74HC240PW,118
74HC240PW,118
    NEXPERIA(安世)
    TSSOP20_6.5X4.4MM
    IC BUFFER INVERT 6V 20TSSOP
74HC240PW,118 数据手册
74HC240; 74HCT240 Octal buffer/line driver; 3-state; inverting Rev. 4 — 25 February 2016 Product data sheet 1. General description The 74HC240; 74HCT240 is an 8-bit inverting buffer/line driver with 3-state outputs. The device can be used as two 4-bit buffers or one 8-bit buffer. The device features two output enables (1OE and 2OE), each controlling four of the 3-state outputs. A HIGH on nOE causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Complies with JEDEC standard JESD7A  Input levels:  For 74HC240: CMOS level  For 74HCT240: TTL level  Inverting 3-state outputs  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC240D Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 40 C to +125 C DHVQFN20 plastic dual-in-line compatible thermal enhanced very SOT764-1 thin quad flat package; no leads; 20 terminals; body 2.5  4.5  0.85 mm 74HCT240D 74HC240DB 74HCT240DB 74HC240PW 74HCT240PW 74HC240BQ 74HCT240BQ 74HC240; 74HCT240 Nexperia Octal buffer/line driver; 3-state; inverting 4. Functional diagram
74HC240PW,118 价格&库存
很抱歉,暂时无法提供与“74HC240PW,118”相匹配的价格&库存,您可以联系我们找货
