74HC423D,652
74HC423D,652
    NEXPERIA(安世)
    SOIC-16
    带复位的双可触发单稳多谐振荡器
74HC423D,652 数据手册
74HC423 Dual retriggerable monostable multivibrator with reset Rev. 7 — 11 February 2016 Product data sheet 1. General description The 74HC423 is a dual retriggerable monostable multivibrator with output pulse width control by two methods. The basic pulse time is programmed by selection of an external resistor (REXT) and capacitor (CEXT). Once triggered, the basic output pulse width may be extended by retriggering (nA) or (nB). By repeating this process, the output pulse period (nQ = HIGH, nQ = LOW) can be made as long as desired. When nRD is LOW, it forces the nQ output LOW, the nQ output HIGH and also inhibits the triggering. Schmitt-trigger action in the nA and nB inputs, makes the circuit highly tolerant to slower input rise and fall times. The '423' is identical to the '123' but cannot be triggered via the reset input. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits       DC triggered from active HIGH or active LOW inputs Retriggerable for very long pulses up to 100 % duty factor Direct reset terminates output pulse Schmitt-trigger action on all inputs except for the reset input Complies with JEDEC standard no. 7A Input levels:  For 74HC423: CMOS level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC423D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC423BQ 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin SOT763-1 quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 4. Functional diagram   6  4 &(;7 5(;7&(;7 4  $ 7  4  % 4 5'   5'  6  4 &(;7 5(;7&(;7 4  $ 7  4  % 4 5'  5' DDK Fig 1. Functional Diagram   &;  &(;7  &(;7   6 4  $  $  %  %  5'  5' Fig 2. Logic symbol 74HC423 Product data sheet 4  4  5' 4  5    7 4  5(;7&(;7  5(;7&(;7  5&; &;    5&;  4   DDK  5 DDK Fig 3. IEC Logic symbol All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 2 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 5(;7&(;7 9&& 4 5' 4 5 &/ &/ 9&& 9&& 5 &/ &/ $ &/ % Fig 4. DDK Logic diagram 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 3 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 5. Pinning information 5.1 Pinning +& 5'   &(;7 4   4 4   4 &(;7   5' 5(;7&(;7   % *1'   %   5(;7&(;7 5'   &(;7 4   4 4  &(;7  5(;7&(;7  $  4 9&&   5'  %   5(;7&(;7 $   %   9&& *1'  $ WHUPLQDO LQGH[DUHD $  9&& +& DDD 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to VCC. Fig 5. Pin configuration SO16 Fig 6. Pin configuration DHVQFN16 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A 1, 9 trigger input (negative edge triggered) 1B, 2B 2, 10 trigger input (positive edge triggered) 1RD, 2RD 3, 11 direct reset (active LOW) 1Q, 2Q 4, 12 output (active LOW) GND 8 ground (0 V) 1Q, 2Q 13, 5 output (active HIGH) 1CEXT, 2CEXT 14, 6 external capacitor connection 1REXT/CEXT, 2REXT/CEXT 15, 7 external resistor/capacitor connection VCC 16 supply voltage 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 4 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 6. Functional description Table 3. Function table[1] Input Output nRD nA nB nQ nQ L X X L H X H X L[2] H[2] L[2] H[2] X X L H L  H  H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care;  = LOW-to-HIGH transition;  = HIGH-to-LOW transition; = one HIGH level output pulse; = one LOW level output pulse. [2] If the monostable multivibrator was triggered before this condition was established, the pulse will continue as programmed. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V IO output current 0.5 V < VO < VCC + 0.5 V ICC supply current IGND ground current Tstg storage temperature total power dissipation Ptot [1] [2] Conditions SO16 and DHVQFN16 packages Min Max 0.5 +7 V [1] - 20 mA [1] - 20 mA - 25 mA - 50 mA 50 - mA 65 +150 C - 500 mW [2] Unit The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SO16 package: above 70 C the value of Ptot derates linearly at 8 mW/K; For DHVQFN16 package: above 60 C the value of Ptot derates linearly at 4.5 mW/K. 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 5 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate Min Typ Max Unit 2.0 0 5.0 6.0 V - VCC V 0 - VCC V 40 - +125 C VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - 1.67 139 ns/V VCC = 6.0 V - - 83 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol VIH VIL VOH VOL Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Min Typ Max Min Max Min Max Unit HIGH-level input voltage VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V LOW-level input voltage VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A CI input capacitance - 3.5 - - - - - pF 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 6 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; test circuit see Figure 12. Symbol Parameter tpd propagation delay 25 C Conditions nA or nB to nQ or nQ; REXT = 5 k; CEXT = 0 pF; see Figure 7 pulse width Typ Max Min Max Min Max VCC = 2.0 V - 80 255 - 320 - 385 ns - 29 51 - 64 - 77 ns VCC = 5.0 V; CL = 15 pF - 25 - - - - - ns - 23 43 - 54 - 65 ns VCC = 2.0 V - 66 215 - 270 - 325 ns VCC = 4.5 V - 24 43 - 54 - 65 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns - 19 37 - 46 - 55 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 100 11 - 125 - 150 - ns VCC = 4.5 V 20 4 - 25 - 30 - ns VCC = 6.0 V 17 3 - 21 - 26 - ns VCC = 2.0 V 100 17 - 125 - 150 - ns VCC = 4.5 V 20 6 - 25 - 30 - ns VCC = 6.0 V 17 5 - 21 - 26 - ns VCC = 2.0 V 100 14 - 125 - 150 - ns VCC = 4.5 V 20 5 - 25 - 30 - ns VCC = 6.0 V 17 4 - 21 - 26 - ns - 450 - - - - - s [1] VCC = 6.0 V tW Min VCC = 4.5 V nRD to nQ or nQ; see Figure 7 transition time 40 C to Unit +125 C [1] VCC = 6.0 V tt 40 C to +85 C [2] see Figure 7 nA input LOW; see Figure 7 and Figure 8 nB input HIGH; see Figure 7 and Figure 8 nRD input LOW; see Figure 7 and Figure 8 nQ HIGH or nQ LOW; VCC = 5.0 V; REXT = 10 k; CEXT = 100 nF; see Figure 7 and Figure 8 trtrig retrigger time 74HC423 Product data sheet nQ HIGH or nQ LOW; VCC = 5.0 V; REXT = 5 k; CEXT = 0 pF; VI = GND to VCC; see Figure 7 and Figure 8 [3] - 75 - - - - - ns nA or nB input; VCC = 5.0 V; REXT = 5 k; CEXT = 0 pF; see Figure 10 [4] - 110 - - - - - ns All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 7 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset Table 7. Dynamic characteristics …continued GND = 0 V; test circuit see Figure 12. Symbol Parameter REXT 25 C Conditions external timing VCC = 2.0 V; see Figure 8 resistor VCC = 5.0 V CEXT external timing VCC = 5.0 V; see Figure 8 capacitor [5] CPD power dissipation capacitance [6] per package; VI = GND to VCC 40 C to +85 C 40 C to Unit +125 C Min Typ 10 - 1000 Max Min Max Min Max - - - - k 2 - 1000 - - - - k no limits - 54 [1] tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] For other REXT and CEXT combinations see Figure 8. If CEXT > 10 pF, the next formula is valid: - - pF - - - pF tW = K  REXT  CEXT (typ.), where: tW = output pulse width in ns; REXT = external resistor in k; CEXT = external capacitor in pF; K = 0.55 for VCC = 2.0 V and 0.45 for VCC = 5.0 V; see Figure 9. Inherent test jig and pin capacitance at pins 15 and 7 (nREXT/CEXT) is 7 pF. [4] The time to retrigger the monostable multivibrator depends on the values of REXT and CEXT. The output pulse width will only be extended when the time between the active-going edges of the trigger input pulses meets the minimum retrigger time. If CEXT > 10 pF, the next formula (at VCC = 5.0 V) for the set-up time of a retrigger pulse is valid: trtrig = 30 + 0.19  REXT  CEXT0.9 + 13  REXT1.05 (typ.); where: trtrig = retrigger time in ns; CEXT = external capacitor in pF; REXT = external resistor in k. Inherent test jig and pin capacitance at pins 15 and 7 (nREXT/CEXT) is 7 pF. [5] [6] When the device is powered-up, initiate the device via a reset pulse, when CEXT < 50 pF. CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N + (CL  VCC2  fo); where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 8 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 11. Waveforms 9, Q%LQSXW 90 *1' W: 9, 90 Q$LQSXW *1' W: W: 9, 90 Q5'LQSXW *1' W3/+ W3/+ 92+ Q4RXWSXW Q4RXWSXW W3/+ W3/+ UHVHW W3+/ 90 9; 92/ 92+ W3+/ UHVHW 9< W: W7/+ W3+/ W7+/ W3+/ 9< 90 9; 92/ W: W7+/ W7/+ DDK Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Table 8. Pulse widths, propagation delays from inputs (nA, nB, nRD) to outputs (nQ, nQ) and output transition times Measurement points Input Output VI VM VM VX VY VCC 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 9 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset DDD  W:  QV DDD  . IDFWRU                   &(;7 S)      9&& 9 VCC = 5.0 V and Tamb = 25 C. External capacitance = 10 nF, external resistance = 10 k to 100 k and Tamb = 25 C. (1) REXT = 100 k. (2) REXT = 50 k. (3) REXT = 10 k. (4) REXT = 2 k. Fig 8. Typical output pulse width as a function of the external capacitor values Fig 9. Typical ‘K’ factor Q%LQSXW W: Q$LQSXW WUWULJ W: Q4RXWSXW W: W: W: PQD nRD = HIGH. Fig 10. Output pulse control using retrigger pulse (trtrig) 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 10 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset Q%LQSXW Q5'LQSXW W: Q4RXWSXW W: W: PQD nA = LOW. Fig 11. Output pulse control using reset input nRD 9, QHJDWLYH SXOVH W:  90 90  *1' WI 9, WI  SRVLWLYH SXOVH *1' WU WU 90 90  W: 9&& * 9, 92 '87 57 &/ DDK  Test data is given in Table 9. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Fig 12. Test circuit for measuring switching times Table 9. Test data Supply Input VCC VI tr, tf CL 2.0 V to 6.0 V VCC 6 ns 15 pF, 50 pF 74HC423 Product data sheet Load All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 11 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 12. Application information 12.1 Timing component connections The basic output pulse width is essentially determined by the values of the external timing components REXT and CEXT.  &(;7 *1' Q&(;7    5(;7 9&& Q5(;7&(;7      Q4   Q$ Q%     Q4   Q5' DDK (1) For minimum noise generation it is recommended that the nCEXT pins (6, 14) are connected to ground externally to the GND pin (8). Fig 13. Timing component connections 12.1.1 Minimum monostable pulse width To set the minimum pulse width, when CEXT < 10 nF, see Figure 8 and when CEXT > 10 nF, the output pulse width is defined as: tW = 0.45  REXT  CEXT (typ.), where: tW = pulse width in s; REXT = external resistor in k; CEXT = external capacitor in nF. 12.2 Power-up considerations When the monostable is powered-up it may produce an output pulse, with a pulse width defined by the values of REXT and CEXT, this output pulse can be eliminated using the circuit shown in Figure 14. 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 12 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset &(;7 5(;7 9&& *1' Q&(;7 Q5(;7&(;7         Q4   Q$ Q%     Q4   Q5' 9&& 5(6(7 DDK Fig 14. Power-up output pulse elimination circuit 12.3 Power-down considerations A large capacitor CEXT may cause problems when powering-down the monostable due to the capacitor’s stored energy. When a system containing this device is powered-down or a rapid decrease of VCC to zero occurs, the monostable may sustain damage, due to the capacitor discharging through the input protection diodes. To avoid this possibility, use a damping diode DEXT preferably a germanium or Schottky type diode able to withstand large current surges and connect as shown in Figure 15. '(;7 &(;7 5(;7 9&& *1' Q&(;7 Q5(;7&(;7         Q4   Q$ Q%     Q4   Q5' DDK Fig 15. Power-down protection circuit 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 13 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 13. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 16. Package outline SOT109-1 (SO16) 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 14 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset '+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV 627 WHUPLQDOVERG\[[PP % ' $ $ $ ( F GHWDLO; WHUPLQDO LQGH[DUHD WHUPLQDO LQGH[DUHD & H H E   \ \ & Y 0 & $ % Z 0 & /   (K H     'K ;   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $   PD[ $ E F '   'K (   (K H H / Y Z \ \ PP                       1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& -(,7$ 627  02  (8523($1 352-(&7,21 ,668('$7(    Fig 17. Package outline SOT763-1 (DHVQFN16) 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 15 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 14. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC423 v.7 20160211 Product data sheet - 74HC_HCT423 v.6 Modifications: 74HC_HCT423 v.6 Modifications: • Type numbers 74HC423N, 74HCT423N, 74HCT423D, 74HCT423DB, 74HCT423PW and 74HCT423BQ removed. 20111219 • Product data sheet - 74HC_HCT423 v.5 Legal pages updated. 74HC_HCT423 v.5 20110825 Product data sheet - 74HC_HCT423 v.4 74HC_HCT423 v.4 20110318 Product data sheet - 74HC_HCT423 v.3 74HC_HCT423 v.3 20080724 Product data sheet - 74HC_HCT423_CNV v.2 74HC_HCT423_CNV v.2 19980708 Product specification - - 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 16 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC423 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 17 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC423 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 11 February 2016 18 of 19 © Nexperia B.V. 2017. All rights reserved 74HC423 Nexperia Dual retriggerable monostable multivibrator with reset 18. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 12.1 12.1.1 12.2 12.3 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Application information. . . . . . . . . . . . . . . . . . 12 Timing component connections . . . . . . . . . . . 12 Minimum monostable pulse width. . . . . . . . . . 12 Power-up considerations . . . . . . . . . . . . . . . . 12 Power-down considerations . . . . . . . . . . . . . . 13 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 February 2016 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC423BQ,115 74HC423D,652 74HC423D,653
74HC423D,652 价格&库存
很抱歉,暂时无法提供与“74HC423D,652”相匹配的价格&库存,您可以联系我们找货
