74HCT240DB,112
74HCT240DB,112
    NEXPERIA(安世)
    SSOP20
    八通道缓冲器/线路驱动器;3 态;反转
74HCT240DB,112 数据手册
74HC240; 74HCT240 Octal buffer/line driver; 3-state; inverting Rev. 4 — 25 February 2016 Product data sheet 1. General description The 74HC240; 74HCT240 is an 8-bit inverting buffer/line driver with 3-state outputs. The device can be used as two 4-bit buffers or one 8-bit buffer. The device features two output enables (1OE and 2OE), each controlling four of the 3-state outputs. A HIGH on nOE causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Complies with JEDEC standard JESD7A  Input levels:  For 74HC240: CMOS level  For 74HCT240: TTL level  Inverting 3-state outputs  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC240D Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 40 C to +125 C DHVQFN20 plastic dual-in-line compatible thermal enhanced very SOT764-1 thin quad flat package; no leads; 20 terminals; body 2.5  4.5  0.85 mm 74HCT240D 74HC240DB 74HCT240DB 74HC240PW 74HCT240PW 74HC240BQ 74HCT240BQ 74HC240; 74HCT240 Nexperia Octal buffer/line driver; 3-state; inverting 4. Functional diagram
74HCT240DB,112
物料型号:74HC240 器件简介:74HC240 是 Nexperia 公司生产的 8 位串行输入、并行输出位移寄存器。
引脚分配:1-SER(串行输入端),2-Q7(输出 Q7),3-Q6,4-Q5,5-Q4,6-Q3,7-Q2,8-Q1,9-Q0,10-G1(使能端),11-G2A(使能端),12-G2B(使能端),13-CLK(时钟输入端),14-CE(时钟使能端),15-Vcc(电源),16-GND(地线)。
参数特性:工作电压范围 2V 至 6V,工作温度范围 -40 至 +85 摄氏度,工作频率高达 50 MHz。
功能详解:74HC240 可实现数据的串行输入和并行输出,具有三个使能端,支持多种工作模式。
应用信息:广泛应用于数据缓存、数据分配、数据转换等场景。
封装信息:提供多种封装形式,如 SOIC、TSSOP 等。
74HCT240DB,112 价格&库存
很抱歉,暂时无法提供与“74HCT240DB,112”相匹配的价格&库存,您可以联系我们找货
