74ALVC16245DGG,112
74ALVC16245DGG,112
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    IC TXRX NON-INVERT 3.6V 48TSSOP
74ALVC16245DGG,112 数据手册
74ALVC16245; 74ALVCH16245 16-bit transceiver with direction pin; 3-state Rev. 4 — 21 November 2017 1 Product data sheet General description The 74ALVC16245; 74ALVCH16245 is a 16-bit transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The 74ALVC16245; 74ALVCH16245 features two output enable inputs (pins nOE) for easy cascading and two send or receive inputs (pins nDIR) for direction control. Pins nOE control the outputs so that the buses are effectively isolated. This device can be used as two 8-bit transceivers or one 16-bit transceiver. The 74ALVCH16245 has an active bushold circuitry which is provided to hold unused or floating data inputs at a valid logic level. This feature eliminates the need for external pull-up or pull-down resistors. 2 Features and benefits • • • • • • • • • Wide supply voltage range from 1.2 V to 3.6 V CMOS low power consumption MULTIBYTE flow-through standard pin-out architecture Low inductance multiple VCC and GND pins for minimize noise and ground bounce Direct interface with TTL levels All data inputs have bushold (74ALVCH16245 only) Output drive capability 50 Ω transmission lines at 85 °C Current drive ±24 mA at VCC = 3.0 V. Complies with JEDEC standards: – JESD8-5 (2.3 V to 2.7 V) – JESD8B/JESD36 (2.7 V to 3.6 V) • ESD protection: – HBM ANSI/ESDA/JEDEC JS-001 exceeds 2000 V – CDM JESD22-C101E exceeds 1000 V 3 Ordering information Table 1. Ordering information Type number 74ALVC16245DL Package Temperature range Name Description Version -40 °C to +85 °C SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 -40 °C to +85 °C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74ALVCH16245DL 74ALVC16245DGG 74ALVCH16245DGG 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 4 Functional diagram 1OE 1DIR 2OE 2DIR 1 24 1DIR 2DIR 1A0 G3 3EN1[BA] 3EN2[AB] G6 6EN1[BA] 6EN2[AB] 1B0 1 2 47 1A0 1B0 2 46 1A1 1B1 3 1A1 1B1 44 1A2 1B2 5 1A2 1B2 43 1A3 1B3 6 1A3 1B3 41 1A4 1B4 8 1A4 1B4 40 1A5 1B5 9 1A5 1B5 38 1A6 1B6 11 1A6 1B6 37 1A7 1B7 12 1A7 1B7 36 2A0 2B0 13 35 2A1 2B1 14 2A0 33 2A2 2B2 16 32 2A3 2B3 17 2A1 2B1 30 2A4 2B4 19 2A2 2B2 29 2A5 2B5 20 2A3 2B3 27 2A6 2B6 22 2A4 2B4 26 2A7 2B7 23 2A5 2B5 2A6 2B6 1OE 5 2OE 2A7 48 25 2B0 4 001aaa853 2B7 001aaa790 Figure 1. Logic symbol Figure 2. IEC logic symbol VCC data input to internal circuit mna004 Figure 3. Bushold circuit 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 2DIR 1DIR 2OE 1OE 2A0 1A0 1B0 1A1 2B0 2A1 1B1 1A2 2B1 2A2 1B2 1A3 2B2 2A3 1B3 1A4 2B3 2A4 1B4 1A5 2B4 2A5 1B5 1A6 2B5 2A6 1B6 2B6 2A7 1A7 1B7 2B7 001aaa789 Figure 4. Logic diagram 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 5 Pinning information 5.1 Pinning 74ALVC16245 74ALVCH16245 1DIR 1 48 1OE 1B0 2 47 1A0 1B1 3 46 1A1 GND 4 45 GND 1B2 5 44 1A2 1B3 6 43 1A3 VCC 7 42 VCC 1B4 8 41 1A4 1B5 9 40 1A5 GND 10 39 GND 1B6 11 38 1A6 1B7 12 37 1A7 2B0 13 36 2A0 2B1 14 35 2A1 GND 15 34 GND 2B2 16 33 2A2 2B3 17 32 2A3 VCC 18 31 VCC 2B4 19 30 2A4 2B5 20 29 2A5 GND 21 28 GND 2B6 22 27 2A6 2B7 23 26 2A7 2DIR 24 25 2OE aaa-027716 Figure 5. Pin configuration (T)SSOP48 5.2 Pin description Table 2. Pin description Pin Symbol Description 1, 24 1DIR, 2DIR direction control inputs 2, 3, 5, 6, 8, 9, 11, 12 1B0, 1B1, 1B2, 1B3, 1B4, 1B5, 1B6, 1B7 data output or input 4, 10, 15, 21, 28, 34, 39, 45 GND ground (0 V) 7, 18, 31, 42 VCC positive supply voltage 13, 14, 16, 17, 19, 20, 22, 23 2B0, 2B1, 2B2, 2B3, 2B4, 2B5, 2B6, 2B7 data output or input 48, 25 1OE, 2OE output enable input (active LOW) 36, 35, 33, 32, 30, 29, 27, 26 2A0, 2A1, 2A2, 2A3, 2A4, 2A5, 2A6, 2A7 data input or output 47, 46, 44, 43, 41, 40, 38, 37 1A0, 1A1, 1A2, 1A3, 1A4, 1A5, 1A6, 1A7 data input or output 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 6 Functional description Table 3. Function table [1] Input Input or output nOE nDIR nAn nBn L L output nAn = nBn input L H input output nBn = nAn H X Z Z [1] H = HIGH voltage level L = LOW voltage level X = don’t care Z = high-impedance OFF-state. 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage Conditions Min Max Unit -0.5 +4.6 V data inputs with bushold [1] -0.5 VCC + 0.5 V data inputs without bushold [1] -0.5 +4.6 V control pins [1] -0.5 +4.6 V [1] -0.5 VCC + 0.5 V -50 - mA VO output voltage IIK input clamping current VI < 0 V IOK output clamping current VO > VCC or VO < 0 V - ±50 mA IO output current VO = 0 V to VCC - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation Tamb = -40 °C to +85 °C SSOP package [2] - 850 mW TSSOP package [3] - 600 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 55 °C the value of Ptot derates linearly with 11.3 mW/K. [3] Above 55 °C the value of Ptot derates linearly with 8 mW/K. 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage maximum speed performance CL = 30 pF 2.3 - 2.7 V CL = 50 pF 3.0 - 3.6 V 1.2 - 3.6 V low-voltage applications VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature -40 - +85 °C Δt/ΔV input transition rise and fall rate VCC = 2.3 V to 3.0 V - - 20 ns/V VCC = 3.0 V to 3.6 V - - 10 ns/V [1] Max Unit 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ HIGH-level input voltage VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 2.7 V to 3.6 V 2.0 1.5 - V LOW-level input voltage VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 2.7 V to 3.6 V - 1.5 0.8 V HIGH-level output voltage VI = VIH or VIL IO = -100 μA; VCC = 2.3 V to 3.6 V VCC - 0.2 VCC - V IO = -6 mA; VCC = 2.3 V VCC - 0.3 VCC - 0.08 - V IO = -12 mA; VCC = 2.3 V VCC - 0.6 VCC - 0.26 - V IO = -12 mA; VCC = 2.7 V VCC - 0.5 VCC - 0.14 - V IO = -12 mA; VCC = 3.0 V VCC - 0.6 VCC - 0.09 - V IO = -24 mA; VCC = 3.0 V VCC - 1.0 VCC - 0.28 - V IO = 100 μA; VCC = 2.3 V to 3.6 V - GND 0.20 V IO = 6 mA; VCC = 2.3 V - 0.07 0.40 V IO = 12 mA; VCC = 2.3 V - 0.15 0.70 V IO = 12 mA; VCC = 2.7 V - 0.14 0.40 V IO = 24 mA; VCC = 3.0 V - 0.27 0.55 V Tamb = -40 °C to +85 °C VIH VIL VOH VOL LOW-level output voltage VI = VIH or VIL II input leakage current VCC = 2.3 V to 3.6 V; VI = VCC or GND - 0.1 5 μA IOZ OFF-state output current VCC = 2.3 V to 3.6 V; VI = VIH or VIL; VO = VCC or GND - 0.1 10 μA 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state Parameter Conditions ICC supply current VCC = 2.3 V to 3.6 V; VI = VCC or GND; IO = 0 A - 0.2 40 μA ΔICC additional supply current 74ALVCH16245; per data I/O pin; VCC = 2.3 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 150 750 μA IBHL bus hold LOW current VCC = 2.3 V; VI = 0.7 V [2] 45 - - μA VCC = 3.0 V; VI = 0.8 V [2] 75 150 - μA VCC = 2.3 V; VI = 1.7 V [2] -45 - - μA VCC = 3.0 V; VI = 2.0 V [2] -75 -175 - μA 500 - - μA -500 - - μA IBHH bus hold HIGH current Min Typ [1] Symbol Max Unit IBHLO bus hold LOW overdrive current VCC = 3.6 V [2] IBHHO bus hold HIGH overdrive current VCC = 3.6 V [2] CI input capacitance - 4.0 - pF CI/O input/output capacitance - 8.0 - pF [1] All typical values are measured at Tamb = 25 °C. [2] Valid for data inputs of bushold parts. 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 10 Dynamic characteristics Table 7. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8. Symbol Parameter Conditions Min Typ VCC = 2.3 V to 2.7 V 1.0 VCC = 2.7 V [1] Max Unit 2.0 3.7 ns 1.0 2.1 3.6 ns 1.0 1.9 3.0 ns VCC = 2.3 V to 2.7 V 1.0 2.7 5.7 ns VCC = 2.7 V 1.0 3.0 5.4 ns 1.0 2.3 4.4 ns VCC = 2.3 V to 2.7 V 1.0 2.2 5.2 ns VCC = 2.7 V 1.0 3.1 4.6 ns 1.0 2.8 4.1 ns outputs enabled - 29 - pF outputs disabled - 5 - pF Tamb = -40 °C to +85 °C tpd propagation delay nAn to nBn; nBn to nAn; see Figure 6 [2] VCC = 3.0 V to 3.6 V ten enable time nOE to nAn; nOE to nBn; see Figure 7 [3] VCC = 3.0 V to 3.6 V tdis disable time nOE to nAn; nOE to nBn; see Figure 7 [4] VCC = 3.0 V to 3.6 V CPD power dissipation capacitance per buffer; VI = GND to VCC [5] [1] Typical values are measured at Tamb = 25 °C Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V. Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZL and tPZH. [4] tdis is the same as tPLZ and tPHZ. [5] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts; N = total load switching outputs; 2 ∑(CL × VCC × fo) = sum of outputs. 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 10.1 Waveforms and test circuit VI nAn, nBn input VM GND tPHL tPLH VOH nBn, nAn output VM VOL 001aaa792 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Figure 6. Input (nAn, nBn) to output (nBn, nAn) propagation delay times VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs disabled outputs enabled mna362 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Figure 7. 3-state enable and disable times Table 8. Measurement points Supply voltage Input Output VCC VM VM VX VY < 2.7 V 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V ≥ 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance includes jig and probe capacitance. RT = Termination resistance should be equal to Zo of pulse generator. VEXT = Test voltage for switching times. Figure 8. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPHZ, tPZH tPLZ, tPZL < 2.7 V VCC ≤2.0 ns 30 pF 500 Ω open GND 2 × VCC 2.7 V to 3.6 V 2.7 V ≤2.5 ns 50 pF 500 Ω open GND 2 × VCC 74ALVC_ALVCH16245 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 11 Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3 ) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-118 Figure 9. Package outline SOT370-1 (SSOP48) 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit mm max nom min A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Figure 10. Package outline SOT362-1 (TSSOP48) 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVC_ALVCH16245 v.4 20171121 Product data sheet - 74ALVC_ALVCH16245 v.3 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74ALVC_ALVCH16245 v.3 20040512 Product data sheet - 74ALVCH16245 v.2 74ALVC16245_ 74ALVCH16245 v.1 Modifications: • The format of this data sheet has been redesigned to comply with the current presentation and information standard of Philips Semiconductors. • Section 1: General description updated. 74ALVCH16245 v.2 19980629 Product specification - 74ALVCH16245 v.1 74ALVC16245_ 74ALVCH16245 v.1 19980325 Product specification - - 74ALVCH16245 v.1 19950102 Preliminary specification - - 74ALVC_ALVCH16245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74ALVC_ALVCH16245 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 16 74ALVC16245; 74ALVCH16245 Nexperia 16-bit transceiver with direction pin; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74ALVC_ALVCH16245 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 21 November 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 16 Nexperia 74ALVC16245; 74ALVCH16245 16-bit transceiver with direction pin; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 4 Pinning ............................................................... 4 Pin description ................................................... 4 Functional description ........................................5 Limiting values .................................................... 5 Recommended operating conditions ................ 6 Static characteristics .......................................... 6 Dynamic characteristics .....................................8 Waveforms and test circuit ................................ 9 Package outline .................................................11 Abbreviations .................................................... 13 Revision history ................................................ 13 Legal information .............................................. 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 November 2017 Document identifier: 74ALVC_ALVCH16245
74ALVC16245DGG,112 价格&库存
很抱歉,暂时无法提供与“74ALVC16245DGG,112”相匹配的价格&库存,您可以联系我们找货
