HEF4047BT,652
HEF4047BT,652
    NEXPERIA(安世)
    SOIC14_150MIL
    单稳态/不稳多谐振荡器
HEF4047BT,652 数据手册
HEF4047B Monostable/astable multivibrator Rev. 6 — 17 March 2017 1 Product data sheet General description The HEF4047B is a retriggerable astable multivibrator that can be configured as either a positive-edge or negative-edge triggered monostable multivibrator. The output pulse width is programmed by selection of external components (Rt and Ct). Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2 Features and benefits 2.1 General • Monostable (one-shot) or astable (free-running) operation • True and complemented buffered outputs • Only one external resistor and capacitor required 2.2 Monostable multivibrator • • • • • • Positive- or negative-edge triggering Output pulse width independent of trigger pulse duration Retriggerable option for pulse-width expansion Long pulse width possible using small RC components with external counter provision Fast recovery time independent of pulse width Pulse-width accuracy maintained at duty cycles approaching 100% 2.3 Astable multivibrator • Free-running or gatable operating modes • 50% duty cycle • Oscillator output available 3 Ordering information Table 1. Ordering information Type number HEF4047BT Package Name Description Version SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 HEF4047B Nexperia Monostable/astable multivibrator 4 Functional diagram Rt Ct ASTABLE ASTABLE - TRIGGER + TRIGGER 5 RCTC CTC RTC 3 2 1 13 ASTABLE GATE CONTROL 4 12 RETRIGGER CONTROL ASTABLE MULTIVIBRATOR 6 MONOSTABLE CONTROL 8 10 FREQUENCY DIVIDER (÷ 2) 11 9 OSCILLATOR OUTPUT RETRIGGER O O MR aaa-013282 Figure 1. Functional diagram VDD RCTC(1) ASTABLE ASTABLE + TRIGGER CTC - TRIGGER D O RTC FF 1 CP OSCILLATOR OUTPUT CD CD SD VSS RETRIGGER D SD O D FF 2 CP D FF 3 O CD O CP O O O O FF 4 O CD CD MR CP CD aaa-013284 (1) Special input protection that allows operating input voltages outside the supply voltage lines. Compared to the standard inputprotection pin 3 (RCTC) is more sensitive to static discharge; extra handling precautions are recommended. Figure 2. Logic diagram HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 22 HEF4047B Nexperia Monostable/astable multivibrator 5 Pinning information 5.1 Pinning CTC 1 14 VDD RTC 2 13 RCTC 3 12 RETRIGGER ASTABLE 4 HEF4047B 11 O ASTABLE 5 10 O - TRIGGER 6 9 MR VSS 7 8 + TRIGGER OSCILLATOR OUTPUT aaa-013283 Figure 3. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description CTC 1 external capacitor connection RTC 2 external resistor connection RCTC 3 external capacitor/resistor connection ASTABLE 4 input ASTABLE 5 input -TRIGGER 6 input VSS 7 ground supply voltage +TRIGGER 8 input MR 9 master reset input O 10 output O 11 output RETRIGGER 12 input OSCILLATOR OUTPUT 13 oscillator output VDD 14 supply voltage HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 22 HEF4047B Nexperia Monostable/astable multivibrator 6 Functional description The HEF4047B consists of a gate-able astable multivibrator incorporating logic techniques to permit positive or negative edge-triggered monostable multivibrator action with retriggering and external counting options. Inputs include +TRIGGER, −TRIGGER, ASTABLE, ASTABLE, RETRIGGER and MR (master reset). Buffered outputs are O, O and OSCILLATOR OUTPUT. In all modes of operation an external capacitor (Ct) must be connected between CTC and RCTC, and an external resistor (Rt) must be connected between RTC and RCTC. A HIGH level on the ASTABLE input enables astable operation. The period of the square wave at O and O outputs is a function of the external components employed. ‘True’ input pulses on the ASTABLE or ‘complement’ pulses on the ASTABLE input, allow the circuit to be used as a gate-able multivibrator. The OSCILLATOR OUTPUT period is half of the O output in the astable mode. However, a 50% duty factor is not guaranteed at this output. In the monostable mode, positive edge-triggering is accomplished by applying a leadingedge pulse to the +TRIGGER input and a LOW level to the −TRIGGER input. For negative edge-triggering, a trailing-edge pulse is applied to the −TRIGGER and a HIGH level to the +TRIGGER. Input pulses may be of any duration relative to the output pulse. The multivibrator can be retriggered (on the leading-edge only) by applying a common pulse to both the RETRIGGER and +TRIGGER inputs. In this mode, the output pulse remains HIGH as long as the input pulse period is shorter than the period determined by the RC components. An external count down option implements coupling O to an external ‘N’ counter and resetting the counter with the trigger pulse. The counter output pulse is fed back to the ASTABLE input and has a duration equal to N times the period of the multivibrator. A HIGH level on the MR input assures no output pulse during an ON-power condition. This input can also be activated to terminate the output pulse at any time. In the monostable mode, a HIGH level or power-ON reset pulse must be applied to MR, whenever VDD is applied. HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 22 HEF4047B Nexperia Monostable/astable multivibrator 7 Limiting values Table 3. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit -0.5 +18 V - ±10 mA -0.5 VDD + 0.5 - ±10 mA VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current - ±10 mA IDD supply current - 50 mA Tstg storage temperature -65 +150 °C Tamb ambient temperature -40 +85 °C Ptot total power dissipation - 500 mW - 100 mW Min Max Unit VI < -0.5 V or VI > VDD + 0.5 V VO < -0.5 V or VO > VDD + 0.5 V Tamb = -40 °C to +85 °C SO14 package P [1] power dissipation V per output [1] For SO14 package: Ptot derates linearly with 8 mW/K above 70 °C. 8 Recommended operating conditions Table 4. Operating conditions Symbol Parameter Conditions VDD supply voltage 3 15 V VI input voltage 0 VDD V Tamb ambient temperature in free air -40 +85 °C Δt/ΔV input transition rise and fall rate VDD = 5 V - 3.75 μs/V VDD = 10 V - 0.5 μs/V VDD = 15 V - 0.08 μs/V HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 22 HEF4047B Nexperia Monostable/astable multivibrator 9 Static characteristics Table 5. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL II IDD CI HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage HIGH-level output current LOW-level output current input leakage current supply current input capacitance HEF4047B Product data sheet Conditions Tamb = -40 °C Tamb = 25 °C Tamb = 85 °C Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V VO = 2.5 V 5V - -1.7 - -1.4 - -1.1 mA VO = 4.6 V 5V - -0.52 - -0.44 - -0.36 mA VO = 9.5 V 10 V - -1.3 - -1.1 - -0.9 mA VO = 13.5 V 15 V - -3.6 - -3.0 - -2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - ±0.3 - ±0.3 - ±1.0 μA output transistor OFF; 15 V pin 3 at VDD or VSS - ±0.3 - ±0.3 - ±1.0 μA 5V - 20 - 20 - 150 μA 10 V - 40 - 40 - 300 μA 15 V - 80 - 80 - 600 μA - - - - 7.5 - - pF |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA IO = 0 A VDD All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 Unit © Nexperia B.V. 2017. All rights reserved. 6 / 22 HEF4047B Nexperia Monostable/astable multivibrator 10 Dynamic characteristics Table 6. Dynamic characteristics VSS = 0 V; Tamb = 25 °C; unless otherwise specified; for waveform and test circuit, see Figure 4 and Figure 5. Symbol Parameter tPHL tPLH HIGH to LOW propagation delay LOW to HIGH propagation delay Conditions Extrapolation formula Min Typ 68 ns + (0.55 ns/pF)CL - 95 190 ns 43 ns + (0.23 ns/pF)CL - 45 90 ns 22 ns + (0.16 ns/pF)CL - 30 60 ns 58 ns + (0.55 ns/pF)CL - 85 170 ns 29 ns + (0.23 ns/pF)CL - 40 80 ns 22 ns + (0.16 ns/pF)CL - 30 60 ns 123 ns + (0.55 ns/pF)CL - 150 300 ns 54 ns + (0.23 ns/pF)CL - 65 130 ns 42 ns + (0.16 ns/pF)CL - 50 100 ns 103 ns + (0.55 ns/pF)CL - 130 260 ns 49 ns + (0.23 ns/pF)CL - 60 120 ns 37 ns + (0.16 ns/pF)CL - 45 90 ns 133 ns + (0.55 ns/pF)CL - 160 320 ns 54 ns + (0.23 ns/pF)CL - 65 130 ns 42 ns + (0.16 ns/pF)CL - 50 100 ns 128 ns + (0.55 ns/pF)CL - 155 310 ns 54 ns + (0.23 ns/pF)CL - 65 130 ns 42 ns + (0.16 ns/pF)CL - 50 100 ns 38 ns + (0.55 ns/pF)CL - 65 130 ns 19 ns + (0.23 ns/pF)CL - 30 60 ns 17 ns + (0.16 ns/pF)CL - 25 50 ns 68 ns + (0.55 ns/pF)CL - 95 190 ns 29 ns + (0.23 ns/pF)CL - 40 80 ns 22 ns + (0.16 ns/pF)CL - 30 60 ns 83 ns + (0.55 ns/pF)CL - 100 200 ns 34 ns + (0.23 ns/pF)CL - 45 90 ns 27 ns + (0.16 ns/pF)CL - 35 70 ns 83 ns + (0.55 ns/pF)CL - 100 200 ns 34 ns + (0.23 ns/pF)CL - 45 90 ns 27 ns + (0.16 ns/pF)CL - 35 70 ns 10 ns + (1.0 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns VDD ASTABLE, ASTABLE to OSCILLATOR OUTPUT ASTABLE, ASTABLE to OSCILLATOR OUTPUT 5V [1] 10 V [1] 15 V [1] 5V [1] 10 V 15 V tPHL HIGH to LOW propagation delay ASTABLE, ASTABLE to O, O 5V [1] 10 V 15 V tPLH LOW to HIGH propagation delay ASTABLE, ASTABLE to O, O 5V [1] 10 V 15 V tPHL HIGH to LOW propagation delay +/-TRIGGER to O, O 5V [1] 10 V 15 V tPLH LOW to HIGH propagation delay +/-TRIGGER to O, O 5V [1] 10 V 15 V tPHL HIGH to LOW propagation delay +TRIGGER, RETRIGGER to O 5V [1] 10 V 15 V tPLH LOW to HIGH propagation delay +TRIGGER, RETRIGGER to O 5V [1] 10 V 15 V tPHL HIGH to LOW propagation delay MR to O 5V [1] 10 V 15 V tPLH LOW to HIGH propagation delay MR to O 5V [1] 10 V 15 V tTHL HIGH to LOW output transition time HEF4047B Product data sheet 5V [1] All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 Max Unit © Nexperia B.V. 2017. All rights reserved. 7 / 22 HEF4047B Nexperia Monostable/astable multivibrator Symbol Parameter tTLH Conditions pulse width any input except MR MR HIGH [1] Min Typ 10 ns + (1.0 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 5V - 220 110 - ns 10 V - 100 50 - ns 15 V - 70 35 - ns 5V - 60 30 - ns 10 V - 30 15 - ns 15 V - 20 10 - ns [1] 5V LOW to HIGH output transition time tW Extrapolation formula VDD Max Unit The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). 10.1 Waveform and test circuit tr VI 90 % VM input 0V tf 10 % VOH output VOL tW tPHL tPLH 90 % VM 10 % tTHL tTLH aaa-014878 Measurement points are given in Table 7. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Figure 4. input to output propagation delays, output transition time and pulse width Table 7. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 22 HEF4047B Nexperia Monostable/astable multivibrator VI negative pulse tW 90 % 90 % VM 10 % 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % 90 % VM VM 10 % 10 % tW 001aaj781 a. Input waveform VEXT VDD G VI RL VO DUT RT CL 001aaj915 b. Test circuit Test and measurement data is given in Table 8. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Figure 5. Test circuit for measuring switching times Table 8. Test data Supply voltage 5 V to 15 V HEF4047B Product data sheet Input VEXT Load VI tr, tf CL RL tPLH, tPHL VDD ≤ 20 ns 50 pF 1 kΩ open All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 22 HEF4047B Nexperia Monostable/astable multivibrator 11 Application information Table 9. Functional connections [1] Function Pins connected to Output pulse Output period or pulse width input pulse from pins VDD VSS 4, 5, 6, 14 7, 8, 9, 12 - 10, 11, 13 4, 6, 14 7, 8, 9, 12 5 10, 11, 13 6, 14 5, 7, 8, 9, 12 4 10, 11, 13 Positive edgetriggering 4, 14 5, 6, 7, 9, 12 8 10, 11 Negative edgetriggering 4, 8, 14 5, 7, 9, 12 6 10, 11 4, 14 5, 6, 7, 9 8, 12 10, 11 14 5, 6, 7, 8, 9, 12 - 10, 11 Astable multivibrator Free running True gating Complement gating at pins 10, 11; tA = 4.40 RtCt at pin 13; tA = 2.20 RtCt Monostable multivibrator Retriggerable External countdown [1] [2] [2] at pins 10, 11; tM = 2.48 RtCt In all cases, external resistor between pins 2 and 3, external capacitor between pins 1 and 3. Input pulse to RESET of external counting chip: external counting chip output to pin 4. HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 22 HEF4047B Nexperia Monostable/astable multivibrator 11.1 Astable mode design information 11.1.1 Unit-to-unit transfer voltage variations The following analysis presents worst case variations from unit-to-unit as a function of transfer voltage (VTR) shift for free running (astable) operation. OSCILLATOR OUTPUT (pin 13) t1 t2 t1 t2 O OUTPUT (pin 10) 1 t 2 A tA 1 t 2 A aaa-013285 Figure 6. Astable mode waveforms (1) (2) (3) , where tA = astable mode pulse width; see Table 10. Table 10. Values for astable mode pulse width (tA) VTR VDD = 5 V or 10 V VDD = 15 V [1] HEF4047B Product data sheet tA Typ [1] Min Typ Max Min Max 0.3 × VDD 0.5 × VDD 0.7 × VDD 4.71 RtCt 4.40 RtCt 4.71 RtCt 4V 0.5 × VDD 11 V 4.84 RtCt 4.40 RtCt 4.84 RtCt Therefore if tA = 4.40 RtCt is used, the maximum variation is (+7.0%; -0.0%) at 10 V. All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 22 HEF4047B Nexperia Monostable/astable multivibrator 11.1.2 Variations due to changes in VDD In addition to variations from unit-to-unit, the astable period may vary as a function of frequency with respect to VDD. Typical variations are presented graphically in Figure 7 and Figure 8 with 10 V as a reference. aaa-013286 7.5 period accuracy for O and O (%) 5.0 (1) (2) (3) 2.5 0 -2.5 0 5 10 VDD (V) 15 (1)Tamb = 25 °C; fo = 10 kHz; Ct = 100 pF; Rt = 220 kΩ. (2)Tamb = 25 °C; fo = 5 kHz; Ct = 100 pF; Rt = 470 kΩ. (3)Tamb = 25 °C; fo = 1 kHz; Ct = 1000 pF; Rt = 220 kΩ. Figure 7. Typical O and O period accuracy as a function of supply voltage; astable mode. aaa-013287 15 (1) (2) (3) (4) period accuracy for O and O (%) 10 5 0 -5 0 5 10 VDD (V) 15 (1)Tamb = 25 °C; fo = 500 kHz; Ct = 10 pF; Rt = 47 kΩ. (2)Tamb = 25 °C; fo = 225 kHz; Ct = 100 pF; Rt = 10 kΩ. (3)Tamb = 25 °C; fo = 100 kHz; Ct = 100 pF; Rt = 22 kΩ. (4)Tamb = 25 °C; fo = 50 kHz; Ct = 100 pF; Rt = 47 kΩ. Figure 8. Typical O and O period accuracy as a function of supply voltage; astable mode. HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 22 HEF4047B Nexperia Monostable/astable multivibrator 11.2 Monostable mode design information The following analysis presents worst case variations from unit-to-unit as a function of transfer voltage (VTR) shift for one-shot (monostable) operation. + TRIGGER (pin 8) OSCILLATOR OUTPUT (pin 13) t1' t2 t1 ' t2 O OUTPUT (pin 10) tM tM aaa-013288 Figure 9. Monostable waveforms. (4) (5) (6) , where tM = monostable mode pulse width; see table Table 11. Table 11. Values for monostable mode pulse width (tM) VTR Min VDD = 5 V or 10 V VDD = 15 V [1] HEF4047B Product data sheet 0.3 × VDD 4V Typ 0.5 × VDD 0.5 × VDD tM Max 0.7 × VDD 11 V Min Typ [1] Max 2.78 RtCt 2.48 RtCt 2.52 RtCt 2.88 RtCt 2.48 RtCt 2.56 RtCt 1 In the astable mode, the first positive half cycle has a duration of tM: succeeding durations are ⁄2 tA. Therefore if tM = 2.48 RtCt is used, the maximum variation is (+12%; -0.0%) at 10 V. All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 22 HEF4047B Nexperia Monostable/astable multivibrator 11.2.1 Retrigger mode operation The HEF4047B can be used in the retrigger mode to extend the output pulse duration. It can also be used to compare the frequency of an input signal with the frequency of the internal oscillator. In the retrigger mode, the input pulse is applied to pins 8 and 12, and the output is taken from pin 10 or 11. Normal monostable action is obtained when one retrigger pulse is applied (see Figure 10). Extended pulse duration is obtained when more than one pulse is applied. For two input pulses, tRE = t1' + t1 + 2t2 . For more than two pulses, tRE (output O), terminates at some variable time, tD, after the termination of the last retrigger pulse. tD is variable because tRE (output O) terminates after the second positive edge of the oscillator output appears at flip-flop 4. + TRIGGER; RETRIGGER (pins 8, 12) OSCILLATOR OUTPUT (pin 13) t1 ' t1 t2 t1' t2 t2 O OUTPUT (pin 10) tRE tRE tRE tD aaa-013289 Figure 10. Retrigger mode waveforms. 11.2.2 External counter option The use of external counting circuitry extends time tM by any amount. Advantages include digitally controlled pulse duration, small timing capacitors for long time periods, and extremely fast recovery time. A typical implementation is shown in Figure 11. The pulse duration at the output is: (7) Where text = pulse duration of the circuitry, and N is the number of counts used. HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 22 HEF4047B Nexperia Monostable/astable multivibrator 4 ASTABLE HEF4047B 10 O CP0 14 HEF4017B 12 O5-9 optional buffer output 15 MR input pulse text aaa-013290 Figure 11. Implementation of external counter option. 11.2.3 Timing component limitations The capacitor used in the circuit should be non-polarized and have low leakage (that is the parallel resistance of the capacitor should be an order of magnitude greater than the external resistor used). There is no upper or lower limit for either Rt or Ct value to maintain oscillation. However, for accuracy, Ct must be much larger than the inherent stray capacitance in the system (unless this capacitance can be measured and taken into account). Rt must be much larger than the LOCMOS ‘ON’ resistance in series with it, which typically is hundreds of ohms. The recommended values for Rt and Ct to comply with previously calculated formulae without trimming should be: • Ct ≥ 100 pF, up to any practical value • 10 kΩ ≤ Rt ≤ 1 MΩ 11.2.4 Power consumption In the standby mode (monostable or astable), power dissipation is a function of leakage current in the circuit. For dynamic operation, the power required to charge the external timing capacitor Ct is shown in the following formulae: Astable mode: (8) (9) HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 22 HEF4047B Nexperia Monostable/astable multivibrator Monostable mode: (10) Because the power dissipation does not depend on Rt, a design for minimum power dissipation would be a small value of Ct. The value of R would depend on the desired period (within the limitations discussed previously). Typical power consumption in astable mode is shown in Figure 12, Figure 13 and Figure 14. aaa-013291 105 P (µW) 104 (1) (2) (3) (4) (5) 103 102 10 1 10 102 103 104 105 f (Hz) 106 VDD = 5 V. (1) Ct = 100 nF. (2) Ct = 10 nF. (3) Ct = 1 nF. (4) Ct = 100 pF. (5) Ct = 10 pF. Figure 12. Power consumption as a function of the output frequency at O or O; astable mode. HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 22 HEF4047B Nexperia Monostable/astable multivibrator aaa-013292 106 P (µW) 105 (1) 104 103 1 10 102 (2) 103 (3) 104 (4) 105 (5) f (Hz) 106 VDD = 10 V. (1) Ct = 100 nF. (2) Ct = 10 nF. (3) Ct = 1 nF. (4) Ct = 100 pF. (5) Ct = 10 pF. Figure 13. Power consumption as a function of the output frequency at O or O; astable mode. aaa-013293 106 P (µW) 105 (1) (2) (3) (4) (5) 104 103 1 10 102 103 104 105 f (Hz) 106 VDD = 15 V. (1) Ct = 100 nF. (2) Ct = 10 nF. (3) Ct = 1 nF. (4) Ct = 100 pF. (5) Ct = 10 pF. Figure 14. Power consumption as a function of the output frequency at O or O; astable mode. HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 17 / 22 HEF4047B Nexperia Monostable/astable multivibrator 12 Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 15. Package outline SOT108-1 (SO14) HEF4047B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 18 / 22 HEF4047B Nexperia Monostable/astable multivibrator 13 Abbreviations Table 12. Abbreviations Acronym Description DUT Device Under Test 14 Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4047B v.6 20170317 Product data sheet - HEF4047B v.5 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. HEF4047B v.5 20151216 Modifications: • Type number HEF4047BP (SOT27-1) removed. HEF4047B v.4 20140915 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. HEF4047B_CVN_3 19950101 HEF4047B Product data sheet Product data sheet Product data sheet Product specification - - All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 HEF4047B v.4 HEF4047B_CVN_3 - © Nexperia B.V. 2017. All rights reserved. 19 / 22 HEF4047B Nexperia Monostable/astable multivibrator 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical HEF4047B Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 20 / 22 HEF4047B Nexperia Monostable/astable multivibrator Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer HEF4047B Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 March 2017 © Nexperia B.V. 2017. All rights reserved. 21 / 22 HEF4047B Nexperia Monostable/astable multivibrator Contents 1 2 2.1 2.2 2.3 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 11.1 11.1.1 11.1.2 11.2 11.2.1 11.2.2 11.2.3 11.2.4 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 General .............................................................. 1 Monostable multivibrator ....................................1 Astable multivibrator .......................................... 1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 5 Recommended operating conditions ................ 5 Static characteristics .......................................... 6 Dynamic characteristics .....................................7 Waveform and test circuit ..................................8 Application information .................................... 10 Astable mode design information .................... 11 Unit-to-unit transfer voltage variations ............. 11 Variations due to changes in VDD ...................12 Monostable mode design information .............. 13 Retrigger mode operation ................................14 External counter option ....................................14 Timing component limitations .......................... 15 Power consumption ......................................... 15 Package outline .................................................18 Abbreviations .................................................... 19 Revision history ................................................ 19 Legal information .............................................. 20 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 March 2017 Document identifier: HEF4047B Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: HEF4047BT,652 HEF4047BT,653
HEF4047BT,652 价格&库存
很抱歉,暂时无法提供与“HEF4047BT,652”相匹配的价格&库存,您可以联系我们找货
