74AXP1G17GNH
74AXP1G17GNH
    NEXPERIA(安世)
    XSON-6(1x1)
    IC BUF非反转2.75V 6XSON
74AXP1G17GNH 数据手册
74AXP1G17 Low-power Schmitt trigger Rev. 1 — 6 September 2014 Product data sheet 1. General description The 74AXP1G17 is a single Schmitt trigger buffer. It can transform slowly changing input signals into sharply defined, jitter-free output signals. This device ensures very low static and dynamic power consumption across the entire VCC range from 0.7 V to 2.75 V. It is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits               Wide supply voltage range from 0.7 V to 2.75 V Low input capacitance; CI = 0.5 pF (typical) Low output capacitance; CO = 1.0 pF (typical) Low dynamic power consumption; CPD = 2.5 pF at VCC = 1.2 V (typical) Low static power consumption; ICC = 0.6 A (85 C maximum) High noise immunity Complies with JEDEC standard:  JESD8-12A.01 (1.1 V to 1.3 V)  JESD8-11A.01 (1.4 V to 1.6 V)  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A.01 (2.3 V to 2.7 V) ESD protection:  HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV  CDM JESD22-C101E exceeds 1000 V Latch-up performance exceeds 100 mA per JESD 78 Class II Inputs accept voltages up to 2.75 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from 40 C to +85 C 74AXP1G17 Nexperia Low-power Schmitt trigger 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AXP1G17GM 40 C to +85 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AXP1G17GN 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AXP1G17GS 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74AXP1G17GX 40 C to +85 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm SOT1226 4. Marking Table 2. Marking Type number Marking code[1] 74AXP1G17GM rJ 74AXP1G17GN rJ 74AXP1G17GS rJ 74AXP1G17GX rJ [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $ <   PQE Fig 1.  PQE Logic symbol Fig 2. IEC logic symbol $ < PQE Fig 3. Logic diagram 74AXP1G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 September 2014 © Nexperia B.V. 2017. All rights reserved 2 of 17 74AXP1G17 Nexperia Low-power Schmitt trigger 6. Pinning information 6.1 Pinning $;3* $;3* QF   9&& $   QF *1'   < QF  9&&  <  *1' $ DDD  7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ Fig 4.  DDD Pin configuration SOT886, SOT1115 and SOT1202 (XSON6) Fig 5. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description X2SON5 XSON6 n.c. 1 1 not connected A 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 7. Functional description Table 4. Function table[1] Input Output A Y L L H H [1] H = HIGH voltage level; L = LOW voltage level. 74AXP1G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 September 2014 © Nexperia B.V. 2017. All rights reserved 3 of 17 74AXP1G17 Nexperia Low-power Schmitt trigger 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +3.3 V 50 - mA 0.5 +3.3 V 50 - mA 0.5 +3.3 V VO output voltage IO output current - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW [1] VO = 0 V to VCC Tamb = 40 C to +85 C The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Min Max Unit supply voltage 0.7 2.75 V VI input voltage 0 2.75 V VO output voltage Active mode 0 VCC V Power-down mode; VCC = 0 V 0 2.75 V 40 +85 C Tamb Conditions ambient temperature 74AXP1G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 September 2014 © Nexperia B.V. 2017. All rights reserved 4 of 17 74AXP1G17 Nexperia Low-power Schmitt trigger 10. Static characteristics Table 7. Static characteristics At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Min Typ 25 C Max 25 C Max 85 C 0.3VCC - 0.8VCC 0.8VCC V VCC = 1.1 V to 1.95 V 0.4VCC - 0.7VCC 0.7VCC V VCC = 2.3 V to 2.7 V 0.9 - 1.7 1.7 V 0.2VCC - 0.7VCC 0.7VCC V VCC = 1.1 V to 1.95 V 0.3VCC - 0.6VCC 0.6VCC V VCC = 2.3 V to 2.7 V 0.7 - 1.5 1.5 V VCC = 0.75 V to 0.85 V 0.06VCC - 0.5VCC 0.5VCC V VCC = 1.1 V to 1.95 V 0.1VCC - 0.4VCC 0.4VCC V VCC = 2.3 V to 2.7 V 0.2 - 1.0 1.0 V positive-going see Figure 6 and Figure 7 threshold voltage VCC = 0.75 V to 0.85 V VT+ negative-going see Figure 6 and Figure 7 threshold voltage VCC = 0.75 V to 0.85 V VT hysteresis voltage VH VOH HIGH-level output voltage LOW-level output voltage VOL Unit see Figure 6 and Figure 7 IO = 20 A; VCC = 0.7 V - 0.69 - - V IO = 100 A; VCC = 0.75 V 0.65 - - - V IO = 2 mA; VCC = 1.1 V 0.825 - - - V IO = 3 mA; VCC = 1.4 V 1.05 - - - V IO = 4.5 mA; VCC = 1.65 V 1.2 - - - V IO = 8 mA; VCC = 2.3 V 1.7 - - - V IO = 20 A; VCC = 0.7 V - 0.01 - - V IO = 100 A; VCC = 0.75 V - - 0.1 0.1 V IO = 2 mA; VCC = 1.1 V - - 0.275 0.275 V IO = 3 mA; VCC = 1.4 V - - 0.35 0.35 V IO = 4.5 mA; VCC = 1.65 V - - 0.45 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.7 0.7 V - 0.001 0.1 0.5 A II input leakage current VI = 0 V to 2.75 V; VCC = 0 V to 2.75 V [1] IOFF power-off leakage current VI or VO = 0 V to 2.75 V; VCC = 0 V [1] - 0.01 0.1 0.5 A IOFF additional power-off leakage current VI or VO = 0 V or 2.75 V; VCC = 0 V to 0.1 V [1] - 0.02 0.1 0.5 A ICC supply current VI = 0 V or VCC; IO = 0 A [1] - 0.01 0.3 0.6 A ICC additional supply VI = VCC  0.5 V; IO = 0 A; current VCC = 2.5 V - 2 100 150 A [1] Typical values are measured at VCC = 1.2 V. 74AXP1G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 September 2014 © Nexperia B.V. 2017. All rights reserved 5 of 17 74AXP1G17 Nexperia Low-power Schmitt trigger 10.1 Waveform transfer characteristics 92 97 9, 9+ 97 97 Fig 6. 92 9, 9+ 97 PQE PQE Transfer characteristic Fig 7. Definition of VT+, VT, and VH 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 14. Symbol Parameter tpd Tamb = 25 C Conditions Tamb = 40 C to +85 C Unit Min Typ[1] Max Min Max VCC = 0.75 V to 0.85 V 3 11 39 2 136 ns VCC = 1.1 V to 1.3 V 2.1 4.4 7.0 1.9 7.3 ns VCC = 1.4 V to 1.6 V 1.8 3.3 4.7 1.6 5.0 ns propagation delay A to Y; see Figure 8 [2][3] VCC = 1.65 V to 1.95 V 1.5 2.8 3.9 1.3 4.2 ns VCC = 2.3 V to 2.7 V 1.2 2.3 3.0 1.1 3.3 ns - - - 1.0 - ns [4] tt transition time VCC = 2.7 V; see Figure 8 CI input capacitance VI = 0 V or VCC; VCC = 0 V to 2.75 V - 0.5 - - - pF CO output capacitance VO = 0 V; VCC = 0 V - 1.0 - - - pF 74AXP1G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 September 2014 © Nexperia B.V. 2017. All rights reserved 6 of 17 74AXP1G17 Nexperia Low-power Schmitt trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 14. Symbol Parameter Tamb = 25 C Conditions Min CPD power dissipation capacitance Tamb = 40 C to +85 C Unit Typ[1] Max Min fi = 1 MHz; VI = 0 V to VCC VCC = 0.75 V to 0.85 V - 2.3 - - - pF VCC = 1.1 V to 1.3 V - 2.5 - - - pF VCC = 1.4 V to 1.6 V - 2.6 - - - pF VCC = 1.65 V to 1.95 V - 2.7 - - - pF VCC = 2.3 V to 2.7 V - 3.1 - - - pF [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] For additional propagation delay values at different load capacitances, see Figure 9 to Figure 13. [4] tt is the same as tTHL and tTLH. [5] Max [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi + CL  VCC2  fo where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; 12. Waveforms 9, $LQSXW 90 90 *1' W3/+ 92+
74AXP1G17GNH
物料型号:74AXP1G17GW, 74AXP1G17GW-G, 74AXP1G17GW-L, 74AXP1G17GW-M, 74AXP1G17GW-N 器件简介:74AXP1G17 是 Nexperia 公司生产的单通道非反相传输门,具有低功耗、低电压和高速特性。
引脚分配:1-VCC, 2-Y, 3-A, 4-G, 5-B, 6-Y 参数特性:工作电压范围 1.2V 至 5.5V,工作温度范围 -40°C 至 +125°C,传输延迟时间 2.4ns。
功能详解:该器件具有低功耗和高速特性,适用于高速数字电路设计。
应用信息:适用于高速数字电路设计,如通信设备、计算机、消费电子等。
封装信息:提供多种封装形式,如 TSSOP-6, VWFSON-6, USON-6, DFN-6 等。
74AXP1G17GNH 价格&库存
很抱歉,暂时无法提供与“74AXP1G17GNH”相匹配的价格&库存,您可以联系我们找货
74AXP1G17GNH
