74HC2G17GV-Q100H
74HC2G17GV-Q100H
    NEXPERIA(安世)
    TSOP6
    类型:缓冲器,非反相 电源电压:2V~6V 输入类型:施密特触发器 输出类型:推挽 低电平输出电流(IOL):5.2mA 高电平输出电流(IOH):5.2mA
74HC2G17GV-Q100H 数据手册
74HC2G17-Q100; 74HCT2G17-Q100 Dual non-inverting Schmitt trigger Rev. 1 — 22 May 2013 Product data sheet 1. General description The 74HC2G17-Q100; 74HCT2G17-Q100 are dual buffers with Schmitt-trigger inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Input levels:  For 74HC2G17-Q100: CMOS level  For 74HCT2G17-Q100: TTL level  Complies with JEDEC standard no. 7A  High noise immunity  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Low power dissipation  Balanced propagation delays  Unlimited input rise and fall times  Multiple package options 3. Applications  Wave and pulse shaper for highly noisy environments  Astable multivibrators  Monostable multivibrators 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC2G17GW-Q100 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74HC2G17GV-Q100 40 C to +125 C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74HCT2G17GW-Q100 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 40 C to +125 C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74HCT2G17GV-Q100 5. Marking Table 2. Marking Type number Marking code[1] 74HC2G17GW-Q100 HV 74HC2G17GV-Q100 HV 74HCT2G17GW-Q100 TV 74HCT2G17GV-Q100 TV [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 6. Functional diagram 1 1A 1Y 6 3 2A 2Y 4 1 6 3 4 mnb067 mnb066 Fig 1. Logic symbol Fig 2. IEC logic symbol 1A 1Y 2A 2Y mnb068 Fig 3. Logic diagram 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 2 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger 7. Pinning information 7.1 Pinning +&*4 +&7*4 $   < *1'   9&& $   < DDD Fig 4. Pin configuration 7.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 8. Functional description Table 4. Function table[1] Input Output nA nY L L H H [1] H = HIGH voltage level; L = LOW voltage level. 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 3 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7.0 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] - 20 mA output current VO = 0.5 V to VCC + 0.5 V [1] - 25 mA supply current [1] - 50 mA [1] - 50 mA 65 +150 C - 250 mW IO ICC IGND ground current Tstg storage temperature Ptot total power dissipation [2] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 10. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit 74HC2G17-Q100 VCC supply voltage 2.0 5.0 6.0 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C 74HCT2G17-Q100 VCC supply voltage 4.5 5.0 5.5 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C 11. Static characteristics Table 7. Static characteristics for 74HC2G17 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit HIGH-level output voltage VI = VT+ or VT IO = 20 A; VCC = 2.0 V 1.9 2.0 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - V Tamb = 25 C VOH 74HC_HCT2G17_Q100 Product data sheet IO = 20 A; VCC = 6.0 V 5.9 6.0 - V IO = 4.0 mA; VCC = 4.5 V 4.18 4.32 - V IO = 5.2 mA; VCC = 6.0 V 5.68 5.81 - V All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 4 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger Table 7. Static characteristics for 74HC2G17 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VOL LOW-level output voltage VI = VT+ or VT IO = 20 A; VCC = 2.0 V - 0 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 V II input leakage current VI = GND or VCC; VCC = 6.0 V - - 0.1 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 6.0 V - - 1.0 A CI input capacitance - 2.0 - pF IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 4.0 mA; VCC = 4.5 V 4.13 - - V IO = 5.2 mA; VCC = 6.0 V 5.63 - - V Tamb = 40 C to +85 C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT VI = VT+ or VT IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.33 V IO = 5.2 mA; VCC = 6.0 V - - 0.33 V II input leakage current VI = GND or VCC; VCC = 6.0 V - - 1.0 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 6.0 V - - 10.0 A IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 4.0 mA; VCC = 4.5 V 3.7 - - V IO = 5.2 mA; VCC = 6.0 V 5.2 - - V Tamb = 40 C to +125 C VOH HIGH-level output voltage 74HC_HCT2G17_Q100 Product data sheet VI = VT+ or VT All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 5 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger Table 7. Static characteristics for 74HC2G17 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VOL LOW-level output voltage VI = VT+ or VT IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.4 V IO = 5.2 mA; VCC = 6.0 V - - 0.4 V II input leakage current VI = GND or VCC; VCC = 6.0 V - - 1.0 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 6.0 V - - 20.0 A Typ Max Unit Table 8. Static characteristics for 74HCT2G17 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions HIGH-level output voltage VI = VT+ or VT; VCC = 4.5 V Min Tamb = 25 C VOH VOL LOW-level output voltage IO = 20 A 4.4 4.5 - V IO = 4.0 mA 4.18 4.32 - V IO = 20 A - 0 0.1 V IO = 4.0 mA VI = VT+ or VT; VCC = 4.5 V - 0.15 0.26 V II input leakage current VI = GND or VCC; VCC = 5.5 V - - 0.1 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 1.0 A ICC additional supply current VI = VCC  2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 300 A CI input capacitance - 2.0 - pF IO = 20 A 4.4 - - V IO = 4.0 mA 4.13 - - V Tamb = 40 C to +85 C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT; VCC = 4.5 V VI = VT+ or VT; VCC = 4.5 V IO = 20 A - - 0.1 V IO = 4.0 mA - - 0.33 V II input leakage current VI = GND or VCC; VCC = 5.5 V - - 1.0 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 10.0 A ICC additional supply current VI = VCC  2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 375 A 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 6 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger Table 8. Static characteristics for 74HCT2G17 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit Tamb = 40 C to +125 C HIGH-level output voltage VOH LOW-level output voltage VOL VI = VT+ or VT; VCC = 4.5 V IO = 20 A 4.4 - - V IO = 4.0 mA 3.7 - - V IO = 20 A - - 0.1 V IO = 4.0 mA VI = VT+ or VT; VCC = 4.5 V - - 0.4 V II input leakage current VI = GND or VCC; VCC = 5.5 V - - 1.0 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 20.0 A ICC additional supply current VI = VCC  2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 410 A 12. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Min Max (85 C) Max (125 C) VCC = 2.0 V; CL = 50 pF - 36 115 - 140 175 ns VCC = 4.5 V; CL = 50 pF - 12 22 - 27 34 ns VCC = 6.0 V; CL = 50 pF - 10 18 - 22 28 ns VCC = 2.0 V; CL = 50 pF - 20 75 - 95 110 ns VCC = 4.5 V; CL = 50 pF - 7 15 - 19 22 ns VCC = 6.0 V; CL = 50 pF - 5 13 - 16 19 ns - 10 - - - - pF 74HC2G17-Q100 tpd tt CPD propagation delay transition time power dissipation capacitance 74HC_HCT2G17_Q100 Product data sheet nA to nY; see Figure 5 [2] nY; see Figure 5 VI = GND to VCC [1] [3] All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 7 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger Table 9. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Min Max (85 C) Max (125 C) - 21 29 - 36 45 - 6 15 - 19 22 ns - 10 - - - - pF 74HCT2G17-Q100 propagation delay tpd [1] nA to nY; see Figure 5 VCC = 4.5 V; CL = 50 pF tt transition time CPD power dissipation capacitance nY; see Figure 5 VCC = 4.5 V; CL = 50 pF [1] tpd is the same as tPLH and tPHL [2] tt is the same as tTLH and tTHL [3] ns [2] VI = GND to VCC  1.5 V [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 13. Waveforms VI VM VM nA input GND tPHL tPLH VOH 90 % 90 % nY output VOL 10 % 10 % tTLH tTHL 001aaf302 Measurement points are given in Table 10. VOL and VOH are typical voltage output levels that occur with the output load. Fig 5. Table 10. The data input (nA) to output (nY) propagation delays and output transition times Measurement points Type Input Output VM VI tr = tf VM 74HC2G17-Q100 0.5VCC GND to VCC 6.0 ns 0.5VCC 74HCT2G17-Q100 1.3 V GND to 3.0 V 6.0 ns 1.3 V 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 8 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger VCC VCC PULSE GENERATOR VI VO RL = 1 kΩ open D.U.T RT CL 50 pF mgk563 Test data is given in Table 11. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 6. Table 11. Test circuit for measuring switching times Test data Type Input Test VI tr, tf tPHL, tPLH 74HC2G17-Q100 GND to VCC 6 ns open 74HCT2G17-Q100 GND to 3.0 V 6 ns open 14. Transfer characteristics Table 12. Transfer characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Min Max (85 C) Max (125 C) VCC = 2.0 V 1.00 1.18 1.50 1.00 1.50 1.50 V VCC = 4.5 V 2.30 2.60 3.15 2.30 3.15 3.15 V VCC = 6.0 V 3.00 3.46 4.20 3.00 4.20 4.20 V VCC = 2.0 V 0.30 0.60 0.90 0.30 0.90 0.90 V VCC = 4.5 V 1.13 1.47 2.00 1.13 2.00 2.00 V VCC = 6.0 V 1.50 2.06 2.60 1.50 2.60 2.60 V VCC = 2.0 V 0.30 0.60 1.00 0.30 1.00 1.00 V VCC = 4.5 V 0.60 1.13 1.40 0.60 1.40 1.40 V VCC = 6.0 V 0.80 1.40 1.70 0.80 1.70 1.70 V 74HC2G17-Q100 VT+ VT VH positive-going threshold voltage negative-going threshold voltage hysteresis voltage 74HC_HCT2G17_Q100 Product data sheet see Figure 7, Figure 8 see Figure 7, Figure 8 VT+  VT; see Figure 7, Figure 8 and Figure 9 All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 9 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger Table 12. Transfer characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Min Max (85 C) Max (125 C) VCC = 4.5 V 1.20 1.58 1.90 1.20 1.90 1.90 V VCC = 5.5 V 1.40 1.78 2.10 1.40 2.10 2.10 V VCC = 4.5 V 0.50 0.87 1.20 0.50 1.20 1.20 V VCC = 5.5 V 0.60 1.11 1.40 0.60 1.40 1.40 V VCC = 4.5 V 0.40 0.71 - 0.40 - - V VCC = 5.5 V 0.40 0.67 - 0.40 - - V 74HCT2G17-Q100 VT+ VT VH positive-going threshold voltage see Figure 7 and Figure 8 negative-going threshold voltage see Figure 7 and Figure 8 VT+  VT; see Figure 7, Figure 8 and Figure 10 hysteresis voltage 15. Waveforms transfer characteristics VO VI VT+ VH VT− VO VI VH VT− Fig 7. VT+ Transfer characteristic 74HC_HCT2G17_Q100 Product data sheet mnb155 mnb154 VT+ and VT limits at 70 % and 20 %. Fig 8. Definition of VT+, VT and VH All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 10 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger mna028 100 mna029 1.0 ICC (mA) ICC (μA) 0.8 0.6 50 0.4 0.2 0 0 0 1.0 VI (V) 2.5 0 2.0 a. VCC = 2.0 V VI (V) 5.0 b. VCC = 4.5 V mna030 1.6 ICC (mA) 0.8 0 0 c. Fig 9. 3.0 VI (V) 6.0 VCC = 6.0 V Typical 74HC2G17 transfer characteristics 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 11 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger mna031 2.0 mna032 3.0 ICC (mA) ICC (mA) 2.0 1.0 1.0 0 0 0 2.5 VI (V) 0 5.0 a. VCC = 4.5 V. 3.0 VI (V) 6.0 b. VCC = 5.5 V. Fig 10. Typical 74HCT2G17-Q100 transfer characteristics 16. Application information The slow input rise and fall times cause additional power dissipation which can be calculated using the following formula: Padd = fi  (tr  ICC(AV) + tf  ICC(AV))  VCC where: Padd = additional power dissipation (W); fi = input frequency (MHz); tr = input rise time (ns); 10 % to 90 %; tf = input fall time (ns); 90 % to 10 %; ICC(AV) = average additional supply current (A). ICC(AV) differs with positive or negative input transitions, as shown in Figure 11 and Figure 12. 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 12 of 19 Nexperia 74HC2G17-Q100; 74HCT2G17-Q100 Dual non-inverting Schmitt trigger mna036 200 ΔICC(AV) (μA) 150 positive-going edge 100 50 negative-going edge 0 0 2.0 4.0 VCC (V) 6.0 Fig 11. ICC(AV) as a function of VCC for 74HC2G17-Q100; linear change of VI between 0.1VCC to 0.9VCC mna058 200 ΔICC(AV) (μA) 150 positive-going edge 100 negative-going edge 50 0 0 2 4 VCC (V) 6 Fig 12. ICC(AV) as a function of VCC for 74HCT2G17-Q100; linear change of VI between 0.1VCC to 0.9VCC 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 13 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger 17. Package outline Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig 13. Package outline SOT363 (SC-88) 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 14 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger Plastic surface-mounted package (TSOP6); 6 leads D SOT457 E B y A HE 6 5 X v M A 4 Q pin 1 index A A1 c 1 2 3 Lp bp e w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT457 JEITA EUROPEAN PROJECTION ISSUE DATE 05-11-07 06-03-16 SC-74 Fig 14. Package outline SOT457 (SC-74) 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 15 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger 18. Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor TTL Transistor-Transistor Logic HBM Human Body Model ESD ElectroStatic Discharge MM Machine Model DUT Device Under Test MIL Military 19. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT2G17_Q100 v.1 20130522 Product data sheet - - 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 16 of 19 74HC2G17-Q100; 74HCT2G17-Q100 Nexperia Dual non-inverting Schmitt trigger 20. Legal information 20.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 20.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 20.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT2G17_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 17 of 19 Nexperia 74HC2G17-Q100; 74HCT2G17-Q100 Dual non-inverting Schmitt trigger No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 20.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 21. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT2G17_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 May 2013 © Nexperia B.V. 2017. All rights reserved 18 of 19 Nexperia 74HC2G17-Q100; 74HCT2G17-Q100 Dual non-inverting Schmitt trigger 22. Contents 1 2 3 4 5 6 7 7.1 7.2 8 9 10 11 12 13 14 15 16 17 18 19 20 20.1 20.2 20.3 20.4 21 22 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Transfer characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms transfer characteristics. . . . . . . . 10 Application information. . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 22 May 2013
74HC2G17GV-Q100H 价格&库存
很抱歉,暂时无法提供与“74HC2G17GV-Q100H”相匹配的价格&库存,您可以联系我们找货
