74AXP1G125GSH
74AXP1G125GSH
    NEXPERIA(安世)
    XSON6
    缓冲器,非反向 1 元件 1 位每元件 三态 Output 6-XSON,SOT1202(1x1)
74AXP1G125GSH 数据手册
74AXP1G125 Low-power buffer/line driver; 3-state Rev. 2 — 18 April 2018 1 Product data sheet General description The 74AXP1G125 is a single buffer/line driver with 3-state output. Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times. This device ensures very low static and dynamic power consumption across the entire VCC range from 0.7 V to 2.75 V. It is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2 Features and benefits • • • • • • • • • • • • • • Wide supply voltage range from 0.7 V to 2.75 V Low input capacitance; CI = 0.5 pF (typical) Low output capacitance; CO = 1.0 pF (typical) Low dynamic power consumption; CPD = 2.5 pF at VCC = 1.2 V (typical) Low static power consumption; ICC = 0.6 μA (85 °C maximum) High noise immunity Complies with JEDEC standard: – JESD8-12A.01 (1.1 V to 1.3 V) – JESD8-11A.01 (1.4 V to 1.6 V) – JESD8-7A (1.65 V to 1.95 V) – JESD8-5A.01 (2.3 V to 2.7 V) ESD protection: – HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV – CDM JESD22-C101E exceeds 1000 V Latch-up performance exceeds 100 mA per JESD 78 Class II Inputs accept voltages up to 2.75 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from -40 °C to +85 °C 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description 74AXP1G125GM -40 °C to +85 °C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1 x 1.45 x 0.5 mm 74AXP1G125GN -40 °C to +85 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm SOT1115 74AXP1G125GS -40 °C to +85 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm SOT1202 74AXP1G125GX -40 °C to +85 °C X2SON5 plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm SOT1226 4 Version Marking Table 2. Marking [1] Type number Marking code 74AXP1G125GM rM 74AXP1G125GN rM 74AXP1G125GS rM 74AXP1G125GX rM [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5 Functional diagram 2 A 1 OE Y Figure 1.  Logic symbol Product data sheet A 2 1 mna118 74AXP1G125 4 Y 4 EN OE mna119 Figure 2.  IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 001aad068 Figure 3.  Logic diagram © Nexperia B.V. 2018. All rights reserved. 2 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state 6 Pinning information 6.1 Pinning 74AXP1G125 OE 1 6 VCC A 2 5 n.c. GND 3 4 74AXP1G125 OE 1 5 VCC 4 Y 3 GND Y 2 A aaa-010416 Transparent top view aaa-010417 Figure 4.  Pin configuration SOT886, SOT1115 and SOT1202 (XSON6) Transparent top view Figure 5.  Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description X2SON5 XSON6 OE 1 1 output enable input A 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 7 Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = Don’t care; Z = high-impedance OFF-state. Output Input OE A Y L L L L H H H X Z 74AXP1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit -0.5 +3.3 V -50 - -0.5 +3.3 -50 - -0.5 +3.3 V - ±20 mA mA V mA VO output voltage IO output current ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW VO = 0 V to VCC Tamb = -40 °C to +85 °C [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. 9 Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74AXP1G125 Product data sheet Min Max Unit 0.7 2.75 V 0 2.75 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 2.75 V -40 +85 °C 0 200 ns/V VCC = 0.7 V to 2.75 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state 10 Static characteristics Table 7. Static characteristics At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = -40 °C to +85 °C Min VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage Unit Typ 25 °C Max 25 °C Max 85 °C VCC = 0.75 V to 0.85 V 0.75VCC - - - V VCC = 1.1 V to 1.95 V 0.65VCC - - - V VCC = 2.3 V to 2.7 V 1.6 - - - V VCC = 0.75 V to 0.85 V - - 0.25VCC 0.25VCC V VCC = 1.1 V to 1.95 V - - 0.35VCC 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 0.7 V IO = -20 μA; VCC = 0.7 V - 0.69 - - V IO = -100 μA; VCC = 0.75 V 0.65 - - - V IO = -2 mA; VCC = 1.1 V 0.825 - - - V IO = -3 mA; VCC = 1.4 V 1.05 - - - V IO = -4.5 mA; VCC = 1.65 V 1.2 - - - V IO = -8 mA; VCC = 2.3 V 1.7 - - - V IO = 20 μA; VCC = 0.7 V - 0.01 - - V IO = 100 μA; VCC = 0.75 V - - 0.1 0.1 V IO = 2 mA; VCC = 1.1 V - - 0.275 0.275 V IO = 3 mA; VCC = 1.4 V - - 0.35 0.35 V IO = 4.5 mA; VCC = 1.65 V - - 0.45 0.45 V IO = 8 mA; VCC = 2.3 V VI = 0 V to 2.75 V; VCC = 0 V to 2.75 V - - 0.7 0.7 V [1] - 0.001 ±0.1 ±0.5 μA II input leakage current IOZ OFF-state output VI = VIH or VIL; VO = 0 V to 2.75 V current [1] - 0.02 ±0.1 ±0.5 μA IOFF power-off leakage current VI or VO = 0 V to 2.75 V; VCC = 0 V [1] - 0.01 ±0.1 ±0.5 μA ΔIOFF additional power-off leakage current VI or VO = 0 V or 2.75 V; VCC = 0 V to 0.1 V [1] - 0.02 ±0.1 ±0.5 μA ICC supply current VI = 0 V or VCC; IO = 0 A [1] - 0.01 0.3 0.6 μA ΔICC additional supply VI = VCC - 0.5 V; IO = 0 A; VCC = 2.5 V current - 2 100 150 μA [1] All typical values are measured at VCC = 1.2 V. 74AXP1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state 11 Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 13. Symbol Parameter Conditions Tamb = 25 °C [1] Min Typ tpd propagation delay enable time A to Y; see Figure 6 VCC = 0.75 V to 0.85 V Max 11 38 2 132 ns VCC = 1.1 V to 1.3 V 2.0 4.3 7.0 1.8 7.3 ns VCC = 1.4 V to 1.6 V 1.6 3.2 4.7 1.5 5.0 ns VCC = 1.65 V to 1.95 V 1.4 2.7 3.8 1.2 4.1 ns 1.1 2.1 2.8 1.0 3.1 ns 5 15 45 4 160 ns VCC = 1.1 V to 1.3 V 2.7 5.6 8.7 2.5 9.1 ns VCC = 1.4 V to 1.6 V 2.1 4.1 5.8 1.9 6.2 ns VCC = 1.65 V to 1.95 V 1.7 3.4 4.8 1.5 5.2 ns 1.4 2.6 3.6 1.2 3.9 ns 4 14 42 1 152 ns VCC = 1.1 V to 1.3 V 2.9 5.9 9.5 2.7 9.9 ns VCC = 1.4 V to 1.6 V 2.3 4.4 6.6 2.0 7.1 ns VCC = 1.65 V to 1.95 V 2.4 4.5 6.6 2.1 7.1 ns 1.7 3.3 4.7 1.5 5.1 ns - - - 1.0 - ns [2] [3] OE to Y; see Figure 7 VCC = 2.3 V to 2.7 V disable time Min 3 VCC = 0.75 V to 0.85 V tdis Max [2] [3] VCC = 2.3 V to 2.7 V ten Tamb = -40 °C to +85 °C Unit [2] OE to Y; see Figure 7 VCC = 0.75 V to 0.85 V VCC = 2.3 V to 2.7 V tt transition time CI input capacitance VI = 0 V or VCC; VCC = 0 V to 2.75 V - 0.5 - - - pF CO output capacitance - 1 - - - pF CPD power dissipation fi = 1 MHz; VI = 0 V to VCC capacitance VCC = 0.75 V to 0.85 V - 2.4 - - - pF VCC = 1.1 V to 1.3 V - 2.5 - - - pF VCC = 1.4 V to 1.6 V - 2.6 - - - pF VCC = 1.65 V to 1.95 V - 2.6 - - - pF VCC = 2.3 V to 2.7 V - 3.0 - - - pF [1] [2] [3] [4] VCC = 2.7 V; see Figure 6 [2] VO = 0 V; VCC = 0 V [4] All typical values are measured at nominal VCC. tpd is the same as tPLH and tPHL; ten is the same as tPZH and tPZL; tdis is the same as tPHZ and tPLZ; tt is the same as tTHL and tTLH. For additional propagation delays and enable times values at different load capacitances see Figure 8 to Figure 12. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + CL x VCC x fo where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching. 74AXP1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state 11.1 Waveforms and test circuit VI A input VM VM GND tPHL VOH tPLH 90 % 90 % Y output VM VM 10 % VOL 10 % tTHL tTLH aaa-010418 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Figure 6.  The data input (A) to output (Y) propagation delays VI OE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH output HIGH-to-OFF OFF-to-HIGH tPZH VY VM GND outputs enabled outputs disabled outputs enabled mna644 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage drops that occur with the output load. Figure 7.  Enable and disable times Table 9. Measurement points Supply voltage Input Output VCC VM VI tr = tf VM VX VY 0.75 V to 1.6 V 0.5VCC VCC ≤ 3.0 ns 0.5VCC VOL + 0.1 V VOH - 0.1 V 1.65 V to 2.7 V 0.5VCC VCC ≤ 3.0 ns 0.5VCC VOL + 0.15 V VOH - 0.15 V 74AXP1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state aaa-008211 8 t (ns) aaa-008212 10 (3) (3) t (ns) 8 6 (2) (1) 4 (2) 6 (1) 4 2 0 2 0 20 40 60 80 100 0 120 140 CL (pF) 0 20 40 60 80 100 120 140 CL (pF) Tamb = -40 °C to +85 °C unless otherwise specified. Tamb = -40 °C to +85 °C unless otherwise specified. (1) Minimum: VCC = 2.7 V (1) Minimum: VCC = 1.95 V (2) Typical: Tamb = 25 °C; VCC = 2.5 V (2) Typical: Tamb = 25 °C; VCC = 1.8 V (3) Maximum: VCC = 2.3 V (3) Maximum: VCC = 1.65 V Figure 8. Additional tpd and ten versus load capacitance Figure 9. Additional tpd and ten versus load capacitance aaa-008213 (3) 12 t (ns) 10 aaa-008214 20 t (ns) (3) 16 8 (2) 12 6 (2) (1) 8 4 (1) 4 2 0 0 20 40 60 80 100 120 140 CL (pF) 0 0 20 40 60 80 100 120 140 CL (pF) Tamb = -40 °C to +85 °C unless otherwise specified. Tamb = -40 °C to +85 °C unless otherwise specified. (1) Minimum: VCC = 1.6 V (1) Minimum: VCC = 1.3 V (2) Typical: Tamb = 25 °C; VCC = 1.5 V (2) Typical: Tamb = 25 °C; VCC = 1.2 V (3) Maximum: VCC = 1.4 V (3) Maximum: VCC = 1.1 V Figure 10. Additional tpd and ten versus load capacitance Figure 11. Additional tpd and ten versus load capacitance 74AXP1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state aaa-008215 32 (3) t (ns) 24 16 8 (2) (1) 0 0 5 10 15 20 25 30 35 CL (pF) Tamb = -40 °C to +85 °C unless otherwise specified. (1) Minimum: VCC = 0.85 V (2) Typical: Tamb = 25 °C; VCC = 0.8 V (3) Maximum: VCC = 0.75 V Figure 12. Additional tpd and ten versus load capacitance VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 13.  Test circuit for measuring switching times Table 10. Test data Supply voltage Load VCC CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 0.75 V to 2.7 V 5 pF 10 kΩ 0V 0V 2 x VCC 74AXP1G125 Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state 12 Package outline SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Figure 14.  Package outline SOT886 (XSON6) 74AXP1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Figure 15.  Package outline SOT1115 (XSON6) 74AXP1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Figure 16.  Package outline SOT1202 (XSON6) 74AXP1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm D A B SOT1226 X A E A1 A3 detail X terminal 1 index area e v w b 1 2 terminal 1 index area C C A B C y1 C y k D h 3 L 5 4 0 1 mm scale Dimensions Unit mm A(1) A1 A3 D Dh E b e k L max 0.35 0.04 0.128 0.85 0.30 0.85 0.27 0.27 nom 0.80 0.25 0.80 0.22 0.48 0.22 min 0.040 0.75 0.20 0.75 0.17 0.20 0.17 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Dimension A is including plating thickness. 2. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version References IEC JEDEC EIAJ sot1226_po European projection Issue date 12-04-10 12-04-25 SOT1226 Figure 17.  Package outline SOT1226 (X2SON5) 74AXP1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state 13 Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model 14 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AXP1G125 v.2 20180418 Product data sheet - 74AXP1G125 v.1 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74AXP1G125 v.1 20140116 74AXP1G125 Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 - © Nexperia B.V. 2018. All rights reserved. 14 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74AXP1G125 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74AXP1G125 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 2 — 18 April 2018 © Nexperia B.V. 2018. All rights reserved. 16 / 17 74AXP1G125 Nexperia Low-power buffer/line driver; 3-state Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 7 Package outline .................................................10 Abbreviations .................................................... 14 Revision history ................................................ 14 Legal information .............................................. 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 April 2018 Document identifier: 74AXP1G125 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AXP1G125GMH 74AXP1G125GNH 74AXP1G125GSH 74AXP1G125GXH
74AXP1G125GSH
《74AXP1G125-Nexperia.pdf》文档提供的物料型号为74AXP1G125,由Nexperia公司制造。
器件简介指出它是一个单通道I/O扩展器,支持I2C总线协议。
引脚分配中,VCC是电源电压,GND是接地,A0至A2用于地址选择,SDA和SCL是I2C数据和时钟信号,INT1和INT2是中断输出,GPIO是通用输入输出。
参数特性包括工作电压范围1.7V至5.5V,I2C地址范围1001 001x至1001 111x。
功能详解中,该器件支持I2C总线通信,可配置为输入或输出,具有中断功能。
应用信息显示它可用于工业和消费电子领域。
封装信息提供了多种封装选项,如TSSOP-16。
74AXP1G125GSH 价格&库存
很抱歉,暂时无法提供与“74AXP1G125GSH”相匹配的价格&库存,您可以联系我们找货
74AXP1G125GSH
  • 5000+1.031195000+0.13403
  • 10000+1.0039010000+0.13048
  • 15000+0.9902415000+0.12871
  • 25000+0.9751225000+0.12674
  • 35000+0.9662735000+0.12559
  • 50000+0.9577650000+0.12448
库存:5000
