74HC240; 74HCT240
Octal buffer/line driver; 3-state; inverting
Rev. 4 — 25 February 2016
Product data sheet
1. General description
The 74HC240; 74HCT240 is an 8-bit inverting buffer/line driver with 3-state outputs. The
device can be used as two 4-bit buffers or one 8-bit buffer. The device features two output
enables (1OE and 2OE), each controlling four of the 3-state outputs. A HIGH on nOE
causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes.
This enables the use of current limiting resistors to interface inputs to voltages in excess
of VCC.
2. Features and benefits
Complies with JEDEC standard JESD7A
Input levels:
For 74HC240: CMOS level
For 74HCT240: TTL level
Inverting 3-state outputs
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Ordering information
Table 1.
Type number
74HC240D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
40 C to +125 C
SSOP20
plastic shrink small outline package; 20 leads; body
width 5.3 mm
SOT339-1
40 C to +125 C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
40 C to +125 C
DHVQFN20
plastic dual-in-line compatible thermal enhanced very SOT764-1
thin quad flat package; no leads; 20 terminals; body
2.5 4.5 0.85 mm
74HCT240D
74HC240DB
74HCT240DB
74HC240PW
74HCT240PW
74HC240BQ
74HCT240BQ
74HC240; 74HCT240
Nexperia
4. Functional diagram
很抱歉,暂时无法提供与“74HCT240PW,112”相匹配的价格&库存,您可以联系我们找货
