74HC125-Q100; 74HCT125-Q100
Quad buffer/line driver; 3-state
Rev. 2 — 19 January 2015
Product data sheet
1. General description
The 74HC125-Q100; 74HCT125-Q100 is a quad buffer/line driver with 3-state outputs
controlled by the output enable inputs (nOE). A HIGH on nOE causes the outputs to
assume a high impedance OFF-state. Inputs include clamp diodes which enable the use
of current limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Complies with JEDEC standard no. 7A
Input levels:
The 74HC125-Q100: CMOS levels
The 74HCT125-Q100: TTL levels
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
3. Ordering information
Table 1.
Type number
74HC125D-Q100
Package
Temperature range Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74HCT125D-Q100
74HC125PW-Q100
74HCT125PW-Q100
Nexperia
4. Functional diagram
2(
2(
(1
2(
Q<
Q$
2(
Q2(
PQD
Fig 1.
Logic symbol
PQD
Fig 2.
PQD
IEC logic symbol
Fig 3.
Logic diagram (one buffer)
5. Pinning information
5.1 Pinning
+&4
+&74
2(
9&&
2(
2(
2(
*1'
DDD
Fig 4.
Pin configuration SO14 and TSSOP14
74HC_HCT125_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1OE, 2OE, 3OE, 4OE
1, 4, 10, 13
output enable input (active LOW)
1A, 2A, 3A, 4A
2, 5, 9, 12
data input
1Y, 2Y, 3Y, 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
nOE
nA
nY
L
H
[1]
L
L
H
H
X
Z
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = 0.5 V to (VCC + 0.5 V)
ICC
supply current
+70
mA
IGND
ground current
70
mA
Tstg
storage temperature
65
+150
C
500
mW
[1]
total power dissipation
Ptot
Min
Max
Unit
0.5
+7
V
mA
mA
35
mA
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: Ptot derates linearly with 8 mW/K above 70 C.
For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
74HC_HCT125_Q100
Product data sheet
3 of 15
Nexperia
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC125-Q100
Min
Typ
74HCT125-Q100
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 6.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 7.8 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
74HC125-Q100
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
0.1
1.0
1.0
A
IOZ
OFF-state
output current
VI = VIH or VIL;
VO = VCC or GND;
VCC = 6.0 V
0.5
5.0
10.0
A
74HC_HCT125_Q100
Product data sheet
4 of 15
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
ICC
supply current
CI
input
capacitance
25 C
Conditions
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
Min
Typ
Max
Min
Max
Min
Max
8.0
80
160
3.5
A
pF
74HCT125-Q100
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
4.4
4.4
V
IO = 6 mA
3.98
4.32
3.84
3.7
V
VOL
LOW-level
output voltage
IO = 20 A
0.1
0.1
V
IO = 6.0 mA
0.16
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND;
VCC = 5.5 V
0.1
1.0
1.0
A
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 5.5 V;
VO = VCC or GND
0.5
5.0
10
A
ICC
supply current
VCC = 5.5 V
8.0
80
160
A
ICC
additional
supply current
per input pin;
VI = VCC 2.1 V; IO = 0 A;
other inputs at VCC or GND;
100
360
450
490
A
CI
input
capacitance
3.5
74HC_HCT125_Q100
Product data sheet
pF
5 of 15
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 7.
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
30
100
125
150
ns
VCC = 4.5 V
11
30
ns
VCC = 5 V; CL = 15 pF
9
ns
VCC = 6.0 V
9
17
21
26
ns
VCC = 2.0 V
41
125
155
190
ns
VCC = 4.5 V
15
25
31
38
ns
VCC = 6.0 V
12
21
26
32
ns
VCC = 2.0 V
41
125
155
190
ns
VCC = 4.5 V
15
25
31
38
ns
VCC = 6.0 V
12
21
26
32
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
22
pF
74HC125-Q100
tpd
ten
tdis
tt
CPD
propagation
delay
enable time
nA to nY; see Figure 5
nOE to nY; see Figure 6
disable time nOE to nY; see Figure 6
transition
time
power
dissipation
capacitance
74HC_HCT125_Q100
Product data sheet
[1]
[2]
[3]
[4]
nY; see Figure 5
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[5]
6 of 15
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
15
25
31
38
ns
12
ns
15
28
35
42
ns
74HCT125-Q100
propagation
delay
tpd
[1]
VCC = 4.5 V
ten
enable time
tdis
[2]
VCC = 4.5 V
[3]
VCC = 4.5 V
tt
transition
time
nY; see Figure 5
[4]
CPD
power
dissipation
capacitance
VI = GND to VCC 1.5 V
[5]
[1]
15
25
31
38
ns
5
12
15
18
ns
24
pF
tpd is the same as tPLH and tPHL.
[2]
ten is the same as tPZH and tPZL.
[3]
tdis is the same as tPLZ and tPHZ.
[4]
tt is the same as tTHL and tTLH.
[5]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
11. Waveforms
9,
Q$LQSXW
90
90
*1'
W3+/
W3/+
92+
90
Q
很抱歉,暂时无法提供与“74HC125D-Q100J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+1.098782500+0.13696
- 5000+1.058575000+0.13195
- 7500+1.038457500+0.12944
- 12500+1.0161512500+0.12666
- 17500+1.0031117500+0.12504
- 25000+0.9905725000+0.12348
- 62500+0.9635662500+0.12011
- 国内价格 香港价格
- 2500+0.712142500+0.08877
- 7500+0.708817500+0.08836
- 12500+0.7088012500+0.08835
- 25000+0.7087925000+0.08835
- 50000+0.7087750000+0.08835
