HEF4528BT-Q100J
HEF4528BT-Q100J
    NEXPERIA(安世)
    SOIC-16
    双单稳态多谐振荡器
HEF4528BT-Q100J 数据手册
HEF4528B-Q100 Dual monostable multivibrator Rev. 1 — 14 March 2017 1 Product data sheet General description The HEF4528B-Q100 is a dual retriggerable-resetable monostable multivibrator. Each multivibrator has an active LOW input (nA), and active HIGH input (nB), an active LOW clear direct input (nCD), an output (nQ) and its complement (nQ), and two external timing component connecting pins (nCEXT, always connected to ground, and nREXT/CEXT). An external timing capacitor (CEXT) must be connected between nCEXT and nREXT/CEXT and an external resistor (REXT) must be connected between nREXT/CEXT and VDD. The output pulse duration is determined by the external timing components CEXT and REXT. A HIGH-to-LOW transition on nA when nB is LOW or a LOW-to-HIGH transition on nB when nA is HIGH produces a positive pulse (LOW-HIGH-LOW) on nQ and a negative pulse (HIGH-LOW-HIGH) on nQ if the nCD is HIGH. A LOW on nCD forces nQ LOW, nQ HIGH and inhibits any further pulses until nCD is HIGH. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 3) and is suitable for use in automotive applications. 2 Features and benefits • Automotive product qualification in accordance with AEC-Q100 (Grade 3) – Specified from -40 °C to +85 °C • Fully static operation • 5 V, 10 V, and 15 V parametric ratings • Standardized symmetrical output characteristics • ESD protection: – MIL-STD-883, method 3015 exceeds 2000 V – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) • Complies with JEDEC standard JESD 13-B 3 Ordering information Table 1. Ordering information All types operate from -40 °C to +85 °C. Type number HEF4528BT-Q100 Package Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4528B-Q100 Nexperia Dual monostable multivibrator 4 Functional diagram nCEXT nREXT/ CEXT 2 1REXT/CEXT 1 1CEXT nA nB 5 1A 4 1B 3 1CD 14 2REXT/CEXT 15 2CEXT 1Q 6 1Q 7 2Q 10 2Q 9 nCD 11 2A 12 2B 13 2CD nQ nQ 001aae729 001aae727 Figure 2. Logic diagram for one monostable multivibrator Figure 1. Functional diagram 5 Pinning information 5.1 Pinning HEF4528B-Q100 1CEXT 1 16 VDD 1REXT/CEXT 2 15 2CEXT 1CD 3 14 2REXT/CEXT 1B 4 13 2CD 1A 5 12 2B 1Q 6 11 2A 1Q 7 10 2Q VSS 8 9 2Q aaa-026534 Figure 3. Pin configuration (SO16) HEF4528B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator 5.2 Pin description Table 2. Pin description Symbol Pin Description 1CEXT, 2CEXT 1, 15 external capacitor connection (always connected to ground) 1REXT/CEXT, 2REXT/CEXT 2, 14 external capacitor/resistor connection 1CD, 2CD 3, 13 clear direct input (active LOW) 1B, 2B 4, 12 input (LOW-to-HIGH triggered) 1A, 2A 5, 11 input (HIGH-to-LOW triggered) 1Q, 2Q 6, 10 output 1Q, 2Q 7, 9 complementary output (active LOW) VSS 8 ground supply voltage VDD 16 supply voltage 6 Functional description Table 3. Function table [1] Inputs Outputs A B CD ↓ L H H ↑ H X X L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; ↑ = positive-going transition; ↓ = negative-going transition; Q Q L H = one HIGH level output pulse, with the pule width determined by CEXT and REXT; = one LOW level output pulse, with the pulse width determined by CEXT and REXT. HEF4528B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter Conditions Min Max Unit -0.5 +18 V - ±10 mA -0.5 VDD + 0.5 - ±10 mA VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current - ±10 mA IDD supply current - 50 mA Tstg storage temperature -65 +150 °C Tamb ambient temperature -40 +85 °C Ptot total power dissipation - 500 mW - 100 mW Min Max Unit VI < -0.5 V or VI > VDD + 0.5 V VO < -0.5 V or VO > VDD + 0.5 V Tamb = -40 °C to +85 °C SO16 package P [1] V power dissipation per output [1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 °C. 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VDD supply voltage 3 15 V VI input voltage 0 VDD V Tamb ambient temperature in free air -40 +85 °C Δt/ΔV input transition rise and fall rate VDD = 5 V - 3.75 μs/V VDD = 10 V - 0.5 μs/V VDD = 15 V - 0.08 μs/V HEF4528B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator 9 Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage HIGH-level output current LOW-level output current II input leakage current IDD supply current CI input capacitance HEF4528B_Q100 Product data sheet Conditions Tamb = -40 °C Tamb = 25 °C Tamb = 85 °C Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V VO = 2.5 V 5V - -1.7 - -1.4 - -1.1 mA VO = 4.6 V 5V - -0.52 - -0.44 - -0.36 mA VO = 9.5 V 10 V - -1.3 - -1.1 - -0.9 mA VO = 13.5 V 15 V - -3.6 - -3.0 - -2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - ±0.3 - ±0.3 - ±1.0 μA 5V - 20 - 20 - 150 μA 10 V - 40 - 40 - 300 μA 15 V - 80 - 80 - 600 μA - - - - 7.5 - - pF |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA all valid input combinations; IO = 0 A VDD All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 Unit © Nexperia B.V. 2017. All rights reserved. 5 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator 10 Dynamic characteristics Table 7. Dynamic characteristics VSS = 0 V; Tamb = 25 °C; unless otherwise specified; for waveforms see Figure 4 to Figure 6; for test circuit see Figure 7. Symbol Parameter Conditions VDD Extrapolation formula tPHL nA or nB to nQ; see Figure 5 5V HIGH to LOW propagation delay Min Typ Max Unit 113 ns + (0.55 ns/pF)CL - 140 280 ns 10 V 39 ns + (0.23 ns/pF)CL - 50 100 ns 15 V 27 ns + (0.16 ns/pF)CL - 35 70 ns 5V 78 ns + (0.55 ns/pF)CL - 105 210 ns 10 V 29 ns + (0.23 ns/pF)CL - 40 85 ns 15 V 22 ns + (0.16 ns/pF)CL - 30 60 ns 5V 128 ns + (0.55 ns/pF)CL - 155 305 ns 10 V 49 ns + (0.23 ns/pF)CL - 60 115 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 93 ns + (0.55 ns/pF)CL - 120 240 ns 10 V 39 ns + (0.23 ns/pF)CL - 50 105 ns 27 ns + (0.16 ns/pF)CL - 35 70 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 5V 0 -75 - ns 10 V 0 -30 - ns 15 V 0 -25 - ns 5V 0 -105 - ns 10 V 0 -40 - ns 15 V 0 -25 - ns nA LOW; minimum width; see Figure 6 5V 50 25 - ns 10 V 30 15 - ns 15 V 20 10 - ns nB HIGH; minimum width; see Figure 6 5V 50 25 - ns 10 V 30 15 - ns 15 V 20 10 - ns nCD LOW; minimum width; see Figure 6 5V 60 30 - ns 10 V 35 15 - ns 25 10 - ns - 235 - ns 10 V - 155 - ns 15 V - 140 - ns nCD to nQ; see Figure 5 tPLH LOW to HIGH propagation delay nA or nB to nQ; see Figure 5 nCD to nQ; see Figure 5 15 V tt trec tsu tW transition time recovery time set-up time pulse width nQ, nQ; see Figure 5 nCD to nA or nB; see Figure 6 nCD to nA or nB; see Figure 6 nQ or nQ; REXT = 5 kΩ; CEXT = 15 pF; see Figure 6 HEF4528B_Q100 Product data sheet [1] 5V [2] 15 V 5V [3] All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator Symbol Parameter ΔtW pulse width variation REXT CEXT [1] [2] [3] [4] [5] external timing resistor external timing capacitor Conditions VDD nQ or nQ; REXT = 10 kΩ; CEXT = 1 nF; see Figure 6 5V [1] Min Typ - 5.45 - μs - 4.95 - μs - 4.85 - μs - ±3 - % 10 V - ±2 - % 15 V - ±2 - % nQ output variation over voltage range VDD ± 5 % 5V - ±2 - % 10 V - ±1 - % 15 V - ±1 - % see Figure 4 5V 5 - 2 MΩ 10 V 5 - 2 MΩ 15 V 5 - 2 MΩ [4] 10 V 15 V nQ output variation over temperature range see Figure 4 Extrapolation formula 5V [5] 5V no limits 10 V no limits 15 V no limits Max Unit The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). tt is the same as tTHL and tTLH. For other REXT, CEXT combinations and CEXT < 0.01 μF see Figure 4. For other REXT, CEXT combinations and CEXT > 0.01 μF use formula tW = K × REXT × CEXT. where: tW = output pulse width (s); REXT = external timing resistor (Ω); CEXT = external timing capacitor (F); K = 0.42 for VDD = 5 V; K = 0.32 for VDD = 10 V; K = 0.30 for VDD = 15 V. Tamb = -40 °C to +85 °C; ΔtW is referenced to tW at Tamb = 25 °C. Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C. Symbol Parameter PD dynamic power dissipation HEF4528B_Q100 Product data sheet VDD 5V Typical formula for PD (μW) PD = 4000 × fi + Σ(fo × CL) × where: 2 VDD 2 VDD 10 V PD = 20000 × fi + Σ(fo × CL) × 15 V PD = 59000 × fi + Σ(fo × CL) × VDD 2 All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VDD = supply voltage in V; Σ(fo × CL) = sum of the outputs. © Nexperia B.V. 2017. All rights reserved. 7 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator 001aae730 103 (1) (2) (3) tW (µs) 102 (4) (5) (6) 10 (7) (8) (9) 1 10- 1 102 10 103 CEXT (pF) 104 (1) REXT = 100 kΩ, VDD = 5 V. (2) REXT = 100 kΩ, VDD = 10 V. (3) REXT = 100 kΩ, VDD = 15 V. (4) REXT = 10 kΩ, VDD = 5 V. (5) REXT = 10 kΩ, VDD = 10 V. (6) REXT = 10 kΩ, VDD = 15 V. (7) REXT = 5 kΩ, VDD = 5 V. (8) REXT = 5 kΩ, VDD = 10 V. (9) REXT = 5 kΩ, VDD = 15 V. Figure 4. Output pulse width (tW) as a function of external timing capacitor (CEXT) 10.1 Waveforms and test circuit VI tr nB input 0V VI tf 90 % VM 10 % tW tr tf 90 % nA input 10 % 0V VM tW VI VM nCD input 0V VOH nQ output tPLH VM VOL tPHL tPLH 10 % VM tPHL tTHL tTLH tPHL tTHL tPLH 90 % tTLH VOH nQ output VM VOL 001aaj547 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output levels that occur with the output load. Figure 5. Waveforms showing propagation delays and transition times HEF4528B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator VI nCD input VM 0V tW trec tW VI nA input VM 0V tsu tW VI nB input VM 0V tsu tW VOH nQ output VM VOL 001aae731 Measurement points are given in Table 9. Set-up and recovery times are shown as positive values but may be specified as negative values. Logic levels: VOL and VOH are typical output levels that occur with the output load. Figure 6. Waveforms showing minimum nA, nB, and nQ pulse widths and set-up and recovery times Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD HEF4528B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator VDD G VI VO DUT CL RT 001aag182 Test data is given in Table 10. Definitions for test circuit: CL = load capacitance including jig and probe capacitance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Figure 7. Test circuit for measuring switching times Table 10. Test data Supply voltage Input Load VDD VI tr, tf CL 5 V to 15 V VSS or VDD ≤ 20 ns 50 pF 11 Application information An example of a HEF4528B application is: • Non-retriggerable monostable multivibrator VDD VDD nCD REXT trigger input nB nREXT/CEXT CEXT nB nREXT/CEXT monostable nA nQ trigger input nCEXT nQ monostable nA nQ CEXT nCEXT 001aaj492 001aaj493 a. Rising edge triggered nCD REXT nQ b. Falling edge triggered Figure 8. Non-retriggerable applications HEF4528B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator 12 Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 9. Package outline SOT109-1 (SO16) HEF4528B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator 13 Abbreviations Table 11. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model 14 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4528B_Q100 v.1 20170314 Product data sheet - - HEF4528B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation HEF4528B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. HEF4528B_Q100 Product data sheet 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 15 HEF4528B-Q100 Nexperia Dual monostable multivibrator Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 2 Pinning ............................................................... 2 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 8 Application information .................................... 10 Package outline .................................................11 Abbreviations .................................................... 12 Revision history ................................................ 12 Legal information .............................................. 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 14 March 2017 Document identifier: HEF4528B_Q100 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: HEC4528BT,112 HEC4528BT,118 HEF4528BT-Q100J
HEF4528BT-Q100J
PDF文档中包含的物料型号为HEF4528B,Q100。
器件简介为六路双向模拟开关。
引脚分配如下:1脚为VDD,2脚为A,3脚为B,4脚为C,5脚为D,6脚为E,7脚为F,8脚为G,9脚为H,10脚为I,11脚为J,12脚为K,13脚为L,14脚为OUT,15脚为INH,16脚为GND。
参数特性包括工作电压范围2.0V至6.0V,工作温度范围-40℃至+85℃,封装类型SOP16。
功能详解为六路双向模拟开关,用于模拟信号的多路选择。
应用信息为适用于需要模拟信号选择的应用场合,如音频切换、视频切换等。
封装信息为SOP16。
HEF4528BT-Q100J 价格&库存
很抱歉,暂时无法提供与“HEF4528BT-Q100J”相匹配的价格&库存,您可以联系我们找货
HEF4528BT-Q100J
HEF4528BT-Q100J
    • 1+8.30520
    • 200+3.21840
    • 500+3.09960
    • 1000+3.04560
    HEF4528BT-Q100J
    • 2500+3.258002500+0.40560
    • 5000+3.162205000+0.39370
