74AHC126; 74AHCT126
Quad buffer/line driver; 3-state
Rev. 04 — 12 August 2009
Product data sheet
1. General description
The 74AHC126; 74AHCT126 is a high-speed Si-gate CMOS device and is pin compatible
with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard
No. 7-A.
The 74AHC126; 74AHCT126 provides four non-inverting buffer/line drivers with 3-state
outputs. The 3-state outputs (nY) are controlled by the output enable input (nOE).
A LOW-level at pin nOE causes the outputs to assume a high-impedance OFF-state.
The 74AHC126; 74AHCT126 is identical to the 74AHC125; 74AHCT125 but has active
HIGH output enable inputs.
2. Features
n
n
n
n
Balanced propagation delays
All inputs have Schmitt-trigger action
Inputs accept voltages higher than VCC
Input levels:
u For 74AHC126: CMOS level
u For 74AHCT126: TTL level
n ESD protection:
u HBM JESD22-A114E exceeds 2000 V
u MM JESD22-A115-A exceeds 200 V
u CDM JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
74AHC126; 74AHCT126
Nexperia
3. Ordering information
Table 1.
Type number
74AHC126D
Package
Temperature range
Name
Description
Version
−40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
−40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
−40 °C to +125 °C
DHVQFN14 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
74AHCT126D
74AHC126PW
74AHCT126PW
74AHC126BQ
74AHCT126BQ
SOT762-1
4. Functional diagram
2
1A
1
1OE
5
2A
4
2OE
9
3A
10
3OE
12
4A
13
4OE
1Y
3
2Y
6
3Y
8
4Y
11
mna235
Fig 1.
Functional diagram
2
1
1
3
EN1
5
6
4
9
8
10
nA
nY
12
11
13
nOE
mna234
Fig 2.
Logic symbol
mna236
Fig 3.
IEC logic symbol
74AHC_AHCT126_4
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 15
74AHC126; 74AHCT126
Nexperia
5. Pinning information
5.1 Pinning
14 VCC
1A
2
13 4OE
1Y
3
12 4A
1OE
1
terminal 1
index area
1
1OE
5
10 3OE
2Y
6
9
3A
GND
7
8
3Y
1Y
3
12 4A
2OE
4
11 4Y
2A
5
2Y
6
GND(1)
10 3OE
9
8
2A
13 4OE
3Y
11 4Y
2
7
4
1A
GND
2OE
14 VCC
74AHC126
74AHCT126
74AHC126
74AHCT126
3A
001aak180
Transparent top view
001aac982
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as
a supply pin or input.
Fig 4. Pin configuration SO14 and TSSOP14
Fig 5. Pin configuration DHVQFN14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1OE
1
output enable input 1 (active HIGH)
1A
2
data input 1
1Y
3
data output 1
2OE
4
output enable input 2 (active HIGH)
2A
5
data input 2
2Y
6
data output 2
GND
7
ground (0 V)
3Y
8
data output 3
3A
9
data input 3
3OE
10
output enable input 3 (active HIGH)
4Y
11
data output 4
4A
12
data input 4
4OE
13
output enable input 4 (active HIGH)
VCC
14
supply voltage
74AHC_AHCT126_4
Product data sheet
3 of 15
74AHC126; 74AHCT126
Nexperia
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
nOE
nA
nY
H
L
L
H
H
H
L
X
Z
[1]
H = HIGH voltage state;
L = LOW voltage state;
X = don’t care;
Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
−0.5
+7.0
V
IIK
input clamping current
VI < −0.5 V
[1]
−20
mA
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
−20
+20
mA
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
−25
+25
mA
ICC
supply current
+75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
500
mW
total power dissipation
Ptot
Conditions
Tamb = −40 °C to +125 °C
[2]
Min
Max
Unit
−0.5
+7.0
V
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For TSSOP14 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
For DHVQFN14 packages: above 60 °C the value of Ptot derates linearly at 4.5 mW/K.
74AHC_AHCT126_4
Product data sheet
4 of 15
74AHC126; 74AHCT126
Nexperia
8. Recommended operating conditions
Table 5.
Operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
74AHC126
VCC
supply voltage
2.0
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHCT126
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
74AHC126
VIH
VIL
VOH
VOL
HIGH-level
input voltage
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
74AHC_AHCT126_4
Product data sheet
5 of 15
74AHC126; 74AHCT126
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
µA
IOZ
OFF-state
VI = VIH or VIL;
output current VO = VCC or GND;
VCC = 5.5 V
±0.25
±2.5
±10.0
µA
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2.0
µA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
VI = VCC or GND
74AHCT126
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
4.4
4.5
4.4
4.4
V
3.94
3.80
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
OFF-state
VI = VIH or VIL;
output current VO = VCC or GND per input
pin; other inputs at
VCC = 5.5 V
±0.25
±2.5
±10.0
µA
ICC
VCC = 5.5 V
2.0
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V; other pins
at VCC or GND; IO = 0 A;
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
II
input leakage
current
IOZ
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
VI = VCC or GND
74AHC_AHCT126_4
Product data sheet
6 of 15
74AHC126; 74AHCT126
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
4.7
8.0
1.0
9.5
1.0
10.0
ns
CL = 50 pF
6.7
11.5
1.0
13.0
1.0
14.5
ns
3.3
5.5
1.0
6.5
1.0
7.0
ns
4.7
7.5
1.0
8.5
1.0
9.5
ns
CL = 15 pF
5.3
8.0
1.0
9.5
1.0
10.0
ns
CL = 50 pF
7.6
11.5
1.0
13.0
1.0
14.5
ns
3.6
5.3
1.0
6.1
1.0
7.0
ns
5.1
7.6
1.0
8.7
1.0
9.5
ns
CL = 15 pF
6.6
9.7
1.0
11.5
1.0
12.5
ns
CL = 50 pF
9.4
13.2
1.0
15.0
1.0
16.5
ns
CL = 15 pF
4.7
6.8
1.0
8.0
1.0
8.5
ns
CL = 50 pF
6.7
8.8
1.0
10.0
1.0
11.0
ns
10
pF
3.0
5.5
1.0
6.5
1.0
7.0
ns
4.3
7.5
1.0
8.5
1.0
9.5
ns
3.3
5.1
1.0
6.0
1.0
6.5
ns
4.7
7.1
1.0
8.0
1.0
9.0
ns
4.8
6.8
1.0
8.0
1.0
8.5
ns
6.9
8.9
1.0
10.0
1.0
11.5
ns
12
pF
74AHC126
tpd
propagation
delay
nA to nY; see Figure 6
[2]
CL = 15 pF
CL = 50 pF
ten
enable time
nOE to nY; see Figure 7
[3]
CL = 15 pF
CL = 50 pF
tdis
disable time
[4]
CPD
power
fi = 1 MHz;
dissipation
VI = GND to VCC
capacitance
[5]
74AHCT126; VCC = 4.5 V to 5.5 V
tpd
propagation
delay
enable time
[2]
CL = 15 pF
CL = 50 pF
ten
[3]
CL = 15 pF
CL = 50 pF
tdis
disable time
[4]
CL = 15 pF
CL = 50 pF
CPD
power
fi = 1 MHz;
dissipation
VI = GND to VCC
capacitance
[5]
74AHC_AHCT126_4
Product data sheet
7 of 15
74AHC126; 74AHCT126
Nexperia
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
ten is the same as tPZL and tPZH.
[4]
tdis is the same as tPLZ and tPHZ.
[5]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
11. Waveforms
VI
VM
nA input
GND
tPHL
tPLH
VOH
VM
nY output
VOL
mna237
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6.
Input to output propagation delays
VI
nOE input
VM
GND
t PLZ
t PZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PZH
t PHZ
VOH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
mna949
Fig 7.
Enable and disable times
74AHC_AHCT126_4
Product data sheet
8 of 15
74AHC126; 74AHCT126
Nexperia
Table 8.
Measurement points
Type
Input
Output
VM
VM
VX
VY
74AHC126
0.5 × VCC
0.5 × VCC
VOL + 0.3 V
VOH − 0.3 V
74AHCT126
1.5 V
0.5 × VCC
VOL + 0.3 V
VOH − 0.3 V
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
G
VI
VO
RL
S1
open
DUT
CL
RT
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
RL = load resistance.
S1 = test selection switch.
Fig 8.
Test circuitry for measuring switching times
Table 9.
Test data
Type
Input
VI
Load
S1 position
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74AHC126
VCC
≤ 3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74AHCT126
3.0 V
≤ 3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74AHC_AHCT126_4
Product data sheet
9 of 15
74AHC126; 74AHCT126
Nexperia
12. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 9. Package outline SOT108-1 (SO14)
74AHC_AHCT126_4
Product data sheet
10 of 15
74AHC126; 74AHCT126
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 10. Package outline SOT402-1 (TSSOP14)
74AHC_AHCT126_4
Product data sheet
11 of 15
74AHC126; 74AHCT126
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
mm
c
D (1)
Dh
E (1)
Eh
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 11. Package outline SOT762-1 (DHVQFN14)
74AHC_AHCT126_4
Product data sheet
12 of 15
74AHC126; 74AHCT126
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT126_4
20090812
Product data sheet
74AHC_AHCT126_3
Modifications:
74AHC_AHCT126_3
Added type numbers 74AHC126BQ and 74AHCT126BQ (DHVQFN14 package)
20080425
Product data sheet
74AHC_AHCT126_2
74AHC_AHCT126_2
19990929
Product specification
74AHC_AHCT126_N_1
74AHC_AHCT126_N_1
19990112
Preliminary specification
74AHC_AHCT126_4
Product data sheet
13 of 15
74AHC126; 74AHCT126
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT126_4
Product data sheet
14 of 15
Nexperia
74AHC126; 74AHCT126
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Contact information. . . . . . . . . . . . . . . . . . . . . 14
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Date of release: 12 August 2009
很抱歉,暂时无法提供与“74AHCT126BQ,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.794721+0.49024
- 10+2.6627010+0.34400
- 25+2.3766025+0.30704
- 100+2.05746100+0.26581
- 250+1.90585250+0.24622
- 500+1.81471500+0.23445
- 1000+1.743131000+0.22520
- 国内价格 香港价格
- 3000+1.646603000+0.21273
- 6000+1.601156000+0.20686
- 9000+1.578399000+0.20392
- 15000+1.5531715000+0.20066
- 21000+1.5384321000+0.19875
- 30000+1.5242630000+0.19692
- 国内价格 香港价格
- 1+3.664911+0.47347
- 10+2.5453210+0.32883
- 25+2.2741725+0.29380
- 100+1.96803100+0.25425
- 250+1.82808250+0.23617
- 500+1.74936500+0.22600
- 1000+1.688131000+0.21809
- 3000+1.591923000+0.20566
- 30000+1.4957030000+0.19323
- 国内价格
- 1+3.74633
- 10+2.61429
- 25+2.33739
- 100+2.02791
- 216+2.01976
- 250+1.88131
- 500+1.79172
- 1000+1.73471
- 3000+1.63698
- 30000+1.53111
