74AVCH16245
16-bit transceiver with direction pin; 3.6 V tolerant; 3-state
Rev. 3 — 8 January 2013
Product data sheet
1. General description
The 74AVCH16245 is a 16-bit transceiver featuring non-inverting 3-state bus compatible
outputs in both send and receive directions. The device features two output enable inputs
(nOE) for easy cascading and two send/receive inputs (nDIR) for direction control.
Inputs nOE control the outputs so that the buses are effectively isolated. This device can
be used as two 8-bit transceivers or one 16-bit transceiver.
The 74AVCH16245 is designed to have an extremely fast propagation delay and a
minimum amount of power consumption.
To ensure the high-impedance output state during power-up or power-down, tie pins nOE
to VCC through a pull-up resistor (Live Insertion).
A Dynamic Controlled Output (DCO) circuitry is implemented to support termination line
drive during transient (see Figure 4 and Figure 5)
The 74AVCH16245 has active bus-hold circuitry to hold unused or floating data inputs at a
valid logic level. This feature eliminates the need for external pull-up or pull-down
resistors.
2. Features and benefits
Wide supply voltage range from 1.2 V to 3.6 V
Complies with JEDEC standards:
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-1A (2.7 V to 3.6 V)
CMOS low power consumption
Input/output tolerant up to 3.6 V
Dynamic Controlled Output (DCO) circuit dynamically changes output impedance,
resulting in noise reduction without speed degradation
Low inductance multiple VCC and GND pins to minimize noise and ground bounce
Supports Live Insertion
All inputs have bus-hold
74AVCH16245
Nexperia
3. Ordering information
Table 1.
Type number
74AVCH16245DGG
Package
Temperature range
Name
Description
Version
40 C to +85 C
TSSOP48
plastic thin shrink small outline package;
48 leads; body width 6.1 mm
SOT362-1
4. Functional diagram
2DIR
1DIR
2OE
1OE
2A0
1A0
1B0
1A1
2B0
2A1
2B1
1B1
1A2
2A2
1B2
1A3
2B2
2A3
1B3
1A4
2B3
2A4
2B4
1B4
1A5
2A5
1B5
1A6
2B5
2A6
1B6
2B6
2A7
1A7
1B7
2B7
001aaa789
Fig 1.
Logic symbol
74AVCH16245
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 16
74AVCH16245
Nexperia
1OE
1DIR
2OE
2DIR
1A0
G3
3EN1[BA]
3EN2[AB]
G6
6EN1[BA]
6EN2[AB]
1B0
1
2
1A1
1B1
1A2
1B2
1A3
1B3
1A4
1B4
1A5
1B5
1A6
1B6
1A7
1B7
2A0
2B0
4
5
2A1
2B1
2A2
2B2
2A3
2B3
2A4
2B4
2A5
2B5
2A6
2B6
2B7
2A7
001aaa790
Fig 2.
IEC logic symbol
74AVCH16245
Product data sheet
3 of 16
74AVCH16245
Nexperia
5. Pinning information
5.1 Pinning
$9&+
',5
2(
*1'
*1'
9&&
9&&
*1'
*1'
*1'
*1'
9&&
9&&
*1'
*1'
',5
2(
DDD
Fig 3.
Pin configuration
74AVCH16245
Product data sheet
4 of 16
74AVCH16245
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1DIR, 2DIR
1, 24
direction control input
1B0 to 1B7
2, 3, 5, 6, 8, 9, 11, 12
data input/output
2B0 to 2B7
13, 14, 16, 17, 19, 20, 22, 23
data input/output
GND
4, 10, 15, 21, 28, 34, 39, 45
ground (0 V)
VCC
7, 18, 31, 42
supply voltage
1OE, 2OE
48, 25
output enable input (active LOW)
1A0 to 1A7
47, 46, 44, 43, 41, 40, 38, 37
data input/output
2A0 to 2A7
36, 35, 33, 32, 30, 29, 27, 26
data input/output
6. Functional description
Table 3.
Function table[1]
Inputs
Outputs
nOE
nDIR
nAn
nBn
L
L
A=B
inputs
L
H
inputs
B=A
H
X
Z
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+4.6
V
50
mA
0.5
+4.6
V
50
mA
output HIGH or LOW
[1]
0.5
VCC + 0.5
V
output 3-state
[1]
0.5
+4.6
V
50
mA
VO < 0 V
IO
output current
VO = 0 V to VCC
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Above 60 C the value of Ptot derates linearly with 5.5 mW/K.
74AVCH16245
Product data sheet
5 of 16
74AVCH16245
Nexperia
8. Recommended operating conditions
Table 5.
Symbol Parameter
VCC
supply voltage
Conditions
Min
Typ
Max
Unit
according to JEDEC Low Voltage Standards
1.4
1.6
V
1.65
1.95
V
2.3
2.7
V
3.0
3.6
V
1.2
3.6
V
V
for low-voltage applications
VI
input voltage
VO
output voltage
output HIGH or LOW
VCC
V
output 3-state
V
Tamb
ambient temperature
in free air
40
+85
C
t/V
input transition rise and fall
rate
VCC = 1.4 V to 1.6 V
ns/V
VCC = 1.65 V to 1.95 V
ns/V
VCC = 2.3 V to 3.0 V
ns/V
VCC = 3.0 V to 3.6 V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
VCC = 1.2 V
VCC
V
0.65 VCC
0.9
V
0.65 VCC
0.9
V
VCC = 2.3 V to 2.7 V
1.7
1.2
V
2.0
1.5
V
VCC = 1.2 V
GND
V
0.9
0.35 VCC V
0.9
0.35 VCC V
1.2
0.7
V
1.5
0.8
V
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
74AVCH16245
Product data sheet
VI = VIH or VIL
IO = 100 A; VCC = 1.65 V to 3.6 V
VCC 0.20
VCC
V
IO = 3 mA; VCC = 1.4 V
VCC 0.35
VCC 0.21
V
IO = 4 mA; VCC = 1.65 V
VCC 0.45
VCC 0.25
V
IO = 8 mA; VCC = 2.3 V
VCC 0.55
VCC 0.37
V
IO = 12 mA; VCC = 3.0 V
VCC 0.70
VCC 0.47
V
6 of 16
74AVCH16245
Nexperia
Table 6.
Static characteristics …continued
Min
Typ[1]
Max
Unit
GND
0.20
V
0.22
0.35
V
0.24
0.45
V
0.38
0.55
V
0.53
0.70
V
Symbol Parameter
Conditions
VOL
VI = VIH or VIL
LOW-level output voltage
II
input leakage current
VI = VCC or GND; VCC = 1.4 V to 3.6 V
0.1
2.5
A
IOFF
power-off leakage current
VI or VO = 3.6 V; VCC = 0.0 V
0.1
10
A
IOZ
OFF-state output current
VI = VIH or VIL; VO = VCC or GND
VCC = 1.4 V to 2.7 V
0.1
5
A
0.1
10
A
0.1
A
0.2
40
A
supply current
ICC
bus hold LOW current
IBHL
IBHH
IBHLO
IBHHO
bus hold LOW overdrive
current
bus hold HIGH overdrive
current
VCC = 1.65 V; VI = 0.35 VCC
25
A
VCC = 2.3 V; VI = 0.7 V
45
A
VCC = 3.0 V; VI = 0.8 V
75
A
25
A
VCC = 2.3 V; VI = 0.35 VCC
45
A
VCC = 3.0 V; VI = 0.35 VCC
75
A
VCC = 1.95 V
200
A
VCC = 2.7 V
300
A
VCC = 3.6 V
450
A
VCC = 1.95 V
200
A
VCC = 2.7 V
300
A
VCC = 3.6 V
450
A
5.0
pF
input capacitance
CI
[1]
bus hold HIGH current
VI = VCC or GND; IO = 0 A
All typical values are measured at Tamb = 25 C.
74AVCH16245
Product data sheet
7 of 16
74AVCH16245
Nexperia
9.1 Graphs
DDD
,2+
P$
DDD
9
,2/
P$
9
9
9
9
9
Fig 4.
92+9
Output voltage as a function of the HIGH-level
output current.
Fig 5.
92/9
Output voltage as a function of the LOW-level
output current.
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 8.
Symbol
tpd
Parameter
propagation delay
40 C to +85 C
Conditions
nAn to nBn; nBn to nAn; see Figure 6
tdis
disable time
5.4
ns
3.1
ns
2.3
3.3
ns
0.5
1.6
2.2
ns
0.7
1.4
2.0
ns
VCC = 1.2 V
7.4
ns
6.4
ns
1.4
4.4
7.0
ns
1.0
2.8
4.3
ns
0.7
2.3
3.7
ns
7.3
ns
nOE to nAn, nBn; see Figure 7
Product data sheet
1.4
VCC = 1.2 V
74AVCH16245
Max
enable time
Typ[2]
[1]
VCC = 1.2 V
ten
Unit
Min
[1]
[1]
5.7
ns
2.2
4.2
7.0
ns
1.1
2.3
5.4
ns
1.2
2.5
3.9
ns
8 of 16
74AVCH16245
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol
CPD
[1]
Parameter
power dissipation
capacitance
40 C to +85 C
Conditions
Unit
Min
Typ[2]
outputs enabled
42
pF
outputs disabled
2
pF
Max
[3]
per input; VI = GND to VCC
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
[2]
Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V respectively.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs.
11. Waveforms
VI
nAn, nBn
input
VM
GND
t PHL
t PLH
VOH
nBn, nAn
output
VM
VOL
mna477
Measurement points are given in Table 8.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig 6.
The input (nAn, nBn) to output (nBn, nAn) propagation delays
74AVCH16245
Product data sheet
9 of 16
74AVCH16245
Nexperia
VI
nOE input
VM
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
VOH
tPZH
VY
output
HIGH-to-OFF
OFF-to-HIGH
GND
VM
outputs
enabled
outputs
enabled
outputs
disabled
mna362
Fig 7.
Table 8.
3-state enable and disable times
Measurement points
Supply voltage
VM
VCC
Input
VI
tr = tf
VX
VY
1.2 V
0.5 VCC
VCC
2 ns
VOL + 0.15 V
VOH 0.15 V
1.4 V to 1.6 V
0.5 VCC
VCC
2 ns
VOL + 0.15 V
VOH 0.15 V
1.65 V to 1.95 V
0.5 VCC
VCC
2 ns
VOL + 0.15 V
VOH 0.15 V
2.3 V to 2.7 V
0.5 VCC
VCC
2 ns
VOL + 0.15 V
VOH 0.15 V
3.0 V to 3.6 V
0.5 VCC
VCC
2 ns
VOL + 0.3 V
VOH 0.3 V
74AVCH16245
Product data sheet
10 of 16
74AVCH16245
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
VI
RL
VO
G
DUT
RT
RL
CL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 8.
Table 9.
Test circuit for measuring switching times
Test data
Supply voltage
Input
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.2 V
VCC
2 ns
15 pF
2 k
open
2 VCC
GND
1.4 V to 1.6 V
VCC
2 ns
15 pF
2 k
open
2 VCC
GND
1.65 V to 1.95 V
VCC
2 ns
30 pF
1 k
open
2 VCC
GND
2.3 V to 2.7 V
VCC
2 ns
30 pF
500
open
2 VCC
GND
3.0 V to 3.6 V
VCC
2 ns
30 pF
500
open
2 VCC
GND
74AVCH16245
Product data sheet
Load
VEXT
11 of 16
74AVCH16245
Nexperia
12. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
E
D
A
X
c
HE
y
v M A
Z
48
25
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
detail X
24
w M
bp
e
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
12.6
12.4
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.8
0.4
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT362-1
Fig 9.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Package outline SOT362-1 (TSSOP48)
74AVCH16245
Product data sheet
12 of 16
74AVCH16245
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date Data sheet status
Change notice Order number Supersedes
74AVCH16245 v.3
20130108
74AVCH16245 v.2
74AVCH16245 v.1
Modifications:
74AVCH16245 v.2
Modifications:
74AVCH16245 v.1
74AVCH16245
Product data sheet
Product data sheet
ICC removed (errata).
20120828
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Ordering information table corrected (errata).ICC
20000307
Product specification
13 of 16
74AVCH16245
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AVCH16245
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
14 of 16
74AVCH16245
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AVCH16245
Product data sheet
15 of 16
74AVCH16245
Nexperia
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
9.1
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 08 January 2013
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AVCH16245DGG,112 74AVCH16245DGG,118
