74AVCH16244DGG,118
74AVCH16244DGG,118
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    IC BUF NON-INVERT 3.6V 48TSSOP
74AVCH16244DGG,118 数据手册
74AVCH16244 16-bit buffer/line driver; 3.6 V tolerant; 3-state Rev. 2 — 20 February 2018 1 Product data sheet General description The 74AVCH16244 is a 16-bit non-inverting buffer/line driver with 3-state outputs. The device can be used as four 4-bit buffers, two 8-bit buffers or one 16-bit buffer. The 3‑state outputs are controlled by the output enable inputs nOE. A HIGH on nOE causes the outputs to assume a high impedance OFF-state. The 74AVCH16244 is designed to have an extremely fast propagation delay and a minimum amount of power consumption. To ensure the high-impedance output state during power-up or power-down, nOE should be tied to VCC through a pull-up resistor (Live Insertion). A dynamic controlled output (DCO) circuitry is implemented to support termination line drive during transient (see Figure 4). The 74AVCH16244 has active bus-hold circuitry to hold unused or floating data inputs at a valid logic level. This feature eliminates the need for external pull-up or pull-down resistors. 2 Features and benefits • • • • • Wide supply voltage range from 1.2 V to 3.6 V CMOS low power consumption Low inductance multiple VCC and GND pins for minimum noise and ground bounce Input/output tolerant up to 3.6 V Dynamic controlled output (DCO) circuit dynamically changes the output impedance, resulting in noise reduction without speed degradation • Bus hold on all data inputs • Supports Live Insertion • Complies with JEDEC standards: – JESD8-7 (1.2 V to 1.95 V) – JESD8-5 (1.8 V to 2.7 V) – JESD8-1A (2.7 V to 3.6 V) 3 Ordering information Table 1. Ordering information Type number 74AVCH16244DGG Package Temperature range Name Description Version −40 °C to +85 °C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state 4 Functional diagram 1A0 1A1 1A2 1A3 47 2 46 3 44 5 43 6 1Y0 3A0 1Y1 3A1 1Y2 3A2 1Y3 3A3 1 1OE 3OE 36 13 35 14 33 16 32 17 3Y0 3Y1 1 1OE 48 2OE 25 3OE 24 4OE 3Y2 3Y3 1A0 1A1 25 1A2 1A3 2A0 2A1 41 40 8 9 2Y0 2Y1 4A0 4A1 30 29 19 20 2A0 2A1 4Y0 2A2 2A3 3A0 4Y1 3A1 2A2 2A3 2OE 38 37 11 12 2Y2 2Y3 48 4A2 4A3 4OE 27 26 22 23 3A2 4Y2 3A3 4A0 4A1 4Y3 4A2 24 4A3 EN1 EN2 EN3 EN4 47 46 74AVCH16244 Product data sheet 1 2 3 44 5 43 6 41 40 1 2 8 9 38 11 37 12 36 35 1 3 13 14 33 16 32 17 30 29 1 4 19 20 27 22 26 23 1Y0 1Y1 1Y2 1Y3 2Y0 2Y1 2Y2 2Y3 3Y0 3Y1 3Y2 3Y3 4Y0 4Y1 4Y2 4Y3 001aae231 mna996 Figure 1. Logic symbol 1 Figure 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state 5 Pinning information 5.1 Pinning 74AVCH16244 1OE 1 48 2OE 1Y0 2 47 1A0 1Y1 3 46 1A1 GND 4 45 GND 1Y2 5 44 1A2 1Y3 6 43 1A3 VCC 7 2Y0 8 42 VCC 41 2A0 2Y1 9 40 2A1 GND 10 39 GND 2Y2 11 38 2A2 2Y3 12 37 2A3 3Y0 13 36 3A0 3Y1 14 35 3A1 GND 15 34 GND 3Y2 16 33 3A2 3Y3 17 32 3A3 VCC 18 4Y0 19 31 VCC 30 4A0 4Y1 20 29 4A1 GND 21 28 GND 4Y2 22 27 4A2 4Y3 23 26 4A3 4OE 24 25 3OE aaa-028181 Figure 3. Pin configuration SOT362-1 (TSSOP48) 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE, 3OE, 4OE 1, 48, 25, 24 output enable inputs (active LOW) 1A0, 1A1, 1A2, 1A3 2A0, 2A1, 2A2, 2A3 3A0, 3A1, 3A2, 3A3 4A0, 4A1, 4A2, 4A3 47, 46, 44, 43 41, 40, 38, 37 36, 35, 33, 32 30, 29, 27, 26 data inputs 1Y0, 1Y1, 1Y2, 1Y3 2Y0, 2Y1, 2Y2, 2Y3 3Y0, 3Y1, 3Y2, 3Y3 4Y0, 4Y1, 4Y2, 4Y3 2, 3, 5, 6 8, 9, 11, 12 13, 14, 16, 17 19, 20, 22, 23 data outputs GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 74AVCH16244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state 6 Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Input Output nOE nAn nYn L L L L H H H X Z 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO Conditions VI < 0 V [1] VO < 0 V output voltage Min Max Unit −0.5 +4.6 V - −50 mA −0.5 +4.6 V - −50 mA output HIGH or LOW [1] −0.5 output 3-state [1] −0.5 +4.6 V - +50 mA IO output current ICC supply current - +100 mA IGND ground current −100 - mA Tstg storage temperature −65 +150 °C - 500 mW Ptot VO = 0 V to VCC VCC + 0.5 V total power dissipation Tamb = −40 °C to +85 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 60 °C the value of Ptot derates linearly with 5.5 mW/K. 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC for low-voltage applications 1.2 - 3.6 V according to JEDEC Low Voltage Standards 1.4 - 1.6 V 1.65 - 1.95 V 2.3 - 2.7 V 3.0 - 3.6 V 0 - 3.6 V output HIGH or LOW 0 - VCC V output 3-state 0 - 3.6 V supply voltage VI input voltage VO output voltage 74AVCH16244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state Symbol Parameter Conditions Min Typ Max Unit Tamb ambient temperature in free air −40 - +85 °C Δt/ΔV input transition rise and fall rate VCC = 1.4 V to 1.6 V 0 - 40 ns/V VCC = 1.65 V to 2.3 V 0 - 30 ns/V VCC = 2.3 V to 3.0 V 0 - 20 ns/V VCC = 3.0 V to 3.6 V 0 - 10 ns/V 9 Static characteristics Table 6. Static characteristics At recommended operating conditions. Tamb = −40 °C to +85 °C; Voltages are referenced to GND (ground = 0 V). [1] Symbol Parameter Conditions Min Typ VIH VCC = 1.2 V VCC - - V VCC = 1.4 V to 1.6 V 0.65 × VCC 0.9 - V VCC = 1.65 V to 1.95 V 0.65 × VCC 0.9 - V VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 3.0 V to 3.6 V 2.0 1.5 - V VCC = 1.2 V - - GND V VCC = 1.4 V to 1.6 V - 0.9 0.35 × VCC V VCC = 1.65 V to 1.95 V - 0.9 0.35 × VCC V VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 3.0 V to 3.6 V - 1.5 0.8 V IO = -100 μA; VCC = 1.65 V to 3.6 V VCC - 0.20 VCC - V IO = -3 mA; VCC = 1.4 V VCC - 0.35 VCC - 0.21 - V IO = -4 mA; VCC = 1.65 V VCC - 0.45 VCC - 0.25 - V IO = -8 mA; VCC = 2.3 V VCC - 0.55 VCC - 0.37 - V IO = -12 mA; VCC = 3.0 V VCC - 0.70 VCC - 0.47 - V IO = 100 μA; VCC = 1.65 V to 3.6 V - GND 0.20 V IO = 3 mA; VCC = 1.4 V - 0.22 0.35 V IO = 4 mA; VCC = 1.65 V - 0.24 0.45 V IO = 8 mA; VCC = 2.3 V - 0.38 0.55 V IO = 12 mA; VCC = 3.0 V - 0.53 0.70 V VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage Max Unit VI = VIH or VIL; see Figure 4 VI = VIH or VIL; see Figure 4 II input leakage current per input pin; VI = VCC or GND; VCC = 1.4 V to 3.6 V - 0.1 2.5 μA IOFF power-off leakage current VI or VO = 3.6 V; VCC = 0 V - 0.1 ±10 μA IBHL bus hold LOW current VCC = 1.65 V; VI = 0.35 × VCC 25 - - μA VCC = 2.3 V; VI = 0.7 V 45 - - μA VCC = 3.0 V; VI = 0.8 V 75 - - μA 74AVCH16244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state Symbol Parameter IBHH Conditions Typ −25 - - μA VCC = 2.3 V; VI = 0.65 × VCC −45 - - μA VCC = 3.0 V; VI = 0.65 × VCC −75 - - μA VCC = 1.95 V 200 - - μA VCC = 2.7 V 300 - - μA VCC = 3.6 V 450 - - μA VCC = 1.95 V -200 - - μA VCC = 2.7 V -300 - - μA VCC = 3.6 V -450 - - μA VCC = 1.4 V to 2.7 V - 0.1 5 μA VCC = 3.0 V to 3.6 V - 0.1 10 μA VCC = 1.4 V to 2.7 V - 0.1 20 μA VCC = 3.0 V to 3.6 V - 0.2 40 μA - 5.0 - pF bus hold HIGH current VCC = 1.65 V; VI = 0.65 × VCC IBHLO bus hold LOW overdrive current IBHHO bus hold HIGH overdrive current IOZ OFF-state output current ICC Max Unit VI = VIH or VIL; VO = VCC or GND supply current CI [1] Min VI = VCC or GND; IO = 0 A input capacitance [1] All typical values are measured at Tamb = 25 °C. 9.1 Dynamic controlled output graphs aaa-003759 0 IOH (mA) aaa-003760 300 3.3 V IOL (mA) 1.8 V -100 200 2.5 V 2.5 V -200 100 1.8 V 3.3 V -300 0 1 2 3 VOH (V) 4 a. HIGH-level output current. 0 0 1 2 3 VOL (V) 4 b. LOW-level output current. Figure 4. Output current as a function of output voltage. 74AVCH16244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 7. Symbol Parameter Conditions −40 °C to +85 °C Min tpd propagation delay nAn to nYn; see Figure 5 enable time disable time - 5.2 - ns VCC = 1.4 V to 1.6 V - 2.9 - ns VCC = 1.65 V to 1.95 V 0.8 2.1 3.4 ns VCC = 2.3 V to 2.7 V 0.7 1.5 2.2 ns 0.6 1.3 2.0 ns VCC = 1.2 V - 5.7 - ns VCC = 1.4 V to 1.6 V - 4.0 - ns VCC = 1.65 V to 1.95 V 1.3 3.3 6.8 ns VCC = 2.3 V to 2.7 V 0.9 2.2 4.0 ns 0.7 1.9 3.5 ns VCC = 1.2 V - 5.9 - ns VCC = 1.4 V to 1.6 V - 4.2 - ns VCC = 1.65 V to 1.95 V 1.6 3.7 6.2 ns VCC = 2.3 V to 2.7 V 1.0 1.9 4.3 ns 1.1 2.2 3.5 ns outputs enabled - 34 - pF outputs disabled - 1 - pF nOE to nYn; see Figure 6 [2] nOE to nYn; see Figure 6 [2] VCC = 3.0 V to 3.6 V CPD Max VCC = 1.2 V VCC = 3.0 V to 3.6 V tdis Unit [2] VCC = 3.0 V to 3.6 V ten Typ [1] power dissipation capacitance per buffer; VI = GND to VCC [3] [1] Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V respectively. [2] tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [3] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL x VCC x fo) = sum of the outputs. 74AVCH16244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state 10.1 Waveforms and test circuit VI nAn input VM VM GND tPLH tPHL VOH VM nYn output VM VOL mna171 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 5. Inputs nAn to output nYn propagation delays VI nOE input VM GND t PLZ nYn output LOW-to-OFF OFF-to-LOW t PZL VCC VM VX VOL t PZH t PHZ nYn output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled 001aae014 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. 3-state enable and disable times Table 8. Measurement points Supply voltage Input VCC VI VM VM VX VY ≤ 2.3 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.3 V VOH - 0.3 V 74AVCH16244 Product data sheet Output All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 7. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC ≤ 2.0 ns 15 pF 2000 Ω open 2 × VCC GND 1.4 V to 1.6 V VCC ≤ 2.0 ns 15 pF 2000 Ω open 2 × VCC GND 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1000 Ω open 2 × VCC GND 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 × VCC GND 74AVCH16244 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state 11 Package outline TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit max nom min mm A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Figure 8. Package outline SOT362-1 (TSSOP48) 74AVCH16244 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DCO Dynamic Controlled Output DUT Device Under Test 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AVCH16244 v.2 20180220 Product data sheet - 74AVCH16244 v.1 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74AVCH16244 v.1 20000307 74AVCH16244 Product data sheet Product specification - All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 - © Nexperia B.V. 2018. All rights reserved. 11 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74AVCH16244 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74AVCH16244 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 14 74AVCH16244 Nexperia 16-bit buffer/line driver; 3.6 V tolerant; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 9.1 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic controlled output graphs ..................... 6 Dynamic characteristics .....................................7 Waveforms and test circuit ................................ 8 Package outline .................................................10 Abbreviations .................................................... 11 Revision history ................................................ 11 Legal information .............................................. 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 February 2018 Document identifier: 74AVCH16244 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AVCH16244DGG,112 74AVCH16244DGG,118
74AVCH16244DGG,118
物料型号:74AVCH16244
器件简介: - 74AVCH16244是一款16位非反相缓冲/线驱动器,具有3态输出。 - 该器件可以用作四个4位缓冲器、两个8位缓冲器或一个16位缓冲器。 - 3态输出由输出使能输入nOE控制,nOE为高电平时,输出呈现高阻态关闭状态。
引脚分配: - 引脚包括输出使能输入(2OE, 1OE)、数据输入(1A0, 1A1, 1A2, 1A3等)、数据输出(1Y0, 1Y1, 1Y2, 1Y3等)、地(GND)和电源(VCC)。
参数特性: - 工作电压范围宽,从1.2V至3.6V。 - CMOS低功耗设计。 - 输入/输出耐压高达3.6V。 - 动态控制输出(DCO)电路,动态改变输出阻抗,降低噪声而不降低速度。 - 所有数据输入都有总线保持功能。
功能详解: - 该器件设计用于具有极快的传播延迟和最小的功耗。 - 为了确保上电或掉电时输出状态为高阻态,nOE应通过上拉电阻连接到VCC(实时插入)。 - 支持实时插入。
应用信息: - 符合JEDEC标准,适用于多种电压范围。
封装信息: - 74AVCH16244DGG封装为TSSOP48,是一种塑料薄缩型小外形封装,共有48个引脚,体宽6.1毫米。
74AVCH16244DGG,118 价格&库存
很抱歉,暂时无法提供与“74AVCH16244DGG,118”相匹配的价格&库存,您可以联系我们找货
