74AUP2G126
Low-power dual buffer/line driver; 3-state
Rev. 11 — 3 July 2017
1
Product data sheet
General description
The 74AUP2G126 provides the dual non-inverting buffer/line driver with 3-state output.
The 3-state output is controlled by the output enable input (nOE). A LOW level at pin
nOE causes the output to assume a high-impedance OFF-state. This device has the
input-disable feature, which allows floating input signals. The inputs are disabled when
the output enable input nOE is LOW.
Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V. This device ensures a very low
static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing a damaging backflow current through the device
when it is powered down.
2
Features and benefits
• Wide supply voltage range from 0.8 V to 3.6 V
• High noise immunity
• Complies with JEDEC standards:
– JESD8-12 (0.8 V to 1.3 V)
– JESD8-11 (0.9 V to 1.65 V)
– JESD8-7 (1.2 V to 1.95 V)
– JESD8-5 (1.8 V to 2.7 V)
– JESD8-B (2.7 V to 3.6 V)
• ESD protection:
– HBM JESD22-A114F Class 3A exceeds 5000 V
– MM JESD22-A115-A exceeds 200 V
– CDM JESD22-C101E exceeds 1000 V
• Low static power consumption; ICC = 0.9 μA (maximum)
• Latch-up performance exceeds 100 mA per JESD78 Class II
• Inputs accept voltages up to 3.6 V
• Low noise overshoot and undershoot < 10 % of VCC
• Input-disable feature allows floating input conditions
• IOFF circuitry provides partial Power-down mode operation
• Multiple package options
• Specified from -40 °C to +85 °C and -40 °C to +125 °C
74AUP2G126
Nexperia
3
Ordering information
Table 1. Ordering information
Type number
Package
Temperature
range
Name
Description
Version
74AUP2G126DC
-40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads;
body width 2.3 mm
SOT765-1
74AUP2G126GT
-40 °C to +125 °C XSON8
plastic extremely thin small outline package; no leads;
8 terminals; body 1 x 1.95 x 0.5 mm
SOT833-1
74AUP2G126GF
8 terminals; body 1.35 x 1 x 0.5 mm
SOT1089
74AUP2G126GM
-40 °C to +125 °C XQFN8
plastic, extremely thin quad flat package; no leads;
8 terminals; body 1.6 x 1.6 x 0.5 mm
SOT902-2
74AUP2G126GN
8 terminals; body 1.2 x 1.0 x 0.35 mm
SOT1116
74AUP2G126GS
8 terminals; body 1.35 x 1.0 x 0.35 mm
SOT1203
74AUP2G126GX
-40 °C to +125 °C X2SON8 plastic thermal enhanced extremely thin small outline
SOT1233
package; no leads; 8 terminals; body 1.35 x 0.8 x 0.35 mm
4
Marking
Table 2. Marking codes
Type number
Marking code
74AUP2G126DC
p26
74AUP2G126GT
p26
74AUP2G126GF
pN
74AUP2G126GM
p26
74AUP2G126GN
pN
74AUP2G126GS
pN
74AUP2G126GX
pN
[1]
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74AUP2G126
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 26
74AUP2G126
Nexperia
5
Functional diagram
1Y
1A
1OE
nY
nA
2Y
2A
2OE
nOE
001aah787
Figure 1. Logic symbol
6
mna234
Figure 2. Logic diagram (one gate)
Pinning information
6.1 Pinning
74AUP2G126
1OE
1
8
VCC
1A
2
7
2OE
2Y
3
6
1Y
GND
4
5
2A
74AUP2G126
1OE
1
8
VCC
1A
2
7
2OE
2Y
3
6
1Y
GND
4
5
2A
001aae998
Transparent top view
001aae997
Figure 4. Pin configuration SOT833-1,
SOT1089,SOT1116 and SOT1203
Figure 3. Pin configuration SOT765-1
74AUP2G126
1
74AUP2G126
8
2OE
VCC
terminal 1
index area
7
1OE
1OE 1
1Y
2
6
1A
2A
3
5
2Y
4
GND
Product data sheet
2
6
1Y
5
2A
4
GND
2Y
3
001aae999
aaa-023986
74AUP2G126
2OE
VCC
1A
Figure 5. Pin configuration SOT902-2
7
8
Figure 6. Pin configuration SOT1233
3 / 26
74AUP2G126
Nexperia
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
SOT765-1, SOT833-1, SOT1089, SOT1116,
SOT1203 and SOT1233
SOT902-2
1OE, 2OE
1, 7
7, 1
output enable input (active HIGH)
1A, 2A
2, 5
6, 3
data input
1Y, 2Y
6, 3
2, 5
data output
GND
4
4
ground (0 V)
VCC
8
8
supply voltage
7
Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Output
Input
nOE
nA
nY
H
L
L
H
H
H
L
X
Z
74AUP2G126
Product data sheet
4 / 26
74AUP2G126
Nexperia
8
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
-0.5
+4.6
V
-50
-0.5
+4.6
-50
-0.5
+4.6
V
±20
mA
mA
V
mA
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
Tamb = -40 °C to +125 °C
[2]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For VSSOP8 packages: above 110 °C the value of Ptot derates linearly with 8.0 mW/K.
For XSON8 and XQFN8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
For X2SON8 package: above 118 °C the value of Ptot derates linearly with 7.7 mW/K.
9
Recommended operating conditions
Table 6. Operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74AUP2G126
Product data sheet
Min
Max
0.8
3.6
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
-40
+125
°C
ns/V
VCC = 0.8 V to 3.6 V
Unit
5 / 26
74AUP2G126
Nexperia
10 Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 x VCC
V
VCC = 0.9 V to 1.95 V
0.65 x VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 x VCC
V
0.35 x VCC
V
0.7
V
0.9
V
VCC - 0.1
V
IO = -1.1 mA; VCC = 1.1 V
0.75 x VCC
V
IO = -1.7 mA; VCC = 1.4 V
1.11
V
IO = -1.9 mA; VCC = 1.65 V
1.32
V
IO = -2.3 mA; VCC = 2.3 V
2.05
V
IO = -3.1 mA; VCC = 2.3 V
1.9
V
IO = -2.7 mA; VCC = 3.0 V
2.72
V
IO = -4.0 mA; VCC = 3.0 V
2.6
V
IO = 20 μA; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.3 x VCC
V
IO = 1.7 mA; VCC = 1.4 V
0.31
V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
Tamb = 25 °C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
VI = VIH or VIL
IO = -20 μA; VCC = 0.8 V to 3.6 V
VOL
LOW-level output voltage
VI = VIH or VIL
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
IOZ
OFF-state output current
VI = VIH or VIL; VO = 0 V to 3.6 V;
VCC = 0 V to 3.6 V
±0.1
μA
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.2
μA
ΔIOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
±0.2
μA
74AUP2G126
Product data sheet
6 / 26
74AUP2G126
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
ICC
supply current
VI = GND or VCC; IO = 0 A;
ΔICC
additional supply current
data input; VI = VCC - 0.6 V; IO = 0 A;
VCC = 3.3 V
Unit
0.5
μA
[1]
40
μA
nOE input; VI = VCC - 0.6 V; IO = 0 A;
VCC = 3.3 V
[1]
110
μA
all inputs; VI = GND to 3.6 V;
nOE = GND; VCC = 0.8 V to 3.6 V
[2]
1
μA
CI
input capacitance
VI = GND or VCC; VCC = 0 V to 3.6 V
0.9
pF
CO
output capacitance
output enabled; VO = GND;
VCC = 0 V
1.7
pF
output disabled; VO = GND or VCC;
VCC = 0 V to 3.6 V
1.5
pF
VCC = 0.8 V
0.70 x VCC
V
0.65 x VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.30 x VCC
V
0.35 x VCC
V
0.7
V
0.9
V
VCC - 0.1
V
0.7 x VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
74AUP2G126
Product data sheet
VI = VIH or VIL
7 / 26
74AUP2G126
Nexperia
Symbol Parameter
Conditions
VOL
VI = VIH or VIL
Min
Typ
Max
Unit
0.1
V
0.3 x VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
II
±0.5
μA
IOZ
VCC = 0 V to 3.6 V
±0.5
μA
IOFF
±0.5
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.6
μA
ICC
supply current
0.9
μA
ΔICC
VCC = 3.3 V
[1]
50
μA
VCC = 3.3 V
[1]
120
μA
[2]
1
μA
VCC = 0.8 V
0.75 x VCC
V
0.70 x VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.25 x VCC
V
0.30 x VCC
V
0.7
V
0.9
V
VIH
VIL
74AUP2G126
Product data sheet
8 / 26
74AUP2G126
Nexperia
Symbol Parameter
Conditions
VOH
VI = VIH or VIL
VOL
Min
Typ
Max
Unit
VCC - 0.11
V
0.6 x VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33 x VCC
V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
VI = VIH or VIL
II
±0.75
μA
IOZ
VCC = 0 V to 3.6 V
±0.75
μA
IOFF
±0.75
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.75
μA
ICC
supply current
1.4
μA
ΔICC
VCC = 3.3 V
[1]
75
μA
VCC = 3.3 V
[1]
180
μA
[2]
1
μA
[1]
[2]
One input at VCC - 0.6 V, other input at VCC or GND.
To show ICC remains very low when the input-disable feature is enabled.
74AUP2G126
Product data sheet
9 / 26
74AUP2G126
Nexperia
11 Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9.
Symbol Parameter
Conditions
25 °C
Min
[1]
Typ
-40 °C to +125 °C
Max
Min
Unit
Max
Max
(85 °C) (125 °C)
CL = 5 pF
tpd
propagation delay
nA to nY; see Figure 7
[2]
VCC = 0.8 V
20.6
ns
VCC = 1.1 V to 1.3 V
2.8
5.5
10.5
2.5
11.7
12.9
ns
VCC = 1.4 V to 1.6 V
2.2
3.9
6.1
2.0
7.3
8.1
ns
VCC = 1.65 V to 1.95 V
1.9
3.2
4.1
1.7
6.1
6.7
ns
1.6
2.6
3.6
1.4
4.3
4.9
ns
1.4
2.4
3.1
1.2
3.9
4.4
ns
71.6
ns
2.8
6.2
12.4
2.6
13.6
13.6
ns
2.3
4.2
6.9
2.2
7.4
7.7
ns
1.9
3.3
5.3
1.7
5.9
6.2
ns
1.5
2.4
3.6
1.4
3.8
4.1
ns
1.3
2.0
2.9
1.2
3.2
3.4
ns
10.3
ns
2.6
4.2
6.2
2.9
6.4
6.5
ns
2.1
3.2
4.4
2.2
4.6
4.7
ns
2.1
3.1
4.4
1.7
4.6
4.8
ns
1.7
2.4
3.2
1.4
3.4
3.6
ns
2.1
2.8
3.6
1.2
3.7
3.8
ns
ten
enable time
nOE to nY; see Figure 8
[3]
VCC = 0.8 V
tdis
disable time
VCC = 0.8 V
74AUP2G126
Product data sheet
[4]
10 / 26
74AUP2G126
Nexperia
Symbol Parameter
Conditions
25 °C
Min
[1]
Typ
-40 °C to +125 °C
Max
Min
Unit
Max
Max
(85 °C) (125 °C)
CL = 10 pF
tpd
propagation delay
[2]
VCC = 0.8 V
24.0
ns
3.2
6.4
12.3
3.0
13.8
15.2
ns
2.1
4.5
7.3
1.9
8.5
9.4
ns
1.9
3.8
5.5
1.7
6.8
7.6
ns
2.1
3.2
4.2
1.6
5.3
5.9
ns
1.8
3.0
3.8
1.6
4.6
5.2
ns
75.3
ns
3.2
7.1
14.1
3.0
15.4
15.4
ns
2.2
4.8
8.0
2.1
8.3
8.6
ns
1.8
3.9
5.9
1.7
6.5
6.8
ns
1.5
2.9
4.2
1.4
4.5
4.8
ns
1.4
2.6
3.6
1.3
3.8
4.0
ns
12.2
ns
3.5
5.3
7.6
3.3
7.9
7.9
ns
2.2
4.1
5.6
2.1
5.7
5.9
ns
2.4
4.2
5.7
1.7
5.8
6.0
ns
1.9
3.2
4.1
1.4
4.3
4.5
ns
2.4
4.1
5.0
1.3
5.2
5.3
ns
27.4
ns
3.6
7.2
14.1
3.3
15.8
17.5
ns
3.0
5.1
8.1
2.5
9.8
10.9
ns
2.2
4.3
6.3
2.0
7.9
8.8
ns
2.0
3.7
4.9
1.8
6.0
6.7
ns
2.0
3.5
4.4
1.8
5.4
6.1
ns
ten
enable time
[3]
VCC = 0.8 V
tdis
disable time
[4]
VCC = 0.8 V
CL = 15 pF
tpd
propagation delay
VCC = 0.8 V
74AUP2G126
Product data sheet
[2]
11 / 26
74AUP2G126
Nexperia
Symbol Parameter
Conditions
25 °C
Min
ten
enable time
Min
Max
Max
(85 °C) (125 °C)
79.2
ns
3.6
7.8
15.8
3.3
17.1
17.1
ns
3.0
5.4
8.8
2.9
9.4
9.7
ns
2.1
4.3
6.7
2.0
7.3
7.7
ns
1.8
3.4
4.8
1.7
5.2
5.6
ns
1.6
3.1
4.1
1.5
4.5
4.7
ns
14.9
ns
4.3
6.4
8.5
3.7
9.3
9.4
ns
3.0
5.0
6.6
2.5
6.9
7.0
ns
3.1
5.4
6.6
2.0
7.4
7.5
ns
2.4
4.0
5.0
1.7
5.1
5.5
ns
3.2
5.3
6.2
1.5
6.7
6.9
ns
37.4
ns
4.8
9.5
18.7
4.4
21.4
24.0
ns
4.0
6.7
10.8
3.0
13.0
14.5
ns
2.9
5.6
8.4
2.6
10.3
11.5
ns
2.7
4.8
6.3
2.5
7.8
8.7
ns
2.7
4.6
5.8
2.5
7.0
8.3
ns
90.6
ns
4.7
10.0
20.4
4.3
22.0
22.0
ns
3.0
6.9
11.3
3.7
12.0
12.5
ns
2.6
5.6
8.6
3.2
9.5
10.1
ns
2.3
4.5
6.3
2.9
6.8
7.3
ns
2.2
4.2
5.8
2.7
6.4
6.7
ns
disable time
Max
Unit
[3]
VCC = 0.8 V
tdis
[1]
Typ
-40 °C to +125 °C
[4]
VCC = 0.8 V
CL = 30 pF
tpd
propagation delay
[2]
VCC = 0.8 V
ten
enable time
VCC = 0.8 V
74AUP2G126
Product data sheet
[3]
12 / 26
74AUP2G126
Nexperia
Symbol Parameter
Conditions
25 °C
Min
tdis
disable time
[1]
Typ
-40 °C to +125 °C
Max
Min
Unit
Max
Max
(85 °C) (125 °C)
[4]
VCC = 0.8 V
51.6
ns
6.0
9.8
13.6
4.7
14.3
14.4
ns
4.5
7.7
10.5
3.0
10.7
11.0
ns
5.2
8.8
11.4
2.6
11.5
11.6
ns
3.9
6.4
7.4
2.3
9.0
10.2
ns
5.5
9.0
10.7
2.2
10.8
12.0
ns
VCC = 0.8 V
2.7
pF
2.8
pF
2.9
pF
3.0
pF
3.6
pF
4.2
pF
CL = 5 pF, 10 pF, 15 pF and 30 pF
CPD
power dissipation
capacitance
[1]
[2]
[3]
[4]
[5]
output enabled; fi = 1 MHz;
VI = GND to VCC
[5]
All typical values are measured at nominal VCC.
tpd is the same as tPLH and tPHL.
ten is the same as tPZH and tPZL.
tdis is the same as tPHZ and tPLZ.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of the outputs.
74AUP2G126
Product data sheet
13 / 26
74AUP2G126
Nexperia
11.1 Waveforms and test circuit
VI
VM
nA input
GND
tPHL
tPLH
VOH
VM
nY output
VOL
mna230
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Figure 7. The data input (nA) to output (nY) propagation delays
Table 9. Measurement points
Supply voltage
Output
Input
VCC
VM
VM
VI
tr = tf
0.8 V to 3.6 V
0.5 × VCC
0.5 × VCC
VCC
≤ 3.0 ns
VI
nOE input
VM
GND
t PLZ
t PZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
t PZH
VY
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
mna949
Measurement points are given in Table 10.
Figure 8. Enable and disable times
Table 10. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
0.8 V to 1.6 V
0.5 × VCC
0.5 × VCC
VOL + 0.1 V
VOH - 0.1 V
1.65 V to 2.7 V
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
3.0 V to 3.6 V
0.5 × VCC
0.5 × VCC
VOL + 0.3 V
VOH - 0.3 V
74AUP2G126
Product data sheet
14 / 26
74AUP2G126
Nexperia
VCC
G
VI
DUT
VEXT
5 kΩ
VO
RT
CL
RL
001aac521
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 9. Test circuit for measuring switching times
Table 11. Test data
Supply voltage
Load
VEXT
[1]
VCC
CL
RL
0.8 V to 3.6 V
5 kΩ or 1 MΩ
[1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
open
GND
2 × VCC
For measuring enable and disable times RL = 5 kΩ.
For measuring propagation delays, set-up and hold times and pulse width RL = 1 MΩ.
74AUP2G126
Product data sheet
15 / 26
74AUP2G126
Nexperia
12 Package outline
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
A
max.
max
nom
min
mm
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Figure 10. Package outline SOT765-1 (VSSOP8)
74AUP2G126
Product data sheet
16 / 26
74AUP2G126
Nexperia
XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
1
2
SOT833-1
b
4
3
4×
(2)
L
L1
e
8
7
6
e1
5
e1
e1
8×
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A(1)
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.25
0.17
2.0
1.9
1.05
0.95
0.6
0.5
0.35
0.27
0.40
0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT833-1
MO-252
EUROPEAN
PROJECTION
ISSUE DATE
07-11-14
07-12-07
Figure 11. Package outline SOT833-1 (XSON8)
74AUP2G126
Product data sheet
17 / 26
74AUP2G126
Nexperia
XSON8: extremely thin small outline package; no leads;
SOT1089
E
terminal 1
index area
D
A
A1
detail X
(4×)(2)
e
L
(8×)(2)
b 4
5
e1
1
terminal 1
index area
8
L1
X
scale
Dimensions
Unit
max
nom
min
mm
1 mm
A(1)
0.5
A1
b
D
E
e
e1
L
L1
0.04 0.20 1.40 1.05
0.35 0.40
0.15 1.35 1.00 0.55 0.35 0.30 0.35
0.12 1.30 0.95
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
SOT1089
sot1089_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-09
10-04-12
MO-252
Figure 12. Package outline SOT1089 (XSON8)
74AUP2G126
Product data sheet
18 / 26
74AUP2G126
Nexperia
XQFN8: plastic, extremely thin quad flat package; no leads;
SOT902-2
X
D
B
A
terminal 1
index area
E
A
A1
detail X
e
v
w
b
4
3
C
C A B
C
y1 C
y
5
e1
terminal 1
index area
2
6
L 1
7
k
8
L2
L
k
metal area
not for soldering
L3
L1
Dimensions
Unit(1)
max
nom
min
mm
2 mm
scale
A
0.5
A1
b
D
E
e
e1
0.05 0.25 1.65 1.65
0.20 1.60 1.60 0.55
0.00 0.15 1.55 1.55
0.5
k
0.2
L
L1
L2
L3
0.35 0.15 0.25 0.35
0.30 0.10 0.20 0.30
0.25 0.05 0.15 0.25
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT902-2
MO-255
sot902-2_po
European
projection
Issue date
16-07-14
16-11-08
Figure 13. Package outline SOT902-2 (XQFN8)
74AUP2G126
Product data sheet
19 / 26
74AUP2G126
Nexperia
1
2
SOT1116
b
4
3
(4×)(2)
L
L1
e
8
7
e1
6
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 1.25 1.05
nom
0.15 1.20 1.00 0.55
min
0.12 1.15 0.95
mm
1 mm
scale
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
Outline
version
sot1116_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1116
Figure 14. Package outline SOT1116 (XSON8)
74AUP2G126
Product data sheet
20 / 26
74AUP2G126
Nexperia
SOT1203
b
1
2
3
(4×)(2)
4
L
L1
e
8
7
6
e1
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.40 1.05
0.35 0.40
nom
min
0.12 1.30 0.95
0.27 0.32
mm
Note
Outline
version
sot1203_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1203
Figure 15. Package outline SOT1203 (XSON8)
74AUP2G126
Product data sheet
21 / 26
74AUP2G126
Nexperia
X2SON8: plastic thermal enhanced extremely thin small outline package; no leads;
SOT1233
X
A
B
D
A
E
A1
detail X
pin 1
index area
e
e
1
2
pin 1
index area
C
b
(6x)
8
v
w
3
C A B
C
y
4
Dh
L
(6x)
7
6
b1
(2x)
5
y1 C
e1
1 mm
scale
Unit
mm
A
A1
max 0.35 0.04
nom 0.32
min 0.30 0.00
b
0.25
0.20
0.15
b1
D
Dh
E
1.40 0.27 0.85
0.15 1.35 0.22 0.80
(ref) 1.30 0.17 0.75
e
0.5
e1
L
0.27
0.54 0.22
0.17
v
0.1
w
y
y1
0.05 0.05 0.05
sot1233_po
Outline
version
SOT1233
References
IEC
JEDEC
JEITA
European
projection
Issue date
16-04-21
17-01-05
Figure 16. Package outline SOT1233 (X2SON8)
74AUP2G126
Product data sheet
22 / 26
74AUP2G126
Nexperia
13 Abbreviations
Table 12. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14 Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AUP2G126 v.11
20170703
Product data sheet
74AUP2G126 v.10
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
• Figure 6 and Figure 16 (drawings SOT1233/X2SON8) updated
• Type number 74AUP2G126GD removed.
74AUP2G126 v.10
20161028
Modifications:
• Added type number 74AUP2G126GX (SOT1233/X2SON8)
74AUP2G126 v.9
20130211
Modifications:
• For type number 74AUP2G126GD XSON8U has changed to XSON8.
74AUP2G126 v.8
20120606
Product data sheet
74AUP2G126 v.7
74AUP2G126 v.7
20111201
Product data sheet
74AUP2G126 v.6
74AUP2G126 v.6
20100621
Product data sheet
74AUP2G126 v.5
74AUP2G126 v.5
20090202
Product data sheet
74AUP2G126 v.4
74AUP2G126 v.4
20090114
Product data sheet
74AUP2G126 v.3
74AUP2G126 v.3
20080409
Product data sheet
74AUP2G126 v.2
74AUP2G126 v.2
20070515
Product data sheet
74AUP2G126 v.1
74AUP2G126 v.1
20061009
Product data sheet
74AUP2G126
Product data sheet
Product data sheet
Product data sheet
74AUP2G126 v.9
74AUP2G126 v.8
23 / 26
74AUP2G126
Nexperia
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74AUP2G126
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
24 / 26
74AUP2G126
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74AUP2G126
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
25 / 26
74AUP2G126
Nexperia
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
12
13
14
15
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Marking .................................................................2
Functional diagram ............................................. 3
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 4
Functional description ........................................4
Limiting values .................................................... 5
Recommended operating conditions ................ 5
Static characteristics .......................................... 6
Dynamic characteristics ...................................10
Waveforms and test circuit .............................. 14
Package outline .................................................16
Abbreviations .................................................... 23
Revision history ................................................ 23
Legal information .............................................. 24
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 3 July 2017
Document identifier: 74AUP2G126
