74AVC16836A
20-bit registered driver with inverted register enable and
Dynamic Controlled Outputs; 3-state
Rev. 6 — 24 September 2018
Product data sheet
1. General description
The 74AVC16836A is a 20-bit universal bus driver. Data flow is controlled by output enable (OE),
latch enable (LE) and clock inputs (CP).
This product is designed to have an extremely fast propagation delay and a minimum amount of
power consumption.
To ensure the high-impedance state during power up or power down, OE should be tied to VCC
through a pullup resistor (Live Insertion).
A Dynamic Controlled Output (DCO) circuitry is implemented to support termination line drive
during transient. See Fig. 5 for typical curves.
2. Features and benefits
Wide supply voltage range from 1.2 V to 3.6 V
Complies with JEDEC standards:
• JESD8-7 (1.2 V to 1.95 V)
• JESD8-5 (1.8 V to 2.7 V)
• JESD8-1A (2.7 V to 3.6 V)
CMOS low power consumption
Input/output tolerant up to 3.6 V
Dynamic Controlled Output (DCO) circuit dynamically changes output impedance, resulting in
noise reduction without speed degradation
Low inductance multiple VCC and GND pins to minimize noise and ground bounce
Power off disables 74AVC16836A outputs, permitting Live Insertion
Integrated input diodes to minimize input overshoot and undershoot
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
74AVC16836ADGG
-40 °C to + 85 °C
Description
TSSOP56 plastic thin shrink small outline package; 56 leads;
body width 6.1 mm
Version
SOT364-1
74AVC16836A
Nexperia
20-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state
4. Functional diagram
OE
CP
LE
1
56
29
EN1
2C3
C3
G2
A1
A2
A3
A4
A5
A6
A7
A8
A9
A10
A11
OE
A12
CP
A13
LE
A15
A1
A17
A14
A16
D
LE
A18
Y1
A19
CP
A20
55
54
3D
1
3
52
5
51
6
49
8
48
9
47
10
45
12
44
13
43
14
42
15
41
16
40
17
38
19
37
21
34
23
33
24
31
26
30
27
Y1
Y2
Y3
Y4
Y5
Y6
Y7
Y8
Y9
Y10
Y11
Y12
Y13
Y14
Y15
Y16
Y17
Y18
Y19
Y20
aaa-029024
aaa-026917
Fig. 1.
2
1
Logic diagram
Fig. 2.
Logic symbol (IEEE/IEC)
VCC
A1
002aac725
Fig. 3.
Typical input (data or control)
74AVC16836A
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 14
74AVC16836A
Nexperia
5. Pinning information
5.1. Pinning
74AVC16836A
OE
1
56 CP
Y1
2
55 A1
Y2
3
54 A2
GND
4
53 GND
Y3
5
52 A3
Y4
6
51 A4
VCC
7
50 VCC
Y5
8
49 A5
Y6
9
48 A6
Y7 10
47 A7
GND 11
46 GND
Y8 12
45 A8
Y9 13
44 A9
Y10 14
43 A10
Y11 15
42 A11
Y12 16
41 A12
Y13 17
40 A13
GND 18
39 GND
Y14 19
38 A14
Y15 20
37 A15
Y16 21
36 A16
VCC 22
35 VCC
Y17 23
34 A17
Y18 24
33 A18
GND 25
32 GND
Y19 26
31 A19
Y20 27
30 A20
n.c. 28
29 LE
aaa-029062
Fig. 4.
Pin configuration TSSOP56 (SOT364-1)
74AVC16836A
Product data sheet
3 / 14
74AVC16836A
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
A1, A2, A3, A4, A5, A6, A7,
A8, A9, A10, A11, A12, A13,
A14, A15, A16, A17, A18, A19, A20
55, 54, 52, 51, 49, 48, 47,
45, 44, 43, 42, 41, 40,
38, 37, 36, 34, 33, 31, 30
data inputs
Y1, Y2, Y3, Y4, Y5, Y6, Y7,
Y8, Y9, Y10, Y11, Y12, Y13,
Y14, Y15, Y16, Y17, Y18, Y19, Y20
2, 3, 5, 6, 8, 9, 10,
12, 13, 14, 15, 16, 17,
19, 20, 21, 23, 24, 26, 27
data outputs
n.c.
28
not connected
LE
29
latch enable input (active LOW)
OE
1
output enable input (active LOW)
CP
56
clock input
(LOW-to-HIGH, edge-triggered)
GND
4, 11, 18, 25, 32, 39, 46, 53
ground (0 V)
VCC
7, 22, 35, 50
supply voltage
6. Functional description
Table 3. Function selection
H = HIGH voltage level; L = LOW voltage level; X = Don’t care; Z = high-impedance OFF-state; ↑ = LOW to HIGH level
transition.
Outputs
Inputs
OE
LE
CP
An
Yn
H
X
X
X
Z
L
L
X
L
L
L
L
X
H
H
L
H
L
L
L
H
H
H
L
H
H
X
Y0 [1]
L
H
L
X
Y0 [2]
[1]
[2]
Output level before the indicated steady-state input conditions were established, provided that CP is high before LE goes low.
Output level before the indicated steady-state input conditions were established.
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+4.6
V
-50
-0.5
+4.6
V
±50
mA
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO > VCC or VO < 0 V
VO
output voltage
output HIGH or LOW
[1]
-0.5
output 3-state
[1]
-0.5
+4.6
V
±50
mA
IO
output current
74AVC16836A
Product data sheet
VI < 0 V
[1]
VO = 0 V to VCC
mA
VCC + 0.5 V
4 / 14
74AVC16836A
Nexperia
Symbol Parameter
Conditions
Min
Max
Unit
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
600
mW
Max
Unit
[1]
[2]
Tamb = −40 °C to +85 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
Above 55 °C the value of Ptot derates linearly with 8 mW/K.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Min
Typ
for low-voltage applications
1.2
3.6
V
according to JEDEC Low Voltage
Standards
1.65
1.95
V
2.3
2.7
V
3.0
3.6
V
V
output HIGH or LOW
VCC
V
output 3-state
V
−40
+85
°C
Tamb
ambient temperature
in free air
Δt/ΔV
input transition rise and fall rate
VCC = 1.65 V to 2.3 V
ns/V
VCC = 2.3 V to 3.0 V
ns/V
VCC = 3.0 V to 3.6 V
ns/V
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; Tamb = −40 °C to +85 °C; Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
VIH
VCC = 1.2 V
VCC
V
VIL
HIGH-level input
voltage
LOW-level input
voltage
74AVC16836A
Product data sheet
VCC = 1.65 V to 1.95 V
Unit
0.65 × VCC
0.9
V
VCC = 2.3 V to 2.7 V
1.7
1.2
V
2.0
1.5
V
VCC = 1.2 V
GND
V
0.9
1.2
0.7
V
1.5
0.8
V
0.35 × VCC V
5 / 14
74AVC16836A
Nexperia
Symbol Parameter
Conditions
VOH
VI = VIH or VIL
HIGH-level output
voltage
VOL
Min
Typ[1]
Max
Unit
IO = -100 μA; VCC = 1.65 V to 3.6 V
VCC - 0.20
VCC
V
IO = -4 mA; VCC = 1.65 V
VCC - 0.45
VCC - 0.10
V
IO = -8 mA; VCC = 2.3 V
VCC - 0.55
VCC - 0.28
V
IO = -12 mA; VCC = 3.0 V
VCC - 0.70
VCC - 0.32
V
IO = 100 μA; VCC = 1.65 V to 3.6 V
GND
0.20
V
IO = 4 mA; VCC = 1.65 V
0.10
0.45
V
IO = 8 mA; VCC = 2.3 V
0.26
0.55
V
IO = 12 mA; VCC = 3.0 V
0.36
0.70
V
VI = VIH or VIL
LOW-level output
voltage
II
input leakage current
VI = VCC or GND; VCC = 3.6 V
0.1
2.5
μA
IOFF
power-off leakage
current
VI or VO = 3.6 V; VCC = 0 V
0.1
±10
μA
IOZ
OFF-state output
current
VI = VIH or VIL; VO = VCC or GND
VCC = 1.65 V to 2.7 V
0.1
5
μA
0.1
10
μA
0.1
μA
0.2
40
μA
3.8
pF
ICC
CI
[1]
VI = VCC or GND; IO = 0 A
supply current
input capacitance
All typical values are measured at Tamb = 25 °C.
9.1. Dynamic Controlled Output graphs
A Dynamic Controlled Output (DCO) circuit is designed in. During the transition, it initially lowers
the output impedance to effectively drive the load and, subsequently, raises the impedance to
reduce noise. Fig. 5 shows VOL vs. IOL and VOH vs. IOH curves to illustrate the output impedance
and drive capability of the circuit. At the beginning of the signal transition, the DCO circuit provides
a maximum dynamic drive that is equivalent to a high drive standard output device.
aaa-028429
3.5
VOL
output
3
voltage
(V)
2.5
VOH
output
3
voltage
(V)
2.5
2
2
1.5
1.5
1
VCC = 2.5 V
50
100
150
200
250
IOL output current (mA)
a. LOW-level output current.
Fig. 5.
VCC = 2.5 V
VCC = 1.8 V
0.5
VCC = 1.8 V
VCC = 3.3 V
1
VCC = 3.3 V
0.5
aaa-028430
3.5
-200
-150
-100
-50
IOH output current (mA)
b. HIGH-level output current.
Output current as a function of output voltage.
74AVC16836A
Product data sheet
6 / 14
74AVC16836A
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 12.
Symbol Parameter
Conditions
tpd
An to Yn; see Fig. 6
propagation delay
ns
5.3
ns
2.4
4.4
ns
0.8
1.7
3.2
ns
0.7
1.5
2.7
ns
[2]
5.0
ns
VCC = 1.4 V to 1.6 V
2.0
5.6
ns
1.5
2.7
5.0
ns
1.0
2.1
3.5
ns
0.7
1.7
3.4
ns
5.7
ns
2.0
4.7
ns
1.2
2.3
4.1
ns
0.8
1.7
3.2
ns
0.7
1.6
3.0
ns
6.0
ns
2.5
6.8
ns
1.5
3.0
5.4
ns
1.0
2.4
4.0
ns
1.0
1.9
3.6
ns
6.6
ns
2.5
7.6
ns
1.5
3.7
7.5
ns
1.0
2.1
4.7
ns
1.0
2.5
4.8
ns
2.0
ns
1.2
ns
1.0
ns
2.0
ns
1.2
ns
1.0
ns
[2]
OE to Yn; see Fig. 11
[2]
VCC = 1.2 V
VCC = 1.2 V
pulse width
4.7
1.0
VCC = 1.2 V
tW
2.0
CP to Yn; see Fig. 9
disable time
Unit
VCC = 1.2 V
tdis
Max
LE to Yn; see Fig. 7
enable time
Typ [1]
[2]
VCC = 1.2 V
ten
Min
[2]
CP HIGH or LOW; see Fig. 9.
LE HIGH; see Fig. 7.
74AVC16836A
Product data sheet
7 / 14
74AVC16836A
Nexperia
Symbol Parameter
Conditions
tsu
An to CP; see Fig. 10
set-up time
VCC = 1.2 V
Min
Typ [1]
Max
Unit
0.0
ns
0.3
ns
0.2
0.0
ns
0.3
0.0
ns
0.2
0.0
ns
An to LE; see Fig. 8
VCC = 1.2 V
th
hold time
1.2
ns
1.3
ns
0.9
0.4
ns
0.6
0.2
ns
0.3
0.0
ns
0.1
ns
0.6
ns
0.6
0.2
ns
0.6
0.2
ns
1.2
0.5
ns
-0.7
ns
0.2
ns
0.4
0.0
ns
0.5
0.1
ns
1.0
0.5
ns
250
MHz
400
MHz
500
MHz
outputs enabled
25
pF
outputs disabled
6
pF
VCC = 1.2 V
VCC = 1.2 V
fmax
maximum frequency
CP; see Fig. 9
power dissipation capacitance per buffer; VI = GND to VCC
CPD
[1]
[2]
[3]
[3]
Typical values are measured at Tamb = 25 °C and VCC = 1.5 V, 1.8 V, 2.5 V and 3.3 V respectively.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
2
Σ(CL x VCC x fo) = sum of the outputs.
74AVC16836A
Product data sheet
8 / 14
74AVC16836A
Nexperia
10.1. Waveforms and test circuit
An input
LE input
VI
VM
tPHL
VM
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that
occur with the output load.
Input (An) to output (Yn) propagation delay
An
input
VM
th
LE
input
VOL
002aac727
Fig. 7.
tsu
VM
CP input
GND
th
VM
tw
VI
VM
LE input pulse width, LE input to Yn output
propagation delays
1 / fmax
VI
VM
tsu
VOH
VM
VOL
002aac726
Fig. 6.
GND
tPLH
tPHL
Yn output
VOH
VI
VM
tw
GND
tPLH
Yn output
VM
Yn output
GND
VI
VM
VOH
VM
VOL
002aac729
002aac728
The shaded areas indicate when the input
is permitted to change for predictable output
performance.
Fig. 8.
Data set-up and hold times, An input to LE input
CP
input
GND
tPLH
tPHL
Fig. 9.
CP to Yn propagation delays, clock pulse width,
and maximum clock frequency
VI
VM
tsu
th
tsu
th
GND
OE input
VI
An
input
GND
VOH
Yn
output
VOL
002aac730
performance.
output
LOW-to-OFF
OFF-to-LOW
VI
VM
tPLZ
GND
tPZL
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VCC
VM
VX
VOL
tPZH
VY
outputs
enabled
VM
outputs
disabled
Fig. 11. 3-state enable and disable times
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VI
VM
VM
VX
VY
≤ 2.3 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
2.3 V to 2.7 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
3.0 V to 3.6 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.3 V
VOH - 0.3 V
Product data sheet
GND
outputs
enabled
002aac731
Fig. 10. Data set-up and hold times, An input to CP
input
74AVC16836A
VOH
9 / 14
74AVC16836A
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 12. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
≤ 2.3 V
VCC
≤ 2.0 ns
30 pF
1000 Ω
open
2 x VCC
GND
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 x VCC
GND
3.0 V to 3.6 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 x VCC
GND
74AVC16836A
Product data sheet
Load
VEXT
10 / 14
74AVC16836A
Nexperia
11. Package outline
TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm
SOT364-1
E
D
A
X
c
HE
y
v M A
Z
56
29
Q
A2
(A 3 )
A1
pin 1 index
A
θ
Lp
L
1
28
w M
bp
e
detail X
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
14.1
13.9
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.5
0.1
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT364-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 13. Package outline SOT364-1 (TSSOP56)
74AVC16836A
Product data sheet
11 / 14
74AVC16836A
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DCO
DUT
Device Under Test
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AVC16836A v.6
20180924
Product data sheet
74AVC16836A v.5
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74AVC16836ADGV (SOT481-2) removed.
74AVC16836A v.5
20020802
Product data sheet
74AVC16836A v.4
74AVC16836A v.4
20000803
Product specification
74AVC16836A v.3
74AVC16836A v.3
20000502
Preliminary specification
74AVC16836 v.2
74AVC16836 v.2
19990723
74AVC_AVCH16836 v.1
74AVC_AVCH16836 v.1
19981207
Objective specification
74AVC16836A
Product data sheet
12 / 14
74AVC16836A
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AVC16836A
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
13 / 14
74AVC16836A
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 4
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................5
9. Static characteristics....................................................5
9.1. Dynamic Controlled Output graphs..............................6
10. Dynamic characteristics..............................................7
10.1. Waveforms and test circuit........................................ 9
11. Package outline........................................................ 11
12. Abbreviations............................................................ 12
13. Revision history........................................................12
14. Legal information......................................................13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 24 September 2018
74AVC16836A
Product data sheet
14 / 14
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AVC16836ADGG,112 74AVC16836ADGG,118
