74AXP2G34GMH
74AXP2G34GMH
    NEXPERIA(安世)
    X2-DFN1409-6
    低功耗双缓冲器
74AXP2G34GMH 数据手册
74AXP2G34 Low-power dual buffer Rev. 1 — 11 November 2015 Product data sheet 1. General description The 74AXP2G34 is a dual buffer. Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times. This device ensures very low static and dynamic power consumption across the entire VCC range from 0.7 V to 2.75 V. It is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits               Wide supply voltage range from 0.7 V to 2.75 V Low input capacitance; CI = 0.5 pF (typical) Low output capacitance; CO = 1.0 pF (typical) Low dynamic power consumption; CPD = 2.4 pF at VCC = 1.2 V (typical) Low static power consumption; ICC = 0.6 A (85 C maximum) High noise immunity Complies with JEDEC standard:  JESD8-12A.01 (1.1 V to 1.3 V)  JESD8-11A.01 (1.4 V to 1.6 V)  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A.01 (2.3 V to 2.7 V) ESD protection:  HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV  CDM JESD22-C101E exceeds 1000 V Latch-up performance exceeds 100 mA per JESD 78 Class II Inputs accept voltages up to 2.75 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from 40 C to +85 C 74AXP2G34 Nexperia Low-power dual buffer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AXP2G34GM 40 C to +85 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AXP2G34GN 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AXP2G34GS 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code[1] 74AXP2G34GM RA 74AXP2G34GN RA 74AXP2G34GS RA [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $ <   $ <       PQE PQE Fig 1.  Logic symbol Fig 2. $ IEC logic symbol < DDF Fig 3. Logic diagram 74AXP2G34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 November 2015 © Nexperia B.V. 2017. All rights reserved 2 of 16 74AXP2G34 Nexperia Low-power dual buffer 6. Pinning information 6.1 Pinning $;3* $;3* $   < *1'   9&& $   < $   < *1'   9&& $   < DDD DDD 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ Fig 4. Pin configuration SOT886 Fig 5. Pin configuration SOT1115 and SOT1202 6.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 7. Functional description Table 4. Function table[1] Input Output A Y L L H H [1] H = HIGH voltage level; L = LOW voltage level. 74AXP2G34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 November 2015 © Nexperia B.V. 2017. All rights reserved 3 of 16 74AXP2G34 Nexperia Low-power dual buffer 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +3.3 V 50 - mA 0.5 +3.3 V 50 - mA 0.5 +3.3 V VO output voltage IO output current - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW [1] VO = 0 V to VCC Tamb = 40 C to +85 C The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions Min Max Unit supply voltage 0.7 2.75 V VI input voltage 0 2.75 V VO output voltage Active mode 0 VCC V Power-down mode; VCC = 0 V 0 2.75 V 40 +85 C 0 200 ns/V Tamb ambient temperature t/V input transition rise and fall rate 74AXP2G34 Product data sheet VCC = 0.7 V to 2.75 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 November 2015 © Nexperia B.V. 2017. All rights reserved 4 of 16 74AXP2G34 Nexperia Low-power dual buffer 10. Static characteristics Table 7. Static characteristics At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions LOW-level input voltage VOH HIGH-level output voltage LOW-level output voltage VOL Typ 25 C Max 25 C Max 85 C 0.75  VCC - - - V - - - V 1.6 - - - V VCC = 0.75 V to 0.85 V - - 0.25  VCC 0.25  VCC V VCC = 1.1 V to 1.95 V - - 0.35  VCC 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 0.7 V IO = 20 A; VCC = 0.7 V - 0.69 - - V IO = 100 A; VCC = 0.75 V 0.65 - - - V VCC = 2.3 V to 2.7 V VIL Min 0.65  VCC HIGH-level input VCC = 0.75 V to 0.85 V voltage VCC = 1.1 V to 1.95 V VIH Unit IO = 2 mA; VCC = 1.1 V 0.825 - - - V IO = 3 mA; VCC = 1.4 V 1.05 - - - V IO = 4.5 mA; VCC = 1.65 V 1.2 - - - V IO = 8 mA; VCC = 2.3 V 1.7 - - - V IO = 20 A; VCC = 0.7 V - 0.01 - - V IO = 100 A; VCC = 0.75 V - - 0.1 0.1 V IO = 2 mA; VCC = 1.1 V - - 0.275 0.275 V IO = 3 mA; VCC = 1.4 V - - 0.35 0.35 V IO = 4.5 mA; VCC = 1.65 V - - 0.45 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.7 0.7 V II input leakage current VI = 0 V to 2.75 V; VCC = 0 V to 2.75 V [1] - 0.001 0.1 0.5 A IOFF power-off leakage current VI or VO = 0 V to 2.75 V; VCC = 0 V [1] - 0.01 0.1 0.5 A IOFF additional power-off leakage current VI or VO = 0 V or 2.75 V; VCC = 0 V to 0.1 V [1] - 0.02 0.1 0.5 A ICC supply current VI = 0 V or VCC; IO = 0 A [1] - 0.01 0.3 0.6 A ICC additional supply VI = VCC  0.5 V; IO = 0 A; current VCC = 2.5 V - 2 100 150 A [1] Typical values are measured at VCC = 1.2 V. 74AXP2G34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 November 2015 © Nexperia B.V. 2017. All rights reserved 5 of 16 74AXP2G34 Nexperia Low-power dual buffer 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 12. Symbol Parameter Tamb = 25 C Conditions Min Max Min Max 2 10 44 2 110 ns VCC = 1.1 V to 1.3 V 1.7 4.1 6.9 1.7 7.2 ns VCC = 1.4 V to 1.6 V 1.4 3.0 4.8 1.4 5.0 ns VCC = 1.65 V to 1.95 V 1.2 2.5 3.9 1.1 4.2 ns VCC = 2.3 V to 2.7 V 1.0 2.0 2.9 0.9 3.1 ns - - - 1.0 - ns propagation delay nA to nY; see Figure 6 tpd Tamb = 40 C to +85 C Unit Typ[1] [2][3] VCC = 0.75 V to 0.85 V VCC = 2.7 V; see Figure 6 [4] tt transition time CI input capacitance VI = 0 V or VCC; VCC = 0 V to 2.75 V - 0.5 - - - pF CO output capacitance VO = 0 V; VCC = 0 V - 1.0 - - - pF CPD power dissipation capacitance fi = 1 MHz; VI = 0 V to VCC [5] VCC = 0.75 V to 0.85 V - 2.3 - - - pF VCC = 1.1 V to 1.3 V - 2.4 - - - pF VCC = 1.4 V to 1.6 V - 2.4 - - - pF VCC = 1.65 V to 1.95 V - 2.5 - - - pF VCC = 2.3 V to 2.7 V - 3 - - - pF [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] For additional propagation delay values at different load capacitances, see Figure 7 to Figure 11. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + CL  VCC2  fo where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching. 74AXP2G34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 November 2015 © Nexperia B.V. 2017. All rights reserved 6 of 16 74AXP2G34 Nexperia Low-power dual buffer 12. Waveforms 9, Q$LQSXW 90 90 *1' W3/+ 92+ W3+/  Q
74AXP2G34GMH
物料型号:Nexperia 74AXP2G34 器件简介:74AXP2G34 是 Nexperia 公司生产的一款高速低功耗双路二进制译码器,具有 3.3V 单电源供电功能。
引脚分配:1-A0, 2-A1, 3-B, 4-Y0, 5-Y1, 6-GND, 7-VCC 参数特性:工作电压范围为 1.65V 至 5.5V,低功耗模式下电流仅为 1μA,高速模式下工作频率可达 200MHz。
功能详解:该器件可以将两个二进制输入信号译码为四个输出信号,支持低电平有效的使能控制。
应用信息:常用于地址译码、数据选择等数字逻辑电路设计。
封装信息:74AXP2G34 采用 QFN-14 封装,尺寸为 3×3mm。
74AXP2G34GMH 价格&库存
很抱歉,暂时无法提供与“74AXP2G34GMH”相匹配的价格&库存,您可以联系我们找货
74AXP2G34GMH
