74AUP2G16
Low-power dual buffer
Rev. 2 — 7 October 2016
Product data sheet
1. General description
The 74AUP2G16 provides two low-power, low-voltage buffers.
Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F Class 3A exceeds 5000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 A (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74AUP2G16
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AUP2G16GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AUP2G16GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AUP2G16GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
4. Marking
Table 2.
Marking
Marking code[1]
Type number
74AUP2G16GW
5A
74AUP2G16GM
5A
74AUP2G16GF
5A
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Logic symbol
74AUP2G16
Product data sheet
PQE
PQE
Fig 1.
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
DDF
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 17
74AUP2G16
Nexperia
6. Pinning information
6.1 Pinning
$83*
$83*
*1'
9&&
*1'
9&&
DDD
7UDQVSDUHQWWRSYLHZ
DDD
Fig 4.
Pin configuration SOT363
Fig 5.
Pin configuration SOT886 and SOT891
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
7. Functional description
Table 4.
Function table[1]
Input
Output
nA
nY
L
L
H
H
[1]
H = HIGH voltage level; L = LOW voltage level.
74AUP2G16
Product data sheet
3 of 17
74AUP2G16
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
0.5
+4.6
V
50
0.5
+4.6
50
0.5
+4.6
mA
V
mA
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
mA
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[2]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
V
For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
74AUP2G16
Product data sheet
Min
Max
Unit
0.8
3.6
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
C
200
ns/V
VCC = 0.8 V to 3.6 V
4 of 17
74AUP2G16
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 VCC
V
VCC = 0.9 V to 1.95 V
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
IO = 20 A; VCC = 0.8 V to 3.6 V
VCC 0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.75 VCC
V
IO = 1.7 mA; VCC = 1.4 V
1.11
V
Tamb = 25 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VI = VIH or VIL
IO = 1.9 mA; VCC = 1.65 V
1.32
V
IO = 2.3 mA; VCC = 2.3 V
2.05
V
IO = 3.1 mA; VCC = 2.3 V
1.9
V
IO = 2.7 mA; VCC = 3.0 V
2.72
V
IO = 4.0 mA; VCC = 3.0 V
2.6
V
0.1
V
VI = VIH or VIL
0.3 VCC V
0.31
V
0.31
V
0.31
V
0.44
V
0.31
V
0.44
V
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
0.1
A
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
0.2
A
IOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
0.2
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
A
ICC
additional supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 3.3 V
40
A
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
74AUP2G16
Product data sheet
5 of 17
74AUP2G16
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 VCC
V
0.65 VCC
V
1.6
V
2.0
V
0.30 VCC V
0.35 VCC V
Tamb = 40 C to +85 C
VIH
VIL
VOH
VOL
VCC = 0.8 V
0.7
V
0.9
V
VI = VIH or VIL
VCC 0.1
V
0.7 VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
VI = VIH or VIL
0.3 VCC V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
II
0.5
A
IOFF
0.5
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.6
A
ICC
supply current
0.9
A
ICC
VCC = 3.3 V
50
A
74AUP2G16
Product data sheet
6 of 17
74AUP2G16
Nexperia
Table 7.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.75 VCC
V
0.70 VCC
V
1.6
V
2.0
V
0.25 VCC V
0.30 VCC V
VIH
VIL
VOH
VOL
VCC = 0.8 V
0.7
V
0.9
V
VI = VIH or VIL
VCC 0.11
V
0.6 VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
VI = VIH or VIL
0.33 VCC V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
II
0.75
A
IOFF
0.75
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.75
A
ICC
supply current
1.4
A
ICC
VCC = 3.3 V
75
A
74AUP2G16
Product data sheet
7 of 17
74AUP2G16
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7.
Symbol Parameter
25 C
Conditions
40 C to +125 C
Min
Typ[1]
Max
Min
Max
(85 C)
Max
(125 C)
14.9
Unit
CL = 5 pF
tpd
propagation delay nA to nY; see Figure 6
[2]
VCC = 0.8 V
ns
VCC = 1.1 V to 1.3 V
2.6
4.7
9.2
2.0
10.0
11.0
ns
VCC = 1.4 V to 1.6 V
2.1
3.4
5.7
1.6
6.5
7.2
ns
VCC = 1.65 V to 1.95 V
1.8
2.9
4.5
1.4
5.2
5.8
ns
1.5
2.3
3.5
1.2
4.2
4.6
ns
1.4
2.1
3.2
1.0
3.8
4.2
ns
18.4
ns
3.2
5.6
10.9
2.3
11.8
13.1
ns
2.6
4.1
6.7
1.9
7.7
8.5
ns
2.3
3.4
5.3
1.7
6.2
6.9
ns
2.0
2.9
4.2
1.5
5.0
5.5
ns
1.7
2.6
3.8
1.4
4.6
5.1
ns
21.9
ns
CL = 10 pF
tpd
[2]
VCC = 0.8 V
CL = 15 pF
tpd
[2]
VCC = 0.8 V
3.6
6.4
12.6
2.6
13.8
15.2
ns
3.0
4.6
7.6
2.2
8.9
9.8
ns
2.6
3.9
6.0
2.0
7.2
7.9
ns
2.3
3.3
4.8
1.8
5.7
6.3
ns
2.1
3.1
4.2
1.6
5.0
5.5
ns
32.1
ns
CL = 30 pF
tpd
VCC = 0.8 V
74AUP2G16
Product data sheet
[2]
4.8
8.7
16.3
3.6
18.9
20.8
ns
4.0
6.2
10.3
3.4
12.2
13.4
ns
3.6
5.2
8.1
3.2
9.8
10.8
ns
3.0
4.4
6.4
2.7
7.7
8.5
ns
2.9
4.2
5.6
2.5
6.5
7.2
ns
8 of 17
74AUP2G16
Nexperia
Table 8.
Dynamic characteristics …continued
Symbol Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
(85 C)
Max
(125 C)
VCC = 0.8 V
2.5
pF
2.6
pF
2.7
pF
2.9
pF
3.4
pF
4.0
pF
CL = 5 pF, 10 pF, 15 pF and 30 pF
power dissipation
capacitance
CPD
fi = 1 MHz; VI = GND to VCC
[3][4]
[1]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL.
[3]
All specified values are the average typical values over all stated loads.
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
12. Waveforms
9,
Q$LQSXW
90
90
*1'
W3/+
W3+/
92+
90
Q
很抱歉,暂时无法提供与“74AUP2G16GWH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.25009
- 50+1.12067
- 100+1.04187
- 200+0.95432
- 500+0.81949
- 1000+0.77659
- 2000+0.72668
