74HC1G126; 74HCT1G126
Bus buffer/line driver; 3-state
Rev. 04 — 20 July 2007
Product data sheet
1. General description
The 74HC1G126 and 74HCT1G126 are high-speed, Si-gate CMOS devices. They
provide one non-inverting buffer/line driver with 3-state output. The 3-state output is
controlled by the output enable input pin (OE). A LOW at pin OE causes the output as
assume a high-impedance OFF-state.
The HC device has CMOS input switching levels and supply voltage range 2 V to 6 V.
The HCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
The bus driver output currents are equal to those of the 74HC126 and 74HCT126.
2. Features
n
n
n
n
n
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
SOT353-1 and SOT753 package options
3. Ordering information
Table 1.
Type number
74HC1G126GW
Package
Temperature range Name
Description
Version
−40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
−40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74HCT1G126GW
74HC1G126GV
74HCT1G126GV
4. Marking
Table 2.
Marking codes
Type number
Marking
74HC1G126GW
HN
74HCT1G126GW
TN
74HC1G126GV
H26
74HCT1G126GV
T26
Nexperia
5. Functional diagram
2
A
Y
4
Y
A
2
4
1
OE
1
OE
OE
mna125
Fig 1. Logic symbol
mna127
mna126
Fig 2. IEC logic symbol
Fig 3. Logic diagram
6. Pinning information
6.1 Pinning
74HC1G126
74HCT1G126
OE
1
A
2
GND
3
5
VCC
4
Y
001aaf103
Fig 4. Pin configuration
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
OE
1
output enable input
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
7. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state
Inputs
Output
OE
A
Y
H
L
L
H
H
H
L
X
Z
74HC_HCT1G126_4
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 12
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). [1]
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI < −0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
−0.5 V < VO < VCC + 0.5 V
±35.0
mA
ICC
supply current
70
mA
IGND
ground current
−70
mA
Tstg
storage temperature
−65
+150
°C
200
mW
Tamb = −40 °C to +125 °C
total power dissipation
Ptot
[2]
Min
Max
Unit
−0.5
+7.0
V
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
9. Recommended operating conditions
Table 6.
Symbol Parameter
VCC
supply voltage
Conditions
74HC1G126
74HCT1G126
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
−40
+25
+125
−40
+25
+125
°C
∆t/∆V
input transition rise
and fall rate
VCC = 2.0 V
625
VCC = 4.5 V
139
139
ns/V
VCC = 6.0 V
83
ns/V
ns/V
10. Static characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C.
Symbol
Parameter
Conditions
−40 °C to +85 °C
−40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
V
For type 74HC1G126
VIH
VIL
HIGH-level input
voltage
LOW-level input
voltage
VCC = 2.0 V
0.8
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
V
74HC_HCT1G126_4
Product data sheet
3 of 12
Nexperia
Table 7.
Static characteristics …continued
Symbol
VOH
VOL
Parameter
HIGH-level output
voltage
LOW-level output
voltage
−40 °C to +85 °C
Conditions
−40 °C to +125 °C
Min
Typ
Max
Min
Max
Unit
VI = VIH or VIL
IO = −20 µA; VCC = 2.0 V
1.9
2.0
1.9
V
IO = −20 µA; VCC = 4.5 V
4.4
4.5
4.4
V
IO = −20 µA; VCC = 6.0 V
5.9
6.0
5.9
V
IO = −6.0 mA; VCC = 4.5 V
3.84
4.32
3.7
V
IO = −7.8 mA; VCC = 6.0 V
5.34
5.81
5.2
V
IO = 20 µA; VCC = 2.0 V
0.1
V
IO = 20 µA; VCC = 4.5 V
0.1
V
IO = 20 µA; VCC = 6.0 V
0.1
V
IO = 6.0 mA; VCC = 4.5 V
0.15
0.33
0.4
V
IO = 7.8 mA; VCC = 6.0 V
0.16
0.33
0.4
V
VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
1.0
1.0
µA
IOZ
OFF-state output
current
VI = VIH or VIL; VO = VCC or
GND; VCC = 6.0 V
5
10
µA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
10
µA
CI
input capacitance
1.5
pF
For type 74HCT1G126
VIH
HIGH-level input
voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
V
VIL
LOW-level input
voltage
1.2
0.8
0.8
V
VOH
HIGH-level output
voltage
VI = VIH or VIL; VCC = 4.5 V
IO = −20 µA
4.4
4.5
4.4
V
IO = −6.0 mA
3.84
4.32
3.7
V
LOW-level output
voltage
IO = 20 µA
0.1
V
IO = 6.0 mA
0.16
0.33
0.4
V
µA
VOL
II
VI = VCC or GND; VCC = 5.5 V
1.0
1.0
IOZ
OFF-state output
current
GND; VCC = 5.5 V
5
10
ICC
supply current
VCC = 5.5 V
10
µA
∆ICC
additional supply
current
per input; VCC = 4.5 V to 5.5 V;
VI = VCC − 2.1 V; IO = 0 A
500
850
µA
CI
input capacitance
1.5
pF
74HC_HCT1G126_4
Product data sheet
4 of 12
Nexperia
11. Dynamic characteristics
Table 8.
GND = 0 V; tr = tf ≤ 6.0 ns; CL = 50 pF unless otherwise specified. All typical values are measured at Tamb = 25 °C. For test
circuit see Figure 7
Symbol Parameter
−40 °C to +85 °C
Conditions
−40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
24
125
150
VCC = 4.5 V
10
25
30
ns
VCC = 5.0 V; CL = 15 pF
9
ns
9
21
26
ns
VCC = 2.0 V
24
155
190
ns
VCC = 4.5 V
10
31
38
ns
8
26
32
ns
VCC = 2.0 V
16
155
190
ns
VCC = 4.5 V
12
31
38
ns
11
26
32
ns
30
pF
11
30
36
ns
For type 74HC1G126
tpd
[1]
propagation delay A to Y; see Figure 5
VCC = 2.0 V
VCC = 6.0 V
ten
enable time
OE to Y; see Figure 6
[1]
VCC = 6.0 V
tdis
disable time
[1]
VCC = 6.0 V
CPD
power dissipation
capacitance
[2]
VI = GND to VCC
ns
For type 74HCT1G126
tpd
[1]
VCC = 4.5 V
ten
tdis
CPD
10
ns
OE to Y; see Figure 6; VCC = 4.5 V
[1]
10
35
42
ns
disable time
[1]
12
31
38
ns
power dissipation
capacitance
VI = GND to VCC − 1.5 V
[2]
27
pF
enable time
[1]
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
[2]
CPD is used to determine the dynamic power dissipation PD (µW).
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
∑ (CL × VCC2 × fo) = sum of outputs
74HC_HCT1G126_4
Product data sheet
5 of 12
Nexperia
12. Waveforms
VI
VM
A input
GND
tPLH
tPHL
VM
Y output
mna121
Measurement points are given in Table 9.
Fig 5. The input (A) to output (Y) propagation delays
VI
VM
OE input
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VOL + 0.3 V
tPHZ
tPZH
VOH − 0.3 V
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
output
enabled
output
disabled
output
enabled
mna129
Fig 6. The 3-state enable and disable times
Table 9.
Measurement points
Type
Input
Output
VM
VI
VM
74HC1G126
0.5 × VCC
GND to VCC
0.5 × VCC
74HCT1G126
1.3 V
GND to 3.0 V
1.3 V
74HC_HCT1G126_4
Product data sheet
6 of 12
Nexperia
S1
VCC
PULSE
GENERATOR
VI
RL =
1000 Ω
VO
VCC
open
GND
D.U.T.
RT
CL
mna232
Test data is given in Table 8. Definitions for test circuit:
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistance
For tPLH, tPHL, S1 = open
For tPLZ, tPZL, S1 = VCC
For tPHZ, tPZH, S1 = GND
Fig 7. Load circuitry for switching times
74HC_HCT1G126_4
Product data sheet
7 of 12
Nexperia
13. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
E
D
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
L
e
w M
bp
detail X
e1
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig 8. Package outline SOT353-1 (TSSOP5)
74HC_HCT1G126_4
Product data sheet
8 of 12
Nexperia
Plastic surface-mounted package; 5 leads
SOT753
D
E
B
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Fig 9. Package outline SOT753 (SC-74A)
74HC_HCT1G126_4
Product data sheet
9 of 12
Nexperia
14. Abbreviations
Table 10.
Abbreviations
Acronym
Description
DUT
Device Under Test
TTL
Transistor-Transistor Logic
15. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT1G126_4
20070720
Product data sheet
74HC_HCT1G126_3
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Package SOT353 changed to SOT353-1 in Table 1 and Figure 8.
Quick Reference Data and Soldering sections removed.
Section 2 “Features” updated.
74HC_HCT1G126_3
20020515
Product specification
74HC_HCT1G126_2
20010406
74HC_HCT1G126
74HC_HCT1G126
19970924
Preliminary specification
74HC_HCT1G126_2
74HC_HCT1G126_4
Product data sheet
10 of 12
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
16.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected to
result in personal injury, death or severe property or environmental damage.
Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore
such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
74HC_HCT1G126_4
Product data sheet
11 of 12
Nexperia
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional description . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 3
Static characteristics. . . . . . . . . . . . . . . . . . . . . 3
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 20 July 2007
很抱歉,暂时无法提供与“74HCT1G126GW,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.437393000+0.05651
- 6000+0.422216000+0.05455
- 9000+0.414629000+0.05357
- 15000+0.4061915000+0.05248
- 21000+0.4012721000+0.05184
- 30000+0.3965430000+0.05123
- 国内价格
- 1+1.14019
- 10+0.89586
- 25+0.79162
- 100+0.74927
- 250+0.71506
- 500+0.64176
- 1000+0.59860
- 3000+0.57824
- 国内价格 香港价格
- 1+1.086351+0.14035
- 10+0.8729310+0.11278
- 25+0.7714725+0.09967
- 100+0.72861100+0.09413
- 250+0.69625250+0.08995
- 500+0.62452500+0.08069
- 1000+0.582541000+0.07526
- 3000+0.562423000+0.07266
- 国内价格
- 5+0.65664
- 50+0.51182
- 150+0.43946
- 500+0.38513
- 3000+0.34172
- 6000+0.32001
