74ABT16245BDGG,112
74ABT16245BDGG,112
    NEXPERIA(安世)
    TSSOP-48
    16位总线收发器;3-state
74ABT16245BDGG,112 数据手册
74ABT16245B 16-bit bus transceiver; 3-state Rev. 5 — 10 April 2017 1 Product data sheet General description The 74ABT16245B high-performance BiCMOS device combines low static and dynamic power dissipation with high speed and high output drive. The 74ABT16245B device is a dual octal transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The control function implementation minimizes external timing requirements. The device features two output enable (1OE, 2OE) inputs for easy cascading and two direction (1DIR, 2DIR) inputs for direction control. 2 Features and benefits • • • • • • • • 3 16-bit bidirectional bus interface Multiple VCC and GND pins minimize switching noise Power-up 3-state 3-state buffers Output capability: +64 mA and -32 mA Live insertion/extraction permitted Latch-up performance: JESD 78 Class II ESD protection: – HBM JESD22-A114E exceeds 2000 V – CDM JESD22-C101C exceeds 1000 V Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74ABT16245BDL -40 °C to +85 °C SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 74ABT16245BDGG -40 °C to +85 °C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74ABT16245B Nexperia 16-bit bus transceiver; 3-state 4 Functional diagram 2DIR 1DIR 2OE 1OE 2A0 1A0 1B0 1A1 2B0 2A1 1B1 1A2 2B1 2A2 1B2 1A3 2B2 2A3 1B3 1A4 2B3 2A4 1B4 1A5 2B4 2A5 1B5 1A6 2B5 2A6 1B6 2B6 2A7 1A7 1B7 2B7 001aaa789 Figure 1. Logic symbol 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state 1OE 1DIR 2OE 2DIR 1A0 G3 3EN1[BA] 3EN2[AB] G6 6EN1[BA] 6EN2[AB] 1B0 1 2 1A1 1B1 1A2 1B2 1A3 1B3 1A4 1B4 1A5 1B5 1A6 1B6 1A7 1B7 2A0 2B0 4 5 2A1 2B1 2A2 2B2 2A3 2B3 2A4 2B4 2A5 2B5 2A6 2B6 2B7 2A7 001aaa790 Figure 2. IEC logic symbol 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state 5 Pinning information 5.1 Pinning 74ABT16245B 1DIR 1 48 1OE 1B0 2 47 1A0 1B1 3 46 1A1 GND 4 45 GND 1B2 5 44 1A2 1B3 6 43 1A3 VCC 7 42 VCC 1B4 8 41 1A4 1B5 9 40 1A5 GND 10 39 GND 1B6 11 38 1A6 1B7 12 37 1A7 2B0 13 36 2A0 2B1 14 35 2A1 GND 15 34 GND 2B2 16 33 2A2 2B3 17 32 2A3 VCC 18 31 VCC 2B4 19 30 2A4 2B5 20 29 2A5 GND 21 28 GND 2B6 22 27 2A6 2B7 23 26 2A7 2DIR 24 25 2OE aaa-013906 Figure 3. Pin configuration SOT370-1 (SSOP48) and SOT362-1 (TSSOP48) 5.2 Pin description Table 2. Pin description Symbol Pin Description 1DIR, 2DIR 1, 24 direction control input 1B0 to 1B7 2, 3, 5, 6, 8, 9, 11, 12 data input/output 2B0 to 2B7 13, 14, 16, 17, 19, 20, 22, 23 data input/output GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 1OE, 2OE 48, 25 output enable input (active LOW) 1A0 to 1A7 47, 46, 44, 43, 41, 40, 38, 37 data input/output 2A0 to 2A7 36, 35, 33, 32, 30, 29, 27, 26 data input/output 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state 6 Functional description Table 3. Function table [1] Inputs Outputs nOE nDIR nAn nBn L L nAn = nBn inputs L H inputs nBn = nAn H X Z Z [1] 7 H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions supply voltage Min Max Unit -0.5 +7.0 V input voltage [1] -1.2 +7.0 V VO output voltage output in OFF-state or HIGH-state [1] -0.5 +5.5 V IIK input clamping current VI < 0 V -18 - mA IOK output clamping current VO < 0 V -50 - mA IO output current output in LOW-state - 128 mA -64 - mA - 150 °C -65 +150 °C VI output in HIGH-state Tj junction temperature Tstg storage temperature [1] [2] [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state 8 Recommended operating conditions Table 5. Operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit 4.5 5.5 V 0 VCC V VCC supply voltage VI input voltage VIH HIGH-level input voltage 2.0 - V VIL LOW-level input voltage - 0.8 V IOH HIGH-level output current -32 - mA IOL LOW-level output current - 64 mA Δt/ΔV input transition rise and fall rate - 10 ns/V Tamb ambient temperature -40 +85 °C 9 in free air Static characteristics Table 6. Static characteristics Symbol Parameter Conditions 25 °C -40 °C to +85 °C Unit Min Typ Max Min Max -1.2 -0.9 - -1.2 - V VCC = 4.5 V; IOH = -3 mA 2.5 2.9 - 2.5 - V VCC = 5.0 V; IOH = -3 mA 3.0 3.4 - 3.0 - V VCC = 4.5 V; IOH = -32 mA 2.0 2.4 - 2.0 - V VIK input clamping voltage VCC = 4.5 V; IIK = -18 mA VOH HIGH-level output voltage VI = VIL or VIH VOL LOW-level output voltage VCC = 4.5 V; IOL = 64 mA; VI = VIL or VIH - 0.42 0.55 - 0.55 V II input leakage current control pins; VCC = 5.5 V; VI = VCC or GND - ±0.01 ±1.0 - ±1.0 μA IOFF power-off VCC = 0 V; VI or VO ≤ 4.5 V leakage current - ±5.0 ±100 - ±100 μA IO(pu/pd) power-up/ power-down output current VCC = 2.0 V; VO = 0.5 V; VI = GND or VCC; nOE = HIGH - ±5.0 ±50 - ±50 μA IOZ OFF-state output current VCC = 5.5 V; VI = VIL or VIH output HIGH-state at VO = 5.5 V - 0.1 10 - 10 μA output LOW-state at VO = 0 V - -0.1 -10 - -10 μA - 5.0 50 - 50 μA -50 -92 -180 -50 -180 mA - 0.30 0.7 - 0.7 mA ICEX output high HIGH-state; VO = 5.5 V; VCC = 5.5 V; leakage current VI = GND or VCC IO output current VCC = 5.5 V; VO = 2.5 V ICC supply current VCC = 5.5 V; VI = GND or VCC outputs HIGH-state 74ABT16245B Product data sheet [1] [2] All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state Symbol Parameter Conditions 25 °C Min outputs LOW-state additional supply current Typ Max Min Max - 10 19 - 19 mA - 0.30 0.7 - 0.7 mA outputs enabled - 400 700 - 700 μA outputs disabled - 100 250 - 250 μA control pins; outputs disabled; one enable input at 3.4 V and other inputs at VCC or GND - 400 700 - 700 μA outputs 3-state ΔICC -40 °C to +85 °C Unit [3] per input pin; VCC = 5.5 V; one data input at 3.4 V and other inputs at VCC or GND CI input capacitance VI = 0 V or VCC - 4 - - - pF CI/O input/output capacitance outputs disabled; VO = 0 V or VCC - 7 - - - pF [1] [2] [3] This parameter is valid for any VCC between 0 V and 2.1 V, with a transition time of up to 10 ms. From VCC = 2.1 V to VCC = 5 V ± 10 %, a transition time of up to 100 μs is permitted. Not more than one output should be tested at a time, and the duration of the test should not exceed one second. This is the increase in supply current for each input at 3.4 V. 10 Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V. For test circuit, see Figure 6. Symbol Parameter Conditions 25 °C; VCC = 5.0 V -40 °C to +85 °C; Unit VCC = 5.0 V ± 0.5 V Min Typ Max Min Max tPLH LOW to HIGH propagation delay nAn to nBn; see Figure 4 1.0 2.0 3.2 1.0 3.5 ns tPHL HIGH to LOW propagation delay nAn to nBn; see Figure 4 1.0 2.3 3.5 1.0 4.0 ns tPZH OFF-state to HIGH nOE to nAn or nBn; propagation delay see Figure 5 1.0 3.0 4.4 1.0 5.1 ns tPZL OFF-state to LOW nOE to nAn or nBn; propagation delay see Figure 5 1.7 4.0 5.2 1.7 6.1 ns tPHZ HIGH to OFF-state nOE to nAn or nBn; propagation delay see Figure 5 1.7 3.5 4.9 1.7 5.4 ns tPLZ LOW to OFF-state nOE to nAn or nBn; propagation delay see Figure 5 1.5 3.2 4.4 1.5 5.0 ns 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state 10.1 Waveforms and test circuit VI nAn, nBn input VM GND t PHL t PLH VOH nBn, nAn output VM VOL mna477 VM = 1.5 V VOL and VOH are typical voltage output levels that occur with the output load. Figure 4. Input (nAn) to output (nBn) propagation delay times VI VM nOE input GND tPZL tPLZ 3.5 V VM nAn, nBn output VOL + 0.3 V VOL tPZH tPHZ VOH VM nAn, nBn output 0V VOH - 0.3 V aaa-013908 VM = 1.5 V VOL and VOH are typical voltage output levels that occur with the output load. Figure 5. 3-state output enable and disable times 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state VI negative pulse tW 90 % 90 % VM 10 % 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % 90 % VM VM 10 % 10 % tW 001aai298 VM = 1.5 V a.Input pulse definition VEXT VCC PULSE GENERATOR VI DUT RL VO CL RT RL 001aac764 Test data is given in Table 8. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. b.Test circuit Figure 6. Test circuit for measuring switching times Table 8. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 3.0 V 1 MHz 500 ns 2.5 ns 50 pF 500 Ω open 7.0 V open 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state 11 Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3 ) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-118 Figure 7. Package outline SOT370-1 (SSOP48) 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit max nom min mm A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Figure 8. Package outline SOT362-1 (TSSOP48) 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state 12 Abbreviations Table 9. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model 13 Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ABT16245B v.5 20170410 Product data sheet - 74ABT16245B v.4 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74ABT16245B v.4 20140819 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. • Type number 74ABTH16245BDL removed. 74ABT_H16245B v.3 20021213 Product data sheet - 74ABT_H16245B v.2 74ABT_H16245B v.2 19980225 Product data sheet - 74ABT_H16245B v.1 74ABT_H16245B v.1 19961120 Product data sheet - - 74ABT16245B Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 74ABT_H16245B v.3 © Nexperia B.V. 2017. All rights reserved. 12 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74ABT16245B Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74ABT16245B Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 15 74ABT16245B Nexperia 16-bit bus transceiver; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 4 Pinning ............................................................... 4 Pin description ................................................... 4 Functional description ........................................5 Limiting values .................................................... 5 Recommended operating conditions ................ 6 Static characteristics .......................................... 6 Dynamic characteristics .....................................7 Waveforms and test circuit ................................ 8 Package outline .................................................10 Abbreviations .................................................... 12 Revision history ................................................ 12 Legal information .............................................. 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 April 2017 Document identifier: 74ABT16245B
74ABT16245BDGG,112
1. 物料型号:74ABT16245B,由Nexperia生产。
2. 器件简介:74ABT16245B是一款高速CMOS传输门,具有低功耗和高噪声抑制特性,适用于高速数字电路。
3. 引脚分配:该器件包含4个独立的传输门,每个门有2个引脚,分别为输入端和输出端。
4. 参数特性: - 电源电压范围:2.0V至5.5V。 - 最大传输延迟时间:5ns。 - 最低输入高电平电压:0.8V。 - 最低输入低电平电压:0.2V。
5. 功能详解:74ABT16245B的每个传输门都可以独立控制,实现信号的传输或阻断。
6. 应用信息:适用于高速数字电路、通信设备、计算机外设等。
7. 封装信息:该器件提供多种封装选项,包括TSSOP、SOIC等。
74ABT16245BDGG,112 价格&库存
很抱歉,暂时无法提供与“74ABT16245BDGG,112”相匹配的价格&库存,您可以联系我们找货
