74HCT2G34GW,125
74HCT2G34GW,125
    NEXPERIA(安世)
    SOT363
    缓冲器,非反向 2 元件 1 位每元件 推挽式 Output 6-TSSOP
74HCT2G34GW,125 数据手册
74HC2G34; 74HCT2G34 Dual buffer gate Rev. 01 — 6 October 2006 Product data sheet 1. General description The 74HC2G34; 74HCT2G34 is a high-speed Si-gate CMOS device. The 74HC2G34; 74HCT2G34 provides two buffers. 2. Features n n n n n n n n n Wide supply voltage range from 2.0 V to 6.0 V Complies with JEDEC standard no. 7A High noise immunity ESD protection: u HBM JESD22-A114-D exceeds 2000 V u MM JESD22-A115-A exceeds 200 V Low power dissipation Balanced propagation delays Unlimited input rise and fall times Multiple package options Specified from −40 °C to +85 °C and −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC2G34GW −40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74HC2G34GV −40 °C to +125 °C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74HCT2G34GW −40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74HCT2G34GV −40 °C to +125 °C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 4. Marking Table 2. Marking Type number Marking code 74HC2G34GW PA 74HC2G34GV P34 74HCT2G34GW UA 74HCT2G34GV U34 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate 5. Functional diagram 1 1A 1Y 6 3 2A 2Y 4 1 1 6 1 3 4 A Y mnb064 mnb063 Fig 1. Logic symbol 001aac536 Fig 2. IEC logic symbol Fig 3. Logic diagram (one gate) 6. Pinning information 6.1 Pinning 74HC2G34 74HCT2G34 1A 1 6 1Y GND 2 5 VCC 2A 3 4 2Y 001aaf303 Fig 4. Pin configuration 6.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 2 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate 7. Functional description Table 4. Function table[1] Input Output nA nY L L H H [1] H = HIGH voltage level; L = LOW voltage level. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit −0.5 +7.0 V input clamping current VI < −0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current VO = −0.5 V to VCC + 0.5 V [1] - ±25 mA supply current [1] - +50 mA IGND ground current [1] - −50 mA Tstg storage temperature −65 +150 °C Ptot total power dissipation - 250 mW IIK ICC [2] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 and SC-74 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. 9. Recommended operating conditions Table 6. Symbol Recommended operating conditions Parameter Conditions Min Typ Max Unit Type 74HC2G34 VCC supply voltage 2.0 5.0 6.0 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature −40 +25 +125 °C tr rise time VCC = 2.0 V - - 1000 ns VCC = 4.5 V - - 500 ns VCC = 6.0 V - - 400 ns VCC = 2.0 V - - 1000 ns VCC = 4.5 V - - 500 ns VCC = 6.0 V - - 400 ns tf fall time except for Schmitt trigger inputs except for Schmitt trigger inputs © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 3 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate Table 6. Recommended operating conditions …continued Symbol Parameter Conditions Min Typ Max Unit Type 74HCT2G34 VCC supply voltage 4.5 5.0 5.5 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature −40 +25 +125 °C tr rise time - - 500 ns - - 500 ns except for Schmitt trigger inputs VCC = 4.5 V tf fall time except for Schmitt trigger inputs VCC = 4.5 V 10. Static characteristics Table 7. Static characteristics for 74HC2G34 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit Tamb = 25 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage II input leakage current ICC supply current VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V IO = −20 µA; VCC = 2.0 V 1.9 2.0 - V IO = −20 µA; VCC = 4.5 V 4.4 4.5 - V IO = −20 µA; VCC = 6.0 V 5.9 6.0 - V IO = −4.0 mA; VCC = 4.5 V 4.18 4.32 - V IO = −5.2 mA; VCC = 6.0 V 5.68 5.81 - V IO = 20 µA; VCC = 2.0 V - 0 0.1 V IO = 20 µA; VCC = 4.5 V - 0 0.1 V IO = 20 µA; VCC = 6.0 V - 0 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 V VI = GND or VCC; VCC = 6.0 V - - ±0.1 µA VI = GND or VCC; IO = 0 A; - - 1.0 µA - 1.5 - pF VI = VIH or VIL VI = VIH or VIL VCC = 6.0 V CI input capacitance © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 4 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate Table 7. Static characteristics for 74HC2G34 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = −20 µA; VCC = 2.0 V 1.9 - - V IO = −20 µA; VCC = 4.5 V 4.4 - - V Tamb = −40 °C to +85 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL IO = −20 µA; VCC = 6.0 V 5.9 - - V IO = −4.0 mA; VCC = 4.5 V 4.13 - - V IO = −5.2 mA; VCC = 6.0 V 5.63 - - V VI = VIH or VIL IO = 20 µA; VCC = 2.0 V - - 0.1 V IO = 20 µA; VCC = 4.5 V - - 0.1 V IO = 20 µA; VCC = 6.0 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.33 V IO = 5.2 mA; VCC = 6.0 V - - 0.33 V II input leakage current VI = GND or VCC; VCC = 6.0 V - - ±1.0 µA ICC supply current VI = GND or VCC; IO = 0 A; - - 10.0 µA VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = −20 µA; VCC = 2.0 V 1.9 - - V IO = −20 µA; VCC = 4.5 V 4.4 - - V IO = −20 µA; VCC = 6.0 V 5.9 - - V IO = −4.0 mA; VCC = 4.5 V 3.7 - - V IO = −5.2 mA; VCC = 6.0 V 5.2 - - V VCC = 6.0 V Tamb = −40 °C to +125 °C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 5 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate Table 7. Static characteristics for 74HC2G34 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VOL LOW-level output voltage VI = VIH or VIL IO = 20 µA; VCC = 2.0 V - - 0.1 V IO = 20 µA; VCC = 4.5 V - - 0.1 V IO = 20 µA; VCC = 6.0 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.4 V IO = 5.2 mA; VCC = 6.0 V - - 0.4 V II input leakage current VI = GND or VCC; VCC = 6.0 V - - ±1.0 µA ICC supply current VI = GND or VCC; IO = 0 A; - - 20.0 µA Max Unit VCC = 6.0 V Table 8. Static characteristics for 74HCT2G34 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Tamb = 25 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V VOH HIGH-level output voltage VI = VIH or VIL IO = −20 µA; VCC = 4.5 V 4.4 4.5 - V IO = −4.0 mA; VCC = 4.5 V 4.18 4.32 - V IO = 20 µA; VCC = 4.5 V - 0 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 V VOL LOW-level output voltage VI = VIH or VIL II input leakage current VI = GND or VCC; VCC = 5.5 V - - ±0.1 µA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 1.0 µA ∆ICC additional supply current VI = VCC − 2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 300 µA CI input capacitance - 1.5 - pF Tamb = −40 °C to +85 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL IO = −20 µA; VCC = 4.5 V 4.4 - - V IO = −4.0 mA; VCC = 4.5 V 4.13 - - V IO = 20 µA; VCC = 4.5 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.33 V VOL LOW-level output voltage VI = VIH or VIL II input leakage current VI = GND or VCC; VCC = 5.5 V - - ±1.0 µA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 10.0 µA ∆ICC additional supply current VI = VCC − 2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 375 µA © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 6 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate Table 8. Static characteristics for 74HCT2G34 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit Tamb = −40 °C to +125 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL IO = −20 µA; VCC = 4.5 V 4.4 - - V IO = −4.0 mA; VCC = 4.5 V 3.7 - - V IO = 20 µA; VCC = 4.5 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.4 V VOL LOW-level output voltage VI = VIH or VIL II input leakage current VI = GND or VCC; VCC = 5.5 V - - ±1.0 µA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 20.0 µA ∆ICC additional supply current VI = VCC − 2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 410 µA 11. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max (85 °C) Max (125 °C) VCC = 2.0 V; CL = 50 pF - 29 75 - 95 125 ns VCC = 4.5 V; CL = 50 pF - 9 15 - 19 25 ns - 8 13 - 16 20 ns VCC = 2.0 V; CL = 50 pF - 18 75 - 95 125 ns VCC = 4.5 V; CL = 50 pF - 6 15 - 19 25 ns - 5 13 - 16 20 ns - 10 - - - - pF 74HC2G34 tpd propagation delay nA to nY; see Figure 5 [1] VCC = 6.0 V; CL = 50 pF tt transition time nY; see Figure 5 [2] VCC = 6.0 V; CL = 50 pF CPD power dissipation capacitance VI = GND to VCC [3] © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 7 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate Table 9. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max (85 °C) Max (125 °C) - 10 18 - 23 29 - 6 15 - 19 25 ns - 9 - - - - pF 74HCT2G34 propagation delay tpd [1] nA to nY; see Figure 5 VCC = 4.5 V; CL = 50 pF tt transition time CPD power dissipation capacitance ns [2] nY; see Figure 5 VCC = 4.5 V; CL = 50 pF VI = GND to VCC − 1.5 V [3] [1] tpd is the same as tPLH and tPHL [2] tt is the same as tTLH and tTHL [3] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of the outputs. 12. Waveforms VI VM VM nA input GND tPLH VOH 90 % tPHL 90 % nY output VOL 10 % 10 % tTLH tTHL 001aaf302 Measurement points are given in Table 10. VOL and VOH are typical voltage output drop that occur with the output load. Fig 5. The data input (nA) to output (nY) propagation delays and output transition times Table 10. Measurement points Type Input Output VM VI tr = tf VM 74HC2G34 0.5VCC GND to VCC 6.0 ns 0.5VCC 74HCT2G34 1.3 V GND to 3.0 V 6.0 ns 1.3 V © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 8 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate VCC VCC PULSE GENERATOR VI VO RL = 1 kΩ open D.U.T RT CL 50 pF mgk563 Test data is given in Table 11. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 6. Load circuitry for switching times Table 11. Test data Type Input Test VI tr, tf tPHL, tPLH 74HC2G34 GND to VCC 6 ns open 74HCT2G34 GND to 3.0 V 6 ns open © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 9 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate 13. Package outline Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC SOT363 JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig 7. Package outline SOT363 (SC-88) © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 10 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate Plastic surface-mounted package (TSOP6); 6 leads D SOT457 E B y A HE 6 5 X v M A 4 Q pin 1 index A A1 c 1 2 3 Lp bp e w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC SOT457 JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-11-07 06-03-16 SC-74 Fig 8. Package outline SOT457 (SC-74) © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 11 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate 14. Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model DUT Device Under Test 15. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT2G34_1 20061006 Product data sheet - - © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 12 of 14 74HC2G34; 74HCT2G34 Nexperia Dual buffer gate 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 16.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © 74HC_HCT2G34_1 Product data sheet Rev. 01 — 6 October 2006 Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia 74HC2G34; 74HCT2G34 Dual buffer gate 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 3 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 06 October 2006
74HCT2G34GW,125 价格&库存
很抱歉,暂时无法提供与“74HCT2G34GW,125”相匹配的价格&库存,您可以联系我们找货
