74ABT162244
16-bit buffer/line driver with 30 series termination resistors;
3-state
Rev. 6 — 3 November 2011
Product data sheet
1. General description
The 74ABT162244 high-performance Bipolar CMOS (BiCMOS) device combines low
static and dynamic power dissipation with high speed and high output drive.
The 74ABT162244 is a 16-bit buffer that is ideal for driving bus lines. The device features
four output enable inputs (1OE, 2OE, 3OE, 4OE), each controlling four of the 3-state
outputs.
The 74ABT162244 is designed with 30 series resistance in both the upper and lower
output structures. This design reduces line noise in applications such as memory address
drivers, clock drivers and bus receivers/transmitters.
2. Features and benefits
16-bit bus interface
Multiple VCC and GND pins minimize switching noise
Power-up 3-state
3-state buffers
Output capability: +12 mA and 32 mA
Live insertion and extraction permitted
Latch-up performance: JESD 78 Class II
ESD protection:
HBM JESD-A114E exceeds 2000 V
CDM JESD 22-C101-C exceeds 1000 V
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74ABT162244DGG
40 C to +85 C
TSSOP48
plastic thin shrink small outline package; 48 leads;
body width 6.1 mm
SOT362-1
74ABT162244DL
40 C to +85 C
SSOP48
plastic shrink small outline package; 48 leads; body SOT370-1
width 7.5 mm
74ABT162244
Nexperia
16-bit buffer/line driver with 30 series termination resistors; 3-state
4. Functional diagram
2
47
1A0
46
3Y0
35
1Y1
3A1
1Y2
3A2
5
44
13
3A0
3
1A1
1A2
36
1Y0
1
1OE
48
2OE
25
3OE
24
4OE
14
3Y1
33
16
3Y2
1A0
1A3
6
43
1Y3
3A3
32
17
1A1
3Y3
1A2
1OE
1
3OE
25
1A3
2A0
2A1
8
41
2A0
30
2Y0
2A2
19
4A0
2A3
4Y0
3A0
40
29
9
2A1
2Y1
3A1
4A1
4Y1
3A2
3A3
2A2
11
38
2Y2
4A2
27
22
4A0
4Y2
4A1
2A3
2OE
12
37
2Y3
48
4A3
4OE
EN1
EN2
EN3
EN4
26
4A2
23
4Y3
4A3
47
46
1
2
1
3
44
5
43
6
41
40
1
8
2
9
38
11
37
12
36
35
1
3
13
14
33
16
32
17
30
29
1
4
19
22
26
23
1Y0
1Y1
1Y2
1Y3
2Y0
2Y1
2Y2
2Y3
3Y0
3Y1
3Y2
3Y3
4Y0
4Y1
4Y2
4Y3
001aae231
24
mna996
Fig 1.
Logic symbol
Fig 2.
IEC logic symbol
VCC
output
GND
Fig 3.
001aac384
Logic diagram one output
74ABT162244
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
74ABT162244
Nexperia
5. Pinning information
5.1 Pinning
1OE
1
48 2OE
1Y0
2
47 1A0
1Y1
3
46 1A1
GND
4
45 GND
1Y2
5
44 1A2
1Y3
6
43 1A3
VCC
7
42 VCC
2Y0
8
41 2A0
2Y1
9
40 2A1
GND 10
39 GND
2Y2 11
38 2A2
2Y3 12
37 2A3
74ABT162244
3Y0 13
36 3A0
3Y1 14
35 3A1
GND 15
34 GND
3Y2 16
33 3A2
3Y3 17
32 3A3
VCC 18
31 VCC
4Y0 19
30 4A0
4Y1 20
29 4A1
GND 21
28 GND
4Y2 22
27 4A2
4Y3 23
26 4A3
4OE 24
25 3OE
001aaj890
Fig 4.
Pin configuration
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1OE
1
1 output enable (LOW active)
1Y[0:3]
2, 3, 5, 6
1 data output 0 to output 3
GND
4
ground (0 V)
VCC
7
supply voltage
2Y[0:3]
8, 9, 11, 12
2 data output 0 to output 3
GND
10
ground (0 V)
3Y[0:3]
13, 14, 16, 17 3 data output 0 to output 3
GND
15
ground (0 V)
VCC
18
supply voltage
4Y[0:3]
19, 20, 22, 23 4 data output 0 to output 3
GND
21
ground (0 V)
4OE
24
4 output enable (LOW active)
74ABT162244
Product data sheet
3 of 15
74ABT162244
Nexperia
Table 2.
Pin description …continued
Symbol
Pin
Description
3OE
25
3 output enable (LOW active)
GND
28
ground (0 V)
4A[0:3]
30, 29, 27, 26 4 data input 0 to input 3
VCC
31
supply voltage
GND
34
ground (0 V)
3A[0:3]
36, 35, 33, 32 3 data input 0 to input 3
GND
39
ground (0 V)
2A[0:3]
41, 40, 38, 37 2 data input 0 to input 3
VCC
42
supply voltage
GND
45
ground (0 V)
1A[0:3]
47, 46, 44, 43 1 data input 0 to input 3
2OE
48
74ABT162244
Product data sheet
2 output enable (LOW active)
4 of 15
74ABT162244
Nexperia
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
nOE
nAn
nYn
L
L
L
L
H
H
H
X
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7.0
V
[1]
1.2
+7.0
V
[1]
0.5
+5.5
V
VI
input voltage
VO
output voltage
output in OFF-state or HIGH-state
IIK
input clamping current
VI < 0 V
18
mA
IOK
output clamping current
VO < 0 V
50
mA
IO
output current
output in LOW-state
128
mA
output in HIGH-state
64
mA
150
C
65
+150
C
Tj
junction temperature
Tstg
storage temperature
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
8. Recommended operating conditions
Table 5.
Operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Typ
Max
Unit
VCC
supply voltage
Conditions
4.5
5.5
V
VI
input voltage
VCC
V
VIH
HIGH-level input voltage
2.0
V
VIL
LOW-level Input voltage
0.8
V
IOH
HIGH-level output current
32
mA
IOL
LOW-level output current
12
mA
t/V
input transition rise and fall rate
10
ns/V
Tamb
ambient temperature
40
+85
C
74ABT162244
Product data sheet
in free air
5 of 15
74ABT162244
Nexperia
9. Static characteristics
Table 6.
Symbol
Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
0.9
1.2
1.2
V
VCC = 4.5 V; IOH = 3 mA
2.5
2.9
2.5
V
VCC = 5.0 V; IOH = 3 mA
3.0
3.4
3.0
V
VCC = 4.5 V; IOH = 32 mA
2.0
2.4
2.0
V
VCC = 4.5 V; IOL = 8 mA
0.65
0.65
V
VCC = 4.5 V; IOL = 12 mA
0.80
0.80
V
VIK
input clamping voltage VCC = 4.5 V; IIK = 18 mA
VOH
HIGH-level output
voltage
LOW-level output
voltage
VOL
40 C to +85 C Unit
VI = VIL or VIH
VI = VIL or VIH
II
input leakage current
VCC = 5.5 V; VI = VCC or GND
0.01 1.0
1.0
A
IOFF
power-off leakage
current
VCC = 0 V; VI or VO 4.5 V
5.0
100
100
A
IO(pu/pd)
power-up/power-down VCC = 2.0 V; VO = 0.5 V;
output current
VI = GND or VCC; nOE = HIGH
5.0
50
50
A
IOZ
OFF-state output
current
output HIGH-state at VO = 5.5 V
0.1
10
10
A
output LOW-state at VO = 0 V
0.1
10
10
A
5.0
50
50
A
50
180
mA
1.0
mA
[1]
VCC = 5.5 V; VI = VIL or VIH
ILO
output leakage current HIGH-state; VO = 5.5 V;
VCC = 5.5 V; VI = GND or VCC
IO
output current
VCC = 5.5 V; VO = 2.5 V
ICC
supply current
[2]
50
100 180
outputs HIGH-state
0.50
1.0
outputs LOW-state
10
19
19
mA
outputs 3-state
0.50
1.0
1.0
mA
100
250
250
A
ICC
additional supply
current
per input pin; VCC = 5.5 V; one input
at 3.4 V and other inputs at VCC or
GND
CI
input capacitance
VI = 0 V or VCC
3
pF
CI/O
input/output
capacitance
outputs disabled; VO = 0 V or VCC
7
pF
[3][4]
[1]
This parameter is valid for any VCC between 0 V and 2.1 V, with a transition time of up to 10 ms. From VCC = 2.1 V to VCC = 5 V 10 %,
a transition time of up to 100 s is permitted.
[2]
Not more than one output should be tested at a time, and the duration of the test should not exceed one second.
[3]
This is the increase in supply current for each input at 3.4 V.
[4]
This data sheet limit may vary among suppliers.
74ABT162244
Product data sheet
6 of 15
74ABT162244
Nexperia
10. Dynamic characteristics
Table 7.
GND = 0 V. For test circuit, see Figure 7.
Symbol Parameter
25 C; VCC = 5.0 V
Conditions
40 C to +85 C;
VCC = 5.0 V 0.5 V
Unit
Min
Typ
Max
Min
Max
tPLH
LOW to HIGH
propagation delay
nAn to nYn, see Figure 5
1.0
1.8
2.4
1.0
2.7
tPHL
HIGH to LOW
propagation delay
1.6
3.2
4.0
1.6
4.4
tPZH
OFF-state to HIGH
propagation delay
nOE to nYn; see Figure 6
1.2
2.7
3.5
1.2
4.3
ns
tPZL
OFF-state to LOW
propagation delay
2.6
5.0
6.2
2.6
7.3
ns
tPHZ
HIGH to OFF-state
propagation delay
1.5
3.0
3.8
1.5
4.5
ns
tPLZ
LOW to OFF-state
propagation delay
1.3
2.6
3.3
1.3
4.6
ns
74ABT162244
Product data sheet
ns
7 of 15
74ABT162244
Nexperia
11. Waveforms
VI
VM
VM
input nAn
0V
tPHL
tPLH
VOH
VM
output nYn
VM
VOL
001aaj028
VM = 1.5 V
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 5.
Input (nAn) to output (nYn) propagation delay
VI
VM
nOE input
GND
tPZL
tPLZ
3.5 V
VM
nYn output
VOL + 0.3 V
VOL
tPZH
tPHZ
VOH
VM
nYn output
VOH − 0.3 V
0V
001aaj892
VM = 1.5 V
Fig 6.
3-state output enable and disable times
74ABT162244
Product data sheet
8 of 15
74ABT162244
Nexperia
12. Test information
VI
tW
90 %
90 %
negative
pulse
VM
10 %
0V
VI
10 %
tf
tr
tr
tf
90 %
positive
pulse
0V
VM
90 %
VM
VM
10 %
10 %
tW
001aai298
VM = 1.5 V
a. Input pulse definition
VEXT
VCC
PULSE
GENERATOR
VI
RL
VO
DUT
CL
RT
RL
001aac764
Test data is given in Table 8.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
b. Test circuit for 3-state outputs
Fig 7.
Table 8.
Load circuitry for switching times
Test data
Input
Load
VEXT
VI
fi
tW
tr, tf
CL
RL
tPHZ, tPZH
tPLZ, tPZL
tPLH, tPHL
3.0 V
1 MHz
500 ns
2.5 ns
50 pF
500
open
7.0 V
open
74ABT162244
Product data sheet
9 of 15
74ABT162244
Nexperia
13. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
E
D
A
X
c
HE
y
v M A
Z
48
25
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
detail X
24
w M
bp
e
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
12.6
12.4
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.8
0.4
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT362-1
Fig 8.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Package outline SOT362-1 (TSSOP48)
74ABT162244
Product data sheet
10 of 15
74ABT162244
Nexperia
SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm
SOT370-1
D
E
A
X
c
y
HE
v M A
Z
25
48
Q
A2
A1
A
(A 3)
θ
pin 1 index
Lp
L
24
1
detail X
w M
bp
e
10 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2.8
0.4
0.2
2.35
2.20
0.25
0.3
0.2
0.22
0.13
16.00
15.75
7.6
7.4
0.635
10.4
10.1
1.4
1.0
0.6
1.2
1.0
0.25
0.18
0.1
0.85
0.40
8o
o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT370-1
Fig 9.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-118
Package outline SOT370-1 (SSOP48)
74ABT162244
Product data sheet
11 of 15
74ABT162244
Nexperia
14. Abbreviations
Table 9.
Abbreviations
Acronym
Description
CDM
Charged Device Model
ESD
ElectroStatic Discharge
HBM
Human Body Model
15. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ABT162244 v.6
20111103
Product data sheet
74ABT162244 v.5
74ABT162244 v.4
Modifications:
74ABT162244 v.5
Legal pages updated
20100525
Product data sheet
74ABT162244 v.4
20090409
Product data sheet
74ABT_H162244 v.3
74ABT_H162244 v.3
19981022
Product specification
74ABT_H162244 v.2
74ABT_H162244 v.2
19980225
74ABT_H162244 v.1
74ABT_H162244 v.1
19961023
74ABT162244
Product data sheet
12 of 15
74ABT162244
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
74ABT162244
Product data sheet
13 of 15
74ABT162244
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74ABT162244
Product data sheet
14 of 15
74ABT162244
Nexperia
18. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Contact information. . . . . . . . . . . . . . . . . . . . . 14
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Date of release: 03 November 2011
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74ABT162244DL,112 74ABT162244DL,118 74ABT162244DGG,112 74ABT162244DGG,118
