74HCT2G17GW,125
74HCT2G17GW,125
    NEXPERIA(安世)
    SOT-363
    缓冲器,非反向 2 元件 1 位每元件 推挽式 Output 6-TSSOP
74HCT2G17GW,125 数据手册
74HC2G17; 74HCT2G17 Dual non-inverting Schmitt trigger Rev. 01 — 6 October 2006 Product data sheet 1. General description The 74HC2G17; 74HCT2G17 is a high-speed Si-gate CMOS device. The 74HC2G17; 74HCT2G17 provides two non-inverting Schmitt trigger buffers. They are capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. The inputs switch at different points for positive and negative-going signals. The difference between the positive voltage VT+ and the negative voltage VT− is defined as the input hysteresis voltage VH. 2. Features n n n n n n n n n Wide supply voltage range from 2.0 V to 6.0 V Complies with JEDEC standard no. 7A High noise immunity ESD protection: u HBM JESD22-A114-D exceeds 2000 V u MM JESD22-A115-A exceeds 200 V Low power dissipation Balanced propagation delays Unlimited input rise and fall times Multiple package options Specified from −40 °C to +85 °C and −40 °C to +125 °C 3. Applications n Wave and pulse shaper for highly noisy environments n Astable multivibrators n Monostable multivibrators 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger 4. Ordering information Table 1. Ordering information Type number Package 74HC2G17GW Temperature range Name Description Version −40 °C to +125 °C plastic surface-mounted package; 6 leads SOT363 SC-88 74HC2G17GV −40 °C to +125 °C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74HCT2G17GW −40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74HCT2G17GV −40 °C to +125 °C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 5. Marking Table 2. Marking Type number Marking code 74HC2G17GW HV 74HC2G17GV HV 74HCT2G17GW TV 74HCT2G17GV TV 6. Functional diagram 1 1A 1Y 6 3 2A 2Y 4 1 6 3 4 mnb067 mnb066 Fig 1. Logic symbol Fig 2. IEC logic symbol 1A 1Y 2A 2Y mnb068 Fig 3. Logic diagram © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 2 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger 7. Pinning information 7.1 Pinning 74HC2G17 74HCT2G17 1A 1 6 1Y GND 2 5 VCC 2A 3 4 2Y 001aaf201 Fig 4. Pin configuration 7.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 8. Functional description Table 4. Function table[1] Input Output nA nY L L H H [1] H = HIGH voltage level; L = LOW voltage level. © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 3 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit −0.5 +7.0 V IIK input clamping current VI < −0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] - ±20 mA output current VO = −0.5 V to VCC + 0.5 V [1] - ±25 mA supply current [1] - 50 mA IGND ground current [1] Tstg storage temperature IO ICC [2] total power dissipation Ptot - −50 mA −65 +150 °C - 250 mW [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 and SC-74 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. 10. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit Type 74HC2G17 VCC supply voltage 2.0 5.0 6.0 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature −40 +25 +125 °C 4.5 5.0 5.5 V Type 74HCT2G17 VCC supply voltage VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature −40 +25 +125 °C 11. Static characteristics Table 7. Static characteristics for 74HC2G17 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit HIGH-level output voltage VI = VIH or VIL IO = −20 µA; VCC = 2.0 V 1.9 2.0 - V IO = −20 µA; VCC = 4.5 V 4.4 4.5 - V Tamb = 25 °C VOH IO = −20 µA; VCC = 6.0 V 5.9 6.0 - V IO = −4.0 mA; VCC = 4.5 V 4.18 4.32 - V IO = −5.2 mA; VCC = 6.0 V 5.68 5.81 - V © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 4 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger Table 7. Static characteristics for 74HC2G17 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VOL LOW-level output voltage VI = VIH or VIL IO = 20 µA; VCC = 2.0 V - 0 0.1 V IO = 20 µA; VCC = 4.5 V - 0 0.1 V IO = 20 µA; VCC = 6.0 V - 0 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 V II input leakage current VI = GND or VCC; VCC = 6.0 V - - ±0.1 µA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 6.0 V - - 1.0 µA CI input capacitance - 2.0 - pF IO = −20 µA; VCC = 2.0 V 1.9 - - V IO = −20 µA; VCC = 4.5 V 4.4 - - V Tamb = −40 °C to +85 °C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VIH or VIL IO = −20 µA; VCC = 6.0 V 5.9 - - V IO = −4.0 mA; VCC = 4.5 V 4.13 - - V IO = −5.2 mA; VCC = 6.0 V 5.63 - - V VI = VIH or VIL IO = 20 µA; VCC = 2.0 V - - 0.1 V IO = 20 µA; VCC = 4.5 V - - 0.1 V IO = 20 µA; VCC = 6.0 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.33 V IO = 5.2 mA; VCC = 6.0 V - - 0.33 V II input leakage current VI = GND or VCC; VCC = 6.0 V - - ±1.0 µA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 6.0 V - - 10.0 µA IO = −20 µA; VCC = 2.0 V 1.9 - - V IO = −20 µA; VCC = 4.5 V 4.4 - - V Tamb = −40 °C to +125 °C VOH HIGH-level output voltage VI = VIH or VIL IO = −20 µA; VCC = 6.0 V 5.9 - - V IO = −4.0 mA; VCC = 4.5 V 3.7 - - V IO = −5.2 mA; VCC = 6.0 V 5.2 - - V © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 5 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger Table 7. Static characteristics for 74HC2G17 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VOL LOW-level output voltage VI = VIH or VIL IO = 20 µA; VCC = 2.0 V - - 0.1 V IO = 20 µA; VCC = 4.5 V - - 0.1 V IO = 20 µA; VCC = 6.0 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.4 V IO = 5.2 mA; VCC = 6.0 V - - 0.4 V II input leakage current VI = GND or VCC; VCC = 6.0 V - - ±1.0 µA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 6.0 V - - 20.0 µA Table 8. Static characteristics for 74HCT2G17 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = −20 µA 4.4 4.5 - V IO = −4.0 mA 4.18 4.32 - V - 0 0.1 V Tamb = 25 °C VOH VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = −20 µA IO = −4.0 mA - 0.15 0.26 V II input leakage current VI = GND or VCC; VCC = 5.5 V - - ±0.1 µA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 1.0 µA ∆ICC additional supply current VI = VCC − 2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 300 µA CI input capacitance - 2.0 - pF IO = −20 µA 4.4 - - V IO = −4.0 mA 4.13 - - V IO = −20 µA - - 0.1 V IO = −4.0 mA - - 0.33 V Tamb = −40 °C to +85 °C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = GND or VCC; VCC = 5.5 V - - ±1.0 µA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 10.0 µA ∆ICC additional supply current VI = VCC − 2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 375 µA © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 6 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger Table 8. Static characteristics for 74HCT2G17 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit IO = −20 µA 4.4 - - V IO = −4.0 mA 3.7 - - V - - 0.1 V Tamb = −40 °C to +125 °C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V VI = VIH or VIL; VCC = 4.5 V IO = −20 µA IO = −4.0 mA - - 0.4 V II input leakage current VI = GND or VCC; VCC = 5.5 V - - ±1.0 µA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 20.0 µA ∆ICC additional supply current VI = VCC − 2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 410 µA 12. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max (85 °C) Max (125 °C) VCC = 2.0 V; CL = 50 pF - 36 115 - 140 175 ns VCC = 4.5 V; CL = 50 pF - 12 22 - 27 34 ns VCC = 6.0 V; CL = 50 pF - 10 18 - 22 28 ns VCC = 2.0 V; CL = 50 pF - 20 75 - 95 110 ns VCC = 4.5 V; CL = 50 pF - 7 15 - 19 22 ns VCC = 6.0 V; CL = 50 pF - 5 13 - 16 19 ns - 10 - - - - pF 74HC2G17 tpd tt CPD propagation delay transition time power dissipation capacitance nA to nY; see Figure 5 nY; see Figure 5 VI = GND to VCC [1] [2] [3] © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 7 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger Table 9. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max (85 °C) Max (125 °C) - 21 29 - 36 45 - 6 15 - 19 22 ns - 10 - - - - pF 74HCT2G17 propagation delay tpd [1] nA to nY; see Figure 5 VCC = 4.5 V; CL = 50 pF tt transition time CPD power dissipation capacitance ns [2] nY; see Figure 5 VCC = 4.5 V; CL = 50 pF VI = GND to VCC − 1.5 V [3] [1] tpd is the same as tPLH and tPHL [2] tt is the same as tTLH and tTHL [3] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of the outputs. 13. Waveforms VI VM VM nA input GND tPLH VOH 90 % tPHL 90 % nY output VOL 10 % 10 % tTLH tTHL 001aaf302 Measurement points are given in Table 10. VOL and VOH are typical voltage output drop that occur with the output load. Fig 5. The data input (nA) to output (nY) propagation delays and output transition times Table 10. Measurement points Type Input Output VM VI tr = tf VM 74HC2G17 0.5VCC GND to VCC 6.0 ns 0.5VCC 74HCT2G17 1.3 V GND to 3.0 V 6.0 ns 1.3 V © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 8 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger VCC VCC PULSE GENERATOR VI VO RL = 1 kΩ open D.U.T RT CL 50 pF mgk563 Test data is given in Table 11. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 6. Load circuitry for switching times Table 11. Test data Type Input Test VI tr, tf tPHL, tPLH 74HC2G17 GND to VCC 6 ns open 74HCT2G17 GND to 3.0 V 6 ns open 14. Transfer characteristics Table 12. Transfer characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max (85 °C) Max (125 °C) VCC = 2.0 V 1.00 1.18 1.50 1.00 1.50 1.50 V VCC = 4.5 V 2.30 2.60 3.15 2.30 3.15 3.15 V VCC = 6.0 V 3.00 3.46 4.20 3.00 4.20 4.20 V VCC = 2.0 V 0.30 0.60 0.90 0.30 0.90 0.90 V VCC = 4.5 V 1.13 1.47 2.00 1.13 2.00 2.00 V VCC = 6.0 V 1.50 2.06 2.60 1.50 2.60 2.60 V VCC = 2.0 V 0.30 0.60 1.00 0.30 1.00 1.00 V VCC = 4.5 V 0.60 1.13 1.40 0.60 1.40 1.40 V VCC = 6.0 V 0.80 1.40 1.70 0.80 1.70 1.70 V 74HC2G17 VT+ VT− VH positive-going threshold voltage negative-going threshold voltage hysteresis voltage see Figure 7, Figure 8 see Figure 7, Figure 8 VT+ − VT−; see Figure 7, Figure 8 and Figure 9 © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 9 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger Table 12. Transfer characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max (85 °C) Max (125 °C) VCC = 4.5 V 1.20 1.58 1.90 1.20 1.90 1.90 V VCC = 5.5 V 1.40 1.78 2.10 1.40 2.10 2.10 V VCC = 4.5 V 0.50 0.87 1.20 0.50 1.20 1.20 V VCC = 5.5 V 0.60 1.11 1.40 0.60 1.40 1.40 V VCC = 4.5 V 0.40 0.71 - 0.40 - - V VCC = 5.5 V 0.40 0.67 - 0.40 - - V 74HCT2G17 VT+ VT− VH positive-going threshold voltage see Figure 7 and Figure 8 negative-going threshold voltage see Figure 7 and Figure 8 VT+ − VT−; see Figure 7, Figure 8 and Figure 10 hysteresis voltage 15. Waveforms transfer characteristics VO VI VT+ VH VT− VO VI VH VT− VT+ Fig 7. Transfer characteristic mnb154 mnb155 VT+ and VT- limits at 70 % and 20 %. Fig 8. Definition of VT+, VT- and VH © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 10 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger mna028 100 mna029 1.0 ICC (mA) ICC (µA) 0.8 0.6 50 0.4 0.2 0 0 0 1.0 VI (V) 2.5 0 2.0 a. VCC = 2.0 V VI (V) 5.0 b. VCC = 4.5 V mna030 1.6 ICC (mA) 0.8 0 0 c. 3.0 VI (V) 6.0 VCC = 6.0 V Fig 9. Typical 74HC2G17 transfer characteristics © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 11 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger mna031 2.0 mna032 3.0 ICC (mA) ICC (mA) 2.0 1.0 1.0 0 0 0 2.5 VI (V) 0 5.0 a. VCC = 4.5 V. 3.0 VI (V) 6.0 b. VCC = 5.5 V. Fig 10. Typical 74HCT2G17 transfer characteristics 16. Application information The slow input rise and fall times cause additional power dissipation, this can be calculated using the following formula: Padd = fi × (tr × ∆ICC(AV) + tf × ∆ICC(AV)) × VCC where: Padd = additional power dissipation (µW); fi = input frequency (MHz); tr = input rise time (ns); 10 % to 90 %; tf = input fall time (ns); 90 % to 10 %; ∆ICC(AV) = average additional supply current (µA). ∆ICC(AV) differs with positive or negative input transitions, as shown in Figure 11 and Figure 12. © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 12 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger mna036 200 ∆ICC(AV) (mA) 150 positive-going edge 100 50 negative-going edge 0 0 2.0 4.0 VCC (V) 6.0 Fig 11. ∆ICC(AV) as a function of VCC for 74HC2G17; linear change of VI between 0.1VCC to 0.9VCC mna058 200 ∆ICC(AV) (µA) 150 positive-going edge 100 negative-going edge 50 0 0 2 4 VCC (V) 6 Fig 12. ∆ICC(AV) as a function of VCC for 74HCT2G17; linear change of VI between 0.1VCC to 0.9VCC © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 13 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger 17. Package outline Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC SOT363 JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig 13. Package outline SOT363 (SC-88) © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 14 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger Plastic surface-mounted package (TSOP6); 6 leads D SOT457 E B y A HE 6 5 X v M A 4 Q pin 1 index A A1 c 1 2 3 Lp bp e w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC SOT457 JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-11-07 06-03-16 SC-74 Fig 14. Package outline SOT457 (SC-74) © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 15 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger 18. Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model DUT Device Under Test 19. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT2G17_1 20061006 Product data sheet - - © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 16 of 18 74HC2G17; 74HCT2G17 Nexperia Dual non-inverting Schmitt trigger 20. Legal information 20.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 20.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 20.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 20.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 21. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © 74HC_HCT2G17_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 17 of 18 Nexperia 74HC2G17; 74HCT2G17 Dual non-inverting Schmitt trigger 22. Contents 1 2 3 4 5 6 7 7.1 7.2 8 9 10 11 12 13 14 15 16 17 18 19 20 20.1 20.2 20.3 20.4 21 22 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Transfer characteristics. . . . . . . . . . . . . . . . . . . 9 Waveforms transfer characteristics . . . . . . . . 10 Application information. . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 06 October 2006
74HCT2G17GW,125 价格&库存
很抱歉,暂时无法提供与“74HCT2G17GW,125”相匹配的价格&库存,您可以联系我们找货
74HCT2G17GW,125
  • 1+1.759951+0.22852
  • 10+1.1818310+0.15346
  • 25+1.0410425+0.13518
  • 100+0.88734100+0.11522
  • 250+0.81431250+0.10574
  • 500+0.76986500+0.09997
  • 1000+0.733261000+0.09521
库存:1908
74HCT2G17GW,125
  • 3000+0.687573000+0.08928
  • 6000+0.665496000+0.08641
  • 9000+0.654419000+0.08498
  • 15000+0.6421615000+0.08338
  • 21000+0.6349921000+0.08245
  • 30000+0.6281030000+0.08156
库存:1908
74HCT2G17GW,125
