to zero occurs, the monostable may sustain damage, due to the capacitor discharging through the input protection diodes. To avoid this possibility, use a damping diode (DEXT) preferably a germanium or Schottky type diode able to withstand large current surges and connect as shown in Figure 16. '(;7 &(;7 *1' Q&(;7 5(;7 9&& Q5(;7&(;7 DDD Fig 16. Power-down protection circuit 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 14 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 13. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 17. Package outline SOT109-1 (SO16) 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 15 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 14. Abbreviations Table 10. Abbreviations Acronym Abbreviation CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HCT221 v.3 20161026 Product data sheet - 74HC_HCT221 v.2 Modifications: 74HC_HCT221 v.2 74HCT221 Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC221N, 74HC221D, 74HC221DB and 74HCT221N removed. 19901201 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 - © Nexperia B.V. 2017. All rights reserved 16 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HCT221 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 17 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HCT221 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 18 of 19 74HCT221 Nexperia Dual non-retriggerable monostable multivibrator with reset 18. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 12.1 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms and graphs . . . . . . . . . . . . . . . . . . . 9 Application information. . . . . . . . . . . . . . . . . . 14 Power-down considerations . . . . . . . . . . . . . . 14 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 15 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 October 2016 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HCT221D,112 74HCT221D,118
74HCT221D,118 价格&库存
很抱歉,暂时无法提供与“74HCT221D,118”相匹配的价格&库存,您可以联系我们找货
74HCT221D,118
  • 1+7.530171+0.93905
  • 10+5.3347610+0.66527
  • 50+4.4602050+0.55621
  • 100+4.19176100+0.52273
74HCT221D,118
  • 2500+3.444522500+0.42955
  • 5000+3.354595000+0.41834
