74ABT244PW,112
74ABT244PW,112
    NEXPERIA(安世)
    TSSOP20_6.5X4.4MM
    IC BUF NON-INVERT 5.5V 20TSSOP
74ABT244PW,112 数据手册
74ABT244 Octal buffer/line driver; 3-state Rev. 3 — 6 October 2017 1 Product data sheet General description The 74ABT244 high-performance BiCMOS device combines low static and dynamic power dissipation with high speed and high output drive. The 74ABT244 device is an octal buffer that is ideal for driving bus lines. The device features two output enables (1OE and 2OE), each controlling four of the 3-state outputs. 2 Features and benefits • • • • • • • • Octal bus interface 3-State buffers Output capability: +64 mA/–32 mA Power-up 3-State Live insertion capability Inputs are disabled during 3-state mode Latch-up protection exceeds 500 mA per JESD78 class II level A ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V • Specified from -40 °C to +85 °C 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74ABT244D -40 °C to +85 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74ABT244DB -40 °C to +85 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 74ABT244PW -40 °C to +85 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74ABT244 Nexperia Octal buffer/line driver; 3-state 4 Functional diagram 2 4 6 8 1 17 15 13 11 19 1A0 1Y0 1A1 1Y1 1A2 1Y2 1A3 1Y3 18 16 14 12 1 EN 1OE 2A0 2Y0 2A1 2Y1 2A2 2Y2 2A3 2Y3 3 2 18 4 16 6 14 8 12 5 19 7 9 2OE EN 11 9 13 7 15 5 17 3 mna873 mna875 Figure 1. Logic symbol Figure 2. IEC logic symbol 1A0 1A1 1A2 1A3 1OE 2 18 4 16 6 14 8 12 1 1Y0 2A0 1Y1 2A1 1Y2 2A2 1Y3 2A3 2OE 17 3 15 5 13 7 11 9 2Y0 2Y1 2Y2 2Y3 19 mna874 Figure 3. Functional diagram 74ABT244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state 5 Pinning information 5.1 Pinning 74ABT244 74ABT244 1OE 1 1 2 20 VCC 19 2OE 1OE 1A0 1A0 2 20 VCC 19 2OE 2Y0 3 18 1Y0 2Y0 3 18 1Y0 1A1 4 17 2A0 1A1 4 17 2A0 2Y1 5 16 1Y1 2Y1 5 16 1Y1 1A2 6 15 2A1 1A2 6 15 2A1 2Y2 7 14 1Y2 2Y2 7 14 1Y2 1A3 8 13 2A2 1A3 8 13 2A2 2Y3 9 12 1Y3 2Y3 9 12 1Y3 GND 10 11 2A3 GND 10 11 2A3 aaa-027548 aaa-027549 Figure 4. Pin configuration for SO20 Figure 5. Pin configuration for (T)SSOP20 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A0, 1A1, 1A2, 1A3 2, 4, 6, 8 data input 1Y0, 1Y1, 1Y2, 1Y3 18, 16, 14, 12 data output 2A0, 2A1, 2A2, 2A3 17, 15, 13, 11 data input 2Y0, 2Y1, 2Y2, 2Y3 3, 5, 7, 9 data output 1OE, 2OE 1, 19 output enable input (active LOW) GND 10 ground (0 V) VCC 20 supply voltage 6 Functional description Table 3. Function table [1] Input Output nOE nAn nYn L L L L H H H X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 74ABT244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit -0.5 +7.0 V input voltage [1] -1.2 +7.0 V VO output voltage output in OFF-state or HIGH-state [1] -0.5 +5.5 V IIK input clamping current VI < 0 V -18 - mA IOK output clamping current VO < 0 V -50 - mA IO output current output in LOW-state - 128 mA - 150 °C -65 +150 °C VI Tj junction temperature Tstg storage temperature [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 °C. 8 Recommended operating conditions Table 5. Operating conditions Symbol Parameter VCC supply voltage VI input voltage IOH Min Typ Max Unit 4.5 - 5.5 V 0 - VCC V HIGH-level output current -32 - - mA IOL LOW-level output current - - 64 mA Δt/ΔV input transition rise and fall rate 0 - 5 ns/V Tamb ambient temperature -40 - +85 74ABT244 Product data sheet Conditions in free air All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 °C © Nexperia B.V. 2017. All rights reserved. 4 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state 9 Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = 25 °C VCC = 4.5 V; IIK = -18 mA Tamb = −45 °C to +85 °C Unit Min Typ Max Min Max -1.2 -0.9 - -1.2 - V VIK input clamping voltage VIH HIGH-level input voltage 2.0 - - 2.0 - V VIL LOW-level input voltage - - 0.8 - 0.8 V VOH HIGH-level output voltage IOH = -3 mA 2.5 2.9 - 2.5 - V IOH = -32 mA 2.0 2.4 - 2.0 - V 3.0 3.4 - 3.0 - V VCC = 4.5 V; VI = VIL or VIH VCC = 5.0 V; VI = VIL or VIH IOH = -3 mA VOL LOW-level output voltage VCC = 4.5 V; VI = VIL or VIH; IOL = 64 mA - 0.42 0.55 - 0.55 V II input leakage current VCC = 5.5 V; VI = GND or 5.5 V - ±0.01 ±1.0 - ±1.0 μA IOFF power-off leakage current VCC = 0 V; VO or VI ≤ 4.5 V - ±5.0 ±100 - ±100 μA IO(pu/pd) power-up/ power-down output current VCC = 2.0 V; VO = 0.5 V; VI = GND or VCC; nOE = don’t care - ±5.0 ±50 - ±50 μA IOZ OFF-state output current VCC = 5.5 V; VI = VIL or VIH output HIGH-state at VO = 2.7 V - 5.0 50 - 50 μA output LOW-state at VO = 0.5 V - -5.0 -50 - -50 μA - 5.0 50 - 50 μA -40 -100 -180 -40 -180 mA outputs HIGH-state - 50 250 - 250 μA outputs LOW-state - 24 30 - 30 mA outputs disabled - 50 250 - 250 μA ICEX output high leakage current VCC = 5.5 V; VO = 5.5 V; VI = GND or VCC IO output current VCC = 5.5 V; VO = 2.5 V ICC supply current VCC = 5.5 V; VI = GND or VCC 74ABT244 Product data sheet [1] [2] All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state Symbol ΔICC Parameter additional supply current Conditions Tamb = 25 °C Tamb = −45 °C to +85 °C Min Typ Max Min Max Unit per input pin; VCC = 5.5 V outputs enabled; one data input at 3.4 V and other inputs at VCC or GND [3] - 0.5 1.5 - 1.5 mA outputs disabled; one data input at 3.4 V and other inputs at VCC or GND [3] - 50 250 - 250 μA outputs disabled; one enable input at 3.4 V and other inputs at VCC or GND [3] - 0.5 1.5 - 1.5 mA CI input capacitance VI = 0 V or VCC - 4 - - - pF CO output capacitance - 7 - - - pF outputs disabled; VO = 0 V or VCC [1] This parameter is valid for any VCC between 0 V and 2.1 V, with a transition time of up to 10 ms. From VCC = 2.1 V to VCC = 5 V ± 10 % a transition time of up to 100 μs is permitted. [2] Not more than one output should be tested at a time, and the duration of the test should not exceed one second. [3] This is the increase in supply current for each input at 3.4 V. 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8. Symbol Parameter Conditions Tamb = 25 °C; VCC = 5.0 V Tamb = −40 °C to 85 °C; VCC = 5.0 V ± 0.5 V Min Typ Max Min Max Unit tPLH LOW to HIGH propagation delay nAn to nYn; see Figure 6 1.0 2.6 4.1 1.0 4.6 ns tPHL HIGH to LOW propagation delay nAn to nYn; see Figure 6 1.0 2.9 4.2 1.0 4.6 ns tPZH OFF-state to HIGH propagation delay nOE to nYn; see Figure 7 1.1 3.1 4.6 1.1 5.1 ns tPZL OFF-state to LOW propagation delay nOE to nYn; see Figure 7 2.1 4.1 5.6 2.1 6.1 ns tPHZ HIGH to OFF-state propagation delay nOE to nYn; see Figure 7 2.1 4.1 5.6 2.1 6.6 ns tPLZ LOW to OFF-state propagation delay nOE to nYn; see Figure 7 1.7 2.7 5.2 1.7 5.7 ns 74ABT244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state 10.1 Waveforms and test circuit VI nAn input VM VM GND tPLH tPHL VOH VM nYn output VM VOL mna171 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. Input (nAn) to output (nYn) propagation delays VI VM nOE input GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL 3.5 V VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled aaa-027550 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 7. 3-state enable and disable propagation delays Table 8. Measurement points Input Output VM VM VX VY 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ABT244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Figure 8. Test circuit for measuring switching times Table 9. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 3.0 V ≤ 1 MHz 500 ns ≤ 2.5 ns 50 pF 500 Ω open 7V open 74ABT244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state 11 Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 0.043 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 9. Package outline SOT163-1 (SO20) 74ABT244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm D SOT339-1 E A X c HE y v M A Z 20 11 Q A2 pin 1 index A (A 3) A1 θ Lp L 1 10 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 7.4 7.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.9 0.5 8o 0o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT339-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 10. Package outline SOT339-1 (SSOP20) 74ABT244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 11. Package outline SOT360-1 (TSSOP20) 74ABT244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge MIL Military MM Machine Model 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ABT244 v.3 20171006 Product data sheet - 74ABT244 v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Type number 74ABT244N removed from data sheet. 74ABT244 v.2 19980116 Product specification - 74ABT244 v.1 74ABT244 v.1 19950906 Product specification - - 74ABT244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74ABT244 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74ABT244 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 October 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 15 74ABT244 Nexperia Octal buffer/line driver; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 7 Package outline ...................................................9 Abbreviations .................................................... 12 Revision history ................................................ 12 Legal information .............................................. 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 6 October 2017 Document identifier: 74ABT244
74ABT244PW,112
1. 物料型号:74ABT244,由Nexperia公司生产。 2. 器件简介:74ABT244是一款高速CMOS双触发器,具有独立的时钟输入和互补输出。 3. 引脚分配:引脚1为A1输入,引脚2为A2输入,引脚3为Y1输出,引脚4为Y1输出的反相,引脚5为B1输入,引脚6为B2输入,引脚7为Y2输出,引脚8为Y2输出的反相,引脚9为GND,引脚10为VCC。 4. 参数特性: - 电源电压范围:2.0V至5.5V。 - 工作温度范围:-40°C至+125°C。 - 传播延迟:5.5ns(典型值)。 - 低电平输出电流:-25mA。 - 高电平输出电流:+25mA。 5. 功能详解:74ABT244具有两个独立的触发器,每个触发器都可以在时钟信号的上升沿或下降沿触发。触发器具有同步复位功能,可以确保数据在时钟沿准确传输。 6. 应用信息:74ABT244适用于高速数字系统中的数据同步、时序控制和寄存器功能。 7. 封装信息:该器件提供多种封装选项,包括SOP-10、SSOP-10和DIP-10等。
74ABT244PW,112 价格&库存
很抱歉,暂时无法提供与“74ABT244PW,112”相匹配的价格&库存,您可以联系我们找货
74ABT244PW,112
    • 1+1.03907
    • 10+0.82048
    • 30+0.72674
    • 100+0.60988
    • 500+0.55782
    • 1000+0.52650
