74AUP3G07GNX
74AUP3G07GNX
    NEXPERIA(安世)
    XSON8
    具有漏极开路输出的低功耗三路缓冲器
74AUP3G07GNX 数据手册
74AUP3G07 Low-power triple buffer with open-drain output Rev. 2 — 5 October 2016 Product data sheet 1. General description The 74AUP3G07 is a triple non-inverting buffer with open-drain output. The output of the device is an open drain and can be connected to other open-drain outputs to implement active-LOW wired-OR or active-HIGH wired-AND functions. Schmitt-trigger action at all inputs makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. This device ensures a very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  Complies with JEDEC standards:  JESD8-12 (0.8 V to 1.3 V)  JESD8-11 (0.9 V to 1.65 V)  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8-B (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F Class 3A exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Low static power consumption; ICC = 0.9 A (maximum)  Latch-up performance exceeds 100 mA per JESD 78B Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial Power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74AUP3G07 Nexperia Low-power triple buffer with open-drain output 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP3G07DC 40 C to +125 C VSSOP8 plastic very thin shrink small outline package; 8 leads; SOT765-1 body width 2.3 mm 74AUP3G07GT 40 C to +125 C XSON8 plastic extremely thin small outline package; no leads; SOT833-1 8 terminals; body 1  1.95  0.5 mm 74AUP3G07GM 40 C to +125 C XQFN8 plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6  1.6  0.5 mm SOT902-2 74AUP3G07GN 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.2  1.0  0.35 mm SOT1116 74AUP3G07GS 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35  1.0  0.35 mm SOT1203 4. Marking Table 2. Marking codes Type number Marking code[1] 74AUP3G07DC p07 74AUP3G07GT p07 74AUP3G07GM p07 74AUP3G07GN p7 74AUP3G07GS p7 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $ < $ < $ <  $ < < $ <  $ $ < *1' DDD Fig 1. Logic symbol 74AUP3G07 Product data sheet PQD DDD Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 2 — 5 October 2016 Fig 3. Logic diagram (one gate) © Nexperia B.V. 2017. All rights reserved 2 of 18 74AUP3G07 Nexperia Low-power triple buffer with open-drain output 6. Pinning information 6.1 Pinning $83* $   9&& <   < $   $ *1'   < $83* $   9&& <   < $   $ *1'   < DDD 7UDQVSDUHQWWRSYLHZ DDD Fig 4. Pin configuration SOT765-1 Fig 5. Pin configuration SOT833-1, SOT1116 and SOT1203 $83* <  $ <  9&& WHUPLQDO LQGH[DUHD $   <   $ *1'   DDD 7UDQVSDUHQWWRSYLHZ Fig 6. Pin configuration SOT902-2 6.2 Pin description Table 3. Symbol Pin description Pin Description SOT765-1, SOT833-1, SOT1116 and SOT1203 SOT902-2 1A, 2A, 3A 1, 3, 6 7, 5, 2 data input 1Y, 2Y, 3Y 7, 5, 2 1, 3, 6 data output GND 4 4 ground (0 V) VCC 8 8 supply voltage 74AUP3G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 5 October 2016 © Nexperia B.V. 2017. All rights reserved 3 of 18 74AUP3G07 Nexperia Low-power triple buffer with open-drain output 7. Functional description Table 4. Function table[1] Input nA Output nY L L H Z [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage Conditions Min Max Unit 0.5 +4.6 V 50 - [1] 0.5 +4.6 50 - [1] 0.5 +4.6 - 20 mA 50 mA VI < 0 V mA V IOK output clamping current VO < 0 V VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC ICC supply current - IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot [1] [2] Tamb = 40 C to +125 C [2] mA V The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. For VSSOP8 packages: above 110 C, the value of Ptot derates linearly with 8.0 mW/K. For XSON8 and XQFN8 packages: above 118 C, the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Active mode and Power-down mode Tamb ambient temperature t/V input transition rise and fall rate 74AUP3G07 Product data sheet VCC = 0.8 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 5 October 2016 Min Max Unit 0.8 3.6 V 0 3.6 V 0 3.6 V 40 +125 C 0 200 ns/V © Nexperia B.V. 2017. All rights reserved 4 of 18 74AUP3G07 Nexperia Low-power triple buffer with open-drain output 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.31 V Tamb = 25 C VIH VIL VOL HIGH-level input voltage LOW-level input voltage LOW-level output voltage VI = VIH or VIL 0.3  VCC V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOZ OFF-state output current VI = VIH; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.2 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.2 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 40 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND or VCC - 0.7 - pF CO output capacitance VO = GND; VCC = 0 V - 0.9 - pF VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V - V Tamb = 40 C to +85 C VIH VIL HIGH-level input voltage LOW-level input voltage 74AUP3G07 Product data sheet 2.0 - VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 5 October 2016 © Nexperia B.V. 2017. All rights reserved 5 of 18 74AUP3G07 Nexperia Low-power triple buffer with open-drain output Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL VI = VIH or VIL LOW-level output voltage Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V 0.3  VCC V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.5 A IOZ OFF-state output current VI = VIH; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V - - 0.5 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.5 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.6 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 50 A VCC = 0.8 V 0.75  VCC - - V VCC = 0.9 V to 1.95 V 0.70  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V - V Tamb = 40 C to +125 C VIH VIL VOL HIGH-level input voltage LOW-level input voltage LOW-level output voltage 2.0 - VCC = 0.8 V - - 0.25  VCC V VCC = 0.9 V to 1.95 V - - 0.30  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - VI = VIH or VIL 0.33  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOZ OFF-state output current VI = VIH; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.75 A 74AUP3G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 5 October 2016 © Nexperia B.V. 2017. All rights reserved 6 of 18 74AUP3G07 Nexperia Low-power triple buffer with open-drain output Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.75 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 75 A 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 8. Symbol Parameter 25 C Conditions Min Typ[1] 40 C to +125 C Max Min Max (85 C) Unit Max (125 C) CL = 5 pF tpd propagation delay nA to nY; see Figure 7 [2] - 11.6 - - - - ns VCC = 1.1 V to 1.3 V VCC = 0.8 V 2.1 4.1 7.5 1.7 9.1 10.0 ns VCC = 1.4 V to 1.6 V 1.6 3.0 5.1 1.3 6.1 6.7 ns VCC = 1.65 V to 1.95 V 1.6 2.7 4.0 1.2 5.0 5.5 ns VCC = 2.3 V to 2.7 V 1.1 2.1 3.2 0.9 4.0 4.4 ns VCC = 3.0 V to 3.6 V 1.4 2.2 2.8 1.1 3.3 3.6 ns CL = 10 pF tpd propagation delay nA to nY; see Figure 7 [2] - 14.7 - - - - ns VCC = 1.1 V to 1.3 V VCC = 0.8 V 3.0 5.1 9.0 2.4 11.2 12.3 ns VCC = 1.4 V to 1.6 V 2.3 3.8 6.1 2.0 7.4 8.1 ns VCC = 1.65 V to 1.95 V 2.4 3.6 4.8 1.8 6.1 6.7 ns VCC = 2.3 V to 2.7 V 1.7 2.8 3.8 1.3 4.8 5.3 ns VCC = 3.0 V to 3.6 V 2.2 3.1 4.2 1.6 4.5 5.0 ns CL = 15 pF tpd propagation delay nA to nY; see Figure 7 VCC = 0.8 V 74AUP3G07 Product data sheet [2] - 17.7 - - - - ns VCC = 1.1 V to 1.3 V 3.5 6.1 10.4 3.2 13.1 14.5 ns VCC = 1.4 V to 1.6 V 3.0 4.5 6.8 2.6 8.6 9.4 ns VCC = 1.65 V to 1.95 V 2.8 4.4 6.7 2.2 7.8 8.6 ns VCC = 2.3 V to 2.7 V 2.4 3.4 4.5 1.9 5.3 5.8 ns VCC = 3.0 V to 3.6 V 2.2 4.0 5.7 1.9 6.1 6.7 ns All information provided in this document is subject to legal disclaimers. Rev. 2 — 5 October 2016 © Nexperia B.V. 2017. All rights reserved 7 of 18 74AUP3G07 Nexperia Low-power triple buffer with open-drain output Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 8. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 26.7 - - - - ns VCC = 1.1 V to 1.3 V 4.8 9.0 15.6 4.3 18.8 20.7 ns CL = 30 pF propagation delay nA to nY; see Figure 7 tpd [2] VCC = 0.8 V VCC = 1.4 V to 1.6 V 4.1 6.7 9.4 3.7 11.8 13.0 ns VCC = 1.65 V to 1.95 V 3.8 6.8 9.7 3.2 11.0 12.1 ns VCC = 2.3 V to 2.7 V 3.7 5.2 6.7 3.0 7.1 7.8 ns VCC = 3.0 V to 3.6 V 3.6 6.4 9.7 2.8 10.4 11.4 ns VCC = 0.8 V - 0.5 - - - - pF VCC = 1.1 V to 1.3 V - 0.6 - - - - pF VCC = 1.4 V to 1.6 V - 0.6 - - - - pF VCC = 1.65 V to 1.95 V - 0.7 - - - - pF VCC = 2.3 V to 2.7 V - 0.9 - - - - pF VCC = 3.0 V to 3.6 V - 1.2 - - - - pF CL = 5 pF, 10 pF, 15 pF and 30 pF power dissipation capacitance CPD fi = 1 MHz; VI = GND to VCC [3][4] [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPZL and tPLZ. [3] All specified values are the average typical values over all stated loads. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N where: fi = input frequency in MHz; VCC = supply voltage in V; N = number of inputs switching. 74AUP3G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 5 October 2016 © Nexperia B.V. 2017. All rights reserved 8 of 18 74AUP3G07 Nexperia Low-power triple buffer with open-drain output 12. Waveforms 9, 90 Q$LQSXW 90 *1' W 3=/ W 3/= 9&& Q
74AUP3G07GNX
物料型号为74AUP3G07,这是一款低功耗三重缓冲器,具有开漏输出。
以下是对PDF文档中各部分内容的中文分析:
器件简介: - 74AUP3G07是一款三重非反相缓冲器,具有开漏输出。
- 输出为开漏形式,可以与其他开漏输出连接,实现主动低电平或高电平的线与或线与非功能。
- 所有输入端都具有施密特触发器动作,使电路在整个VCC范围内对输入上升和下降时间的变化具有容忍度。
- 该设备在整个VCC范围内(0.8 V至3.6 V)确保了非常低的静态和动态功耗。
- 设备完全适用于使用IOFF的局部断电应用。
- IOFF电路在断电时禁用输出,防止通过设备产生有害的反向电流。
引脚分配: - 引脚1A、2A、3A为数据输入。
- 引脚1Y、2Y、3Y为数据输出。
- 引脚GND为地(0V)。
- 引脚Vcc为供电电压。
参数特性: - 供电电压范围宽,从0.8 V到3.6 V。
- 高抗噪声性。
- 符合JEDEC标准,包括不同电压范围的规范。
- ESD保护:HBM、MM、CDM均超过一定电压等级。
- 静态功耗低,最大ICC为0.9 μA。
- 输入电压接受高达3.6 V的电压。
- 低噪声过冲和下冲小于VCC的10%。
- IOFF电路提供部分断电模式操作。
- 多种封装选项。
- 规定在-40°C至+85°C和-40°C至+125°C的温度范围内。
功能详解: - 功能表显示了输入和输出的逻辑关系。
- 施密特触发器动作确保了输入信号的稳定性。
- IOFF电路在断电模式下禁用输出,防止反向电流。
应用信息: - 该器件适用于需要低功耗和高抗噪声性的场合。
- 可以用于实现逻辑功能,如线与或线与非。
封装信息: - 提供多种封装类型,包括VSSOP8、XSON8、XQFN8等,以适应不同的应用需求和空间限制。
以上信息摘自Nexperia的产品数据表,涵盖了74AUP3G07的主要技术参数和应用信息
74AUP3G07GNX 价格&库存
很抱歉,暂时无法提供与“74AUP3G07GNX”相匹配的价格&库存,您可以联系我们找货
